Sp0T Posted May 8, 2016 Posted May 8, 2016 Hello, I just intalled the new Armbian 5.10 on my orange pi mini. I tried to play a video, but after i start it there was only black screen and audio. If i changed the vo to X11 it's worked but with vdpau it's not. Can someone help me how to make it work? Thanks, Sp0T
damien78 Posted June 3, 2016 Posted June 3, 2016 Hi, Can you provide the log mpv and the results of "ls -la /dev"? and results of "uname -a"?
Sp0T Posted June 4, 2016 Author Posted June 4, 2016 (edited) For some reason im not allowed to attach it so ill do it in the old way sry root@orangepi:/home/orangepi# ls -la /dev total 4 drwxr-xr-x 15 root root 4120 May 25 11:39 . drwxr-xr-x 22 root root 4096 Apr 30 22:51 .. crw------- 1 root root 247, 0 Apr 30 22:51 ace_dev crw------- 1 root root 10, 58 Apr 30 22:51 ashmem crw------- 1 root root 10, 235 Apr 30 22:51 autofs crw------- 1 root root 151, 0 Apr 30 22:51 avs_dev crw------- 1 root root 10, 59 Apr 30 22:51 binder drwxr-xr-x 2 root root 600 May 6 10:49 block drwxr-xr-x 2 root root 60 May 6 10:49 bsg crw-rw---- 1 root disk 10, 234 Apr 30 22:51 btrfs-control drwxr-xr-x 3 root root 60 Jan 1 1970 bus crw------- 1 root root 10, 62 Apr 30 22:51 cachefiles crw-rw---- 1 root video 150, 0 Apr 30 22:51 cedar_dev drwxr-xr-x 2 root root 3440 May 25 11:39 char crw------- 1 root root 5, 1 Apr 30 22:51 console crw------- 1 root root 10, 53 Apr 30 22:51 cpu_dma_latency crw------- 1 root root 10, 60 Apr 30 22:51 cuse drwxr-xr-x 6 root root 120 Jan 1 1970 disk crw-rw---- 1 root video 251, 0 Apr 30 22:51 disp drwxr-xr-x 2 root root 80 May 5 21:34 dri crw------- 1 root root 10, 61 Apr 30 22:51 ecryptfs crw-rw---- 1 root video 29, 0 Apr 30 22:51 fb0 crw-rw---- 1 root video 29, 1 Apr 30 22:51 fb1 lrwxrwxrwx 1 root root 13 Jan 1 1970 fd -> /proc/self/fd crw-rw-rw- 1 root root 1, 7 Apr 30 22:51 full crw-rw-rw- 1 root root 10, 229 Apr 30 22:51 fuse crw------- 1 root root 250, 0 Apr 30 22:51 g2d crw------- 1 root root 245, 0 Apr 30 22:51 hidraw0 crw------- 1 root root 245, 1 May 25 11:39 hidraw1 crw------- 1 root root 245, 2 May 25 11:39 hidraw2 crw-rw---- 1 root i2c 89, 0 Apr 30 22:51 i2c-0 crw-rw---- 1 root i2c 89, 1 Apr 30 22:51 i2c-1 crw-rw---- 1 root i2c 89, 2 Apr 30 22:51 i2c-2 crw-rw---- 1 root i2c 89, 3 Apr 30 22:51 i2c-3 crw-rw---- 1 root i2c 89, 4 Apr 30 22:51 i2c-4 lrwxrwxrwx 1 root root 25 Jan 1 1970 initctl -> /run/systemd/initctl/fifo drwxr-xr-x 4 root root 220 May 25 11:39 input crw-r----- 1 root kmem 1, 2 Apr 30 22:51 kmem crw------- 1 root root 1, 11 Apr 30 22:51 kmsg lrwxrwxrwx 1 root root 21 Apr 30 22:51 lircd -> ../var/run/lirc/lircd lrwxrwxrwx 1 root root 28 Jan 1 1970 log -> /run/systemd/journal/dev-log crw------- 1 root root 10, 56 Apr 30 22:51 log_events crw------- 1 root root 10, 57 Apr 30 22:51 log_main crw------- 1 root root 10, 55 Apr 30 22:51 log_radio crw------- 1 root root 10, 54 Apr 30 22:51 log_system brw-rw---- 1 root disk 7, 0 Apr 30 22:51 loop0 brw-rw---- 1 root disk 7, 1 Apr 30 22:51 loop1 brw-rw---- 1 root disk 7, 2 Apr 30 22:51 loop2 brw-rw---- 1 root disk 7, 3 Apr 30 22:51 loop3 brw-rw---- 1 root disk 7, 4 Apr 30 22:51 loop4 brw-rw---- 1 root disk 7, 5 Apr 30 22:51 loop5 brw-rw---- 1 root disk 7, 6 Apr 30 22:51 loop6 brw-rw---- 1 root disk 7, 7 Apr 30 22:51 loop7 crw-rw---- 1 root disk 10, 237 Apr 30 22:51 loop-control crw-rw---- 1 root video 241, 0 May 5 21:34 mali drwxr-xr-x 2 root root 60 Jan 1 1970 mapper crw-r----- 1 root kmem 1, 1 Apr 30 22:51 mem brw-rw---- 1 root disk 179, 0 Jun 3 18:25 mmcblk0 brw-rw---- 1 root disk 179, 1 Apr 30 22:51 mmcblk0p1 drwxrwxrwt 2 root root 40 Jan 1 1970 mqueue drwxr-xr-x 2 root root 60 Apr 30 22:51 net crw------- 1 root root 10, 52 Apr 30 22:51 network_latency crw------- 1 root root 10, 51 Apr 30 22:51 network_throughput crw-rw-rw- 1 root root 1, 3 Apr 30 22:51 null crw------- 1 root root 246, 0 Apr 30 22:51 pa_dev crw------- 1 root root 108, 0 Apr 30 22:51 ppp crw-rw-rw- 1 root tty 5, 2 Jun 4 11:13 ptmx drwxr-xr-x 2 root root 0 Jan 1 1970 pts brw-rw---- 1 root disk 1, 0 Apr 30 22:51 ram0 brw-rw---- 1 root disk 1, 1 Apr 30 22:51 ram1 brw-rw---- 1 root disk 1, 10 Apr 30 22:51 ram10 brw-rw---- 1 root disk 1, 11 Apr 30 22:51 ram11 brw-rw---- 1 root disk 1, 12 Apr 30 22:51 ram12 brw-rw---- 1 root disk 1, 13 Apr 30 22:51 ram13 brw-rw---- 1 root disk 1, 14 Apr 30 22:51 ram14 brw-rw---- 1 root disk 1, 15 Apr 30 22:51 ram15 brw-rw---- 1 root disk 1, 2 Apr 30 22:51 ram2 brw-rw---- 1 root disk 1, 3 Apr 30 22:51 ram3 brw-rw---- 1 root disk 1, 4 Apr 30 22:51 ram4 brw-rw---- 1 root disk 1, 5 Apr 30 22:51 ram5 brw-rw---- 1 root disk 1, 6 Apr 30 22:51 ram6 brw-rw---- 1 root disk 1, 7 Apr 30 22:51 ram7 brw-rw---- 1 root disk 1, 8 Apr 30 22:51 ram8 brw-rw---- 1 root disk 1, 9 Apr 30 22:51 ram9 crw-rw-rw- 1 root root 1, 8 Apr 30 22:51 random crw-rw-r-- 1 root root 10, 63 Apr 30 22:51 rfkill lrwxrwxrwx 1 root root 4 Apr 30 22:51 rtc -> rtc0 crw------- 1 root root 254, 0 Apr 30 22:51 rtc0 brw-rw---- 1 root disk 8, 0 Apr 30 22:51 sda brw-rw---- 1 root disk 8, 1 May 15 08:55 sda1 crw-rw---- 1 root disk 21, 0 Apr 30 22:51 sg0 drwxrwxrwt 2 root root 40 May 15 09:12 shm drwxr-xr-x 3 root root 200 Apr 30 22:51 snd crw------- 1 root root 153, 0 Apr 30 22:51 spidev0.0 crw------- 1 root root 153, 1 Apr 30 22:51 spidev0.1 lrwxrwxrwx 1 root root 15 Jan 1 1970 stderr -> /proc/self/fd/2 lrwxrwxrwx 1 root root 15 Jan 1 1970 stdin -> /proc/self/fd/0 lrwxrwxrwx 1 root root 15 Jan 1 1970 stdout -> /proc/self/fd/1 crw------- 1 root root 244, 0 Apr 30 22:51 sunxi-lcd crw-rw-rw- 1 root tty 5, 0 May 15 08:52 tty crw--w---- 1 root tty 4, 0 Apr 30 22:51 tty0 crw------- 1 root tty 4, 1 May 5 21:33 tty1 crw--w---- 1 root tty 4, 10 Apr 30 22:51 tty10 crw--w---- 1 root tty 4, 11 Apr 30 22:51 tty11 crw--w---- 1 root tty 4, 12 Apr 30 22:51 tty12 crw--w---- 1 root tty 4, 13 Apr 30 22:51 tty13 crw--w---- 1 root tty 4, 14 Apr 30 22:51 tty14 crw--w---- 1 root tty 4, 15 Apr 30 22:51 tty15 crw--w---- 1 root tty 4, 16 Apr 30 22:51 tty16 crw--w---- 1 root tty 4, 17 Apr 30 22:51 tty17 crw--w---- 1 root tty 4, 18 Apr 30 22:51 tty18 crw--w---- 1 root tty 4, 19 Apr 30 22:51 tty19 crw--w---- 1 root tty 4, 2 Apr 30 22:51 tty2 crw--w---- 1 root tty 4, 20 Apr 30 22:51 tty20 crw--w---- 1 root tty 4, 21 Apr 30 22:51 tty21 crw--w---- 1 root tty 4, 22 Apr 30 22:51 tty22 crw--w---- 1 root tty 4, 23 Apr 30 22:51 tty23 crw--w---- 1 root tty 4, 24 Apr 30 22:51 tty24 crw--w---- 1 root tty 4, 25 Apr 30 22:51 tty25 crw--w---- 1 root tty 4, 26 Apr 30 22:51 tty26 crw--w---- 1 root tty 4, 27 Apr 30 22:51 tty27 crw--w---- 1 root tty 4, 28 Apr 30 22:51 tty28 crw--w---- 1 root tty 4, 29 Apr 30 22:51 tty29 crw--w---- 1 root tty 4, 3 Apr 30 22:51 tty3 crw--w---- 1 root tty 4, 30 Apr 30 22:51 tty30 crw--w---- 1 root tty 4, 31 Apr 30 22:51 tty31 crw--w---- 1 root tty 4, 32 Apr 30 22:51 tty32 crw--w---- 1 root tty 4, 33 Apr 30 22:51 tty33 crw--w---- 1 root tty 4, 34 Apr 30 22:51 tty34 crw--w---- 1 root tty 4, 35 Apr 30 22:51 tty35 crw--w---- 1 root tty 4, 36 Apr 30 22:51 tty36 crw--w---- 1 root tty 4, 37 Apr 30 22:51 tty37 crw--w---- 1 root tty 4, 38 Apr 30 22:51 tty38 crw--w---- 1 root tty 4, 39 Apr 30 22:51 tty39 crw--w---- 1 root tty 4, 4 Apr 30 22:51 tty4 crw--w---- 1 root tty 4, 40 Apr 30 22:51 tty40 crw--w---- 1 root tty 4, 41 Apr 30 22:51 tty41 crw--w---- 1 root tty 4, 42 Apr 30 22:51 tty42 crw--w---- 1 root tty 4, 43 Apr 30 22:51 tty43 crw--w---- 1 root tty 4, 44 Apr 30 22:51 tty44 crw--w---- 1 root tty 4, 45 Apr 30 22:51 tty45 crw--w---- 1 root tty 4, 46 Apr 30 22:51 tty46 crw--w---- 1 root tty 4, 47 Apr 30 22:51 tty47 crw--w---- 1 root tty 4, 48 Apr 30 22:51 tty48 crw--w---- 1 root tty 4, 49 Apr 30 22:51 tty49 crw--w---- 1 root tty 4, 5 Apr 30 22:51 tty5 crw--w---- 1 root tty 4, 50 Apr 30 22:51 tty50 crw--w---- 1 root tty 4, 51 Apr 30 22:51 tty51 crw--w---- 1 root tty 4, 52 Apr 30 22:51 tty52 crw--w---- 1 root tty 4, 53 Apr 30 22:51 tty53 crw--w---- 1 root tty 4, 54 Apr 30 22:51 tty54 crw--w---- 1 root tty 4, 55 Apr 30 22:51 tty55 crw--w---- 1 root tty 4, 56 Apr 30 22:51 tty56 crw--w---- 1 root tty 4, 57 Apr 30 22:51 tty57 crw--w---- 1 root tty 4, 58 Apr 30 22:51 tty58 crw--w---- 1 root tty 4, 59 Apr 30 22:51 tty59 crw--w---- 1 root tty 4, 6 Apr 30 22:51 tty6 crw--w---- 1 root tty 4, 60 Apr 30 22:51 tty60 crw--w---- 1 root tty 4, 61 Apr 30 22:51 tty61 crw--w---- 1 root tty 4, 62 Apr 30 22:51 tty62 crw--w---- 1 root tty 4, 63 Apr 30 22:51 tty63 crw--w---- 1 root tty 4, 7 Apr 30 22:51 tty7 crw--w---- 1 root tty 4, 8 Apr 30 22:51 tty8 crw--w---- 1 root tty 4, 9 Apr 30 22:51 tty9 crw-rw---- 1 root dialout 4, 64 Apr 30 22:51 ttyS0 crw-rw---- 1 root dialout 4, 65 Apr 30 22:51 ttyS1 crw-rw---- 1 root dialout 4, 66 Apr 30 22:51 ttyS2 crw-rw---- 1 root dialout 4, 67 Apr 30 22:51 ttyS3 crw-rw---- 1 root dialout 4, 68 Apr 30 22:51 ttyS4 crw-rw---- 1 root dialout 4, 69 Apr 30 22:51 ttyS5 crw-rw---- 1 root dialout 4, 70 Apr 30 22:51 ttyS6 crw-rw---- 1 root dialout 4, 71 Apr 30 22:51 ttyS7 crw------- 1 root root 10, 223 Apr 30 22:51 uinput crw-rw---- 1 root video 242, 0 May 5 21:34 ump crw-rw-rw- 1 root root 1, 9 Apr 30 22:51 urandom crw------- 1 root root 189, 0 Apr 30 22:51 usbdev1.1 crw------- 1 root root 189, 1 Apr 30 22:51 usbdev1.2 crw------- 1 root root 189, 2 Apr 30 22:51 usbdev1.3 crw------- 1 root root 189, 7 May 25 11:39 usbdev1.8 crw------- 1 root root 189, 128 Apr 30 22:51 usbdev2.1 crw------- 1 root root 189, 256 Apr 30 22:51 usbdev3.1 crw------- 1 root root 189, 257 Apr 30 22:51 usbdev3.2 crw------- 1 root root 189, 384 Apr 30 22:51 usbdev4.1 crw------- 1 root root 248, 0 Apr 30 22:51 usbmon0 crw------- 1 root root 248, 1 Apr 30 22:51 usbmon1 crw------- 1 root root 248, 2 Apr 30 22:51 usbmon2 crw------- 1 root root 248, 3 Apr 30 22:51 usbmon3 crw------- 1 root root 248, 4 Apr 30 22:51 usbmon4 crw-rw---- 1 root