BertHav Posted September 28, 2019 Posted September 28, 2019 Hereby a tutorial to connect an MCP2515 based CAN bus interface to an OrangePi 3 running successfull with Buster minimal nightly with 5.3 kernel. It uses the attached user overlay only and doesn’t need any other overlay. Connections CAN module OPi3 26 pin header Raspberry CAN interface 40 pin header Vcc 3.3 CON12-P01 1 Gnd CON12-P06 6 MOSI CON12-P19 19 MISO CON12-P21 21 CLK CON12-P23 23 CS CON12-P24 24 INT CON12-P26 22 Optional 5V for Transceiver on cheap Chinese modules CON12-P02 Not used when equiped with a 3.3V transceiver Add the attached overlay with the command: sudo armbian-add-overlay spi-h6-mcp2515.dts The file /boot/armbianEnv.txt now contains a line: user_overlays=spi-h6-mcp2515 Reboot the OrangePi 3 Check if the MCP2515 is recognized: pi@orangepi3:~$ dmesg | grep mcp If properly connected it should return a line containing: mcp251x spi1.0 can0: MCP2515 successfully initialized. As stated a can0 interface should be generated check it with: pi@orangepi3:~$ sudo ifconfig -a Bring up the network: sudo ip link set can0 up type can bitrate 250000 Check if the interrupt is hooked: cat /proc/interrupts should return a line like this 46: 1 0 0 0 sunxi_pio_edge 8 Edge mcp251x Check for traffic on the CAN bus with candump from can-utils (sudo apt-get install can-utils) candump can0 spi-h6-mcp2515.dts 0 Quote
DmitryZ Posted December 9, 2019 Posted December 9, 2019 sudo armbian-add-overlay spi-h6-mcp2515.dts Overlays are supported only on mainline kernel based images Problem on: Orange Pi 3, 5.3.9-sunxi64, Buster 0 Quote
BertHav Posted December 9, 2019 Author Posted December 9, 2019 Searching the forum will give an explanation, sometimes Google is your best friend..... For short, replace "sudo armbian-add-overlay spi-h6-mcp2515.dts" with the following commands: dtc -@ -q -I dts -O dtb -o spi-h6-mcp2515.dtbo spi-h6-mcp2515.dts sudo nano /boot/armbianEnv.txt insert the line: user_overlays=spi-h6-mcp2515 write and exit nano sudo mkdir -p /boot/overlay-user sudo cp spi-h6-mcp2515.dtbo /boot/overlay-user/spi-h6-mcp2515.dtbo Reboot the OrangePi 3 and continue with check if the MCP2515 is recognized 1 Quote
Zaltora Posted April 19, 2021 Posted April 19, 2021 Hello, i work on Lime-a64 board (olimex). Based on this topic and some other around, i wrote the overlay attached. The module i used is use on this topic for the raspberry : tutorial raspberryi. The pinout: | Lime-A64 | UEXT Nb | Function | Output | Module | | --------- | ------- | ------------ | ------ | ------- | | +3.3 | 1 | | VCC | 7 | | GND | 2 | | GND | 6 | | PH4 | 3 | UART3TX | | | | PH5 | 4 | UART3RX | | | | PH2 | 5 | TWI1-SCK | INT | 1 | | PH3 | 6 | TWI1-SDA | | | | PC1 | 7 | SPI_MISO | SO | 4 | | PC0 | 8 | SPI_MOSI | SI | 3 | | PC2 | 9 | SPI_CLK | SCK | 2 | | PC3 | 10 | SPI_CS | CS | 5 | The mcp seem will initialized and i can up the interfaces. however, i am not sure interrupts works. This line seem wrong : interrupts = <0 194 2>; /* PH2 IRQ_TYPE_EDGE_FALLING */ Someone know how to correctly set the line with the Allwinner A64, PH2 pin ? spi-a64-mcp2515.dts 0 Quote
Zaltora Posted April 28, 2021 Posted April 28, 2021 I found correct settings to make my overlay work on the board (Armbian : kernel 5.10) I use PB0 as interrupt pin (change if needed, see comment for interrupt pin) A64-mcp2515.dts 1 Quote
Robbudge Posted November 9, 2023 Posted November 9, 2023 I get a complete system hang on 'sudo ip link set can0 up type can bitrate 250000' ifconfig -a shows Can0 and no errors that i can see in dmesg I am using the Waveshare CanHat https://www.waveshare.com/rs485-can-hat.htm dtparam=spi=on dtoverlay=mcp2515-can0,oscillator=12000000,interrupt=25,spimaxfrequency=2000000 so i changed the following lines in the dts file. clock-frequency = <12000000>; spi-max-frequency = <20000000>; nothing else, I am Wired as per directions Orange Pi 3.0.6 Bullseye with Linux 5.16.17-sun50iw6 Anybody got any idea's ?? I know im close, but with a complete hang, its hard to see the error. 0 Quote
Werner Posted November 10, 2023 Posted November 10, 2023 12 hours ago, Robbudge said: Orange Pi 3.0.6 Bullseye with Linux 5.16.17-sun50iw6 You are not using Armbian. Therefore this is the wrong place to ask. Try where you go your OS from. We cannot support 3rd party systems. 0 Quote
