Hi all.
I've just finished reviewing the Khadas VIM3.
It's an amazing SBC with unmatched performance. It's got the Amlogic A311D SoC. Comparable with the S922X of the Odroid N2.
But the 4x A73 cores are clocked at 2.2Ghz and the 2 x A53 cores to 1.8Ghz. So it performs a lot better.
It also comes with an NPU, MIPI-DSI and MIPI-CSI. And can be powered with USB type-c from 5V up to 20V.
Here my review video.
Here all my gathered information.
Khadas VIM3
Ubuntu server - fan over fins
Blender BMW no fan thermal pad      : 59m
                   with copper shim : 58m18s
       with 5V fan                  : 45m01s
       with 5V fan over CPU         : 43m28s
Ubuntu XFCE - fan over CPU, not over fins
Blender no fan : 55m22s
Blender 3V fan : 43m03s
Blender 5V fan : 42m51s
Blender with fan : 48m45s	    Armbian Bionic Small cores @1.9Ghz Big cores @1.7Ghz
Blender with fan : 46m29s       Armbian Disco  Small cores @1.9Ghz Big cores @1.7Ghz
Blender with fan : 46m56s       Armbian Buster Small cores @1.9Ghz Big cores @1.7Ghz
Kdenlive 16m bench 3V lxde : 1h09m (using 1GB zram + 4GB swap file. Not enough ram with 2GB)
Video playback
Ubuntu
Up to 4K 30fps with MPV. Very slight screen tearing. Anything lower is perfect
Youtube playback with Firefox up to 1440p 30fps perfect
KODI doesn't work (yet)
No VPU acceleration for now. All done by CPU.
LibreElec
Wifi doesn't work.
power consumption
Idle no fan        : 0.27A  5V (governor set to interactive)
Maxed out with fan : 1.4A 5V (fan is 0.15A)
Temperatures (fan over CPU, not over fins)
Idle No fan        : 44°C
Maxed out No fan   : 75°C heavy throttling. 1Ghz small cores / 1.8Ghz big cores
Idle 3V fan        : 34°C
Maxed out 3V fan   : 73°C very light throttle. Takes 5min to reach 70°c. +10min to start throttling
Idle 5V fan        : 32°C
Maxed 5V           : 70°C no throttling
Transfer speeds
eMMC 16GB                                : 60 MB/s write
                                         : 165.9 MB/s read
SSD over USB3                            : 380.3 MB/s write
                                         : 286.1 MB/s read
SSD over USB2                            : 40.2 MB/s
Samsung EVO plus with on-board sd-reader : 10.2MB/s write   22.1MB/s read
                 with USB3 sd-reader     : 31.7MB/s write   88.6MB/s read
Ethernet internet speed :   53.9 Mbps       11.5 Mbps
Wifi internet speed     :   43.7 Mbps       11.2 Mbps
Issue's
When using a 2.4Ghz dongle for mouse in the right USB3 port, wifi connection is slow.
When using a USB3 device in the USB3 port wifi stops working. Use left USB2 port for those.
Ubuntu server boots/shuts down slower than XFCE version. Shut down stop job for ifup for eth0 (not in use) 1m30s
                                                         Boot hangs a while. Can't find the reason. After -> Scanning for Btrfs filesystems. Done. about 30s
Can't install Tensorflow
khadas@Khadas:~/tensorflow$ pip3 install tensorflow-1.8.0-cp35-none-linux_aarch64.whl
tensorflow-1.8.0-cp35-none-linux_aarch64.whl is not a supported wheel on this platform.
Android : Can't connect wifi. I can type wifi password, but can't go further. No connect button.
Tips
Use interactive governor for better thermals and power consumption with low use/idle.
Plus/Minus
+ Best single core performance + best multi-core performance for an ARM SBC
+ Nice case + PSU + USB-c cable included + remote + eMMC
+ Amazing low power consumption / best performance per watt
+ Can be powered with 5V up to 20V
+ NPU
- Wifi issue with USB3/No 5Ghz wifi. Could have solved the USB3 interference
- Placing of the buttons would be better on the back. They often get pressed when plugging a USB device. You do get used to it.
- No VPU and X11 drivers (yet)
- Slow On-board SD-card reader
Greetings,
NicoD
@lanefu Sorry, I forgot to share my benchmark file.
I did find out that 7-zip multicore results are not to be trusted on SBC's with different cluster performance. The VIM3 has a very big difference so it only uses 500% of 600%. The N2 has a smaller difference in performance between A73/A53 so uses 550% in 7-zip multicore scores. (also lack of memory is a problem)
CPU Miner is good, 7zip single core benchmarks are good. And for me Blender is important too.
Reasons why benchmarks can be misleading
throttling
32-bit/64-bit
Difference in cores A53/A7/A15/A72
distro (ubuntu/debian...)
distro version
kernel version
driver versions
compiler version
software version/outdated repositories
desktop Mate/Xfce/LXDE/...
display resolution/headless
background processes
cpu clockspeed
ram clockspeed/latency
ram useage/swap/zram
process sheduler
optimizations for the system/distro
crypto engine for encryption
Undervoltage
config settings
Wifi dongle
CONFIG_HZ=250 - 1000 or any other
7-zip works a bit better on 32-bit vs 64-bit, it doesn't use all cores at 100% in multi-core scores. The percentage differs with different distro's and boards. So it's not completely exact.
