Marko Buršič Posted November 19, 2019 Posted November 19, 2019 I have installed Armbian minimal on RockPi 4, but it can't recognise the armbian-config command: armbian-config: command not found login as: pi pi@192.168.0.234's password: ____ _ ____ _ _ _ ____ | _ \ ___ ___| | _| _ \(_) | || | | __ ) | |_) / _ \ / __| |/ / |_) | |_____| || |_| _ \ | _ < (_) | (__| <| __/| |_____|__ _| |_) | |_| \_\___/ \___|_|\_\_| |_| |_| |____/ Welcome to Debian Buster with Armbian Linux 4.4.192-rockchip64 System load: 0.35 0.09 0.03 Up time: 0 min Memory usage: 7 % of 985MB IP: 192.168.0.234 CPU temp: 57°C Usage of /: 4% of 15G pi@rockpi:~$ sudo armbian-config [sudo] password for pi: sudo: armbian-config: command not found pi@rockpi:~$
Marko Buršič Posted November 19, 2019 Author Posted November 19, 2019 OK, next time I have logged on it has said something about to install this feature: sudo apt update && sudo apt install armbian-config And, then it worked, still I have to figure out why it shows garbage characters.
Igor Posted November 19, 2019 Posted November 19, 2019 1 hour ago, Marko Buršič said: but it can't recognise the armbian-config command Minimal images does not have this utility because some rework is needed https://armbian.atlassian.net/browse/AR-50 1 hour ago, Marko Buršič said: why it shows garbage characters. Perhaps wrong terminal settings?
Marko Buršič Posted November 19, 2019 Author Posted November 19, 2019 I do use Putty and WinSCP, both output the same characters instead of lines, corners,..etc
Igor Posted November 19, 2019 Posted November 19, 2019 1 hour ago, Marko Buršič said: I do use Putty and WinSCP, both output the same characters instead of lines, corners,..etc I use Gnome terminal:
Marko Buršič Posted November 27, 2019 Author Posted November 27, 2019 It switches sometimes also with correct view: I don't know how it looks in your GNOME, but if it's a bug it is a welcome bug.
faustf Posted December 24, 2019 Posted December 24, 2019 hi guys i have installed Armbian_19.11.3_Bananapim2ultra_buster_current_5.3.9_minimal and i have the same problem i try to follow the solution but nothing i try to install armbian-config but return me i have no space in /var/cache/archivies , but why i use 4gb sd o_O anyone can help me? thankz at all
