ryny24 Posted July 13, 2019 Posted July 13, 2019 Hello, I can get 5.90 Bionic to boot, but Unifi needs an old mongodb. Stretch 5.65 worked in the past, but 5.83 will not boot. It hangs after "[ OK ] Started udev Coldplug all Devices." I've tried many, many times. Any idea what this means? I also can't get Stretch 5.65 to work again. It does not boot after a dist-upgrade
Igor Posted July 13, 2019 Posted July 13, 2019 3 hours ago, ryny24 said: upgrade When you issue an upgrade, kernel gets upgraded and you get to the same situation as on latest images. It seems there are some problems in H5/A64 since there are a few similar reports. Investigation is needed ... (I am on vacations so can't help)
ryny24 Posted July 13, 2019 Author Posted July 13, 2019 Thank you so much for your help! I will try to get running again without the upgrade. Thank you!
