Hello everyone. I'm trying to install the katoolin tool on orange pi lite 2 but I have a small problem.
I followed these instructions but at the third step something is wrong.
install kali linux tools to any linux system
- sudo su
- git clone https://github.com/LionSec/katoolin.git && cp katoolin/katoolin.py /usr/bin/katoolin
- chmod +x /usr/bin/katoolin - sudo katoolin
root@orangepilite2:~# git clone https://github.com/LionSec/katoolin.git && cp katoolin/katoolin.py /usr/bin/katoolin
Cloning into 'katoolin'...
remote: Enumerating objects: 20, done.
remote: Counting objects: 100% (20/20), done.
remote: Compressing objects: 100% (20/20), done.
remote: Total 253 (delta 9), reused 2 (delta 0), pack-reused 233
Receiving objects: 100% (253/253), 101.71 KiB | 575.00 KiB/s, done.
Resolving deltas: 100% (142/142), done.
root@orangepilite2:~# chmod +x /usr/bin/katoolin - sudo katoolin
chmod: cannot access '-': No such file or directory
chmod: cannot access 'sudo': No such file or directory
Can anyone give me a hand?
Thank @martinayotte
But I don't understand why when I launch the command:
root@orangepilite2:~# sudo katoolin/
sudo: katoolin/: command not found
sudo: unable to execute /usr/bin/katoolin: No such file or directory
I get this error
Maybe it's a stupid idea but I looked at the readme file and noticed that it requires Python 2.7. But Arbian already has the version 3.7 pre-installed so it shouldn't give problems. Quite right?
  On 8/5/2019 at 4:18 PM, martinayotte said:
It seems that you missed the step "cp katoolin/katoolin.py /usr/bin/katoolin" ...
Expand
Sorry if I forgot to mention it but I already copied the file.
With command:
sudo cp katoolin/katoolin.py  /usr/bin/katoolin
  On 8/5/2019 at 4:24 PM, martinayotte said:
But why the previous error says "No such file or directory" ?
Or maybe it is the /usr/bin/python that is not present ?
Expand
In fact in the folder: /usr/bin the python folder is not present.
But is present python3.
Hello!
I tried to install python 2.7 but katoolin still doesn't work.
I tried to run the command you recommended to me and now it gives me this message.
  File "/usr/bin/katoolin", line 8
    print "Sorry. This script requires sudo privledges"
SyntaxError: Missing parentheses in call to 'print'. Did you mean print("Sorry. This script requires sudo privledges")?
Expand
This means that "katoolin" is really using python2...
So remove the previous symlink with "sudo rm /usr/bin/python" and recreate new one to python2.7 with "sudo ln -s python2.7 /usr/bin/python".
Expand
It worked. The tool works perfectly. Unfortunately Armbian on Orange Pi lite 2 is not GUI minutes so I can't use either metasploit or armitage.
Thanks @martinayotte kind and helpful as always.