tty 7, 0 Apr 30 22:51 vcs crw-rw---- 1 root tty 7, 1 Apr 30 22:51 vcs1 crw-rw---- 1 root tty 7, 2 Apr 30 22:51 vcs2 crw-rw---- 1 root tty 7, 3 Apr 30 22:51 vcs3 crw-rw---- 1 root tty 7, 4 Apr 30 22:51 vcs4 crw-rw---- 1 root tty 7, 5 Apr 30 22:51 vcs5 crw-rw---- 1 root tty 7, 6 Apr 30 22:51 vcs6 crw-rw---- 1 root tty 7, 7 May 5 21:34 vcs7 crw-rw---- 1 root tty 7, 128 Apr 30 22:51 vcsa crw-rw---- 1 root tty 7, 129 Apr 30 22:51 vcsa1 crw-rw---- 1 root tty 7, 130 Apr 30 22:51 vcsa2 crw-rw---- 1 root tty 7, 131 Apr 30 22:51 vcsa3 crw-rw---- 1 root tty 7, 132 Apr 30 22:51 vcsa4 crw-rw---- 1 root tty 7, 133 Apr 30 22:51 vcsa5 crw-rw---- 1 root tty 7, 134 Apr 30 22:51 vcsa6 crw-rw---- 1 root tty 7, 135 May 5 21:34 vcsa7 prw-r----- 1 root adm 0 Jun 4 11:13 xconsole crw-rw-rw- 1 root root 1, 5 Apr 30 22:51 zero root@orangepi:/home/orangepi# uname -a Linux orangepi 3.4.112-sun7i #15 SMP PREEMPT Thu Apr 28 23:39:36 CEST 2016 armv7l GNU/Linux [ 0.014][v][cplayer] Setting option 'profile' = 'pseudo-gui' (flags = 8) [ 0.014][v][cplayer] Setting option 'terminal' = 'no' (flags = 12) [ 0.014][v][cplayer] Setting option 'force-window' = 'yes' (flags = 12) [ 0.015][v][cplayer] Setting option 'idle' = 'once' (flags = 12) [ 0.015][v][cplayer] Setting option 'screenshot-directory' = '~~desktop/' (flags = 12) [ 0.020][v][global] config path: 'input.conf' -/-> '/root/.config/mpv/input.conf' [ 0.020][v][global] config path: 'input.conf' -/-> '/root/.mpv/input.conf' [ 0.020][v][global] config path: 'input.conf' -/-> '/etc/mpv/input.conf' [ 0.020][v][input] Falling back on default (hardcoded) input config [ 0.024][v][osc] Loading script @osc.lua... [ 0.027][v][global] config path: 'scripts' -/-> '/root/.config/mpv/scripts' [ 0.027][v][global] config path: 'scripts' -/-> '/root/.mpv/scripts' [ 0.027][v][global] config path: 'scripts' -/-> '/etc/mpv/scripts' [ 0.027][v][osc] loading mp.defaults [ 0.033][v][osc] loading @osc.lua [ 0.052][v][global] config path: 'lua-settings/osc.conf' -/-> '/root/.config/mpv/lua-settings/osc.conf' [ 0.052][v][global] config path: 'lua-settings/osc.conf' -/-> '/root/.mpv/lua-settings/osc.conf' [ 0.052][v][global] config path: 'lua-settings/osc.conf' -/-> '/etc/mpv/lua-settings/osc.conf' [ 0.053][v][osc] lua-settings/osc.conf not found. [ 0.055][v][cplayer] Run command: define-section, flags=0, args=[showhide, mouse_move script-binding osc/__keybinding1 [ 0.055][v][cplayer] mouse_leave script-binding osc/__keybinding2 [ 0.055][v][cplayer] , force] [ 0.055][v][cplayer] Run command: enable-section, flags=0, args=[showhide, allow-hide-cursor+allow-vo-dragging] [ 0.055][v][cplayer] Run command: define-section, flags=0, args=[input, mouse_btn0 script-binding osc/__keybinding3 [ 0.055][v][cplayer] shift+mouse_btn0 script-binding osc/__keybinding4 [ 0.055][v][cplayer] mouse_btn2 script-binding osc/__keybinding5 [ 0.055][v][cplayer] mouse_btn0_dbl ignore [ 0.055][v][cplayer] shift+mouse_btn0_dbl ignore [ 0.055][v][cplayer] mouse_btn2_dbl ignore [ 0.055][v][cplayer] , force] [ 0.056][v][cplayer] Run command: enable-section, flags=0, args=[input, ] [ 0.056][v][cplayer] Run command: define-section, flags=0, args=[input_osc, del script-binding osc/__keybinding6 [ 0.056][v][cplayer] , default] [ 0.056][v][cplayer] Run command: enable-section, flags=0, args=[input_osc, allow-hide-cursor+allow-vo-dragging] [ 0.056][v][cplayer] Run command: define-section, flags=0, args=[input_forced_osc, , force] [ 0.056][v][cplayer] Run command: enable-section, flags=0, args=[input_forced_osc, allow-hide-cursor+allow-vo-dragging] [ 0.061][v][cplayer] Run command: disable-section, flags=0, args=[input] [ 0.062][v][cplayer] Done loading @osc.lua. [ 0.062][v][ytdl_hook] Loading script @ytdl_hook.lua... [ 0.063][v][global] config path: 'scripts' -/-> '/root/.config/mpv/scripts' [ 0.063][v][global] config path: 'scripts' -/-> '/root/.mpv/scripts' [ 0.063][v][global] config path: 'scripts' -/-> '/etc/mpv/scripts' [ 0.063][v][ytdl_hook] loading mp.defaults [ 0.068][v][ytdl_hook] loading @ytdl_hook.lua [ 0.071][v][cplayer] Run command: hook-add, flags=0, args=[on_load, 1, 10] [ 0.071][v][cplayer] Done loading @ytdl_hook.lua. [ 0.071][v][global] config path: 'scripts' -/-> '/root/.config/mpv/scripts' [ 0.071][v][global] config path: 'scripts' -/-> '/root/.mpv/scripts' [ 0.071][v][global] config path: 'scripts' -/-> '/etc/mpv/scripts' [ 0.072][v][global] config path: 'watch_later' -> '/root/.config/mpv/watch_later' [ 0.072][i][cplayer] Playing: /media/orangepi/Mediadisk/movie/sample/sample.mkv [ 0.072][v][cplayer] Running hook: ytdl_hook/on_load [ 0.073][v][cplayer] Run command: hook-ack, flags=0, args=[on_load] [ 0.083][v][ifo] Opening /media/orangepi/Mediadisk/movie/sample/sample.mkv [ 0.083][v][ifo/dvdnav] Opening /media/orangepi/Mediadisk/movie/sample/sample.mkv [ 0.084][v][bdmv/bluray] Opening /media/orangepi/Mediadisk/movie/sample/sample.mkv [ 0.085][v][file] Opening /media/orangepi/Mediadisk/movie/sample/sample.mkv [ 0.086][v][file] Stream opened successfully. [ 0.086][v][cache] Cache size set to 97699 KiB (75000 KiB backbuffer) [ 0.086][v][demux] Trying demuxers for level=normal. [ 0.087][v][mkv] Found the head... [ 0.087][v][mkv] + a segment... [ 0.088][v][mkv] Parsing seek head... [ 0.088][v][mkv] |+ segment information... [ 0.088][v][mkv] | + muxing app: libebml v1.3.1 + libmatroska v1.4.2 [ 0.088][v][mkv] | + writing app: mkvmerge v8.0.0 ('Til The Day That I Die') 64bit [ 0.088][v][mkv] | + timecode scale: 1000000 [ 0.088][v][mkv] | + duration: 64.990s [ 0.088][v][mkv] | + segment uid a5 94 8b 43 9d 9c 6e 3c a2 0a 42 f7 7d ef 24 77 [ 0.088][v][mkv] |+ segment tracks... [ 0.088][v][mkv] | + a track... [ 0.088][v][mkv] | + Track number: 1 [ 0.088][v][mkv] | + Track type: Video [ 0.088][v][mkv] | + Video track [ 0.088][v][mkv] | + Display width: 720 [ 0.088][v][mkv] | + Display height: 302 [ 0.088][v][mkv] | + Pixel width: 720 [ 0.088][v][mkv] | + Pixel height: 302 [ 0.088][v][mkv] | + Codec ID: V_MPEG4/ISO/AVC [ 0.088][v][mkv] | + CodecPrivate, length 43 [ 0.088][v][mkv] | + Default duration: 41.708ms ( = 23.976 fps) [ 0.088][v][mkv] | + a track... [ 0.088][v][mkv] | + Track number: 2 [ 0.088][v][mkv] | + Track type: Audio [ 0.088][v][mkv] | + Audio track [ 0.088][v][mkv] | + Sampling frequency: 48000.000000 [ 0.088][v][mkv] | + Channels: 6 [ 0.088][v][mkv] | + Codec ID: A_AC3 [ 0.088][v][mkv] | + Language: hun [ 0.088][v][mkv] | + Default duration: 32.000ms ( = 31.250 fps) [ 0.088][v][mkv] | + a track... [ 0.088][v][mkv] | + Track number: 3 [ 0.088][v][mkv] | + Track type: Subtitle [ 0.088][v][mkv] | + Codec ID: S_TEXT/UTF8 [ 0.088][v][mkv] | + Language: hun [ 0.088][v][mkv] | + Forced flag: 1 [ 0.088][v][mkv] | + a track... [ 0.088][v][mkv] | + Track number: 4 [ 0.088][v][mkv] | + Track type: Subtitle [ 0.088][v][mkv] | + Codec ID: S_TEXT/UTF8 [ 0.088][v][mkv] | + Language: hun [ 0.088][v][mkv] | + Default flag: 0 [ 0.088][v][mkv] Parsing chapters... [ 0.089][v][mkv] New edition 0 [ 0.089][v][mkv] Default edition flag: 0 [ 0.089][v][mkv] Chapter 0 from 00:00:00.000 to 00:00:00.000, 00:07:58.311 [ 0.089][v][mkv] |+ found cluster [ 0.089][v][mkv] Deferring reading cues. [ 0.089][v][mkv] Seeking to 23242679 to read header element 0x1254c367. [ 0.089][v][cache] Dropping cache at pos 23242679, cached range: 0-393216. [ 0.089][v][cache] Seeking underlying stream: 393216 -> 23242679 [ 0.090][v][mkv] All headers are parsed! [ 0.090][v][cache] Dropping cache at pos 7039, cached range: 23242679-23244330. [ 0.090][v][cache] Seeking underlying stream: 23244330 -> 7039 [ 0.090][v][demux] Detected file format: Matroska [ 0.090][v][cache] blocking for STREAM_CTRL 9 [ 0.093][v][find_files] Loading external files in /media/orangepi/Mediadisk/movie/sample/ [ 0.093][v][global] config path: 'sub/' -/-> '/root/.config/mpv/sub/' [ 0.093][v][global] config path: 'sub/' -/-> '/root/.mpv/sub/' [ 0.093][v][global] config path: 'sub/' -/-> '/etc/mpv/sub/' [ 0.093][v][global] config path: 'audio/' -/-> '/root/.config/mpv/audio/' [ 0.093][v][global] config path: 'audio/' -/-> '/root/.mpv/audio/' [ 0.093][v][global] config path: 'audio/' -/-> '/etc/mpv/audio/' [ 0.093][i][cplayer] (+) Video --vid=1 (*) (h264) [ 0.093][i][cplayer] (+) Audio --aid=1 --alang=hun (*) (ac3) [ 0.093][i][cplayer] (+) Subs --sid=1 --slang=hun (*) (f) (subrip) [ 0.093][i][cplayer] Subs --sid=2 --slang=hun (subrip) [ 0.095][v][vo/vdpau/x11] X11 opening display: :1.0 [ 0.146][v][vo/vdpau/x11] X11 running at 1920x1080 (":1.0" => local display) [ 0.148][v][vo/vdpau/x11] Detected wm supports NetWM. [ 0.153][v][vo/vdpau/x11] Detected wm supports ABOVE state. [ 0.153][v][vo/vdpau/x11] Detected wm supports BELOW state. [ 0.153][v][vo/vdpau/x11] Detected wm supports FULLSCREEN state. [ 0.158][v][vo/vdpau/x11] Display 0 (default): [0, 0, 1920, 1080] @ 60.000000 FPS [ 0.159][v][vo/vdpau/x11] Current display FPS: 60.000000 [ 0.223][v][vo/vdpau] Assuming 60.000000 FPS for display sync. [ 0.226][v][vd] Container reported FPS: 23.976025 [ 0.228][v][vd] Codec list: [ 0.228][v][vd] lavc:h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [ 0.228][v][vd] lavc:h264_vdpau (h264) - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (VDPAU acceleration) [ 0.228][v][vd] Opening video decoder lavc:h264 [ 0.228][v][vd] Probing 'vdpau'... [ 0.228][v][vd] Trying hardware decoding. [ 0.234][v][vd] Selected video codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [lavc:h264] [ 0.235][v][vo/vdpau/x11] Disabling screensaver. [ 0.250][v][ad] Codec list: [ 0.251][v][ad] lavc:ac3 - ATSC A/52A (AC-3) [ 0.251][v][ad] lavc:ac3_fixed (ac3) - ATSC A/52A (AC-3) [ 0.251][v][ad] Opening audio decoder lavc:ac3 [ 0.253][v][ad] Requesting 1 threads for decoding. [ 0.255][v][ad] Selected audio codec: ATSC A/52A (AC-3) [lavc:ac3] [ 0.256][v][global] config