ph1l1p139 Posted October 2, 2019 Posted October 2, 2019 Hi, I'm running Armbian Bionic 4.4 (Linux nanopim4 4.4.190-rk3399 #5 SMP Sun Sep 1 23:12:43 CEST 2019 aarch64 aarch64 aarch64 GNU/Linux) on a NanoPI M4 and I'm trying to enable HDCP on the HDMI output. I can't figure out how to do this (or if it is even possible). dmesg shows that the driver/hardware knows about HDCP to some extent pi@nanopim4:~$ dmesg | grep -i hdcp [ 3.307777] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) xrandr lists no content_protection property pi@nanopim4:~$ xrandr --prop Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192 HDMI-1 connected primary 1920x1080+0+0 1152mm x 648mm EDID: 00ffffffffffff0010e3140211000082 ff1c010380331d7806e295a2554f9f26 115054ffff80d1c0b300950f950081c0 81408180714f4dd000a0f0703e803020 350080884200001e000000fd0a01ff01 ff3c0000000000000000000000fc0044 47433231340a20202020202000000010 000000000000000000000000000001c1 02033571230f1707836900004561605f 5e5dee0f0000000000000000000000f0 0168030c00ffff1078016ad85dc40178 80010000004dd000a0f0703e80302035 0080884200001eb46600a0f0701f8030 20350080884200001e293680a070381f 403020350040442100001eb71a80a070 1c10203020350040442100009e0000ff hue: 50 range: (0, 100) saturation: 50 range: (0, 100) contrast: 50 range: (0, 100) brightness: 50 range: (0, 100) hdmi_quant_range: default supported: default, limit, full hdmi_output_mode_capacity: 7 range: (0, 15) hdmi_color_depth_capacity: 19 range: (0, 255) hdmi_output_colorimetry: None supported: None, ITU_2020 hdmi_output_format: output_rgb supported: output_rgb, output_ycbcr444, output_ycbcr422, output_ycbcr420, output_ycbcr_high_subsampling, output_ycbcr_low_subsampling, invalid_output hdmi_output_depth: 24bit supported: Automatic, 24bit, 30bit There is a sysfs node for content_protection created, but it doesn't return any values pi@nanopim4:~$ cd /sys/class/drm/card0-HDMI-A-1/ pi@nanopim4:/sys/class/drm/card0-HDMI-A-1$ ls -lh total 0 -r--r--r-- 1 root root 4.0K Oct 2 12:35 audioformat -rw-r--r-- 1 root root 4.0K Oct 2 13:05 content_protection lrwxrwxrwx 1 root root 0 Oct 2 12:35 device -> ../../card0 -r--r--r-- 1 root root 4.0K Oct 2 12:35 dpms -r--r--r-- 1 root root 0 Oct 2 12:35 edid -r--r--r-- 1 root root 4.0K Oct 2 12:35 enabled -r--r--r-- 1 root root 4.0K Oct 2 12:35 mode -r--r--r-- 1 root root 4.0K Oct 2 12:35 modes drwxr-xr-x 2 root root 0 Oct 2 12:35 power -rw-r--r-- 1 root root 4.0K Oct 2 12:35 status lrwxrwxrwx 1 root root 0 Oct 2 12:35 subsystem -> ../../../../../../class/drm -rw-r--r-- 1 root root 4.0K Oct 2 12:35 uevent pi@nanopim4:/sys/class/drm/card0-HDMI-A-1$ cat content_protection pi@nanopim4:/sys/class/drm/card0-HDMI-A-1$ Writing to it with the values that look like they should work (by inspecting drivers/gpu/drm/drm_crtc.c and drivers/gpu/drm/drm_sysfs.c) just returns Invalid Value: pi@nanopim4:/sys/class/drm/card0-HDMI-A-1$ su Password: root@nanopim4:/sys/class/drm/card0-HDMI-A-1# echo "Desired" > content_protection bash: echo: write error: Invalid argument (I've also tried echo -n, and various capitalisations of: Undesired, Desired, Enabled. All of which have the same result). Am I missing something here? Is it possible to enable HDCP on the HDMI output? Thanks, Phil
