GPIO not working on Armbian_5.31_Lamobo-r1_Debian_jessie_next_4.9.7.img (sysfs)
I just fresh installed Armbian_5.31_Lamobo-r1_Debian_jessie_next_4.9.7.img on my R1(which is for me a fantastic device).
I tried to use GPIO by sysfs like I used to do on 3.4.113-kernel.
on 3.4.113:
echo "17" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio17/direction
cat /sys/class/gpio/gpio17/value
echo "1" > /sys/class/gpio/gpio17/value
gpio -g read 17
...this is working fine
ls -l /sys/class/gpio/
--w------- 1 root root 4096 Nov  4 19:17 export
lrwxrwxrwx 1 root root    0 Nov  4 19:17 gpio14 -> ../../devices/platform/gpio-sunxi/gpio/gpio14
lrwxrwxrwx 1 root root    0 Nov  4 19:17 gpio15 -> ../../devices/platform/gpio-sunxi/gpio/gpio15
lrwxrwxrwx 1 root root    0 Nov  4 19:17 gpio2 -> ../../devices/platform/gpio-sunxi/gpio/gpio2
lrwxrwxrwx 1 root root    0 Nov  4 19:17 gpio22 -> ../../devices/platform/gpio-sunxi/gpio/gpio22
lrwxrwxrwx 1 root root    0 Nov  4 19:17 gpio27 -> ../../devices/platform/gpio-sunxi/gpio/gpio27
lrwxrwxrwx 1 root root    0 Nov  4 19:17 gpio3 -> ../../devices/platform/gpio-sunxi/gpio/gpio3
lrwxrwxrwx 1 root root    0 Nov  4 19:17 gpio17 -> ../../devices/platform/gpio-sunxi/gpio/gpio17
lrwxrwxrwx 1 root root    0 Nov  8 08:02 gpiochip1 -> ../../devices/platform/gpio-sunxi/gpio/gpiochip1
--w------- 1 root root 4096 Nov  8 08:02 unexport
on 'Linux lamobo 4.9.7-sunxi #1 SMP Thu Feb 2 01:52:06 CET 2017 armv7l GNU/Linux' it is NOT working
root@lamobo:~# echo "17" > /sys/class/gpio/export
root@lamobo:~# ls -l  /sys/class/gpio/
   --w------- 1 root root 4096 Nov  8 08:13 export
   lrwxrwxrwx 1 root root    0 Nov  8 08:13 gpio17 -> ../../devices/platform/soc@01c00000/1c20800.pinctrl/gpiochip0/gpio/gpio17
   lrwxrwxrwx 1 root root    0 Jan  1  1970 gpiochip0 -> ../../devices/platform/soc@01c00000/1c20800.pinctrl/gpio/gpiochip0
   lrwxrwxrwx 1 root root    0 Jan  1  1970 gpiochip413 -> ../../devices/platform/soc@01c00000/1c2ac00.i2c/i2c-0/0-0034/axp20x-gpio/gpio/gpiochip413
   --w------- 1 root root 4096 Jan  1  1970 unexport
...till here it is fine, but when I do
echo "out" > /sys/class/gpio/gpio17/direction (or  'echo out > /sys/class/gpio/gpio17/direction' )
no function of this command / something is crashing and even the "Network/swich" is crashing,
the network does not work anymore and the lights of all ethx's go on in 'dimmed'-modus on.
With other gpio's I are also not working:
->22 does no switch-crash, but shows error on 'out'-command
root@lamobo:~# echo "22" > /sys/class/gpio/export
root@lamobo:~# echo "out" > /sys/class/gpio/gpio22/direction
-bash: echo: write error: Unknown error 517
->14 no error on 'out'-command, but no PIN-function on hardware
root@lamobo:~# echo "14" > /sys/class/gpio/export
root@lamobo:~# echo out > /sys/class/gpio/gpio14/direction
root@lamobo:~# echo "0" > /sys/class/gpio/gpio14/value
root@lamobo:~# echo "1" > /sys/class/gpio/gpio14/value
How Do I get the/those(14,15,2,22,27,3) gpio's to work?
regards
Hi Tido,
thanks for fast answer.
R1 is AP and switch.
- Additional I control 4 LED's to check stuff/States
- 4 Inputs to controll my (smart)homeserver FHEM
- set some relais...