path: 'fonts' -/-> '/root/.config/mpv/fonts' [ 0.256][v][global] config path: 'fonts' -/-> '/root/.mpv/fonts' [ 0.256][v][global] config path: 'fonts' -/-> '/etc/mpv/fonts' [ 0.257][v][vo/vdpau/x11] Disabling screensaver failed (-1). Make sure the xdg-screensaver script is installed. [ 0.257][v][sub/ass] Shaper: FriBidi 0.19.6 (SIMPLE) HarfBuzz-ng 0.9.35 (COMPLEX) [ 0.258][v][global] config path: 'subfont.ttf' -/-> '/root/.config/mpv/subfont.ttf' [ 0.258][v][global] config path: 'subfont.ttf' -/-> '/root/.mpv/subfont.ttf' [ 0.258][v][global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf' [ 0.258][v][global] config path: 'fonts.conf' -/-> '/root/.config/mpv/fonts.conf' [ 0.258][v][global] config path: 'fonts.conf' -/-> '/root/.mpv/fonts.conf' [ 0.258][v][global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf' [ 0.258][v][sub/ass] Setting up fonts... [ 0.284][v][sub/ass] Using font provider fontconfig [ 0.284][v][sub/ass] Done. [ 0.284][v][cplayer] Starting playback... [ 0.305][v][vd] Pixel formats supported by decoder: vdpau vaapi_vld yuv420p [ 0.305][v][vd] Codec profile: High (0x64) [ 0.316][v][af] Audio filter chain: [ 0.317][v][af] [in] 48000Hz stereo 2ch floatp [ 0.317][v][af] [out] 48000Hz stereo 2ch floatp [ 0.317][v][af] [ao] 48000Hz stereo 2ch floatp [ 0.317][v][ao] Trying audio driver 'pulse' [ 0.317][v][ao/pulse] requested format: 48000 Hz, stereo channels, floatp [ 0.334][v][ao/pulse] Library version: 5.0.0 [ 0.334][v][ao/pulse] Proto: 29 [ 0.334][v][ao/pulse] Server proto: 4294967295 [ 0.341][v][ao] Trying audio driver 'alsa' [ 0.341][v][ao/alsa] requested format: 48000 Hz, stereo channels, floatp [ 0.341][v][ao/alsa] using ALSA version: 1.0.28 [ 0.341][v][ao/alsa] opening device 'default' [ 0.353][v][ao/alsa] trying format float [ 0.353][v][ao/alsa] trying format double [ 0.353][v][ao/alsa] trying format s32 [ 0.354][v][ao/alsa] hw pausing supported: yes [ 0.354][v][ao/alsa] buffersize: 12000 samples [ 0.354][v][ao/alsa] period size: 1500 samples [ 0.354][v][ao/alsa] device buffer: 12000 samples. [ 0.354][v][ao/alsa] using soft-buffer of 12000 samples. [ 0.355][i][cplayer] AO: [alsa] 48000Hz stereo 2ch s32 [ 0.355][v][cplayer] AO: Description: ALSA audio output [ 0.355][v][af] Adding filter lavrresample [ 0.356][v][af] Audio filter chain: [ 0.356][v][af] [in] 48000Hz stereo 2ch floatp [ 0.356][v][af] [lavrresample] 48000Hz stereo 2ch s32 [ 0.356][v][af] [out] 48000Hz stereo 2ch s32 [ 0.356][v][af] [ao] 48000Hz stereo 2ch s32 [ 0.387][i][vd] Using hardware decoding (vdpau). [ 0.387][v][vd] Decoder format: 720x302 [0:1] vdpau auto/auto CL=mpeg2/4/h264 [ 0.387][v][vd] Using container aspect ratio. [ 0.387][v][vf] Video filter chain: [ 0.387][v][vf] [in] 720x302 vdpau bt.601/limited CL=mpeg2/4/h264 [ 0.387][v][vf] [out] 720x302 vdpau bt.601/limited CL=mpeg2/4/h264 [ 0.387][i][cplayer] VO: [vdpau] 720x302 vdpau [ 0.387][v][cplayer] VO: Description: VDPAU with X11 [ 0.492][v][vo/vdpau] Window size: 720x302 [ 0.492][v][vo/vdpau] Video source: 720x302 (1:1) [ 0.492][v][vo/vdpau] Video display: (0, 0) 720x302 -> (0, 0) 720x302 [ 0.492][v][vo/vdpau] Video scale: 1.000000/1.000000 [ 0.492][v][vo/vdpau] OSD borders: l=0 t=0 r=0 b=0 [ 0.492][v][vo/vdpau] Video borders: l=0 t=0 r=0 b=0 [ 0.492][v][cplayer] set video colors output-levels=0 [ 0.500][v][vo/vdpau] Recreating vdpau video mixer. [ 0.508][v][global] config path: 'fonts' -/-> '/root/.config/mpv/fonts' [ 0.508][v][global] config path: 'fonts' -/-> '/root/.mpv/fonts' [ 0.508][v][global] config path: 'fonts' -/-> '/etc/mpv/fonts' [ 0.516][v][osd/libass] Shaper: FriBidi 0.19.6 (SIMPLE) HarfBuzz-ng 0.9.35 (COMPLEX) [ 0.516][v][global] config path: 'subfont.ttf' -/-> '/root/.config/mpv/subfont.ttf' [ 0.516][v][global] config path: 'subfont.ttf' -/-> '/root/.mpv/subfont.ttf' [ 0.516][v][global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf' [ 0.516][v][global] config path: 'fonts.conf' -/-> '/root/.config/mpv/fonts.conf' [ 0.516][v][global] config path: 'fonts.conf' -/-> '/root/.mpv/fonts.conf' [ 0.516][v][global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf' [ 0.516][v][osd/libass] Setting up fonts... [ 0.548][v][osd/libass] Using font provider fontconfig [ 0.548][v][osd/libass] Done. [ 0.557][v][osd/libass] fontselect: (sans-serif, 400, 0) -> /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf, 0, DejaVuSans [ 0.570][v][cplayer] first video frame after restart shown [ 0.573][v][cplayer] playback restart complete [ 0.606][v][vo/vdpau] Frame shown too early (1 ms) [ 0.647][v][vo/vdpau] Frame shown too early (3 ms) [ 0.690][v][vo/vdpau] Frame shown too early (4 ms) [ 0.732][v][vo/vdpau] Frame shown too early (4 ms) [ 0.774][v][vo/vdpau] Frame shown too early (4 ms) [ 0.814][v][vo/vdpau] Frame shown too early (3 ms) [ 0.856][v][vo/vdpau] Frame shown too early (4 ms) [ 0.898][v][vo/vdpau] Frame shown too early (4 ms) [ 0.940][v][vo/vdpau] Frame shown too early (3 ms) [ 0.981][v][vo/vdpau] Frame shown too early (4 ms) [ 1.024][v][vo/vdpau] Frame shown too early (4 ms) [ 1.065][v][vo/vdpau] Frame shown too early (3 ms) [ 1.107][v][vo/vdpau] Frame shown too early (4 ms) [ 1.190][v][vo/vdpau] Frame shown too early (-1 ms) [ 1.232][v][vo/vdpau] Frame shown too early (4 ms) [ 1.276][v][vo/vdpau] Frame shown too early (6 ms) [ 1.316][v][vo/vdpau] Frame shown too early (2 ms) [ 1.357][v][vo/vdpau] Frame shown too early (3 ms) [ 1.399][v][vo/vdpau] Frame shown too early (4 ms) [ 1.441][v][vo/vdpau] Frame shown too early (4 ms) [ 1.483][v][vo/vdpau] Frame shown too early (4 ms) [ 1.524][v][vo/vdpau] Frame shown too early (3 ms) [ 1.566][v][vo/vdpau] Frame shown too early (4 ms) [ 1.608][v][vo/vdpau] Frame shown too early (4 ms) [ 1.649][v][vo/vdpau] Frame shown too early (3 ms) [ 1.691][v][vo/vdpau] Frame shown too early (4 ms) [ 1.733][v][vo/vdpau] Frame shown too early (4 ms) [ 1.775][v][vo/vdpau] Frame shown too early (4 ms) [ 1.816][v][vo/vdpau] Frame shown too early (3 ms) [ 1.858][v][vo/vdpau] Frame shown too early (4 ms) [ 1.900][v][vo/vdpau] Frame shown too early (4 ms) [ 1.941][v][vo/vdpau] Frame shown too early (3 ms) [ 1.983][v][vo/vdpau] Frame shown too early (4 ms) [ 2.025][v][vo/vdpau] Frame shown too early (4 ms) [ 2.066][v][vo/vdpau] Frame shown too early (3 ms) [ 2.108][v][vo/vdpau] Frame shown too early (4 ms) [ 2.150][v][vo/vdpau] Frame shown too early (4 ms) [ 2.192][v][vo/vdpau] Frame shown too early (4 ms) [ 2.234][v][vo/vdpau] Frame shown too early (4 ms) [ 2.276][v][vo/vdpau] Frame shown too early (4 ms) [ 2.318][v][vo/vdpau] Frame shown too early (4 ms) [ 2.359][v][vo/vdpau] Frame shown too early (3 ms) [ 2.401][v][vo/vdpau] Frame shown too early (4 ms) [ 2.443][v][vo/vdpau] Frame shown too early (4 ms) [ 2.485][v][vo/vdpau] Frame shown too early (4 ms) [ 2.526][v][vo/vdpau] Frame shown too early (3 ms) [ 2.568][v][vo/vdpau] Frame shown too early (4 ms) [ 2.610][v][vo/vdpau] Frame shown too early (4 ms) [ 2.651][v][vo/vdpau] Frame shown too early (3 ms) [ 2.693][v][vo/vdpau] Frame shown too early (4 ms) [ 2.735][v][vo/vdpau] Frame shown too early (4 ms) [ 2.777][v][vo/vdpau] Frame shown too early (4 ms) [ 2.818][v][vo/vdpau] Frame shown too early (3 ms) [ 2.860][v][vo/vdpau] Frame shown too early (4 ms) [ 2.902][v][vo/vdpau] Frame shown too early (4 ms) [ 2.943][v][vo/vdpau] Frame shown too early (3 ms) [ 2.985][v][vo/vdpau] Frame shown too early (4 ms) [ 3.027][v][vo/vdpau] Frame shown too early (4 ms) [ 3.068][v][vo/vdpau] Frame shown too early (3 ms) [ 3.110][v][vo/vdpau] Frame shown too early (4 ms) [ 3.152][v][vo/vdpau] Frame shown too early (4 ms) [ 3.194][v][vo/vdpau] Frame shown too early (4 ms) [ 3.235][v][vo/vdpau] Frame shown too early (3 ms) [ 3.277][v][vo/vdpau] Frame shown too early (4 ms) [ 3.319][v][vo/vdpau] Frame shown too early (4 ms) [ 3.360][v][vo/vdpau] Frame shown too early (3 ms) [ 3.402][v][vo/vdpau] Frame shown too early (4 ms) [ 3.444][v][vo/vdpau] Frame shown too early (4 ms) [ 3.486][v][vo/vdpau] Frame shown too early (4 ms) [ 3.527][v][vo/vdpau] Frame shown too early (3 ms) [ 3.569][v][vo/vdpau] Frame shown too early (4 ms) [ 3.613][v][vo/vdpau] Frame shown too early (6 ms) [ 3.654][v][vo/vdpau] Frame shown too early (3 ms) [ 3.695][v][vo/vdpau] Frame shown too early (4 ms) [ 3.781][v][vo/vdpau] Frame shown too early (0 ms) [ 3.822][v][vo/vdpau] Frame shown too early (3 ms) [ 3.866][v][vo/vdpau] Frame shown too early (6 ms) [ 3.908][v][vo/vdpau] Frame shown too early (4 ms) [ 3.949][v][vo/vdpau] Frame shown too early (3 ms) [ 3.991][v][vo/vdpau] Frame shown too early (4 ms) [ 4.033][v][vo/vdpau] Frame shown too early (4 ms) [ 4.074][v][vo/vdpau] Frame shown too early (3 ms) [ 4.118][v][vo/vdpau] Frame shown too early (6 ms) [ 4.160][v][vo/vdpau] Frame shown too early (4 ms) [ 4.202][v][vo/vdpau] Frame shown too early (4 ms) [ 4.243][v][vo/vdpau] Frame shown too early (3 ms) [ 4.285][v][vo/vdpau] Frame shown too early (4 ms) [ 4.327][v][vo/vdpau] Frame shown too early (4 ms) [ 4.368][v][vo/vdpau] Frame shown too early (3 ms) [ 4.410][v][vo/vdpau] Frame shown too early (4 ms) [ 4.452][v][vo/vdpau] Frame shown too early (4 ms) [ 4.464][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 4.465][v][cplayer] Run command: enable-section, flags=0, args=[input, ] [ 4.494][v][vo/vdpau] Frame shown too early (4 ms) [ 4.525][v][osd/libass] fontselect: (mpv-osd-symbols, 400, 0) -> mpv-osd-symbols-Regular, 0, mpv-osd-symbols-Regular [ 4.545][v][vo/vdpau] Allocating a 256x128 surface for OSD bitmaps. [ 4.550][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 4.569][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 4.578][v][vo/vdpau] Frame shown too early (-4 ms) [ 4.619][v][vo/vdpau] Frame shown too early (3 ms) [ 4.660][v][vo/vdpau] Frame shown too early (3 ms) [ 4.702][v][vo/vdpau] Frame shown too early (4 ms) [ 