odoll Posted August 28, 2019 Posted August 28, 2019 Hi, I'm using an esprossobin with Debian Stretch with Armbian Linux 4.19.56-mvebu64. However regardless inwhat USB-TTL / Serial adapter I connect to he espressobin's USB2.0 port I don't get a ttyUSB0 device I tried to use a Prolific and a couple of others I got lend from a friend
ManoftheSea Posted August 28, 2019 Posted August 28, 2019 Are you trying to connect to the espressoBIN, or from the espressoBIN? The way I read it, it sounds like from, in which case, does your dmesg give any indication that the serial adapter is connected? There may be a module missing from the kernel compile. If the hardware works on another Debian system, you might try comparing between the dmesg on that system - it might tell you the name of the module.
martinayotte Posted August 28, 2019 Posted August 28, 2019 1 hour ago, odoll said: Armbian Linux 4.19.56-mvebu64. Some USB_SERIAL drivers are present in "default" images but not in "next/dev", so I've added some for future builds : https://github.com/armbian/build/commit/3d45d4e3eec2284787bd8b66f07fd42ca2f0558f
odoll Posted August 28, 2019 Author Posted August 28, 2019 1 hour ago, martinayotte said: I've added some for future builds Thx! Yes, I'm trying to connect to the console of a cubietruck. (Access from the cubietruck to the console of the espressobin works). Mine is a (fake) Prolific [177708.603331] usb 1-1: USB disconnect, device number 12 root@espressobin:~# ls -al /dev/tty* > tty.a [177965.718765] usb 1-1: new high-speed USB device number 13 using orion-ehci [177965.878745] usb 1-1: config 1 interface 0 altsetting 0 bulk endpoint 0x2 has invalid maxpacket 64 [177965.878792] usb 1-1: config 1 interface 0 altsetting 0 bulk endpoint 0x83 has invalid maxpacket 64 [177965.881592] usb 1-1: New USB device found, idVendor=067b, idProduct=2303, bcdDevice= 3.00 [177965.881624] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [177965.881649] usb 1-1: Product: USB-Serial Controller [177965.881673] usb 1-1: Manufacturer: Prolific Technology Inc. root@espressobin:~# ls -al /dev/tty* > tty.b root@espressobin:~# diff tty.a tty.b 66c66 < crw------- 1 root tty 252, 0 Aug 23 11:20 /dev/ttyMV0 --- > crw------- 1 root tty 252, 0 Aug 23 11:26 /dev/ttyMV0 But also any other tried didn't work 1st [446317.220494] usb 1-1: new high-speed USB device number 3 using orion-ehci [446317.408480] usb 1-1: Using ep0 maxpacket: 8 [446317.505569] usb 1-1: device descriptor read/all, error -71 [446317.632451] usb 1-1: new high-speed USB device number 4 using orion-ehci [446317.820467] usb 1-1: Using ep0 maxpacket: 8 [446317.917604] usb 1-1: device descriptor read/all, error -71 [446317.917783] usb usb1-port1: attempt power cycle [446318.568487] usb 1-1: new high-speed USB device number 5 using orion-ehci [446318.598617] usb 1-1: Using ep0 maxpacket: 8 [446318.700609] usb 1-1: device descriptor read/all, error -71 [446318.828458] usb 1-1: new high-speed USB device number 6 using orion-ehci [446318.858618] usb 1-1: Using ep0 maxpacket: 8 [446318.960611] usb 1-1: device descriptor read/all, error -71 [446318.960787] usb usb1-port1: unable to enumerate USB device 2nd [446648.177351] usb 1-1: new high-speed USB device number 7 using orion-ehci [446648.461621] usb 1-1: device descriptor read/all, error -71 [446648.589356] usb 1-1: new high-speed USB device number 8 using orion-ehci [446648.873612] usb 1-1: device descriptor read/all, error -71 [446648.873772] usb usb1-port1: attempt power cycle [446649.525309] usb 1-1: new high-speed USB device number 9 using orion-ehci [446649.649613] usb 1-1: device descriptor read/8, error -71 [446649.873634] usb 1-1: device descriptor read/8, error -71 [446650.109294] usb 1-1: new high-speed USB device number 10 using orion-ehci [446650.233608] usb 1-1: device descriptor read/8, error -71 [446650.457645] usb 1-1: device descriptor read/8, error -71 [446650.565446] usb usb1-port1: unable to enumerate USB device 3rd [446906.516659] usb 1-1: new high-speed USB device number 11 using orion-ehci [446906.672640] usb 1-1: Using ep0 maxpacket: 8 [446906.674543] usb 1-1: device descriptor read/all, error 8 [446906.808639] usb 1-1: new high-speed USB device number 12 using orion-ehci [446906.964630] usb 1-1: Using ep0 maxpacket: 8 [446906.966544] usb 1-1: device descriptor read/all, error 8 [446906.972787] usb usb1-port1: attempt power cycle [446907.624628] usb 1-1: new high-speed USB device number 13 using orion-ehci [446907.654614] usb 1-1: Using ep0 maxpacket: 8 [446907.661636] usb 1-1: device descriptor read/all, error 8 [446907.796623] usb 1-1: new high-speed USB device number 14 using orion-ehci [446907.826606] usb 1-1: Using ep0 maxpacket: 8 [446907.833639] usb 1-1: device descriptor read/all, error 8 [446907.840740] usb usb1-port1: unable to enumerate USB device 4th [447330.134465] usb 1-1: new high-speed USB device number 15 using orion-ehci [447330.290446] usb 1-1: Using ep0 maxpacket: 8 [447330.292544] usb 1-1: device descriptor read/all, error 8 [447330.426458] usb 1-1: new high-speed USB device number 16 using orion-ehci [447330.582432] usb 1-1: Using ep0 maxpacket: 8 [447330.584658] usb 1-1: device descriptor read/all, error 8 [447330.590518] usb usb1-port1: attempt power cycle [447331.242448] usb 1-1: new high-speed USB device number 17 using orion-ehci [447331.272618] usb 1-1: Using ep0 maxpacket: 8 [447331.279637] usb 1-1: device descriptor read/all, error 8 [447331.414424] usb 1-1: new high-speed USB device number 18 using orion-ehci [447331.443595] usb 1-1: Using ep0 maxpacket: 8 [447331.451608] usb 1-1: device descriptor read/all, error 8 [447331.458557] usb usb1-port1: unable to enumerate USB device
