zonegrise Posted August 27, 2019 Posted August 27, 2019 I am currently using Solidrun SbC (ICUBOX and HUMMINGBOARD) and a couple of weeks ago I updated UBUNTU on the Hummingboard to release 18.04 and lost internet..no more network. So try to fix that with no success so after many hours I decided to rebuild the OS with Armbian Buster but I cannot boot from my sd card (sd was flashed with Etcher). So did a surface check with no problems found. I thought it was power supply but I can boot from Android (Cubox and Hummingboard ) so PS should be good. My sd cards are Sandisk extreme 16 gigs. Since I did not build a bootable sd card since 3 years ago, I must have done something wrong but I don’t know what? Does the sd has to be formatted with a specific format or just unzip the Armbian and flash it? I am lost, so need help..thanks. My next move would be to get my app back on OSx or Widows but i have to forget using Solirun devices (I mean Linux).
Igor Posted August 27, 2019 Posted August 27, 2019 3 hours ago, zonegrise said: Does the sd has to be formatted with a specific format or just unzip the Armbian and flash it? https://docs.armbian.com/User-Guide_Getting-Started/ Try images with kernel 4.9.y https://www.armbian.com/cubox-i/ Those are directly tied to official u-boot/kernel sources. 1