4.744][v][vo/vdpau] Frame shown too early (4 ms) [ 4.786][v][vo/vdpau] Frame shown too early (4 ms) [ 4.827][v][vo/vdpau] Frame shown too early (3 ms) [ 4.869][v][vo/vdpau] Frame shown too early (4 ms) [ 4.911][v][vo/vdpau] Frame shown too early (4 ms) [ 4.952][v][vo/vdpau] Frame shown too early (3 ms) [ 4.994][v][vo/vdpau] Frame shown too early (4 ms) [ 5.036][v][vo/vdpau] Frame shown too early (4 ms) [ 5.077][v][vo/vdpau] Frame shown too early (3 ms) [ 5.119][v][vo/vdpau] Frame shown too early (4 ms) [ 5.161][v][vo/vdpau] Frame shown too early (4 ms) [ 5.203][v][vo/vdpau] Frame shown too early (4 ms) [ 5.244][v][vo/vdpau] Frame shown too early (3 ms) [ 5.286][v][vo/vdpau] Frame shown too early (4 ms) [ 5.328][v][vo/vdpau] Frame shown too early (4 ms) [ 5.343][v][cplayer] Run command: disable-section, flags=0, args=[input] [ 5.369][v][vo/vdpau] Frame shown too early (3 ms) [ 5.379][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.411][v][vo/vdpau] Frame shown too early (3 ms) [ 5.424][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.425][v][cplayer] Run command: enable-section, flags=0, args=[input, ] [ 5.453][v][vo/vdpau] Frame shown too early (-11 ms) [ 5.475][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.496][v][vo/vdpau] Frame shown too early (5 ms) [ 5.505][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.514][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.537][v][vo/vdpau] Frame shown too early (3 ms) [ 5.566][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.579][v][vo/vdpau] Frame shown too early (4 ms) [ 5.588][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.598][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.621][v][vo/vdpau] Frame shown too early (4 ms) [ 5.634][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.663][v][vo/vdpau] Frame shown too early (4 ms) [ 5.685][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.705][v][vo/vdpau] Frame shown too early (4 ms) [ 5.721][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.747][v][vo/vdpau] Frame shown too early (5 ms) [ 5.757][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.757][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.789][v][vo/vdpau] Frame shown too early (4 ms) [ 5.803][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.830][v][vo/vdpau] Frame shown too early (3 ms) [ 5.846][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 5.846][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding2] [ 5.872][v][vo/vdpau] Frame shown too early (4 ms) [ 5.914][v][vo/vdpau] Frame shown too early (4 ms) [ 5.955][v][vo/vdpau] Frame shown too early (3 ms) [ 5.999][v][vo/vdpau] Frame shown too early (6 ms) [ 6.039][v][vo/vdpau] Frame shown too early (2 ms) [ 6.080][v][vo/vdpau] Frame shown too early (3 ms) [ 6.102][v][cplayer] Run command: disable-section, flags=0, args=[input] [ 6.124][v][vo/vdpau] Frame shown too early (6 ms) [ 6.166][v][vo/vdpau] Frame shown too early (4 ms) [ 6.208][v][vo/vdpau] Frame shown too early (4 ms) [ 6.220][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 6.251][v][vo/vdpau] Frame shown too early (5 ms) [ 6.259][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding1] [ 6.260][v][cplayer] Run command: script-binding, flags=9, args=[osc/__keybinding2] [ 6.293][v][vo/vdpau] Frame shown too early (4 ms) [ 6.335][v][vo/vdpau] Frame shown too early (4 ms) [ 6.376][v][vo/vdpau] Frame shown too early (3 ms) [ 6.418][v][vo/vdpau] Frame shown too early (4 ms) [ 6.460][v][vo/vdpau] Frame shown too early (4 ms) [ 6.504][v][vo/vdpau] Frame shown too early (6 ms) [ 6.545][v][vo/vdpau] Frame shown too early (3 ms) [ 6.587][v][vo/vdpau] Frame shown too early (4 ms) [ 6.629][v][vo/vdpau] Frame shown too early (4 ms) [ 6.670][v][vo/vdpau] Frame shown too early (3 ms) [ 6.712][v][vo/vdpau] Frame shown too early (4 ms) [ 6.728][v][cplayer] Run command: quit, flags=9, args=[0] [ 6.728][v][cplayer] EOF code: 6 [ 6.730][v][ad] Uninit audio decoder. [ 6.730][v][af] Removing filter lavrresample [ 6.731][v][vd] Uninit video. [ 6.757][v][cache] Terminating cache... [ 6.757][v][cache] Cache exiting... [ 6.775][v][cplayer] finished playback, success (reason 3) [ 6.775][i][cplayer] [ 6.775][i][cplayer] [ 6.775][i][cplayer] Exiting... (Quit) [ 6.776][v][ytdl_hook] Exiting... [ 6.777][v][osc] Exiting... [ 6.778][v][ao/alsa] draining... [ 6.785][v][vo/vdpau/x11] Enabling screensaver. [ 6.786][v][vo/vdpau/x11] uninit ... Regards, Sp0T Edited June 4, 2016 by zador.blood.stained Added spoiler tags
damien78 Posted June 6, 2016 Posted June 6, 2016 Hello,apparently you are logged in as root. you must create a Standard user.You can try to connect via ssh: ssh root@ip. password: 1234normally it should launch an account creation process. You must replace ip by ip of our machine or by name. On allwinner CPU only vdpau output is able to play video. Your user must be in video group.
Sp0T Posted June 6, 2016 Author Posted June 6, 2016 Hello, I created an orangepi user. I also checked all files which need to play video and i have all in the video group. But i still get black screen only orangepi@orange:~$ id orangepi uid=1000(orangepi) gid=1000(orangepi) groups=1000(orangepi),20(dialout),27(sudo),29(audio),44(video),46(plugdev),108(netdev) orangepi@orange:~$ mpv --vo=vdpau --hwdec=vdpau --hwdec-codecs=all --loop=yes /media/orangepi/Mediadisk/movie/sample/sample.mkv Playing: /media/orangepi/Mediadisk/movie/sample/sample.mkv (+) Video --vid=1 (*) (h264) (+) Audio --aid=1 --alang=hun (*) (ac3) (+) Subs --sid=1 --slang=hun (*) (f) (subrip) Subs --sid=2 --slang=hun (subrip) [VDPAU SUNXI] VE version 0x1623 opened [VDPAU SUNXI] OSD disabled! AO: [alsa] 48000Hz stereo 2ch s32 Using hardware decoding (vdpau). VO: [vdpau] 720x302 vdpau [VDPAU SUNXI] Presentation time not supported AV: 00:01:04 / 00:01:04 (99%) A-V: 0.000 Cache: 0s+0KB Regards, Sp0T
Sp0T Posted June 6, 2016 Author Posted June 6, 2016 No, I'm using it thru HDMI with a 23" LG monitor.
damien78 Posted June 8, 2016 Posted June 8, 2016 Your user must be part of the group video normally is the case but it's worth checking. This command will list the groups to which the user belongs : groups orangepi you can post your kernel command line with: cat /proc/cmdline
Sp0T Posted June 8, 2016 Author Posted June 8, 2016 Hello, orangepi is part of the video groups. The kernel commands is below. orangepi@orange:~$ groups orangepi orangepi : orangepi dialout sudo audio video plugdev netdev orangepi@orange:~$ cat /proc/cmdline console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 Regards, Sp0T
damien78 Posted June 9, 2016 Posted June 9, 2016 Hi, The results seem good. But you can test with 1920x1080p24 because video is rarely in 60 fps and blueray are in 24 or 25 fps. You can test with mplayer which also support vdpau.
Sp0T Posted June 9, 2016 Author Posted June 9, 2016 I found a wierd error after i try to change resulution. Both root and orangepi user give this error. root@orange:/home/orangepi# a10disp changehdmimodeforce 8 sunxi disp kernel module version is 1.0 Cannot change HDMI mode because HDMI is not enabled. Regards, Sp0T
damien78 Posted June 10, 2016 Posted June 10, 2016 Hi, You can change your screen resolution by the kernel command line.but it surprised me that the problem comes from this. have you tested another video player?
Sp0T Posted June 10, 2016 Author Posted June 10, 2016 Hello, I just tested with mplayer2 and i think the problem is the codec, which cannot be loaded. Playing /media/orangepi/Mediadisk/movie/sample/sample.mkv. [mkv] Track ID 1: video (V_MPEG4/ISO/AVC), -vid 0 [mkv] Track ID 2: audio (A_AC3), -aid 0, -alang hun [mkv] Track ID 3: subtitles (S_TEXT/UTF8), -sid 0, -slang hun [mkv] Track ID 4: subtitles (S_TEXT/UTF8), -sid 1, -slang hun [mkv] Will play video track 1. Detected file format: Matroska Load subtitles in /media/orangepi/Mediadisk/movie/sample/ [VDPAU SUNXI] VE version 0x1623 opened [VDPAU SUNXI] OSD disabled! Forced video codec: ffmpeg12vdpau Forced video codec: ffh264vdpau Cannot find codec 'h264_vdpau' in libavcodec... Video decoder init failed for codecs.conf entry "ffh264vdpau". Selected video codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [libavcodec] Selected audio codec: ATSC A/52A (AC-3) [libavcodec] AUDIO: 48000 Hz, 2 ch, floatle, 448.0 kbit/14.58% (ratio: 56000->384000) AO: [pulse] Init failed: Connection refused [AO_ALSA] Format floatle is not supported by hardware, trying default. AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample) [AO_ALSA] Unable to find simple control 'Master',0. Starting playback... VIDEO: 720x302 23.976 fps 0.0 kbps ( 0.0 kB/s) VO: [vdpau] 720x302 => 720x302 Planar YV12 [vdpau] Assuming user-specified display refresh rate of 24.000 Hz. [VDPAU SUNXI] Presentation time not supported A: 10.1 V: 10.1 A-V: 0.000 ct: -0.000 0/ 0 9% 28% 4.4% 13 0 Regards, Sp0T
rellla Posted June 10, 2016 Posted June 10, 2016 Do you have a ffmpeg version with vdpau support compiled in? And stay with mpv, mplayer2 is deprecated iirc. Regards rellla
Sp0T Posted June 10, 2016 Author Posted June 10, 2016 I think yes ffmpeg library versions: libavutil 55.17.103 libavcodec 57.24.102 libavformat 57.25.100 libswscale 4.0.100 libavfilter 6.31.100 libswresample 2.0.101 ffmpeg version: n3.0 Regards, Sp0T
RagnerBG Posted June 10, 2016 Posted June 10, 2016 Hello, I just tested with mplayer2 and i think the problem is the codec, which cannot be loaded. Cannot find codec 'h264_vdpau' in libavcodec... No, this is not the case. mplayer2 always show this h264 error. If you want it to work correctly, build mplayer from source. And i suggest you to to the same with mpv, ffmpeg and maybe libvdpau-sunxi. I can show you how i do it, even if it's a little noob way, but it works for me. But of course @rellla could be of more help here.
