frauseo Posted November 17, 2023 Share Posted November 17, 2023 (edited) Hi folks, I had an old install of armbian which worked. I wanted a new install to start fresh all over. My problem is that i don't het any HDMI signal form the board. What i've done so far: - Downloaded ISO from armbian (nanopim4 with DE) - flashed iso to sd 8GB SD card - ssh to the board and did the first install - with `armbian-install` installed to 32GB emmc - enabled RDP for remote access but i was not able to get this to work either -.-' System: _ _ ____ _ __ __ _ _ | \ | | _ \(_) | \/ | || | | \| | |_) | | | |\/| | || |_ | |\ | __/| | | | | |__ _| |_| \_|_| |_| |_| |_| |_| Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64 No end-user support: community creations System load: 2% Up time: 4 min Memory usage: 6% of 3.77G IP: 192.168.0.102 CPU temp: 33°C Usage of /: 28% of 29G RX today: 4.3 GiB Board starts with no issue, ssh works perfectly but i dont have any HDMI output. this is the `armbianmonitor - u` output: https://paste.armbian.com/akovewakud If you need log from the old installation i can provide the logs also. Thanks for your help! Edited November 17, 2023 by frauseo 0 Quote Link to comment Share on other sites More sharing options...
Solution frauseo Posted November 21, 2023 Author Solution Share Posted November 21, 2023 I have found a viable workaround. After trying the latest version of Bookworm and Jammy without success, I downloaded the latest version of Focal from the archive and then updated to Jammy from there. Now I have an up to date system. I hope this helps others who stumble upon the same problem. Cheers 0 Quote Link to comment Share on other sites More sharing options...
