cybero Posted October 15, 2019 Posted October 15, 2019 Is there any working image for Nano Pi Air that supports in same time: - Record in the format of the mpeg4 pipeline, the video codec used is h264. Resolution 1024x768 - Ability to transmit video over WiFi (WiFi AP mode), RTSP protocol. - Ability to connect via USB to transfer recorded files to a PC (USB device mode) - Update firmware via USB (FEL mode for Allwinner SOC)
Igor Posted October 16, 2019 Posted October 16, 2019 9 hours ago, cybero said: Is there any working image for Nano Pi Air that supports in same time: No that I am aware of. Armbian is a basic system. If you need such customisation, you will need to make them. 9 hours ago, cybero said: Record in the format of the mpeg4 pipeline Camera support in mainline is unknown to me, firmware update:
cybero Posted October 23, 2019 Author Posted October 23, 2019 Hi Igor, Thank you for reply. May be you can recomend some developers for that? Thanks