Sp0T Posted June 11, 2016 Author Posted June 11, 2016 Hello, @rellla: I installed ffmpeg codecs and the result is the same, @RagnerBG: I think i'll install my whole system from the begining and use the non desktop version, so I'll know what's are installed and what's not. If i stuck somewhere I'll ask help . Regards, Sp0T
rellla Posted June 11, 2016 Posted June 11, 2016 What does ffmpeg -codecs and ffmpeg -decoders say? You have to compile it yourself, because ready built arm ffmpeg packages normally don't have vdpau support because of arm.
Sp0T Posted June 12, 2016 Author Posted June 12, 2016 root@orange:/home/orangepi/ffmpeg# ffmpeg -codecs ffmpeg version N-80270-gd4cd8e7 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: libavutil 55. 24.100 / 55. 24.100 libavcodec 57. 46.100 / 57. 46.100 libavformat 57. 37.101 / 57. 37.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 46.101 / 6. 46.101 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 Codecs: D..... = Decoding supported .E.... = Encoding supported ..V... = Video codec ..A... = Audio codec ..S... = Subtitle codec ...I.. = Intra frame-only codec ....L. = Lossy compression .....S = Lossless compression ------- D.VI.. 012v Uncompressed 4:2:2 10-bit D.V.L. 4xm 4X Movie D.VI.S 8bps QuickTime 8BPS video .EVIL. a64_multi Multicolor charset for Commodore 64 (encoders: a64multi ) .EVIL. a64_multi5 Multicolor charset for Commodore 64, extended with 5th color (colram) (encoders: a64multi5 ) D.V..S aasc Autodesk RLE D.VIL. aic Apple Intermediate Codec DEVI.S alias_pix Alias/Wavefront PIX image DEVIL. amv AMV Video D.V.L. anm Deluxe Paint Animation D.V.L. ansi ASCII/ANSI art DEV..S apng APNG (Animated Portable Network Graphics) image DEVIL. asv1 ASUS V1 DEVIL. asv2 ASUS V2 D.VIL. aura Auravision AURA D.VIL. aura2 Auravision Aura 2 D.V... avrn Avid AVI Codec DEVI.. avrp Avid 1:1 10-bit RGB Packer D.V.L. avs AVS (Audio Video Standard) video DEVI.. avui Avid Meridien Uncompressed DEVI.. ayuv Uncompressed packed MS 4:4:4:4 D.V.L. bethsoftvid Bethesda VID video D.V.L. bfi Brute Force & Ignorance D.V.L. binkvideo Bink video D.VI.. bintext Binary text DEVI.S bmp BMP (Windows and OS/2 bitmap) D.V..S bmv_video Discworld II BMV video D.VI.S brender_pix BRender PIX image D.V.L. c93 Interplay C93 D.V.L. cavs Chinese AVS (Audio Video Standard) (AVS1-P2, JiZhun profile) D.V.L. cdgraphics CD Graphics video D.VIL. cdxl Commodore CDXL video D.V.L. cfhd Cineform HD DEV.L. cinepak Cinepak DEVIL. cljr Cirrus Logic AccuPak D.VI.S cllc Canopus Lossless Codec D.V.L. cmv Electronic Arts CMV video (decoders: eacmv ) D.V... cpia CPiA video format D.V..S cscd CamStudio (decoders: camstudio ) D.VIL. cyuv Creative YUV (CYUV) ..V.LS daala Daala D.VILS dds DirectDraw Surface image decoder D.V.L. dfa Chronomaster DFA DEV.LS dirac Dirac (encoders: vc2 ) DEVIL. dnxhd VC3/DNxHD DEVI.S dpx DPX (Digital Picture Exchange) image D.V.L. dsicinvideo Delphine Software International CIN video DEVIL. dvvideo DV (Digital Video) D.V..S dxa Feeble Files/ScummVM DXA D.VI.S dxtory Dxtory D.VIL. dxv Resolume DXV D.V.L. escape124 Escape 124 D.V.L. escape130 Escape 130 D.VILS exr OpenEXR image DEV..S ffv1 FFmpeg video codec #1 DEVI.S ffvhuff Huffyuv FFmpeg variant D.V.L. fic Mirillis FIC DEV..S flashsv Flash Screen Video v1 DEV.L. flashsv2 Flash Screen Video v2 D.V..S flic Autodesk Animator Flic video DEV.L. flv1 FLV / Sorenson Spark / Sorenson H.263 (Flash Video) (decoders: flv ) (encoders: flv ) D.V..S fraps Fraps D.VI.S frwu Forward Uncompressed D.V.L. g2m Go2Meeting DEV..S gif GIF (Graphics Interchange Format) DEV.L. h261 H.261 DEV.L. h263 H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2 D.V.L. h263i Intel H.263 DEV.L. h263p H.263+ / H.263-1998 / H.263 version 2 D.V.LS h264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_vdpau ) D.VIL. hap Vidvox Hap decoder D.V.L. hevc H.265 / HEVC (High Efficiency Video Coding) D.V.L. hnm4video HNM 4 video D.VIL. hq_hqa Canopus HQ/HQA D.VIL. hqx Canopus HQX DEVI.S huffyuv HuffYUV D.V.L. idcin id Quake II CIN video (decoders: idcinvideo ) D.VI.. idf iCEDraw text D.V.L. iff_ilbm IFF ACBM/ANIM/DEEP/ILBM/PBM/RGB8/RGBN (decoders: iff ) D.V.L. indeo2 Intel Indeo 2 D.V.L. indeo3 Intel Indeo 3 D.V.L. indeo4 Intel Indeo Video Interactive 4 D.V.L. indeo5 Intel Indeo Video Interactive 5 D.V.L. interplayvideo Interplay MVE video DEVILS jpeg2000 JPEG 2000 DEVILS jpegls JPEG-LS D.VIL. jv Bitmap Brothers JV video D.V.L. kgv1 Kega Game Video D.V.L. kmvc Karl Morton's video codec D.VI.S lagarith Lagarith lossless .EVI.S ljpeg Lossless JPEG D.VI.S loco LOCO D.VI.S m101 Matrox Uncompressed SD D.V.L. mad Electronic Arts Madcow Video (decoders: eamad ) D.VI.S magicyuv MagicYUV Lossless Video D.VIL. mdec Sony PlayStation MDEC (Motion DECoder) D.V.L. mimic Mimic DEVIL. mjpeg Motion JPEG D.VIL. mjpegb Apple MJPEG-B D.V.L. mmvideo American Laser Games MM Video D.V.L. motionpixels Motion Pixels video DEV.L. mpeg1video MPEG-1 video (decoders: mpeg1video mpeg1video_vdpau ) DEV.L. mpeg2video MPEG-2 video (decoders: mpeg2video mpegvideo mpegvideo_vdpau ) DEV.L. mpeg4 MPEG-4 part 2 (decoders: mpeg4 mpeg4_vdpau ) D.V.L. mpegvideo_xvmc MPEG-1/2 video XvMC (X-Video Motion Compensation) D.V.L. msa1 MS ATC Screen D.V.L. msmpeg4v1 MPEG-4 part 2 Microsoft variant version 1 DEV.L. msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2 DEV.L. msmpeg4v3 MPEG-4 part 2 Microsoft variant version 3 (decoders: msmpeg4 ) (encoders: msmpeg4 ) D.V..S msrle Microsoft RLE D.V.L. mss1 MS Screen 1 D.VIL. mss2 MS Windows Media Video V9 Screen DEV.L. msvideo1 Microsoft Video 1 D.VI.S mszh LCL (LossLess Codec Library) MSZH D.V.L. mts2 MS Expression Encoder Screen D.VIL. mvc1 Silicon Graphics Motion Video Compressor 1 D.VIL. mvc2 Silicon Graphics Motion Video Compressor 2 D.V.L. mxpeg Mobotix MxPEG video D.V.L. nuv NuppelVideo/RTJPEG D.V.L. paf_video Amazing Studio Packed Animation File Video DEVI.S pam PAM (Portable AnyMap) image DEVI.S pbm PBM (Portable BitMap) image DEVI.S pcx PC Paintbrush PCX image DEVI.S pgm PGM (Portable GrayMap) image DEVI.S pgmyuv PGMYUV (Portable GrayMap YUV) image D.VIL. pictor Pictor/PC Paint DEV..S png PNG (Portable Network Graphics) image DEVI.S ppm PPM (Portable PixelMap) image DEVIL. prores Apple ProRes (iCodec Pro) (decoders: prores prores_lgpl ) (encoders: prores prores_aw prores_ks ) D.VIL. ptx V.Flash PTX image D.VI.S qdraw Apple QuickDraw D.V.L. qpeg Q-team QPEG DEV..S qtrle QuickTime Animation (RLE) video DEVI.S r10k AJA Kona 10-bit RGB Codec DEVI.S r210 Uncompressed RGB 10-bit DEVI.S rawvideo raw video D.VIL. rl2 RL2 video DEV.L. roq id RoQ video (decoders: roqvideo ) (encoders: roqvideo ) D.V.L. rpza QuickTime video (RPZA) D.V..S rscc innoHeim/Rsupport Screen Capture Codec DEV.L. rv10 RealVideo 1.0 DEV.L. rv20 RealVideo 2.0 D.V.L. rv30 RealVideo 3.0 D.V.L. rv40 RealVideo 4.0 D.V.L. sanm LucasArts SANM/SMUSH video D.V..S screenpresso Screenpresso DEVI.S sgi SGI image D.VI.S sgirle SGI RLE 8-bit D.VI.S sheervideo BitJazz SheerVideo D.V.L. smackvideo Smacker video (decoders: smackvid ) D.V.L. smc QuickTime Graphics (SMC) D.V... smvjpeg Sigmatel Motion Video DEV.LS snow Snow D.VIL. sp5x Sunplus JPEG (SP5X) DEVI.S sunrast Sun Rasterfile image DEV.L. svq1 Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1 D.V.L. svq3 Sorenson Vector Quantizer 3 / Sorenson Video 3 / SVQ3 DEVI.S targa Truevision Targa image D.VI.. targa_y216 Pinnacle TARGA CineWave YUV16 D.V.L. tdsc TDSC D.V.L. tgq Electronic Arts TGQ video (decoders: eatgq ) D.V.L. tgv Electronic Arts TGV video (decoders: eatgv ) D.V.L. theora Theora D.VIL. thp Nintendo Gamecube THP video D.V.L. tiertexseqvideo Tiertex Limited SEQ video DEVI.S tiff TIFF image D.VIL. tmv 8088flex TMV D.V.L. tqi Electronic Arts TQI video (decoders: eatqi ) D.V.L. truemotion1 Duck TrueMotion 1.0 D.V.L. truemotion2 Duck TrueMotion 2.0 D.V.L. truemotion2rt Duck TrueMotion 2.0 Real Time D.V..S tscc TechSmith Screen Capture Codec (decoders: camtasia ) D.V.L. tscc2 TechSmith Screen Codec 2 D.VIL. txd Renderware TXD (TeXture Dictionary) image D.V.L. ulti IBM UltiMotion (decoders: ultimotion ) DEVI.S utvideo Ut Video DEVI.S v210 Uncompressed 4:2:2 10-bit D.VI.S v210x Uncompressed 4:2:2 10-bit DEVI.. v308 Uncompressed packed 4:4:4 DEVI.. v408 Uncompressed packed QT 4:4:4:4 DEVI.S v410 Uncompressed 4:4:4 10-bit D.V.L. vb Beam Software VB D.VI.S vble VBLE Lossless Codec D.V.L. vc1 SMPTE VC-1 (decoders: vc1 vc1_vdpau ) D.V.L. vc1image Windows Media Video 9 Image v2 D.VIL. vcr1 ATI VCR1 D.VIL. vixl Miro VideoXL (decoders: xl ) D.V.L. vmdvideo Sierra VMD video D.V..S vmnc VMware Screen Codec / VMware Video D.V.L. vp3 On2 VP3 D.V.L. vp5 On2 VP5 D.V.L. vp6 On2 VP6 D.V.L. vp6a On2 VP6 (Flash version, with alpha channel) D.V.L. vp6f On2 VP6 (Flash version) D.V.L. vp7 On2 VP7 D.V.L. vp8 On2 VP8 D.V.L. vp9 Google VP9 D.VILS webp WebP DEV.L. wmv1 Windows Media Video 7 DEV.L. wmv2 Windows Media Video 8 D.V.L. wmv3 Windows Media Video 9 (decoders: wmv3 wmv3_vdpau ) D.V.L. wmv3image Windows Media Video 9 Image D.VIL. wnv1 Winnov WNV1 .EV..S wrapped_avframe AVFrame to AVPacket passthrough D.V.L. ws_vqa Westwood Studios VQA (Vector Quantized Animation) video (decoders: vqavideo ) D.V.L. xan_wc3 Wing Commander III / Xan D.V.L. xan_wc4 Wing Commander IV / Xxan D.VI.. xbin eXtended BINary text DEVI.S xbm XBM (X BitMap) image DEVIL. xface X-face image DEVI.S xwd XWD (X Window Dump) image DEVI.. y41p Uncompressed YUV 4:1:1 12-bit D.V.L. yop Psygnosis YOP Video DEVI.. yuv4 Uncompressed packed 4:2:0 D.V..S zerocodec ZeroCodec Lossless Video DEVI.S zlib LCL (LossLess Codec