Daniel Andersen Posted June 18, 2019 Posted June 18, 2019 Armbianmonitor: http://ix.io/1M6E I already saw similar posts on this here, here and here. It looks like the combination of Kernel and Kernel-Header 5.89.190617 again is not complete to build own modules. Based on the configure script: Quote configure:39364: checking whether modules can be built configure:39393: cp conftest.c conftest.h build && make modules -C /usr/src/linux-headers-5.1.11-odroidxu4 EXTRA_CFLAGS=-Werror -Wframe-larger-than=4096 M=/home/daniel/source/zfs/build /bin/sh: 1: scripts/mod/modpost: not found make[1]: *** [__modpost] Error 127 make: *** [modules] Error 2 Then I tried to check the headers: Quote root@odroidxu4:src/linux-headers-5.1.11-odroidxu4 ▒2df16141a*▒# make headers_check make[1]: *** No rule to make target 'arch/arm/tools/syscall.tbl', needed by 'arch/arm/include/generated/uapi/asm/unistd-common.h'. Stop. arch/arm/Makefile:324: recipe for target 'archheaders' failed make: *** [archheaders] Error 2 Since it was already a few times on the forum and sometime there was a new build created and it was fixed again, I would like to know if I just came over the same error again or if I did something wrong. cheers, Daniel
Igor Posted June 18, 2019 Posted June 18, 2019 34 minutes ago, Daniel Andersen said: again is not complete to build own modules. Stable builds = support is as is / best effort. Its also not possible to follow up with the quantity of issues that around. Armbian's few regulars can't fix problems that builds up upstream (www.kernel.org) after 1000+ people poke around a kernel. DEV nightly kernels = support does not exists and welcome to join and dive into the kernel sources, build script. Problem could be made in a kernel sources upstream or in the process of creating a header package ... our packaging patch. Perhaps something is changed and you will need to solve this ... if you need kernel headers with a kernel you want now.
Daniel Andersen Posted June 18, 2019 Author Posted June 18, 2019 Thanks. I will follow the patch and give it a try 1
winfried Posted July 11, 2019 Posted July 11, 2019 It tried on /usr/src/linux-headers-5.1.12-sunxi for olinuxino A20: same problem (/bin/sh: 1: scripts/mod/modpost: not found) when I compiled modpost additionaly in headers: sudo make M=scripts/mod I could compile my module, so somewhere mod is missing in the "make scripts" even it is listed as subdir ... anyhow it works, but it is not a fix..
