Espressobin V7 1G 800MHz DDR4 RAM 1GHz cpu purchased last week.
The board starts up reliably and gets to the boot prompt ok (using minicom).
I downloaded and unpacked Armbian_5.91_Espressobin_Debian_buster_next_4.19.59.img.
Ran shasum and got "Ok".  I dd'd it to a new Samsung SD card, dd'd it back, and ran
shasum again, getting "Ok".
I put the card in the board and powered it up.  It finds the card and tries to boot
but fails, saying:
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc0 is current device
    Failed to mount ext2 filesystem...
    Bad Linux ARM64 Image magic!
I'm guessing that the problem is that I did not update uboot.  I copied
flash-image-ddr4-1g-1cs-1000_800.bin to a FAT formatted USB key, but this:
    Updated u-boot needs new default boot environment and new boot script
    (overwrite the one on your /boot media – needed only if you upgrade from < v5.59).
    This is what you need to copy/paste into u-boot prompt:
is unclear.  This:
    Copy this flash-image-ddr4-1g-1cs-1000_800.bin to your FAT formatted
    USB key, plug it into USB3.0 port and execute from u-boot prompt:
    bubt flash-image-ddr4-1g-1cs-1000_800.bin spi usb
Seems clear enough.  I assume that I am then to paste the list of commands that follows
in at the boot prompt but the part about the "new boot script" is unclear.
[Edit]
I updated uboot and inserted the setenv commands (but ignored the unclear part about the "new boot script").
I'm getting
   U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Feb 20 2019 - 09:45:04 +0100)
so that evidently worked.  However, when it tries to boot from the SD card I get
  Marvell>> run bootcmd_mmc0
  ## Executing script at 06d00000
  Wrong image format for "source" command
  /boot/
  Marvell>>
[Edit]
The SD card is the same one that I used to flash the Uboot update.  Is it necessary to prepare the card
in any way other than to dd the image to it?
[Edit] I loop mounted the image and found that it has an ext4 filesystem with an 8192 block offset.
Used dd to make a copy with no offset.  That copy boots.
John Hasler
Board: Espressobin
Edited by John Hasler
More information