Library) ZLIB DEV..S zmbv Zip Motion Blocks Video ..A.L. 4gv 4GV (Fourth Generation Vocoder) D.A.L. 8svx_exp 8SVX exponential D.A.L. 8svx_fib 8SVX fibonacci DEA.L. aac AAC (Advanced Audio Coding) (decoders: aac aac_fixed ) D.A.L. aac_latm AAC LATM (Advanced Audio Coding LATM syntax) DEA.L. ac3 ATSC A/52A (AC-3) (decoders: ac3 ac3_fixed ) (encoders: ac3 ac3_fixed ) D.A.L. adpcm_4xm ADPCM 4X Movie DEA.L. adpcm_adx SEGA CRI ADX ADPCM D.A.L. adpcm_afc ADPCM Nintendo Gamecube AFC D.A.L. adpcm_aica ADPCM Yamaha AICA D.A.L. adpcm_ct ADPCM Creative Technology D.A.L. adpcm_dtk ADPCM Nintendo Gamecube DTK D.A.L. adpcm_ea ADPCM Electronic Arts D.A.L. adpcm_ea_maxis_xa ADPCM Electronic Arts Maxis CDROM XA D.A.L. adpcm_ea_r1 ADPCM Electronic Arts R1 D.A.L. adpcm_ea_r2 ADPCM Electronic Arts R2 D.A.L. adpcm_ea_r3 ADPCM Electronic Arts R3 D.A.L. adpcm_ea_xas ADPCM Electronic Arts XAS DEA.L. adpcm_g722 G.722 ADPCM (decoders: g722 ) (encoders: g722 ) DEA.L. adpcm_g726 G.726 ADPCM (decoders: g726 ) (encoders: g726 ) D.A.L. adpcm_g726le G.726 ADPCM little-endian (decoders: g726le ) D.A.L. adpcm_ima_amv ADPCM IMA AMV D.A.L. adpcm_ima_apc ADPCM IMA CRYO APC D.A.L. adpcm_ima_dat4 ADPCM IMA Eurocom DAT4 D.A.L. adpcm_ima_dk3 ADPCM IMA Duck DK3 D.A.L. adpcm_ima_dk4 ADPCM IMA Duck DK4 D.A.L. adpcm_ima_ea_eacs ADPCM IMA Electronic Arts EACS D.A.L. adpcm_ima_ea_sead ADPCM IMA Electronic Arts SEAD D.A.L. adpcm_ima_iss ADPCM IMA Funcom ISS D.A.L. adpcm_ima_oki ADPCM IMA Dialogic OKI DEA.L. adpcm_ima_qt ADPCM IMA QuickTime D.A.L. adpcm_ima_rad ADPCM IMA Radical D.A.L. adpcm_ima_smjpeg ADPCM IMA Loki SDL MJPEG DEA.L. adpcm_ima_wav ADPCM IMA WAV D.A.L. adpcm_ima_ws ADPCM IMA Westwood DEA.L. adpcm_ms ADPCM Microsoft D.A.L. adpcm_mtaf ADPCM MTAF D.A.L. adpcm_psx ADPCM Playstation D.A.L. adpcm_sbpro_2 ADPCM Sound Blaster Pro 2-bit D.A.L. adpcm_sbpro_3 ADPCM Sound Blaster Pro 2.6-bit D.A.L. adpcm_sbpro_4 ADPCM Sound Blaster Pro 4-bit DEA.L. adpcm_swf ADPCM Shockwave Flash D.A.L. adpcm_thp ADPCM Nintendo THP D.A.L. adpcm_thp_le ADPCM Nintendo THP (Little-Endian) D.A.L. adpcm_vima LucasArts VIMA audio D.A.L. adpcm_xa ADPCM CDROM XA DEA.L. adpcm_yamaha ADPCM Yamaha DEA..S alac ALAC (Apple Lossless Audio Codec) D.A.L. amr_nb AMR-NB (Adaptive Multi-Rate NarrowBand) (decoders: amrnb ) D.A.L. amr_wb AMR-WB (Adaptive Multi-Rate WideBand) (decoders: amrwb ) D.A..S ape Monkey's Audio D.A.L. atrac1 ATRAC1 (Adaptive TRansform Acoustic Coding) D.A.L. atrac3 ATRAC3 (Adaptive TRansform Acoustic Coding 3) D.A.L. atrac3p ATRAC3+ (Adaptive TRansform Acoustic Coding 3+) (decoders: atrac3plus ) D.A.L. avc On2 Audio for Video Codec (decoders: on2avc ) D.A.L. binkaudio_dct Bink Audio (DCT) D.A.L. binkaudio_rdft Bink Audio (RDFT) D.A.L. bmv_audio Discworld II BMV audio ..A.L. celt Constrained Energy Lapped Transform (CELT) DEA.L. comfortnoise RFC 3389 Comfort Noise D.A.L. cook Cook / Cooker / Gecko (RealAudio G2) D.A.L. dsd_lsbf DSD (Direct Stream Digital), least significant bit first D.A.L. dsd_lsbf_planar DSD (Direct Stream Digital), least significant bit first, planar D.A.L. dsd_msbf DSD (Direct Stream Digital), most significant bit first D.A.L. dsd_msbf_planar DSD (Direct Stream Digital), most significant bit first, planar D.A.L. dsicinaudio Delphine Software International CIN audio D.A.L. dss_sp Digital Speech Standard - Standard Play mode (DSS SP) D.A..S dst DST (Direct Stream Transfer) DEA.LS dts DCA (DTS Coherent Acoustics) (decoders: dca ) (encoders: dca ) D.A.L. dvaudio DV audio DEA.L. eac3 ATSC A/52B (AC-3, E-AC-3) D.A.L. evrc EVRC (Enhanced Variable Rate Codec) DEA..S flac FLAC (Free Lossless Audio Codec) DEA.L. g723_1 G.723.1 D.A.L. g729 G.729 D.A.L. gsm GSM D.A.L. gsm_ms GSM Microsoft variant D.A.L. iac IAC (Indeo Audio Coder) ..A.L. ilbc iLBC (Internet Low Bitrate Codec) D.A.L. imc IMC (Intel Music Coder) D.A.L. interplay_dpcm DPCM Interplay D.A.L. interplayacm Interplay ACM D.A.L. mace3 MACE (Macintosh Audio Compression/Expansion) 3:1 D.A.L. mace6 MACE (Macintosh Audio Compression/Expansion) 6:1 D.A.L. metasound Voxware MetaSound D.A..S mlp MLP (Meridian Lossless Packing) D.A.L. mp1 MP1 (MPEG audio layer 1) (decoders: mp1 mp1float ) DEA.L. mp2 MP2 (MPEG audio layer 2) (decoders: mp2 mp2float ) (encoders: mp2 mp2fixed ) D.A.L. mp3 MP3 (MPEG audio layer 3) (decoders: mp3 mp3float ) D.A.L. mp3adu ADU (Application Data Unit) MP3 (MPEG audio layer 3) (decoders: mp3adu mp3adufloat ) D.A.L. mp3on4 MP3onMP4 (decoders: mp3on4 mp3on4float ) D.A..S mp4als MPEG-4 Audio Lossless Coding (ALS) (decoders: als ) D.A.L. musepack7 Musepack SV7 (decoders: mpc7 ) D.A.L. musepack8 Musepack SV8 (decoders: mpc8 ) DEA.L. nellymoser Nellymoser Asao D.A.L. opus Opus (Opus Interactive Audio Codec) D.A.L. paf_audio Amazing Studio Packed Animation File Audio DEA.L. pcm_alaw PCM A-law / G.711 A-law D.A..S pcm_bluray PCM signed 16|20|24-bit big-endian for Blu-ray media D.A..S pcm_dvd PCM signed 20|24-bit big-endian DEA..S pcm_f32be PCM 32-bit floating point big-endian DEA..S pcm_f32le PCM 32-bit floating point little-endian DEA..S pcm_f64be PCM 64-bit floating point big-endian DEA..S pcm_f64le PCM 64-bit floating point little-endian D.A..S pcm_lxf PCM signed 20-bit little-endian planar DEA.L. pcm_mulaw PCM mu-law / G.711 mu-law DEA..S pcm_s16be PCM signed 16-bit big-endian DEA..S pcm_s16be_planar PCM signed 16-bit big-endian planar DEA..S pcm_s16le PCM signed 16-bit little-endian DEA..S pcm_s16le_planar PCM signed 16-bit little-endian planar DEA..S pcm_s24be PCM signed 24-bit big-endian DEA..S pcm_s24daud PCM D-Cinema audio signed 24-bit DEA..S pcm_s24le PCM signed 24-bit little-endian DEA..S pcm_s24le_planar PCM signed 24-bit little-endian planar DEA..S pcm_s32be PCM signed 32-bit big-endian DEA..S pcm_s32le PCM signed 32-bit little-endian DEA..S pcm_s32le_planar PCM signed 32-bit little-endian planar DEA..S pcm_s8 PCM signed 8-bit DEA..S pcm_s8_planar PCM signed 8-bit planar DEA..S pcm_u16be PCM unsigned 16-bit big-endian DEA..S pcm_u16le PCM unsigned 16-bit little-endian DEA..S pcm_u24be PCM unsigned 24-bit big-endian DEA..S pcm_u24le PCM unsigned 24-bit little-endian DEA..S pcm_u32be PCM unsigned 32-bit big-endian DEA..S pcm_u32le PCM unsigned 32-bit little-endian DEA..S pcm_u8 PCM unsigned 8-bit D.A.L. pcm_zork PCM Zork D.A.L. qcelp QCELP / PureVoice D.A.L. qdm2 QDesign Music Codec 2 ..A.L. qdmc QDesign Music DEA.L. ra_144 RealAudio 1.0 (14.4K) (decoders: real_144 ) (encoders: real_144 ) D.A.L. ra_288 RealAudio 2.0 (28.8K) (decoders: real_288 ) D.A..S ralf RealAudio Lossless DEA.L. roq_dpcm DPCM id RoQ DEA..S s302m SMPTE 302M D.A.L. sdx2_dpcm DPCM Squareroot-Delta-Exact D.A..S shorten Shorten D.A.L. sipr RealAudio SIPR / ACELP.NET D.A.L. smackaudio Smacker audio (decoders: smackaud ) ..A.L. smv SMV (Selectable Mode Vocoder) D.A.L. sol_dpcm DPCM Sol DEA... sonic Sonic .EA... sonicls Sonic lossless ..A.L. speex Speex D.A..S tak TAK (Tom's lossless Audio Kompressor) D.A..S truehd TrueHD D.A.L. truespeech DSP Group TrueSpeech DEA..S tta TTA (True Audio) D.A.L. twinvq VQF TwinVQ D.A.L. vmdaudio Sierra VMD audio DEA.L. vorbis Vorbis ..A.L. voxware Voxware RT29 Metasound D.A... wavesynth Wave synthesis pseudo-codec DEA.LS wavpack WavPack D.A.L. westwood_snd1 Westwood Audio (SND1) (decoders: ws_snd1 ) D.A..S wmalossless Windows Media Audio Lossless D.A.L. wmapro Windows Media Audio 9 Professional DEA.L. wmav1 Windows Media Audio 1 DEA.L. wmav2 Windows Media Audio 2 D.A.L. wmavoice Windows Media Audio Voice D.A.L. xan_dpcm DPCM Xan D.A.L. xma1 Xbox Media Audio 1 D.A.L. xma2 Xbox Media Audio 2 ..D... bin_data binary data ..D... dvd_nav_packet DVD Nav packet ..D... klv SMPTE 336M Key-Length-Value (KLV) metadata ..D... otf OpenType font ..D... timed_id3 timed ID3 metadata ..D... ttf TrueType font DES... ass ASS (Advanced SSA) subtitle (decoders: ssa ass ) (encoders: ssa ass ) DES... dvb_subtitle DVB subtitles (decoders: dvbsub ) (encoders: dvbsub ) ..S... dvb_teletext DVB teletext DES... dvd_subtitle DVD subtitles (decoders: dvdsub ) (encoders: dvdsub ) D.S... eia_608 EIA-608 closed captions (decoders: cc_dec ) D.S... hdmv_pgs_subtitle HDMV Presentation Graphic Stream subtitles (decoders: pgssub ) ..S... hdmv_text_subtitle HDMV Text subtitle D.S... jacosub JACOsub subtitle D.S... microdvd MicroDVD subtitle DES... mov_text MOV text D.S... mpl2 MPL2 subtitle D.S... pjs PJS (Phoenix Japanimation Society) subtitle D.S... realtext RealText subtitle D.S... sami SAMI subtitle ..S... srt SubRip subtitle with embedded timing ..S... ssa SSA (SubStation Alpha) subtitle D.S... stl Spruce subtitle format DES... subrip SubRip subtitle (decoders: srt subrip ) (encoders: srt subrip ) D.S... subviewer SubViewer subtitle D.S... subviewer1 SubViewer v1 subtitle DES... text raw UTF-8 text D.S... vplayer VPlayer subtitle DES... webvtt WebVTT subtitle DES... xsub XSUB root@orange:/home/orangepi/ffmpeg# ffmpeg -decoders ffmpeg version N-80270-gd4cd8e7 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: libavutil 55. 24.100 / 55. 24.100 libavcodec 57. 46.100 / 57. 46.100 libavformat 57. 37.101 / 57. 37.101 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 46.101 / 6. 