mario76 Posted September 25, 2019 Posted September 25, 2019 Here is uploaded image showing problem with text overlapping. I googled without success, so if anyone could suggest how to try fixing it. Chromium version is 76.0.3809.100 (Official Build) Built on Ubuntu, running on Ubuntu 16.04 (32-bit) on Orange Pi Lite. It is not big deal, but if there is easy fix why not to try.
Igor Posted September 27, 2019 Posted September 27, 2019 On 9/25/2019 at 9:41 PM, mario76 said: but if there is easy fix why not to try. You are welcome to try while we never tried and will not even try to fix Chromium bugs. We only added few optimisations/caching, which I doubt, have anything to do with this problem. Chromium is a fairly complex project, developed and supported by much larger group of people, than around Armbian. Check and file report here: https://bugs.chromium.org/p/chromium/issues/list or dive into the code ... Edit: or here https://launchpad.net/~chromium-team/+archive/ubuntu/stable if it comes from Ubuntu. My 77.0.3865.90 on x64 workstation doesn't show this error, but IIRC I saw this problems somewhere.
mario76 Posted September 27, 2019 Author Posted September 27, 2019 I hoped maybe this problem is fixable through settings editing or something similar. Also I have no programming skills, so much about diving into the code, but I will look about it around. Inače, prije dan dva sam shvatio da je armbian susjedski, slovenski projekt iako ga koristim na Orange Pi pločama već duže vrijeme. Hvala Vama i cijeloj ekipi. Pozdrav iz Hrvatske. 1
