How to modify kernel command line (cmdline) in nanoPC-T4 Lubuntu image ?
I am using "rk3399-sd-lubuntu-desktop-xenial-4.4-armhf-20190926" image.
I couldn't find u-boot config under /boot/ ! Can someone please suggest how to change the kernel command line without rebuilding the full image ?
This is Armbian https://www.armbian.com/nanopc-t4 support forum.
I don't know how things are made there but after you switch to Armbian you can add parameters to /boot/armbianEnv.txt this way:
extraargs=key=value