46.101 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 Decoders: V..... = Video A..... = Audio S..... = Subtitle .F.... = Frame-level multithreading ..S... = Slice-level multithreading ...X.. = Codec is experimental ....B. = Supports draw_horiz_band .....D = Supports direct rendering method 1 ------ V....D 012v Uncompressed 4:2:2 10-bit V....D 4xm 4X Movie V....D 8bps QuickTime 8BPS video V....D aasc Autodesk RLE VF...D aic Apple Intermediate Codec V....D alias_pix Alias/Wavefront PIX image V....D amv AMV Video V....D anm Deluxe Paint Animation V....D ansi ASCII/ANSI art VF...D apng APNG (Animated Portable Network Graphics) image V....D asv1 ASUS V1 V....D asv2 ASUS V2 V....D aura Auravision AURA V....D aura2 Auravision Aura 2 V....D avrn Avid AVI Codec V....D avrp Avid 1:1 10-bit RGB Packer V....D avs AVS (Audio Video Standard) video V....D avui Avid Meridien Uncompressed V....D ayuv Uncompressed packed MS 4:4:4:4 V....D bethsoftvid Bethesda VID video V....D bfi Brute Force & Ignorance V....D binkvideo Bink video V....D bintext Binary text V....D bmp BMP (Windows and OS/2 bitmap) V....D bmv_video Discworld II BMV video V....D brender_pix BRender PIX image V....D c93 Interplay C93 V....D cavs Chinese AVS (Audio Video Standard) (AVS1-P2, JiZhun profile) V....D cdgraphics CD Graphics video V....D cdxl Commodore CDXL video VF...D cfhd Cineform HD V....D cinepak Cinepak V....D cljr Cirrus Logic AccuPak V....D cllc Canopus Lossless Codec V....D eacmv Electronic Arts CMV video (codec cmv) V....D cpia CPiA video format V....D camstudio CamStudio (codec cscd) V....D cyuv Creative YUV (CYUV) V.S..D dds DirectDraw Surface image decoder V....D dfa Chronomaster DFA V.S..D dirac BBC Dirac VC-2 VFS..D dnxhd VC3/DNxHD V....D dpx DPX (Digital Picture Exchange) image V....D dsicinvideo Delphine Software International CIN video V.S..D dvvideo DV (Digital Video) V....D dxa Feeble Files/ScummVM DXA V....D dxtory Dxtory VFS..D dxv Resolume DXV V....D escape124 Escape 124 V....D escape130 Escape 130 VFS..D exr OpenEXR image VFS..D ffv1 FFmpeg video codec #1 VF..BD ffvhuff Huffyuv FFmpeg variant V.S..D fic Mirillis FIC V....D flashsv Flash Screen Video v1 V....D flashsv2 Flash Screen Video v2 V....D flic Autodesk Animator Flic video V...BD flv FLV / Sorenson Spark / Sorenson H.263 (Flash Video) (codec flv1) VF...D fraps Fraps V....D frwu Forward Uncompressed V....D g2m Go2Meeting V....D gif GIF (Graphics Interchange Format) V....D h261 H.261 V...BD h263 H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2 V...BD h263i Intel H.263 V...BD h263p H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2 VFS..D h264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 V....D h264_vdpau H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (VDPAU acceleration) (codec h264) VFS..D hap Vidvox Hap decoder VFS..D hevc HEVC (High Efficiency Video Coding) V....D hnm4video HNM 4 video V....D hq_hqa Canopus HQ/HQA V.S..D hqx Canopus HQX VF..BD huffyuv Huffyuv / HuffYUV V....D idcinvideo id Quake II CIN video (codec idcin) V....D idf iCEDraw text V....D iff IFF ACBM/ANIM/DEEP/ILBM/PBM/RGB8/RGBN (codec iff_ilbm) V....D indeo2 Intel Indeo 2 V....D indeo3 Intel Indeo 3 V....D indeo4 Intel Indeo Video Interactive 4 V....D indeo5 Intel Indeo Video Interactive 5 V....D interplayvideo Interplay MVE video VFS..D jpeg2000 JPEG 2000 V....D jpegls JPEG-LS V....D jv Bitmap Brothers JV video V....D kgv1 Kega Game Video V....D kmvc Karl Morton's video codec VF...D lagarith Lagarith lossless V....D loco LOCO V....D m101 Matrox Uncompressed SD V....D eamad Electronic Arts Madcow Video (codec mad) VFS..D magicyuv MagicYUV Lossless Video VF...D mdec Sony PlayStation MDEC (Motion DECoder) VF...D mimic Mimic V....D mjpeg MJPEG (Motion JPEG) V....D mjpegb Apple MJPEG-B V....D mmvideo American Laser Games MM Video V....D motionpixels Motion Pixels video V.S.BD mpeg1video MPEG-1 video V....D mpeg1video_vdpau MPEG-1 video (VDPAU acceleration) (codec mpeg1video) V.S.BD mpeg2video MPEG-2 video V.S.BD mpegvideo MPEG-1 video (codec mpeg2video) V....D mpegvideo_vdpau MPEG-1/2 video (VDPAU acceleration) (codec mpeg2video) VF..BD mpeg4 MPEG-4 part 2 V....D mpeg4_vdpau MPEG-4 part 2 (VDPAU) (codec mpeg4) V...BD mpegvideo_xvmc MPEG-1/2 video XvMC (X-Video Motion Compensation) V....D msa1 MS ATC Screen V...BD msmpeg4v1 MPEG-4 part 2 Microsoft variant version 1 V...BD msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2 V...BD msmpeg4 MPEG-4 part 2 Microsoft variant version 3 (codec msmpeg4v3) V....D msrle Microsoft RLE V....D mss1 MS Screen 1 V....D mss2 MS Windows Media Video V9 Screen V....D msvideo1 Microsoft Video 1 V....D mszh LCL (LossLess Codec Library) MSZH V....D mts2 MS Expression Encoder Screen V....D mvc1 Silicon Graphics Motion Video Compressor 1 V....D mvc2 Silicon Graphics Motion Video Compressor 2 V....D mxpeg Mobotix MxPEG video V....D nuv NuppelVideo/RTJPEG V....D paf_video Amazing Studio Packed Animation File Video V....D pam PAM (Portable AnyMap) image V....D pbm PBM (Portable BitMap) image V....D pcx PC Paintbrush PCX image V....D pgm PGM (Portable GrayMap) image V....D pgmyuv PGMYUV (Portable GrayMap YUV) image V....D pictor Pictor/PC Paint VF...D png PNG (Portable Network Graphics) image V....D ppm PPM (Portable PixelMap) image V.S..D prores ProRes V.S..D prores_lgpl Apple ProRes (iCodec Pro) (codec prores) V....D ptx V.Flash PTX image V....D qdraw Apple QuickDraw V....D qpeg Q-team QPEG V....D qtrle QuickTime Animation (RLE) video V....D r10k AJA Kona 10-bit RGB Codec V....D r210 Uncompressed RGB 10-bit V..... rawvideo raw video V....D rl2 RL2 video V....D roqvideo id RoQ video (codec roq) V....D rpza QuickTime video (RPZA) V....D rscc innoHeim/Rsupport Screen Capture Codec V....D rv10 RealVideo 1.0 V....D rv20 RealVideo 2.0 VF...D rv30 RealVideo 3.0 VF...D rv40 RealVideo 4.0 V....D sanm LucasArts SANM/Smush video V....D screenpresso Screenpresso V....D sgi SGI image V....D sgirle Silicon Graphics RLE 8-bit video VF...D sheervideo BitJazz SheerVideo V....D smackvid Smacker video (codec smackvideo) V....D smc QuickTime Graphics (SMC) V..... smvjpeg SMV JPEG V....D snow Snow V....D sp5x Sunplus JPEG (SP5X) V....D sunrast Sun Rasterfile image V....D svq1 Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1 V...BD svq3 Sorenson Vector Quantizer 3 / Sorenson Video 3 / SVQ3 V....D targa Truevision Targa image V....D targa_y216 Pinnacle TARGA CineWave YUV16 V....D tdsc TDSC V....D eatgq Electronic Arts TGQ video (codec tgq) V....D eatgv Electronic Arts TGV video (codec tgv) VF..BD theora Theora V....D thp Nintendo Gamecube THP video V....D tiertexseqvideo Tiertex Limited SEQ video VF...D tiff TIFF image V....D tmv 8088flex TMV V....D eatqi Electronic Arts TQI Video (codec tqi) V....D truemotion1 Duck TrueMotion 1.0 V....D truemotion2 Duck TrueMotion 2.0 V....D truemotion2rt Duck TrueMotion 2.0 Real Time V....D camtasia TechSmith Screen Capture Codec (codec tscc) V....D tscc2 TechSmith Screen Codec 2 V....D txd Renderware TXD (TeXture Dictionary) image V....D ultimotion IBM UltiMotion (codec ulti) VF...D utvideo Ut Video V....D v210 Uncompressed 4:2:2 10-bit V....D v210x Uncompressed 4:2:2 10-bit V....D v308 Uncompressed packed 4:4:4 V....D v408 Uncompressed packed QT 4:4:4:4 V....D v410 Uncompressed 4:4:4 10-bit V....D vb Beam Software VB VF...D vble VBLE Lossless Codec V....D vc1 SMPTE VC-1 V....D vc1_vdpau SMPTE VC-1 VDPAU (codec vc1) V....D vc1image Windows Media Video 9 Image v2 V....D vcr1 ATI VCR1 V....D xl Miro VideoXL (codec vixl) V....D vmdvideo Sierra VMD video V....D vmnc VMware Screen Codec / VMware Video VF..BD vp3 On2 VP3 V....D vp5 On2 VP5 V....D vp6 On2 VP6 V.S..D vp6a On2 VP6 (Flash version, with alpha channel) V....D vp6f On2 VP6 (Flash version) V....D vp7 On2 VP7 VFS..D vp8 On2 VP8 VF...D vp9 Google VP9 VF...D webp WebP image V...BD wmv1 Windows Media Video 7 V...BD wmv2 Windows Media Video 8 V....D wmv3 Windows Media Video 9 V....D wmv3_vdpau Windows Media Video 9 VDPAU (codec wmv3) V....D wmv3image Windows Media Video 9 Image V....D wnv1 Winnov WNV1 V....D vqavideo Westwood Studios VQA (Vector Quantized Animation) video (codec ws_vqa) V....D xan_wc3 Wing Commander III / Xan V....D xan_wc4 Wing Commander IV / Xxan V....D xbin eXtended BINary text V....D xbm XBM (X BitMap) image V..... xface X-face image V....D xwd XWD (X Window Dump) image V....D y41p Uncompressed YUV 4:1:1 12-bit V..... yop Psygnosis YOP Video V....D yuv4 Uncompressed packed 4:2:0 V....D zerocodec ZeroCodec Lossless Video V....D zlib LCL (LossLess Codec Library) ZLIB V....D zmbv Zip Motion Blocks Video A....D 8svx_exp 8SVX exponential A....D 8svx_fib 8SVX fibonacci A....D aac AAC (Advanced Audio Coding) A....D aac_fixed AAC (Advanced Audio Coding) (codec aac) A....D aac_latm AAC LATM (Advanced Audio Coding LATM syntax) A....D ac3 ATSC A/52A (AC-3) A....D ac3_fixed ATSC A/52A (AC-3) (codec ac3) A....D adpcm_4xm ADPCM 4X Movie A....D adpcm_adx SEGA CRI ADX ADPCM A....D adpcm_afc ADPCM Nintendo Gamecube AFC A....D adpcm_aica ADPCM Yamaha AICA A....D adpcm_ct ADPCM Creative Technology A....D adpcm_dtk ADPCM Nintendo Gamecube DTK A....D adpcm_ea ADPCM Electronic Arts A....D adpcm_ea_maxis_xa ADPCM Electronic Arts Maxis CDROM XA A....D adpcm_ea_r1 ADPCM Electronic Arts R1 A....D adpcm_ea_r2 ADPCM Electronic Arts R2 A....D adpcm_ea_r3 ADPCM Electronic Arts R3 A....D adpcm_ea_xas ADPCM Electronic Arts XAS A....D g722 G.722 ADPCM (codec adpcm_g722) A....D g726 G.726 ADPCM (codec adpcm_g726) A....D g726le G.726 ADPCM little-endian (codec adpcm_g726le) A....D adpcm_ima_amv ADPCM IMA AMV A....D adpcm_ima_apc ADPCM IMA CRYO APC A....D adpcm_ima_dat4 ADPCM IMA Eurocom DAT4 A....D adpcm_ima_dk3 ADPCM IMA Duck DK3 A....D adpcm_ima_dk4 ADPCM IMA Duck DK4 A....D adpcm_ima_ea_eacs ADPCM IMA Electronic Arts EACS A....D adpcm_ima_ea_sead ADPCM IMA Electronic Arts SEAD A....D adpcm_ima_iss ADPCM IMA Funcom ISS A....D adpcm_ima_oki ADPCM IMA Dialogic OKI A....D adpcm_ima_qt ADPCM IMA QuickTime A....D adpcm_ima_rad ADPCM IMA Radical