PaddleStroke Posted June 17, 2019 Posted June 17, 2019 hey guys, Using legacy kernel I have trouble having dual output on LCD and HDMI. I tried to have a cloned dual output (same framebuffer for both) : [disp_init] disp_init_enable = 1 disp_mode = 4 screen0_output_type = 1 screen0_output_mode = 6 screen1_output_type = 3 screen1_output_mode = 4 fb0_width = 0 fb0_height = 0 fb0_framebuffer_num = 2 fb0_format = 10 fb0_pixel_sequence = 0 fb0_scaler_mode_enable = 0 fb1_width = 1024 fb1_height = 600 fb1_framebuffer_num = 2 fb1_format = 10 fb1_pixel_sequence = 0 fb1_scaler_mode_enable = 0 ... Also tried with 2 framebuffers : [disp_init] disp_init_enable = 1 disp_mode = 2 screen0_output_type = 1 screen0_output_mode = 6 screen1_output_type = 3 screen1_output_mode = 4 fb0_width = 0 fb0_height = 0 fb0_framebuffer_num = 2 fb0_format = 10 fb0_pixel_sequence = 0 fb0_scaler_mode_enable = 0 fb1_width = 0 fb1_height = 0 fb1_framebuffer_num = 2 fb1_format = 10 fb1_pixel_sequence = 0 fb1_scaler_mode_enable = 0 ... On both case when booting the signal is first on HDMI until kernel starts. Then the signal goes to LCD and HDMI turns off. Any hint? Full fex below : Spoiler [product] version = "100" machine = "Olimex A20-OLinuXino-LIME2" [platform] eraseflag = 0 [target] boot_clock = 912 dcdc2_vol = 1425 dcdc3_vol = 1300 ldo2_vol = 3000 ldo3_vol = 2800 ldo4_vol = 2800 power_start = 1 storage_type = 0 [clock] pll4 = 300 pll6 = 600 pll7 = 297 pll8 = 336 [card_boot] logical_start = 40960 sprite_gpio0 = [card0_boot_para] card_ctrl = 0 card_high_speed = 1 card_line = 4 sdc_d1 = port:PF00<2><1><default><default> sdc_d0 = port:PF01<2><1><default><default> sdc_clk = port:PF02<2><1><default><default> sdc_cmd = port:PF03<2><1><default><default> sdc_d3 = port:PF04<2><1><default><default> sdc_d2 = port:PF05<2><1><default><default> [card2_boot_para] card_ctrl = 2 card_high_speed = 1 card_line = 4 sdc_cmd = port:PC06<3><1><default><default> sdc_clk = port:PC07<3><1><default><default> sdc_d0 = port:PC08<3><1><default><default> sdc_d1 = port:PC09<3><1><default><default> sdc_d2 = port:PC10<3><1><default><default> sdc_d3 = port:PC11<3><1><default><default> [twi_para] twi_port = 0 twi_scl = port:PB00<2><default><default><default> twi_sda = port:PB01<2><default><default><default> [uart_para] uart_debug_port = 0 uart_debug_tx = port:PB22<2><1><default><default> uart_debug_rx = port:PB23<2><1><default><default> [uart_force_debug] uart_debug_port = 0 uart_debug_tx = port:PB22<2><1><default><default> uart_debug_rx = port:PB23<2><1><default><default> [jtag_para] jtag_enable = 0 jtag_ms = port:PB14<3><default><default><default> jtag_ck = port:PB15<3><default><default><default> jtag_do = port:PB16<3><default><default><default> jtag_di = port:PB17<3><default><default><default> [pm_para] standby_mode = 0 [dram_para] dram_baseaddr = 0x40000000 dram_clk = 384 dram_type = 3 dram_rank_num = 1 dram_chip_density = 4096 dram_io_width = 16 dram_bus_width = 32 dram_cas = 9 dram_zq = 0x7f dram_odt_en = 0 dram_size = 1024 dram_tpr0 = 0x42d899b7 dram_tpr1 = 0xa090 dram_tpr2 = 0x22a00 dram_tpr3 = 0x0 dram_tpr4 = 0x1 dram_tpr5 = 0x0 dram_emr1 = 0x4 dram_emr2 = 0x10 dram_emr3 = 0x0 [mali_para] mali_used = 1 mali_clkdiv = 1 [emac_para] emac_used = 1 emac_rxd3 = port:PA00<2><default><default><default> emac_rxd2 = port:PA01<2><default><default><default> emac_rxd1 = port:PA02<2><default><default><default> emac_rxd0 = port:PA03<2><default><default><default> emac_txd3 = port:PA04<2><default><default><default> emac_txd2 = port:PA05<2><default><default><default> emac_txd1 = port:PA06<2><default><default><default> emac_txd0 = port:PA07<2><default><default><default> emac_rxclk = port:PA08<2><default><default><default> emac_rxerr = port:PA09<2><default><default><default> emac_rxdV = port:PA10<2><default><default><default> emac_mdc = port:PA11<2><default><default><default> emac_mdio = port:PA12<2><default><default><default> emac_txen = port:PA13<2><default><default><default> emac_txclk = port:PA14<2><default><default><default> emac_crs = port:PA15<2><default><default><default> emac_col = port:PA16<2><default><default><default> emac_reset = port:PA17<1><default><default><default> [twi0_para] twi0_used = 1 twi0_scl = port:PB00<2><default><default><default> twi0_sda = port:PB01<2><default><default><default> [twi1_para] twi1_used = 1 twi1_scl = port:PB18<2><default><default><default> twi1_sda = port:PB19<2><default><default><default> [twi2_para] twi2_used = 1 twi2_scl = port:PB20<2><default><default><default> twi2_sda = port:PB21<2><default><default><default> [twi3_para] twi3_used = 0 twi3_scl = port:PI00<3><default><default><default> twi3_sda = port:PI01<3><default><default><default> [twi4_para] twi4_used = 0 twi4_scl = port:PI02<3><default><default><default> twi4_sda = port:PI03<3><default><default><default> [uart_para0] uart_used = 1 uart_port = 0 uart_type = 2 uart_tx = port:PB22<2><1><default><default> uart_rx = port:PB23<2><1><default><default> [uart_para1] uart_used = 0 uart_port = 1 uart_type = 8 uart_tx = port:PA10<4><1><default><default> uart_rx = port:PA11<4><1><default><default> uart_rts = port:PA12<4><1><default><default> uart_cts = port:PA13<4><1><default><default> uart_dtr = port:PA14<4><1><default><default> uart_dsr = port:PA15<4><1><default><default> uart_dcd = port:PA16<4><1><default><default> uart_ring = port:PA17<4><1><default><default> [uart_para2] uart_used = 0 uart_port = 2 uart_type = 4 uart_tx = port:PI18<3><1><default><default> uart_rx = port:PI19<3><1><default><default> uart_rts = port:PI16<3><1><default><default> uart_cts = port:PI17<3><1><default><default> [uart_para3] uart_used = 0 uart_port = 3 uart_type = 4 uart_tx = port:PH00<4><1><default><default> uart_rx = port:PH01<4><1><default><default> uart_rts = port:PH02<4><1><default><default> uart_cts = port:PH03<4><1><default><default> [uart_para4] uart_used = 1 uart_port = 4 uart_type = 2 uart_tx = port:PG10<4><1><default><default> uart_rx = port:PG11<4><1><default><default> [uart_para5] uart_used = 0 uart_port = 5 uart_type = 2 uart_tx = port:PH06<4><1><default><default> uart_rx = port:PH07<4><1><default><default> [uart_para6] uart_used = 0 uart_port = 6 uart_type = 2 uart_tx = port:PI12<3><1><default><default> uart_rx = port:PI13<3><1><default><default> [uart_para7] uart_used = 0 uart_port = 7 uart_type = 2 uart_tx = port:PI20<3><1><default><default> uart_rx = port:PI21<3><1><default><default> [spi0_para] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PI10<2><default><default><default> spi_cs1 = port:PI14<2><default><default><default> spi_sclk = port:PI11<2><default><default><default> spi_mosi = port:PI12<2><default><default><default> spi_miso = port:PI13<2><default><default><default> [spi1_para] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PI16<2><default><default><default> spi_sclk = port:PI17<2><default><default><default> spi_mosi = port:PI18<2><default><default><default> spi_miso = port:PI19<2><default><default><default> [spi2_para] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PC19<3><default><default><default> spi_sclk = port:PC20<3><default><default><default> spi_mosi = port:PC21<3><default><default><default> spi_miso = port:PC22<3><default><default><default> [spi3_para] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PA05<3><default><default><default> spi_cs1 = port:PA09<3><default><default><default> spi_sclk = port:PA06<3><default><default><default> spi_mosi = port:PA07<3><default><default><default> spi_miso = port:PA08<3><default><default><default> [spi_devices] spi_dev_num = 0 [spi_board0] modalias = "spidev" max_speed_hz = 1000000 bus_num = 2 chip_select = 0 mode = 3 full_duplex = 0 manual_cs = 0 [rtp_para] rtp_used = 0 rtp_screen_size = 5 rtp_regidity_level = 5 rtp_press_threshold_enable = 0 rtp_press_threshold = 0x1f40 rtp_sensitive_level = 0xf rtp_exchange_x_y_flag = 0 [ctp_para] ctp_used = 0 ctp_name = "gt811" ctp_twi_id = 2 ctp_twi_addr = 0x40 ctp_screen_max_x = 1024 ctp_screen_max_y = 600 ctp_revert_x_flag = 0 ctp_revert_y_flag = 0 ctp_exchange_x_y_flag = 1 ctp_firm = 1 ctp_int_port = port:PH21<6><default><default><default> ctp_wakeup = port:PB13<1><default><default><1> [ctp_list_para] ctp_det_used = 0 ft5x_ts = 0 gt82x = 0 gslX680 = 0 gt9xx_ts = 0 gt811 = 0 [tkey_para] tkey_used = 0 tkey_twi_id = 2 tkey_twi_addr = 0x62 tkey_int = port:PI13<6><default><default><default> [motor_para] motor_used = 0 motor_shake = port:PB03<1><default><default><1> [leds_para] leds_used = 1 leds_num = 1 leds_pin_1 = port:PH02<1><default><default><0> leds_name_1 = "green:ph02:led1" leds_default_1 = 0 leds_trigger_1 = "mmc0" [nand_para] nand_used = 1 nand_we = port:PC00<2><default><default><default> nand_ale = port:PC01<2><default><default><default> nand_cle = port:PC02<2><default><default><default> nand_ce0 = port:PC04<2><default><default><default> nand_nre = port:PC05<2><default><default><default> nand_rb0 = port:PC06<2><default><default><default> nand_d0 = port:PC08<2><default><default><default> nand_d1 = port:PC09<2><default><default><default> nand_d2 = port:PC10<2><default><default><default> nand_d3 = port:PC11<2><default><default><default> nand_d4 = port:PC12<2><default><default><default> nand_d5 = port:PC13<2><default><default><default> nand_d6 = port:PC14<2><default><default><default> nand_d7 = port:PC15<2><default><default><default> nand_wp = port:PC16<2><default><default><default> good_block_ratio = 0 [disp_init] disp_init_enable = 1 disp_mode = 4 screen0_output_type = 1 screen0_output_mode = 6 screen1_output_type = 3 screen1_output_mode = 4 fb0_width = 0 fb0_height = 0 fb0_framebuffer_num = 2 fb0_format = 10 fb0_pixel_sequence = 0 fb0_scaler_mode_enable = 0 fb1_width = 1024 fb1_height = 600 fb1_framebuffer_num = 2 fb1_format = 10 fb1_pixel_sequence = 0 fb1_scaler_mode_enable = 0 lcd0_backlight = 197 lcd1_backlight = 197 lcd0_bright = 50 lcd0_contrast = 50 lcd0_saturation = 57 lcd0_hue = 50 lcd1_bright = 239 lcd1_contrast = 50 lcd1_saturation = 57 lcd1_hue = 50 [lcd0_para] lcd_used = 1 lcd_x = 640 lcd_y = 480 lcd_dclk_freq = 33 lcd_pwm_not_used = 0 lcd_pwm_ch = 0 lcd_pwm_freq = 10000 lcd_pwm_pol = 1 lcd_max_bright = 240 lcd_min_bright = 64 lcd_if = 0 lcd_hbp = 46 lcd_ht = 1055 lcd_vbp = 23 lcd_vt = 1050 lcd_vspw = 1 lcd_hspw = 30 lcd_hv_if = 0 lcd_hv_smode = 0 lcd_hv_s888_if = 0 lcd_hv_syuv_if = 0 lcd_lvds_ch = 0 lcd_lvds_mode = 0 lcd_lvds_bitwidth = 0 lcd_lvds_io_cross = 0 lcd_cpu_if = 0 lcd_frm = 0 lcd_io_cfg0 = 0 lcd_gamma_correction_en = 0 lcd_gamma_tbl_0 = 0x0 lcd_gamma_tbl_1 = 0x10101 lcd_gamma_tbl_255 = 0xffffff lcd_pwm_used = 1 lcd_pwm = port:PB02<2><0><default><default> lcdd0 = port:PD00<2><0><default><default> lcdd1 = port:PD01<2><0><default><default> lcdd2 = port:PD02<2><0><default><default> lcdd3 = port:PD03<2><0><default><default> lcdd4 = port:PD04<2><0><default><default> lcdd5 = port:PD05<2><0><default><default> lcdd6 = port:PD06<2><0><default><default> lcdd7 = port:PD07<2><0><default><default> lcdd8 = port:PD08<2><0><default><default> lcdd9 = port:PD09<2><0><default><default> lcdd10 = port:PD10<2><0><default><default> lcdd11 = port:PD11<2><0><default><default> lcdd12 = port:PD12<2><0><default><default> lcdd13 = port:PD13<2><0><default><default> lcdd14 = port:PD14<2><0><default><default> lcdd15 = port:PD15<2><0><default><default> lcdd16 = port:PD16<2><0><default><default> lcdd17 = port:PD17<2><0><default><default> lcdd18 = port:PD18<2><0><default><default> lcdd19 = port:PD19<2><0><default><default> lcdd20 = port:PD20<2><0><default><default> lcdd21 = port:PD21<2><0><default><default> lcdd22 = port:PD22<2><0><default><default> lcdd23 = port:PD23<2><0><default><default> lcdclk = port:PD24<2><0><default><default> lcdde = port:PD25<2><0><default><default> lcdhsync = port:PD26<2><0><default><default> lcdvsync = port:PD27<2><0><default><default> [lcd1_para] lcd_used = 0 lcd_x = 0 lcd_y = 0 lcd_dclk_freq = 0 lcd_pwm_not_used = 0 lcd_pwm_ch = 1 lcd_pwm_freq = 0 lcd_pwm_pol = 0 lcd_max_bright = 240 lcd_min_bright = 64 lcd_if = 0 lcd_hbp = 0 lcd_ht = 0 lcd_vbp = 0 lcd_vt = 0 lcd_vspw = 0 lcd_hspw = 0 lcd_hv_if = 0 lcd_hv_smode = 0 lcd_hv_s888_if = 0 lcd_hv_syuv_if = 0 lcd_lvds_ch = 0 lcd_lvds_mode = 0 lcd_lvds_bitwidth = 0 lcd_lvds_io_cross = 0 lcd_cpu_if = 0 lcd_frm = 0 lcd_io_cfg0 = 0 lcd_gamma_correction_en = 0 lcd_gamma_tbl_0 = 0x0 lcd_gamma_tbl_1 = 0x10101 lcd_gamma_tbl_255 = 0xffffff lcd_bl_en_used = 1 lcd_bl_en = lcd_power_used = 0 lcd_power = lcd_pwm_used = 1 lcd_pwm = port:PI03<2><0><default><default> lcd_gpio_0 = lcd_gpio_1 = lcd_gpio_2 = lcd_gpio_3 = lcdd0 = port:PH00<2><0><default><default> lcdd1 = port:PH01<2><0><default><default> lcdd2 = port:PH02<2><0><default><default> lcdd3 = port:PH03<2><0><default><default> lcdd4 = port:PH04<2><0><default><default> lcdd5 = port:PH05<2><0><default><default> lcdd6 = port:PH06<2><0><default><default> lcdd7 = port:PH07<2><0><default><default> lcdd8 = port:PH08<2><0><default><default> lcdd9 = port:PH09<2><0><default><default> lcdd10 = port:PH10<2><0><default><default> lcdd11 = port:PH11<2><0><default><default> lcdd12 = port:PH12<2><0><default><default> lcdd13 = port:PH13<2><0><default><default> lcdd14 = port:PH14<2><0><default><default> lcdd15 = port:PH15<2><0><default><default> lcdd16 = port:PH16<2><0><default><default> lcdd17 = port:PH17<2><0><default><default> lcdd18 = port:PH18<2><0><default><default> lcdd19 = port:PH19<2><0><default><default> lcdd20 = port:PH20<2><0><default><default> lcdd21 = port:PH21<2><0><default><default> [tv_out_dac_para] dac_used = 0 dac0_src = 4 dac1_src = 5 dac2_src = 6 dac3_src = 0 [hdmi_para] hdmi_used = 1 [camera_list_para] camera_list_para_used = 1 ov7670 = 0 gc0308 = 0 gt2005 = 1 hi704 = 0 sp0838 = 0 mt9m112 = 0 mt9m113 = 0 ov2655 = 0 hi253 = 0 gc0307 = 0 mt9d112 = 0 ov5640 = 0 gc2015 = 0 ov2643 = 0 gc0329 = 0 gc0309 = 0 tvp5150 = 0 s5k4ec = 0 ov5650_mv9335 = 0 siv121d = 0 gc2035 = 0 [csi0_para] csi_used = 0 csi_dev_qty = 1 csi_stby_mode = 0 csi_mname = "gt2005" csi_twi_id = 1 csi_twi_addr = 0x78 csi_if = 0 csi_vflip = 0 csi_hflip = 0 csi_iovdd = "axp20_pll" csi_avdd = "" csi_dvdd = "" csi_vol_iovdd = 2800 csi_vol_dvdd = csi_vol_avdd = csi_flash_pol = 0 csi_pck = port:PE00<3><default><default><default> csi_ck = port:PE01<3><default><default><default> csi_hsync = port:PE02<3><default><default><default> csi_vsync = port:PE03<3><default><default><default> csi_d0 = port:PE04<3><default><default><default> csi_d1 = port:PE05<3><default><default><default> csi_d2 = port:PE06<3><default><default><default> csi_d3 = port:PE07<3><default><default><default> csi_d4 = port:PE08<3><default><default><default> csi_d5 = port:PE09<3><default><default><default> csi_d6 = port:PE10<3><default><default><default> csi_d7 = port:PE11<3><default><default><default> csi_reset = port:PH13<1><default><default><0> csi_power_en = port:PC16<1><default><default><0> csi_stby = port:PH12<1><default><default><0> csi_flash = csi_af_en = [csi1_para] csi_used = 0 csi_dev_qty = 1 csi_stby_mode = 0 csi_mname = "gc0308" csi_if = 0 csi_iovdd = "axp20_pll" csi_avdd = "" csi_dvdd = "" csi_vol_iovdd = 2800 csi_vol_dvdd = csi_vol_avdd = csi_vflip = 0 csi_hflip = 0 csi_flash_pol = 0 csi_facing = 1 csi_twi_id = 1 csi_twi_addr = 0x42 csi_pck = port:PG00<3><default><default><default> csi_ck = port:PG01<3><default><default><default> csi_hsync = port:PG02<3><default><default><default> csi_vsync = port:PG03<3><default><default><default> csi_d0 = port:PG04<3><default><default><default> csi_d1 = port:PG05<3><default><default><default> csi_d2 = port:PG06<3><default><default><default> csi_d3 = port:PG07<3><default><default><default> csi_d4 = port:PG08<3><default><default><default> csi_d5 = port:PG09<3><default><default><default> csi_d6 = port:PG10<3><default><default><default> csi_d7 = port:PG11<3><default><default><default> csi_reset = port:PH13<1><default><default><0> csi_power_en = port:PH16<1><default><default><0> csi_stby = port:PH19<1><default><default><0> [tvout_para] tvout_used = 0 tvout_channel_num = 1 [tvin_para] tvin_used = 0 tvin_channel_num = 4 [pwm0_para] pwm_used = 1 pwm_period = 20 pwm_duty_percent = 50 [sata_para] sata_used = 1 sata_power_en = [mmc0_para] sdc_used = 1 sdc_detmode = 1 sdc_buswidth = 4 sdc_clk = port:PF02<2><1><2><default> sdc_cmd = port:PF03<2><1><2><default> sdc_d0 = port:PF01<2><1><2><default> sdc_d1 = port:PF00<2><1><2><default> sdc_d2 = port:PF05<2><1><2><default> sdc_d3 = port:PF04<2><1><2><default> sdc_det = port:PH01<0><1><default><default> sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" [mmc1_para] sdc_used = 0 sdc_detmode = 4 sdc_buswidth = 4 sdc_clk = port:PG00<2><1><2><default> sdc_cmd = port:PG01<2><1><2><default> sdc_d0 = port:PG02<2><1><2><default> sdc_d1 = port:PG03<2><1><2><default> sdc_d2 = port:PG04<2><1><2><default> sdc_d3 = port:PG05<2><1><2><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" [mmc2_para] sdc_used = 0 sdc_detmode = 3 sdc_buswidth = 4 sdc_cmd = port:PC06<3><1><2><default> sdc_clk = port:PC07<3><1><2><default> sdc_d0 = port:PC08<3><1><2><default> sdc_d1 = port:PC09<3><1><2><default> sdc_d2 = port:PC10<3><1><2><default> sdc_d3 = port:PC11<3><1><2><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" [mmc3_para] sdc_used = 0 sdc_detmode = 1 sdc_buswidth = 4 sdc_cmd = port:PI04<2><1><2><default> sdc_clk = port:PI05<2><1><2><default> sdc_d0 = port:PI06<2><1><2><default> sdc_d1 = port:PI07<2><1><2><default> sdc_d2 = port:PI08<2><1><2><default> sdc_d3 = port:PI09<2><1><2><default> sdc_det = port:PH00<0><1><default><default> sdc_use_wp = 0 sdc_wp = sdc_isio = 1 sdc_regulator = "none" [ms_para] ms_used = 0 ms_bs = port:PH06<5><default><default><default> ms_clk = port:PH07<5><default><default><default> ms_d0 = port:PH08<5><default><default><default> ms_d1 = port:PH09<5><default><default><default> ms_d2 = port:PH10<5><default><default><default> ms_d3 = port:PH11<5><default><default><default> ms_det = [smc_para] smc_used = 0 smc_rst = port:PH13<5><default><default><default> smc_vppen = port:PH14<5><default><default><default> smc_vppp = port:PH15<5><default><default><default> smc_det = port:PH16<5><default><default><default> smc_vccen = port:PH17<5><default><default><default> smc_sck = port:PH18<5><default><default><default> smc_sda = port:PH19<5><default><default><default> [ps2_0_para] ps2_used = 0 ps2_scl = port:PI20<2><1><default><default> ps2_sda = port:PI21<2><1><default><default> [ps2_1_para] ps2_used = 0 ps2_scl = port:PI14<3><1><default><default> ps2_sda = port:PI15<3><1><default><default> [can_para] can_used = 0 can_tx = port:PA16<3><default><default><default> can_rx = port:PA17<3><default><default><default> [keypad_para] kp_used = 0 kp_in_size = 8 kp_out_size = 8 kp_in0 = port:PH08<4><1><default><default> kp_in1 = port:PH09<4><1><default><default> kp_in2 = port:PH10<4><1><default><default> kp_in3 = port:PH11<4><1><default><default> kp_in4 = port:PH14<4><1><default><default> kp_in5 = port:PH15<4><1><default><default> kp_in6 = port:PH16<4><1><default><default> kp_in7 = port:PH17<4><1><default><default> kp_out0 = port:PH18<4><1><default><default> kp_out1 = port:PH19<4><1><default><default> kp_out2 = port:PH22<4><1><default><default> kp_out3 = port:PH23<4><1><default><default> kp_out4 = port:PH24<4><1><default><default> kp_out5 = port:PH25<4><1><default><default> kp_out6 = port:PH26<4><1><default><default> kp_out7 = port:PH27<4><1><default><default> [usbc0] usb_used = 1 usb_port_type = 1 usb_detect_type = 0 usb_drv_vbus_gpio = port:PC17<1><0><default><0> usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 [usbc1] usb_used = 1 usb_port_type = 1 usb_detect_type = 0 usb_drv_vbus_gpio = port:PH06<1><0><default><0> usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 [usbc2] usb_used = 1 usb_port_type = 1 usb_detect_type = 0 usb_drv_vbus_gpio = port:PH17<1><0><default><0> usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 [usb_feature] vendor_id = 6353 mass_storage_id = 1 adb_id = 2 manufacturer_name = "USB Developer" product_name = "Android" serial_number = "20080411" [msc_feature] vendor_name = "USB 2.0" product_name = "USB Flash Driver" release = 100 luns = 3 [gsensor_para] gsensor_used = 0 gsensor_twi_id = 1 gsensor_int1 = gsensor_int2 = [gsensor_list_para] gsensor_det_used = 0 bma250 = 1 mma8452 = 1 mma7660 = 1 mma865x = 1 afa750 = 1 lis3de_acc = 1 lis3dh_acc = 1 kxtik = 1 dmard10 = 0 dmard06 = 1 mxc622x = 1 fxos8700 = 1 lsm303d = 1 [gps_para] gps_used = 0 gps_spi_id = 2 gps_spi_cs_num = 0 gps_lradc = 1 gps_clk = port:PI00<2><default><default><default> gps_sign = port:PI01<2><default><default><default> gps_mag = port:PI02<2><default><default><default> gps_vcc_en = port:PC22<1><default><default><0> gps_osc_en = port:PI14<1><default><default><0> gps_rx_en = port:PI15<1><default><default><0> [wifi_para] wifi_used = 0 wifi_sdc_id = 3 wifi_usbc_id = 2 wifi_usbc_type = 1 wifi_mod_sel = 7 wifi_power = "" ap6xxx_wl_regon = port:PH09<1><default><default><0> ap6xxx_bt_regon = port:PH18<1><default><default><0> ap6xxx_bt_wake = port:PH24<1><default><default><0> ap6xxx_bt_host_wake = port:PH25<0><default><default><0> ap6xxx_lpo = port:PI12<4><1><default><1> [usb_wifi_para] usb_wifi_used = 1 usb_wifi_usbc_num = 2 [3g_para] 3g_used = 0 3g_usbc_num = 2 3g_uart_num = 0 3g_pwr = 3g_wakeup = 3g_int = [gy_para] gy_used = 0 gy_twi_id = 1 gy_twi_addr = 0 gy_int1 = port:PH18<6><1><default><default> gy_int2 = port:PH19<6><1><default><default> [ls_para] ls_used = 0 ls_twi_id = 1 ls_twi_addr = 0 ls_int = port:PH20<6><1><default><default> [compass_para] compass_used = 0 compass_twi_id = 1 compass_twi_addr = 0 compass_int = port:PI13<6><1><default><default> [bt_para] bt_used = 1 bt_uart_id = 2 [i2s_para] i2s_used = 0 i2s_channel = 2 i2s_mclk = port:PB05<2><1><default><default> i2s_bclk = port:PB06<2><1><default><default> i2s_lrclk = port:PB07<2><1><default><default> i2s_dout0 = port:PB08<2><1><default><default> i2s_dout1 = i2s_dout2 = i2s_dout3 = i2s_din = port:PB12<2><1><default><default> [spdif_para] spdif_used = 0 spdif_mclk = spdif_dout = port:PB13<4><1><default><default> spdif_din = [audio_para] audio_used = 1 capture_used = 1 playback_used = 1 audio_lr_change = 0 [switch_para] switch_used = 1 [ir_para] ir_used = 0 ir0_rx = port:PB04<2><default><default><default> [pmu_para] pmu_used = 1 pmu_twi_addr = 52 pmu_twi_id = 0 pmu_irq_id = 32 pmu_battery_rdc = 120 pmu_battery_cap = 4000 pmu_init_chgcur = 300 pmu_earlysuspend_chgcur = 600 pmu_suspend_chgcur = 1000 pmu_resume_chgcur = 300 pmu_shutdown_chgcur = 1000 pmu_init_chgvol = 4200 pmu_init_chgend_rate = 15 pmu_init_chg_enabled = 1 pmu_init_adc_freq = 100 pmu_init_adc_freqc = 100 pmu_init_chg_pretime = 50 pmu_init_chg_csttime = 720 pmu_bat_para1 = 0 pmu_bat_para2 = 0 pmu_bat_para3 = 0 pmu_bat_para4 = 0 pmu_bat_para5 = 5 pmu_bat_para6 = 11 pmu_bat_para7 = 13 pmu_bat_para8 = 15 pmu_bat_para9 = 19 pmu_bat_para10 = 32 pmu_bat_para11 = 50 pmu_bat_para12 = 58 pmu_bat_para13 = 71 pmu_bat_para14 = 81 pmu_bat_para15 = 89 pmu_bat_para16 = 100 pmu_usbvol_limit = 1 pmu_usbcur_limit = 0 pmu_usbvol = 4000 pmu_usbcur = 0 pmu_usbvol_pc = 4200 pmu_usbcur_pc = 0 pmu_pwroff_vol = 3300 pmu_pwron_vol = 2900 pmu_pekoff_time = 6000 pmu_pekoff_en = 1 pmu_peklong_time = 1500 pmu_pekon_time = 1000 pmu_pwrok_time = 64 pmu_pwrnoe_time = 2000 pmu_intotp_en = 1 pmu_used2 = 0 pmu_adpdet = port:PH02<0><default><default><default> pmu_init_chgcur2 = 400 pmu_earlysuspend_chgcur2 = 600 pmu_suspend_chgcur2 = 1200 pmu_resume_chgcur2 = 400 pmu_shutdown_chgcur2 = 1200 pmu_suspendpwroff_vol = 3500 pmu_batdeten = 1 pmu_backupen = 0 [recovery_key] key_min = 4 key_max = 40 [dvfs_table] max_freq = 1008000000 min_freq = 720000000 normal_freq = 720000000 LV_count = 7 LV1_freq = 1008000000 LV1_volt = 1450 LV2_freq = 912000000 LV2_volt = 1425 LV3_freq = 864000000 LV3_volt = 1350 LV4_freq = 720000000 LV4_volt = 1250 LV5_freq = 528000000 LV5_volt = 1150 LV6_freq = 312000000 LV6_volt = 1100 LV7_freq = 144000000 LV7_volt = 1050 [gpio_para] gpio_used = 1 gpio_num = 67 gpio_pin_1 = port:PG00<0><default><default><default> gpio_pin_2 = port:PG01<0><default><default><default> gpio_pin_3 = port:PG02<0><default><default><default> gpio_pin_4 = port:PG03<0><default><default><default> gpio_pin_5 = port:PG04<0><default><default><default> gpio_pin_6 = port:PG05<0><default><default><default> gpio_pin_7 = port:PG06<0><default><default><default> gpio_pin_8 = port:PG07<0><default><default><default> gpio_pin_9 = port:PG08<0><default><default><default> gpio_pin_10 = port:PG09<0><default><default><default> gpio_pin_11 = port:PC07<0><default><default><default> gpio_pin_12 = port:PC18<0><default><default><default> gpio_pin_13 = port:PC23<0><default><default><default> gpio_pin_14 = port:PC24<0><default><default><default> gpio_pin_15 = port:PH00<0><default><default><default> gpio_pin_16 = port:PH02<0><default><default><default> gpio_pin_17 = port:PH09<0><default><default><default> gpio_pin_18 = port:PH10<0><default><default><default> gpio_pin_19 = port:PH11<0><default><default><default> gpio_pin_20 = port:PH12<0><default><default><default> gpio_pin_21 = port:PH13<0><default><default><default> gpio_pin_22 = port:PH14<0><default><default><default> gpio_pin_23 = port:PH15<0><default><default><default> gpio_pin_24 = port:PH16<0><default><default><default> gpio_pin_25 = port:PH17<0><default><default><default> gpio_pin_26 = port:PH18<0><default><default><default> gpio_pin_27 = port:PH19<0><default><default><default> gpio_pin_28 = port:PH20<0><default><default><default> gpio_pin_29 = port:PH21<0><default><default><default> gpio_pin_30 = port:PH22<0><default><default><default> gpio_pin_31 = port:PH23<0><default><default><default> gpio_pin_32 = port:PH24<0><default><default><default> gpio_pin_33 = port:PH25<0><default><default><default> gpio_pin_34 = port:PH26<0><default><default><default> gpio_pin_35 = port:PH27<0><default><default><default> gpio_pin_36 = port:PB03<0><default><default><default> gpio_pin_37 = port:PB04<0><default><default><default> gpio_pin_38 = port:PB05<0><default><default><default> gpio_pin_39 = port:PB06<0><default><default><default> gpio_pin_40 = port:PB07<0><default><default><default> gpio_pin_41 = port:PB08<0><default><default><default> gpio_pin_42 = port:PB10<0><default><default><default> gpio_pin_43 = port:PB11<0><default><default><default> gpio_pin_44 = port:PB12<0><default><default><default> gpio_pin_45 = port:PB13<0><default><default><default> gpio_pin_46 = port:PB14<0><default><default><default> gpio_pin_47 = port:PB15<0><default><default><default> gpio_pin_48 = port:PB16<0><default><default><default> gpio_pin_49 = port:PB17<0><default><default><default> gpio_pin_50 = port:PI00<0><default><default><default> gpio_pin_51 = port:PI01<0><default><default><default> gpio_pin_52 = port:PI02<0><default><default><default> gpio_pin_53 = port:PI03<0><default><default><default> gpio_pin_54 = port:PI04<0><default><default><default> gpio_pin_55 = port:PI05<0><default><default><default> gpio_pin_56 = port:PI06<0><default><default><default> gpio_pin_57 = port:PI07<0><default><default><default> gpio_pin_58 = port:PI08<0><default><default><default> gpio_pin_59 = port:PI09<0><default><default><default> gpio_pin_60 = port:PI10<0><default><default><default> gpio_pin_61 = port:PI11<0><default><default><default> gpio_pin_62 = port:PI14<0><default><default><default> gpio_pin_63 = port:PI15<0><default><default><default> gpio_pin_64 = port:PI16<0><default><default><default> gpio_pin_65 = port:PI17<0><default><default><default> gpio_pin_66 = port:PI18<0><default><default><default> gpio_pin_67 = port:PI19<0><default><default><default> [gpio_init] pin_1 = port:PG00<0><default><default><default> pin_2 = port:PG01<0><default><default><default> pin_3 = port:PG02<0><default><default><default> pin_4 = port:PG03<0><default><default><default> pin_5 = port:PG04<0><default><default><default> pin_6 = port:PG05<0><default><default><default> pin_7 = port:PG06<0><default><default><default> pin_8 = port:PG07<0><default><default><default> pin_9 = port:PG08<0><default><default><default> pin_10 = port:PG09<0><default><default><default> pin_11 = port:PC07<0><default><default><default> pin_12 = port:PC18<0><default><default><default> pin_13 = port:PC23<0><default><default><default> pin_14 = port:PC24<0><default><default><default> pin_15 = port:PH00<0><default><default><default> pin_16 = port:PH02<0><default><default><default> pin_17 = port:PH09<0><default><default><default> pin_18 = port:PH10<0><default><default><default> pin_19 = port:PH11<0><default><default><default> pin_20 = port:PH12<0><default><default><default> pin_21 = port:PH13<0><default><default><default> pin_22 = port:PH14<0><default><default><default> pin_23 = port:PH15<0><default><default><default> pin_24 = port:PH16<0><default><default><default> pin_25 = port:PH17<0><default><default><default> pin_26 = port:PH18<0><default><default><default> pin_27 = port:PH19<0><default><default><default> pin_28 = port:PH20<0><default><default><default> pin_29 = port:PH21<0><default><default><default> pin_30 = port:PH22<0><default><default><default> pin_31 = port:PH23<0><default><default><default> pin_32 = port:PH24<0><default><default><default> pin_33 = port:PH25<0><default><default><default> pin_34 = port:PH26<0><default><default><default> pin_35 = port:PH27<0><default><default><default> pin_36 = port:PB03<0><default><default><default> pin_37 = port:PB04<0><default><default><default> pin_38 = port:PB05<0><default><default><default> pin_39 = port:PB06<0><default><default><default> pin_40 = port:PB07<0><default><default><default> pin_41 = port:PB08<0><default><default><default> pin_42 = port:PB10<0><default><default><default> pin_43 = port:PB11<0><default><default><default> pin_44 = port:PB12<0><default><default><default> pin_45 = port:PB13<0><default><default><default> pin_46 = port:PB14<0><default><default><default> pin_47 = port:PB15<0><default><default><default> pin_48 = port:PB16<0><default><default><default> pin_49 = port:PB17<0><default><default><default> pin_50 = port:PI00<0><default><default><default> pin_51 = port:PI01<0><default><default><default> pin_52 = port:PI02<0><default><default><default> pin_53 = port:PI03<0><default><default><default> pin_54 = port:PI04<0><default><default><default> pin_55 = port:PI05<0><default><default><default> pin_56 = port:PI06<0><default><default><default> pin_57 = port:PI07<0><default><default><default> pin_58 = port:PI08<0><default><default><default> pin_59 = port:PI09<0><default><default><default> pin_60 = port:PI10<0><default><default><default> pin_61 = port:PI11<0><default><default><default> pin_62 = port:PI14<0><default><default><default> pin_63 = port:PI15<0><default><default><default> pin_64 = port:PI16<0><default><default><default> pin_65 = port:PI17<0><default><default><default> pin_66 = port:PI18<0><default><default><default> pin_67 = port:PI19<0><default><default><default>
