Hello,
I used your newest Debian wheezy Image 3.8.
Boot up from SD installed to NAND via script so far everything fine.
But if I remove the SD card it won't boot anymore, it even doesn't show some output on serial connection.
Can you give me a hint how to solve it?
Thanks
Fips
  • NAND install (3.4.x only) script sometime fails. Dirty but working workaround â€“ installing Lubuntu to NAND with Phoenix tools and run the nand-install again. Better solution is under development.
Perhaps it's this?
