maracuja Posted July 19, 2019 Posted July 19, 2019 I'm running an armbian build under docker (Host = Linux Mint or Ubuntu Bionic). I ran git clone --depth 1 https://github.com/armbian/build The problem is, in my customize-image.sh script I'm trying to build something that needs to have a package installed before. My lib.config looks like this: #DEBIAN_MIRROR='ftp.at.debian.org/debian/' #DEBOOTSTRAP_LIST="$DEBOOTSTRAP_LIST,apt-transport-https,ca-certificates" display_alert "Adding additional packages" "PHP 7, Redis, udisk2, dnsmasq, python3, ..." "info" PACKAGE_LIST_ADDITIONAL="$PACKAGE_LIST_ADDITIONAL php7.0 php7.0-cli php7.0-fpm php7.0-curl php7.0-intl php7.0-redis php7.0-mbstring" PACKAGE_LIST_ADDITIONAL="$PACKAGE_LIST_ADDITIONAL redis-server udisks2 task-print-server dnsmasq" PACKAGE_LIST_ADDITIONAL="$PACKAGE_LIST_ADDITIONAL libcups2-dev python-pip python3-dev python3-pip libsodium-dev libffi-dev" # lib bluetooth for bdaddr script [[ $BOARD == "orangepizeroplus2-h3" ]] && PACKAGE_LIST_ADDITIONAL="$PACKAGE_LIST_ADDITIONAL bluez bluez-tools libbluetooth-dev" I get to see the alert output. But the packages are never installed, I don't see them on the screen. Another hint that they are not installed is that my customize script relies on libbluetooth-dev to be installed. And it fails (most probably because libbluetooth-dev is missing). I also don't see other packages like hostapd, git, ethtool, network-manager being installed that are in the base additional package list. The output at that point is: htop is already the newest version (2.2.0-1+b1). mmc-utils is already the newest version (0+git20180327.b4fe0c8c-1). sunxi-tools is already the newest version (1.4.2+git20181114.6d598a-3). hostapd is already the newest version (3:2.7-99~armbian5.86+1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Obiously it reads the PACKAGE_LIST_ADDITIONAL variable, but my additional packages are nowhere... There is another problem with buster: I get the output "qemu: Unsupported syscall: 382" in my customize-configuration.sh
maracuja Posted July 19, 2019 Author Posted July 19, 2019 Maybe it's related to this bug: https://www.mail-archive.com/qemu-devel@nongnu.org/msg607319.html
Igor Posted July 19, 2019 Posted July 19, 2019 34 minutes ago, maracuja said: There is another problem with buster: I get the output "qemu: Unsupported syscall: 382" in my customize-configuration.sh Not problematic. Provide full install log. Packages are getting installed in the deboostrap process and new cache image is made when/if you change package base. Is it made?https://github.com/armbian/build/blob/master/lib/debootstrap.sh#L119
maracuja Posted July 19, 2019 Author Posted July 19, 2019 I've attached the output.log It says: Displaying message: Checking for local cache buster-cli-armhf.e51...09a.tar.lz4 info Displaying message: searching on servers ... and then: Extracting ... So .. no, the new cache image is not made. How can I enforce this? output.log
Igor Posted July 19, 2019 Posted July 19, 2019 5 hours ago, maracuja said: So .. no, the new cache image is not made. How can I enforce this? Something is wrong. ... lib.config is read, but packages hash - getting unique cache name - is not done properly. When you add packages, hash should change and image should be debootstrapped from scratch. I will try to find & fix this in the morning unless someone else have more time to dig in.
Igor Posted July 20, 2019 Posted July 20, 2019 @maracuja It should work now. https://github.com/armbian/build/commit/07e00d8a2ff64af87298360db4b3bad701d916c4
maracuja Posted July 20, 2019 Author Posted July 20, 2019 Thank you. I'm in the build process right now. It seems to work, the process is installing a bunch of packages.