- get IR codes from remote control
- PIR to react on movements near to R1
I also need to use gpio for send 433MHz codes, now based on 3.4.113 and wiringpi and rc-switch
My first test with armbianIO failed:
root@lamobo:~/io/ArmbianIO# ./demo
 0=Le potato (Lamobo R1)
 1=Banana Pi M2 Zero (not 'Lamobo R1')
 2=Raspberry Pi (not 'Lamobo R1')
 15=Tinkerboard (not 'Lamobo R1')
Unrecognized board type, aborting...
Problem initializing ArmbianIO library
...no "Banana Pi" no "R1", this would be compatible...
I do not know if it is compatible to raspi???
But why is sysfs NOT working?
and why does 17 crash the switch?
Why is sysfs activated in this lamobo kernel if does not work?
other adresses/gpionumbers?
I do not understand the problem with sysfs...
OK...I am smarter now...
CON3-P01     VCC-3.3V
CON3-P02     VCC-5V
CON3-P03     TWI2-SDA     PB21
CON3-P04     VCC-5V
CON3-P05     TWI2-SCK     PB20
CON3-P06     GND
CON3-P07     GPCLK     PI3
CON3-P08     UART3-TX     PH0    (8-1)*32+0=224 [3.4.113 old-gpio-number-> 14 RxD ] old-WiringPi-number 15
CON3-P09     GND
CON3-P10     UART3-RX     PH1
CON3-P11     IO-0(UART2-RX)     PI19    (9-1)*32+19=275 [3.4.113 -> 17 ALT4 ]
CON3-P12     IO-1     PH2
CON3-P13     IO-2(UART2-TX)     PI18
CON3-P14     GND
CON3-P15     IO-3(UART2-CTS)     PI17
CON3-P16     IO-4(CAN_TX)     PH20
works now by sysfs for physical-pin-8:
echo "224" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio224/direction
cat /sys/class/gpio/gpio224/value
echo "1" > /sys/class/gpio/gpio224/value
Now I have to test it 433mhz-transmitter also works with new adress...
Are those new adresses because of kernel change?
From 3 to 4 or 5 ?
Why?
wiringpi does not see those changes:
/home/Funksteckdosen/433Utils/RPi_utils# cat /sys/class/gpio/gpio224/direction
out
/home/Funksteckdosen/433Utils/RPi_utils# gpio readall
 +-----+-----+---------+------+---+-Model  A-+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |   2 |   8 |   SDA.1 |   IN | 0 |  3 || 4  |   |      | 5v      |     |     |
 |   3 |   9 |   SCL.1 |   IN | 0 |  5 || 6  |   |      | 0v      |     |     |
 |   4 |   7 | GPIO. 7 |   IN | 0 |  7 || 8  | 0 | IN   | TxD     | 15  | 14=in-kernel-3.x   ,NOW in-4.xkernel 224  |
 |     |     |      0v |      |   |  9 || 10 | 0 | IN   | RxD     | 16  | 15  |
Has someone an idea to fix/convert this?
maybe in wiringpi?
I need this wiringpi-adresses for example
/home/Funksteckdosen/433Utils/RPi_utils/codesend 123...023
   nano codesend.cpp
      int PIN = 15; //wiringpi-definition, this shoud be gpio224
      fprintf(stderr, "\n PIN=%i",PIN);
433Utils/RPi_utils needs WiringPi...
This library aims to create simple wrapper functions for accessing I2C, SPI and creates a consistent numbering scheme for accessing GPIO ports based on the physical pin number.
Information about it  https://forum.armbian.com/topic/5655-armbianio-api-proposal/?do=findComment&comment=44769
How to: https://forum.armbian.com/topic/5655-armbianio-api-proposal/?do=findComment&comment=45825
Ok, here my result from weekend for those who are interested:
armbianio needs patch for Lamobo(armbianio.patch):
...armbianio.patch
diff --git a/armbianio.c b/armbianio.c
+static int iLamobor1Pins[] = {-1,-1,-1,53,-1,52,-1,259,224,-1,
+                        225,275,226,274,-1,273,244,-1,245,268,
+                        -1,269,272,267,266,-1
+            ,270};
Sending 433-Mhz-codes now also work with WiringBPi on kernel >=4... with WiringPi it does not work.
Only thing I do still not unterstand is why on PI19(275) worked with 17 on 3.4.x
But, now my gpio's work like it should, if I change addresses like in io-3.x-vs-4-x.png