7-zip has problems with big-LITTLE architecture for multi-core benchmark. Better to test the clusters seperately.
Blender works a lot better on 64-bit than on 32-bit. It uses 100% of the cores.
CPU Miner only works on 64-bit. Works better in Ubuntu Bionic than in Debian Stretch.
Blender : BMW render @ 1080p
7-zip : Numbers are average of 3 of decompressing only
All tests are done with a fan when necessary so no throttling occurs.
64-bit SBC's
Khadas VIM3            |SBC bench result  |CPU Miner      |7-zip s/c A53 |7-zip b/c A73 |7-zip multi avg. of 3 |Blender
Ubuntu 18.04.02         http://ix.io/1MFD  13.10kH/s           1577       2311           10578                  42m51s
Armbian@1.9S.C./1.7B.C. http://ix.io/1NRJ        48m45s
Odroid N2              |SBC bench result  |CPU Miner      |7-zip s/c A53 |7-zip b/c A73 |7-zip multi avg. of 3 |Blender
Ubuntu Bionic           http://ix.io/1Brv  11.35kH/s           1564       1879           9988                   50m28s
NanoPC T3+             |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Armbian Bionic          http://ix.io/1iRJ  10.99kH/s           1290                      10254                  1h10m25s
Arbmian Stretch         http://ix.io/1qiF  8.55kH/s            1275                      10149                  1h13m55s
Rock Pi 4B             |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Ubuntu                  http://ix.io/1uVr  9.50kH/s            1242       1818           7802                   1h17m22s
NanoPi M4              |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Armbian bionic hz1000   http://ix.io/1nLh  10.23kH/s           1335       2005           8352                   1h13m50s
 CONFIG_HZ=250          http://ix.io/1BLW  10.45kH/s           1335       2007           8320                   1h08m28s
Armbionic@1.4/1.8 hz250                                        1253       1828           7821                   1h12m52s
Armbian bionic nightly  http://ix.io/1pDo  10.24kH/s           1329       1990           8292                   1h13m28s
Armbian stretch desktop http://ix.io/1odF  8.66kH/s            1350       1977           8400                   1h14m12s
Armbian stretch dsk nightly  //ix.io/1pM0  8.80kH/s            1359       1993           8500                   1h15m04s
Armbian stretch core no fan  //ix.io/1pKU  8.80-8.65kH/s       1353       1989           8461
Armbian stretch core         //ix.io/1pL9  8.76kH/s            1354       1988           8456
Armbian stretch core nightly //ix.io/1pLf  8.82kH/s            1357       1994           8494
Lubuntu Bionic arm64    http://ix.io/1oGJ  9.24kH/s CPU Miner  1056       1551           6943                   1h28m13s
Lubuntu Bionic armhf    http://ix.io/1pJ1                      1111       1769           7705                   2h02m54s
Lubuntu Xenial armhf	http://ix.io/1oCb                      989        1507           6339                   2h20m51s
Khadas Vim2 Max        |SBC bench result  |CPU Miner          |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Ubuntu Xenial           http://ix.io/1qkA  6.86kH/s            823        1134           6682                   1h14m39s      7-zip only 600% of 800% used
Odroid C2              |SBC bench result  |CPU Miner          |7-zip big core           |7-zip multi avg. of 3 |Blender
Armbian Stretch Core    http://ix.io/1pZu  4.65kH/s            1390                      5342
Armbian Stretch Core Nightly //ix.io/1pZJ  4.66kH/s            1391                      5340
Armbian Stretch Desktop http://ix.io/1q1C  4.65kH/s            1394                      5363
Armbian Stretch Desktop NGHT //ix.io/1p02  4.59kH/s            1394                      5356                   2h38m18s
Meveric Stetch  No-OC                                          1337                      5223                   2h40m00s
Meveric Stretch Only RAM OC                                    1361                      5292
Meveric Stretch OC                                             1548                      6049                   2h14m17s
Ubuntu Mate Bionic      http://ix.io/1q2S  clocked to 100Mhz                                                    2h35m10s
Ubuntu Mate Bionic OC   Doesn't work/Clocked to 100Mhz         1607                      5960                   2h10m21s
Rock64                 |SBC bench result  |CPU Miner          |7-zip small core         |7-zip multi avg. of 3 |Blender
Armbian Stretch 1.5Ghz  http://ix.io/1nCj  4.06kH/s            1406                      5407                   3h00n32s
OLD Armbian Stretch 1.3Ghz   //ix.io/1iHB  3.80kH/s            1211                      4904
Armbian Bionic 1.5Ghz core   //ix.io/1qbK  5.00kH/s            1384                      5379
Armbian Bionic 1.5Ghz dsk    //ix.io/1qcb  4.94kH/s            1379                      5326                   2h55m56s
