Hello all,
I downloaded the Armbian Buster OS desktop version.
I need to run it with a vertical display - portrait mode.
The OS starts correctly and I see the desktop in landscape mode but when I try to rotate left the display, it does not rotate and return to landscape mode.
The display is a large NBT monitor 1920x1080 that I need to rotate to 1080x1920.
Any idea?
Regards
You forget to mention the most important detail. Which kernel version? We provide 4.4, 4.19 and 5.3.
I opened the Xorg log and I noted that on the first list of available resolution is present the frequency values:
[   158.884] (--) modeset(0): HDMI max TMDS frequency 600000KHz
[   158.884] (II) modeset(0): Printing probed modes for output HDMI-1
[   158.884] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[   158.884] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   158.884] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   158.884] (II) modeset(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   158.884] (II) modeset(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e
whilst in the next lists the frequencies are zero-ed:
[   160.568] (II) modeset(0): EDID vendor "NBT", prod id 0
[   160.568] (II) modeset(0): Using EDID range info for horizontal sync
[   160.568] (II) modeset(0): Using EDID range info for vertical refresh
[   160.568] (II) modeset(0): Printing DDC gathered Modelines:
[   160.568] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[   160.568] (II) modeset(0): Modeline "1366x768"x0.0   85.50  1366 1436 1579 1792  768 771 774 798 +hsync +vsync (47.7 kHz e)
[   160.568] (II) modeset(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[   160.568] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
Is it meaningful?
Not sure about this kernel, but it works on development version with 5.3.y / Ubuntu 19.10 ... http://ix.io/20lc
You can try to upgrade your 4.19.y to 5.3.y kernel with armbian-config -> system -> alternative kernels ... or build your own image https://github.com/armbian/build (branch = arm64). It's development version - no free end user support.
Updated to 5.3.7  5.98.191029.
Rotating the display for a while I see the desktop in portrait mode but then it returns to landscape mode :wacko:
And no other resolution is settable !! :blink:
This is normal. It only probes, then you have to confirm this change. Keep in mind that I used Ubuntu 19.10 user space for doing those tests ... it could be related.
Just now, SteMMo said:
How can i confirm the change, please?
I used utility from XFCE desktop settings, not via CLI. I suspect that it throws you back if you use xrand ... just speculating. Rotation works for me on both monitors so I can't really debug.
I have no way to confirm the change: when I see the portrait mode it is for half a second, then it switches to landscape.
I wrote your image.
Nothing to do .. same behavior, no rotations :(
Is it possible that the display information are incompatible ?
Is there anything in the Xorg log? I don't see anything interesting ..
I'm comparing two xorg log:
Display NTB 75":
[   491.878] (II) modeset(0): Allocate new frame buffer 1080x1920 stride
[   492.474] (II) modeset(0): Allocate new frame buffer 320x200 stride
[   492.542] (II) modeset(0): EDID vendor "NBT", prod id 0
[   492.542] (II) modeset(0): Using hsync ranges from config file
[   492.542] (II) modeset(0): Using vrefresh ranges from config file
[   492.542] (II) modeset(0): Printing DDC gathered Modelines:
[   492.542] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[   492.542] (II) modeset(0): Modeline "1366x768"x0.0   85.50  1366 1436 1579 1792  768 771 774 798 +hsync +vsync (47.7 kHz e)
No rotation,  '320x200' ?? Which config file ?
Display TVL :
[    16.667] (II) modeset(0): Allocate new frame buffer 1080x1920 stride
[    19.814] (II) modeset(0): EDID vendor "TVL", prod id 6432
[    19.814] (II) modeset(0): Using EDID range info for horizontal sync
[    19.814] (II) modeset(0): Using EDID range info for vertical refresh
[    19.814] (II) modeset(0): Printing DDC gathered Modelines:
[    19.814] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    19.814] (II) modeset(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
Rotation ok and uses EDID info..
With your image in the Xorg log I see:
[    47.733] (II) modeset(0): Allocate new frame buffer 1080x1920 stride
[    48.253] (II) modeset(0): Allocate new frame buffer 320x200 stride
[    48.314] (II) modeset(0): EDID vendor "NBT", prod id 0
[    48.315] (II) modeset(0): Using hsync ranges from config file
[    48.315] (II) modeset(0): Using vrefresh ranges from config file
[    48.315] (II) modeset(0): Printing DDC gathered Modelines:
[    48.315] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    48.397] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    48.398] (--) modeset(0): HDMI max TMDS frequency 600000KHz
[    48.426] (II) modeset(0): Allocate new frame buffer 1920x1080 stride
[    48.557] (II) modeset(0): EDID vendor "NBT", prod id 0
[    48.557] (II) modeset(0): Using hsync ranges from config file
[    48.557] (II) modeset(0): Using vrefresh ranges from config file
[    48.557] (II) modeset(0): Printing DDC gathered Modelines:
[    48.557] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    48.558] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    48.558] (--) modeset(0): HDMI max TMDS frequency 600000KHz
[    97.626] (II) modeset(0): Allocate new frame buffer 1280x720 stride
[    97.961] (II) modeset(0): Allocate new frame buffer 320x200 stride
[    98.176] (II) modeset(0): EDID vendor "NBT", prod id 0
So there is a quickly sequence of changes 1080x1920 (required) --> 320x200 --> 1920x1080
Why??
24 minutes ago, SteMMo said:
Why??
No idea.
I know this won't help you, but there are lots of other people with the same problem. Read, perhaps you get some clues.
2 hours ago, SteMMo said:
Just tested with Raspberry 4.
Is is able to rotate the display.
This means bug is deep in the video driver as it can be extracted from other topics.
