Younes_Thabet Posted July 24, 2019 Share Posted July 24, 2019 Hello all, I have a 5" waveshare touch screen connected (touch screen cable) to an orange pi one through usb with a separate power cable for screen, and it works fine. but when I used the (microusb to microusb cable) for the touch it doesn't work.. is there any way to make it work!? because i need the usb for something else and i can't use a usb hub for it's too big for my application. Regards, Link to comment Share on other sites More sharing options...
martinayotte Posted July 24, 2019 Share Posted July 24, 2019 16 minutes ago, Younes_Thabet said: but when I used the (microusb to microusb cable) for the touch it doesn't work.. You probably need to change the "dr_mode" from "otg" to "host" in the DT. Link to comment Share on other sites More sharing options...
Younes_Thabet Posted July 24, 2019 Author Share Posted July 24, 2019 19 minutes ago, martinayotte said: You probably need to change the "dr_mode" from "otg" to "host" in the DT. excuse me sir, could you show me the file where i can find the dr_mode!? i am a noob. Link to comment Share on other sites More sharing options...
martinayotte Posted July 24, 2019 Share Posted July 24, 2019 26 minutes ago, Younes_Thabet said: excuse me sir, could you show me the file where i can find the dr_mode!? i am a noob. In DT ( DeviceTree ), but it doesn't seems enough ... I will try to figure out, since I've made such things few years ago ! I will keep you posted when I get it working ... Link to comment Share on other sites More sharing options...
martinayotte Posted July 24, 2019 Share Posted July 24, 2019 3 hours ago, Younes_Thabet said: excuse me sir, could you show me the file where i can find the dr_mode!? i am a noob. Ok ! You probably have this error in "dmesg" like I got : sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO This is a bug probably introduced several months ago ! I don't have yet a real solution/fix, but at least I have a workaround : Download the DT compiler using "wget http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_armhf.deb " , and then installing it using "dpkg -i device-tree-compiler_1.4.7-3_armhf.deb" Then, decompile current DTB into DTS using "dtc -@ -I dtb -O dts -o sun8i-h3-orangepi-one.dts /boot/dtb/sun8i-h3-orangepi-one.dtb". Edit this DTS to change "dr_mode" from "otg" to "host" in the "usb@1c19000" node, and comment out the "usb0_id_det-gpios" line in the "phy@1c19400" node. Recompile DTB from this DTS "dtc -@ -I dts -O dtb -o /boot/dtb/sun8i-h3-orangepi-one.dtb sun8i-h3-orangepi-one.dts" and then reboot. The USB0 should be powered ... 1 Link to comment Share on other sites More sharing options...