32-bit SBC's
Odroid XU4             |SBC bench result                      |7-zip s/c |7-zip b/c     |7-zip multi avg. of 3 |Blender
Debian Jessie           http://ix.io/1q6X                      950        1653           8823                   1h12m19s
Ubuntu Bionic           http://ix.io/1qbL                      1219       2094           9395                   1h44m19s
Asus Tinker board      |SBC bench result                                 |7-zip big core|7-zip multi avg. of 3 |Blender
Tinker OS 9.5 Stretch   http://ix.io/1pRN  				                  1983	         7536                   2h55m00s
Raspberry Pi 3B+       |SBC bench result                      |7-zip small core         |7-zip multi avg. of 3 |Blender
Raspbian Default no fan http://ix.io/1q10                      1471                      5027
Raspbian Default        http://ix.io/1q1Q                      1411                      5371                   5h47m31s
Raspbian OC             http://ix.io/1q5J                      1591                      6141
Ubuntu Mate Xenial      http://ix.io/1q65 7-zip didn't work
Software versions
                                      GIMP        Blender      GTKPerf     SysBench                     SBC-bench
M4 : Lubuntu Xenial armhf             2.8.18      2.79b        0.40        0.4.12                       0.6.1
     Lubuntu Bionic armhf :           2.8.22      2.79b        0.40        1.0.11 LuaJIT 2.1.0-beta3    0.6.1
     Armbian Stretch desktop 9.5 :    2.8.18      2.79b        0.40        0.4.12                       0.6.1
	 Armbian Bionic :                 2.8.22      2.79b        0.40        1.0.11 LuaJIT 2.1.0-beta3    0.6.1
Tinker : TinkerOS 9.5 Stretch :       2.8.18      2.79b        0.40        0.4.12                       0.6.1
Odroid C2 : Armbian Stretch 9.5 :     2.8.18      2.79b        0.40        0.4.12                       0.6.1
          : Ubuntu Mate Bionic :      2.8.22      2.79b        0.40        1.0.11 LuqJIT 2.1.0-beta3    0.6.1 Doesn't work clocks to 100Mhz
		    Meveric Stretch 9.5 :     2.8.18      2.79b        0.40        0.4.12                       Doesn't work
Rock64    : Armbian Stretch 9.5:      2.8.18      2.79b		   0.40        0.4.12                       0.6.1
          : Armbian Bionic :          2.8.22      2.79b        0.40        1.0.11                       0.6.2
RPi 3b+ : Raspbian Stretch 9.5 :      2.8.18      2.78a        0.40        0.4.12                       0.6.1
          Ubuntu Mate Xenial :        2.8.16                   0.40        0.4.12                       0.6.1
Odroid XU4 : Debian Jessie :          2.8.14      2.72b        0.40	       0.4.12                       0.6.1 7-zip doesn't work
		   : Ubuntu Bionic :          2.8.22      2.79b        0.40        1.0.11                       0.6.2
NanoPC T3+ : Armbian Bionic :         2.8.22      2.79b	       0.40        1.0.11                       0.4.6
             Armbian Stretch :                    2.79b        0.40        0.4.12                       0.6.2
Khadas Vim2 Max : Ubuntu Xenial :     2.8.16      2.76b        0.40        0.4.12                       0.6.2
CPU Clocks
Khadas VIM3 :  Ubuntu Bionic          : 2x1.8Ghz(A53) + 4x2.2Ghz(A73)                         64-bit
Odroid N2 :    Ubuntu Bionic          : 2x1.9Ghz(A53) + 4x1.8Ghz(A73)                         64-bit
NanoPi M4 :    Armbian Bionic/Stretch : 2x2Ghz + 4X1.5Ghz                                     64-bit
               Lubuntu armhf/ARM64    : 2x1.8Ghz + 4X1.4Ghz                                   armhf 32-bit / ARM64 64-bit
Tinker Board : TinkerOS Stretch       : 4x1.8Ghz                                              32-bit
Odroid C2 :    Armbian Stretch        : 4x1.5Ghz                                              64-bit
               Ubuntu Mate Bionic     : 4x1.5Ghz RAM 912Mhz                                   64-bit
			   Ubuntu Mate Bionic OC  : 4x1.75Ghz + RAM 1104Mhz                               64-bit
Rock64 :       Armbian Stretch        : 4x1.5Ghz 			                                  64-bit
               Armbian Bionic         : 4x1.5Ghz                                              64-bit
RPi 3B+ :      Raspbian Stretch       : 4x1.4Ghz no fan 4x1.2Ghz above 60°C                   32-bit
               Raspbian Stretch OC    : 4x1.570Ghz over_voltage=4 core_freq=500 sd_freq=510   32-bit
		       Ubuntu Xenial          : 4x1.4Ghz                                              32-bit
Odroid XU4 :   Debian Stretch         : 4x1.4Ghz + 4x1.9Ghz                                   32-bit
           :   Ubuntu Mate Bionic     : 4x1.5Ghz + 4x2Ghz   Underclocks when above 75°C       32-bit
NanoPC T3+ :   Armbian Bionic         : 8x1.4Ghz                                              64-bit
Some benchmark tools can give an estimate of the performance. But they are never an exact reflection.
