Hello everyone.
 We have checked the forum extensively but have not found a good answer to our problem.
Our system is based on a Orange Pi Zero Plus (512 MB), and it is running nicely.
However, after some time, (10 - 15 days from the last boot) or /tmp directory gets full and most of the system is not operational. Only solution we have found for the moment is rebooting the system.
This is the output of df -h in one of our systems which only shows 7% usage. This usage figure increases day by day.
Filesystem      Size  Used Avail Use% Mounted on
udev            174M     0  174M   0% /dev
tmpfs            49M  5.4M   43M  12% /run
/dev/mmcblk0p1  2.0G  1.6G  333M  83% /
tmpfs           241M   12K  241M   1% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           241M     0  241M   0% /sys/fs/cgroup
tmpfs           241M   16M  226M   7% /tmp
tmpfs            10M     0   10M   0% /home/iawot/ficheros_ftp
/dev/zram0       49M   27M   19M  60% /var/log
tmpfs            49M     0   49M   0% /run/user/0
The contents of the /tmp directory is:
ls -la /tmp
total 8
drwxrwxrwt  8 root root  180 Jul 18 13:28 .
drwxrwxrwt 22 root root 4096 Jan 17 02:04 ..
-rw-------  1 root root   31 Jul 16 11:08 armbian-hardware-optimization.hhlnrd
drwxrwxrwt  2 root root   40 Jul 16 11:08 .font-unix
drwxrwxrwt  2 root root   40 Jul 16 11:08 .ICE-unix
drwx------  3 root root   60 Jul 16 11:08 systemd-private-98788f87752540c4a5cf054115c5741a-haveged.service-6uUDLd
drwxrwxrwt  2 root root   40 Jul 16 11:08 .Test-unix
drwxrwxrwt  2 root root   40 Jul 16 11:08 .X11-unix
drwxrwxrwt  2 root root   40 Jul 16 11:08 .XIM-unix
and inside systemd-private-98788f87752540c4a5cf054115c5741a-haveged.service-6uUDLd there is only an empty directory named tmp.
So my question is:
What is the proper way of clearing de /tmp directory?
We have tried to simply erase everything inside it with
rm /tmp/* -r
but it seems that something (invisible) is still there since df -h still reports the /tmp is using 241 MB
Thanks!
So my question is:
rm /tmp/* -r
The file handles are probably still being held open by the service.  try systemctl restart havegd and see if that releases them
also whats output of systemctl status systemd-tmpfiles-setup.service
Thanks for the response.
I will need to wait a few days until tmp is more filled and will try systemctl restart havegd
 This is the outpout of  systemctl status systemd-tmpfiles-setup.service :
● systemd-tmpfiles-setup.service - Create Volatile Files and Directories
   Loaded: loaded (/lib/systemd/system/systemd-tmpfiles-setup.service; static; vendor preset: enabled)
   Active: active (exited) since Thu 2019-07-18 15:32:17 CEST; 2h 13min ago
     Docs: man:tmpfiles.d(5)
           man:systemd-tmpfiles(8)
  Process: 335 ExecStart=/bin/systemd-tmpfiles --create --remove --boot --exclude-prefix=/dev (code=exited, status=0/SUCCESS)
 Main PID: 335 (code=exited, status=0/SUCCESS)
    Tasks: 0 (limit: 4915)
   CGroup: /system.slice/systemd-tmpfiles-setup.service
Jul 18 15:32:17 CESINEL_PACOM_Z0003 systemd[1]: Starting Create Volatile Files and Directories...
Jul 18 15:32:17 CESINEL_PACOM_Z0003 systemd[1]: Started Create Volatile Files and Directories.
logrotate is one item to look at to close out logs and age them out.
FWIW -  There's armbian specific services in systemd that you might want to actually disable - armbian-ramlog for example, as when it runs out of space it gets ugly.
systemctl list-unit-files | grep armbian
armbian-firstrun-config.service            enabled
armbian-firstrun.service                   disabled
armbian-hardware-monitor.service           enabled
armbian-hardware-optimize.service          enabled
armbian-ramlog.service                     disabled
armbian-resize-filesystem.service          disabled
armbian-zram-config.service                disabled
Anyways - the ram logging and ZRAM stuff tend to be problematic for some that come into Armbian from other platforms...
The two services I would disable from SystemD are below:
I know folks might be offended here - but disabling this results in expected behavior.
That's odd in any case - current Armbian tweaked a little bit...  two weeks uptime one NanoPI Neo2
I'm mainly using it as a NTP time source (with GPSD and Chrony), as well as a ssh jump box
$ uname -a
Linux nano2 4.19.63-sunxi64 #5.92 SMP Fri Aug 2 00:18:27 CEST 2019 aarch64 aarch64 aarch64 GNU/Linux
$ uptime
 16:15:54 up 14 days,  6:45,  1 user,  load average: 0.00, 0.05, 0.06
$ df -h
udev            428M     0  428M   0% /dev
tmpfs           100M   14M   86M  14% /run
/dev/mmcblk0p1   15G  6.4G  8.0G  45% /
tmpfs           497M     0  497M   0% /dev/shm
tmpfs           497M     0  497M   0% /sys/fs/cgroup
tmpfs           497M  8.0K  497M   1% /tmp
tmpfs           100M     0  100M   0% /run/user/1000
$ ls -la /tmp
total 12
drwxrwxrwt 11 root root  280 Sep 28 16:11 .
drwxr-xr-x 22 root root 4096 Oct 26  2018 ..
-rw-------  1 root root   31 Sep 14 09:30 armbian-hardware-optimization.r0SxiO
drwxrwxrwt  2 root root   40 Sep 14 09:30 .font-unix
drwxrwxrwt  2 root root   40 Sep 14 09:30 .ICE-unix
-rw-rw-rw-  1 root root  387 Sep 23 21:03 nanohat-oled.log
-rw-rw-rw-  1 root root    0 Sep 14 09:30 nanoled-python.log
drwx------  3 root root   60 Sep 14 09:32 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-chrony.service-5M7ZYn
drwx------  3 root root   60 Sep 14 09:30 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-haveged.service-xAs0dT
drwx------  3 root root   60 Sep 14 09:30 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-ModemManager.service-GdBGMf
drwx------  3 root root   60 Sep 14 09:30 systemd-private-43a0a10b262541e4bbf35bf5370fcd35-systemd-resolved.service-H04TSn
drwxrwxrwt  2 root root   40 Sep 14 09:30 .Test-unix
drwxrwxrwt  2 root root   40 Sep 14 09:30 .X11-unix
drwxrwxrwt  2 root root   40 Sep 14 09:30 .XIM-unix