A....D adpcm_ima_smjpeg ADPCM IMA Loki SDL MJPEG A....D adpcm_ima_wav ADPCM IMA WAV A....D adpcm_ima_ws ADPCM IMA Westwood A....D adpcm_ms ADPCM Microsoft A....D adpcm_mtaf ADPCM MTAF A....D adpcm_psx ADPCM Playstation A....D adpcm_sbpro_2 ADPCM Sound Blaster Pro 2-bit A....D adpcm_sbpro_3 ADPCM Sound Blaster Pro 2.6-bit A....D adpcm_sbpro_4 ADPCM Sound Blaster Pro 4-bit A....D adpcm_swf ADPCM Shockwave Flash A....D adpcm_thp ADPCM Nintendo THP A....D adpcm_thp_le ADPCM Nintendo THP (little-endian) A....D adpcm_vima LucasArts VIMA audio A....D adpcm_xa ADPCM CDROM XA A....D adpcm_yamaha ADPCM Yamaha AF...D alac ALAC (Apple Lossless Audio Codec) A....D amrnb AMR-NB (Adaptive Multi-Rate NarrowBand) (codec amr_nb) A....D amrwb AMR-WB (Adaptive Multi-Rate WideBand) (codec amr_wb) A....D ape Monkey's Audio A....D atrac1 ATRAC1 (Adaptive TRansform Acoustic Coding) A....D atrac3 ATRAC3 (Adaptive TRansform Acoustic Coding 3) A....D atrac3plus ATRAC3+ (Adaptive TRansform Acoustic Coding 3+) (codec atrac3p) A....D on2avc On2 Audio for Video Codec (codec avc) A....D binkaudio_dct Bink Audio (DCT) A....D binkaudio_rdft Bink Audio (RDFT) A....D bmv_audio Discworld II BMV audio A....D comfortnoise RFC 3389 comfort noise generator A....D cook Cook / Cooker / Gecko (RealAudio G2) A..... dsd_lsbf DSD (Direct Stream Digital), least significant bit first A..... dsd_lsbf_planar DSD (Direct Stream Digital), least significant bit first, planar A..... dsd_msbf DSD (Direct Stream Digital), most significant bit first A..... dsd_msbf_planar DSD (Direct Stream Digital), most significant bit first, planar A....D dsicinaudio Delphine Software International CIN audio A....D dss_sp Digital Speech Standard - Standard Play mode (DSS SP) A....D dst DST (Digital Stream Transfer) A....D dca DCA (DTS Coherent Acoustics) (codec dts) A....D dvaudio Ulead DV Audio A....D eac3 ATSC A/52B (AC-3, E-AC-3) A....D evrc EVRC (Enhanced Variable Rate Codec) AF...D flac FLAC (Free Lossless Audio Codec) A....D g723_1 G.723.1 A....D g729 G.729 A....D gsm GSM A....D gsm_ms GSM Microsoft variant A....D iac IAC (Indeo Audio Coder) A....D imc IMC (Intel Music Coder) A....D interplay_dpcm DPCM Interplay A....D interplayacm Interplay ACM A....D mace3 MACE (Macintosh Audio Compression/Expansion) 3:1 A....D mace6 MACE (Macintosh Audio Compression/Expansion) 6:1 A....D metasound Voxware MetaSound A....D mlp MLP (Meridian Lossless Packing) A....D mp1 MP1 (MPEG audio layer 1) A....D mp1float MP1 (MPEG audio layer 1) (codec mp1) A....D mp2 MP2 (MPEG audio layer 2) A....D mp2float MP2 (MPEG audio layer 2) (codec mp2) A....D mp3 MP3 (MPEG audio layer 3) A....D mp3float MP3 (MPEG audio layer 3) (codec mp3) A....D mp3adu ADU (Application Data Unit) MP3 (MPEG audio layer 3) A....D mp3adufloat ADU (Application Data Unit) MP3 (MPEG audio layer 3) (codec mp3adu) A....D mp3on4 MP3onMP4 A....D mp3on4float MP3onMP4 (codec mp3on4) A....D als MPEG-4 Audio Lossless Coding (ALS) (codec mp4als) A....D mpc7 Musepack SV7 (codec musepack7) A....D mpc8 Musepack SV8 (codec musepack8) A....D nellymoser Nellymoser Asao A....D opus Opus A....D paf_audio Amazing Studio Packed Animation File Audio A....D pcm_alaw PCM A-law / G.711 A-law A....D pcm_bluray PCM signed 16|20|24-bit big-endian for Blu-ray media A....D pcm_dvd PCM signed 16|20|24-bit big-endian for DVD media A....D pcm_f32be PCM 32-bit floating point big-endian A....D pcm_f32le PCM 32-bit floating point little-endian A....D pcm_f64be PCM 64-bit floating point big-endian A....D pcm_f64le PCM 64-bit floating point little-endian A....D pcm_lxf PCM signed 20-bit little-endian planar A....D pcm_mulaw PCM mu-law / G.711 mu-law A....D pcm_s16be PCM signed 16-bit big-endian A....D pcm_s16be_planar PCM signed 16-bit big-endian planar A....D pcm_s16le PCM signed 16-bit little-endian A....D pcm_s16le_planar PCM signed 16-bit little-endian planar A....D pcm_s24be PCM signed 24-bit big-endian A....D pcm_s24daud PCM D-Cinema audio signed 24-bit A....D pcm_s24le PCM signed 24-bit little-endian A....D pcm_s24le_planar PCM signed 24-bit little-endian planar A....D pcm_s32be PCM signed 32-bit big-endian A....D pcm_s32le PCM signed 32-bit little-endian A....D pcm_s32le_planar PCM signed 32-bit little-endian planar A....D pcm_s8 PCM signed 8-bit A....D pcm_s8_planar PCM signed 8-bit planar A....D pcm_u16be PCM unsigned 16-bit big-endian A....D pcm_u16le PCM unsigned 16-bit little-endian A....D pcm_u24be PCM unsigned 24-bit big-endian A....D pcm_u24le PCM unsigned 24-bit little-endian A....D pcm_u32be PCM unsigned 32-bit big-endian A....D pcm_u32le PCM unsigned 32-bit little-endian A....D pcm_u8 PCM unsigned 8-bit A....D pcm_zork PCM Zork A....D qcelp QCELP / PureVoice A....D qdm2 QDesign Music Codec 2 A....D real_144 RealAudio 1.0 (14.4K) (codec ra_144) A....D real_288 RealAudio 2.0 (28.8K) (codec ra_288) A....D ralf RealAudio Lossless A....D roq_dpcm DPCM id RoQ A....D s302m SMPTE 302M A....D sdx2_dpcm DPCM Squareroot-Delta-Exact A....D shorten Shorten A....D sipr RealAudio SIPR / ACELP.NET A....D smackaud Smacker audio (codec smackaudio) A....D sol_dpcm DPCM Sol A..X.D sonic Sonic AF...D tak TAK (Tom's lossless Audio Kompressor) A....D truehd TrueHD A....D truespeech DSP Group TrueSpeech AF...D tta TTA (True Audio) A....D twinvq VQF TwinVQ A....D vmdaudio Sierra VMD audio A....D vorbis Vorbis A....D wavesynth Wave synthesis pseudo-codec AF...D wavpack WavPack A....D ws_snd1 Westwood Audio (SND1) (codec westwood_snd1) A....D wmalossless Windows Media Audio Lossless A....D wmapro Windows Media Audio 9 Professional A....D wmav1 Windows Media Audio 1 A....D wmav2 Windows Media Audio 2 A....D wmavoice Windows Media Audio Voice A....D xan_dpcm DPCM Xan A....D xma1 Xbox Media Audio 1 A....D xma2 Xbox Media Audio 2 S..... ssa ASS (Advanced SubStation Alpha) subtitle (codec ass) S..... ass ASS (Advanced SubStation Alpha) subtitle S..... dvbsub DVB subtitles (codec dvb_subtitle) S..... dvdsub DVD subtitles (codec dvd_subtitle) S..... cc_dec Closed Caption (EIA-608 / CEA-708) Decoder (codec eia_608) S..... pgssub HDMV Presentation Graphic Stream subtitles (codec hdmv_pgs_subtitle) S..... jacosub JACOsub subtitle S..... microdvd MicroDVD subtitle S..... mov_text 3GPP Timed Text subtitle S..... mpl2 MPL2 subtitle S..... pjs PJS subtitle S..... realtext RealText subtitle S..... sami SAMI subtitle S..... stl Spruce subtitle format S..... srt SubRip subtitle (codec subrip) S..... subrip SubRip subtitle S..... subviewer SubViewer subtitle S..... subviewer1 SubViewer1 subtitle S..... text Raw text subtitle S..... vplayer VPlayer subtitle S..... webvtt WebVTT subtitle S..... xsub XSUB
Sp0T Posted June 21, 2016 Author Posted June 21, 2016 Hello, I have some time so i installed a clean image with MATE desktop. What is the correct order for HW acc. video? 1, libvpau --> ffmpeg --> mpv 2, libvpau --> mpv --> ffmpeg 3, other Thanks, Sp0T
RagnerBG Posted June 21, 2016 Posted June 21, 2016 1, libvpau --> ffmpeg --> mpv I am using this order, actually - libvpau --> some codecs --> ffmpeg --> mpv. But bear in mind that mpv have it's own build in ffmpeg, if you build it from source and i am not sure it using external ffmpeg at all. You can pass build options for it in ffmpeg_options file, in mpv-build directory. For example: echo --enable-vdpau >> ffmpeg_options
Sp0T Posted June 21, 2016 Author Posted June 21, 2016 Could you give me a correct way or link how to install libvpau propelry? Thanks, Sp0T
rellla Posted June 22, 2016 Posted June 22, 2016 Hi Sp0T, check this out: http://linux-sunxi.org/User:Rellla/Armbian It's necessary, that you don't install ffmpeg, libvdpau or mpv from the repositories (even not deb-multimedia.org) because the arm packages do not have vdpau support compiled in. You have to build them yourself. All packages should find the available dependencies themselves. But you can check config.log after you did ./configure what flags (espec. vdpau) are enabled. Regards rellla
Sp0T Posted June 22, 2016 Author Posted June 22, 2016 Thanks rellla. Just one more question. At this part: "configure kernel with CMA enabled and sized to 192" Do you must have to hardcode CMA into kernel or does "sunxi_ve_mem_reserve=192" is enough in the boot.src Thanks, Sp0T
rellla Posted June 22, 2016 Posted June 22, 2016 If CONFIG_CMA is not set, you have to set sunxi_ve_mem_reserve. 150+ would be a good value. In Armbian default it is not set. If CONFIG_CMA is set, sunxi_ve_mem_reserve= is ignored. By default, the CMA memory is hardcoded to 80MB. So, if no patch activates CMA, you don't have to care about that, but just set sunxi_ve_mem_reserve. In this case, you also don't need libump and must not compile libcedrus with USE_UMP=1. To let Mali and the VE use the same memory area for zerocopy features in the future (for the upcoming vdpau_gles_interop feature e.g.) you need to use UMP with CMA memory as backend. And then you have to increase the hardcoded 80MB depending on how much surfaces etc. your app uses. I hope, this was kind of understandable Regards rellla 2
Sp0T Posted June 22, 2016 Author Posted June 22, 2016 I tried to get "https://github.com/rellla/lib/tree/ump " which not exist so i git cloned the "for_upstream brach from your github. Than i try to build a kernel for my Orange PI Mini A20 and the following error popped up: [error] ERROR in function source [main.sh:113] [error] Board configuration does not define valid kernel config With orange pi A20 it's working.
Sp0T Posted June 22, 2016 Author Posted June 22, 2016 okay. than just simply config the kernel and set CMA = Y?
