Hi there,
    my odroidc1 somehow died last month after updating to 5.3 test kernel so I decided to build new images from scratch starting from master.
I did not touch any configuration and I choose to build the classical server image.
  • Debian Buster boot but I cannot get any network
  • Ubuntu 18.04 does not even boot with a u-boot error (see below)
  • Ubuntu 19.10 does not even boot with a u-boot error (see below)
Here it is the u-boot log of Ubuntu images:
QA5:A;SVN:B72;POC:17F;STS:0;BOOT:0;INIT:10;BOOT:1;INIT:0;READ:0;CHECK:0;PASS:1;
* Welcome to Hardkernel's ODROID-C... (Built at 19:33:00 Dec  8 2014) *
CPU : AMLogic S805
MEM : 1024MB (DDR3@792MHz)
BID : HKC1310001
S/N : HKC11122F37E3A5A
0x0000009f
check SD_boot_type:0x1   card_type:0x1
Loading U-boot...success.
U-boot-00000-gb7b8dc2-dirty(odroidc@b7b8dc21) (Nov 25 2019 - 12:16:58)
I2C:   clear pinmux reg1[24]=0
clear pinmux reg1[1]=0
out reg=c1108058,value=fffcfa00
set output en 0xc1108054[21]=0
set output val 0xc1108058[21]=0
clear pinmux reg1[25]=0
clear pinmux reg8[12]=0
clear pinmux reg1[3]=0
clear pinmux reg1[2]=0
set output en 0xc1108054[20]=1
set output en 0xc1108054[20]=0
set output val 0xc1108058[20]=0
out reg=c1108058,value=ffdcfa00
out reg=c1108058,value=ffccfa00
out reg=c1108058,value=ffecfa00
ready
DRAM:  1 GiB
relocation Offset is: 2ff18000
MMC:   SDCARD: 0, eMMC: 1
IR init is done!
mmc save env ok
vpu clk_level = 3
set vpu clk: 182150000Hz, readback: 182150000Hz(0x701)
mode = 6  vic = 4
set HDMI vic: 4
mode is: 6
viu chan = 1
config HPLL
config HPLL done
reconfig packet setting done
MMC read: dev # 0, block # 33984, count 12288 ... 12288 blocks read: OK
Error: Bad gzipped data
There is no valid bmp file at the given address
Vendor: Man 1b534d Snr 187804ab Rev: 1.0 Prod: 00000
            Type: Removable Hard Disk
            Capacity: 30528.0 MB = 29.8 GB (62521344 x 512)
Partition     Start Sector     Num Sectors     Type
    1                 8192         2236416      83
Net:   Meson_Ethernet
init suspend firmware done. (ret:0)
Hit Enter key to stop autoboot -- :  0
exit abortboot: 0
** Unable to use mmc 0:1 for fatload **
Loading file "/boot/boot.ini" from mmc device 0:1 xxa1
3929 bytes read
Loading boot.ini from mmc0:1 (ext4)
Executing the script...
setenv rootdev "UUID=b1585a8b-1daf-459d-b17b-59fc562b1608"
setenv rootfstype "ext4"
setenv m "1080p"                # 1080P@60Hz
setenv vout_mode "hdmi"
setenv m_bpp "32"
setenv monitor_onoff "false" # true or false
setenv hpd "0"
setenv cec "0"
setenv disableuhs "disableuhs"
setenv vpu "1"
setenv hdmioutput "1"
if test -e mmc 0:1 boot/.next; then setenv condev "console=ttyAML0,115200n8"; else setenv condev "console=ttyS0,115200n8 console=tty0"; fi
setenv disable_vu7 "false" # false
setenv max_freq "1536"
if test "${hpd}" = "0"; then setenv hdmi_hpd "disablehpd=true"; fi
if test "${cec}" = "1"; then setenv hdmi_cec "hdmitx=cecf"; fi
if test "${disable_vu7}" = "false"; then setenv hid_quirks "usbhid.quirks=0x0eef:0x0005:0x0004"; fi
setenv bootargs "root=${rootdev} rootwait rw ${condev} rootfstype=${rootfstype} loglevel=3 no_console_suspend consoleblank=0 vdaccfg=0xa000 logo=osd1,loaded,0x7900000,720p,full dmfc=3 cvbsmode=576cvbs hdmimode=${m} m_bpp=${m_bpp} vout=${vout_mode} ${disableuhs} ${hdmi_hpd} ${hdmi_cec} ${enabledac} monitor_onoff=${monitor_onoff} max_freq=${max_freq} ${hid_quirks} ${extraargs}"
ext4load mmc 0:1 0x21000000 /boot/uImage || fatload mmc 0:1 0x21000000 uImage || ext4load mmc 0:1 0x21000000 uImage
Loading file "/boot/uImage" from mmc device 0:1 xxa1
** File not found /boot/uImage
Loading file "uImage" from mmc device 0:1 xxa1
** File not found uImage
ext4load mmc 0:1 0x22000000 /boot/uInitrd || fatload mmc 0:1 0x22000000 uInitrd || ext4load mmc 0:1 0x22000000 uInitrd
Loading file "/boot/uInitrd" from mmc device 0:1 xxa1
8811479 bytes read
ext4load mmc 0:1 0x21800000 /boot/dtb/meson8b_odroidc.dtb || fatload mmc 0:1 0x21800000 dtb/meson8b_odroidc.dtb || ext4load mmc 0:1 0x21800000 dtb/meson8b_odroidc.dtb
Loading file "/boot/dtb/meson8b_odroidc.dtb" from mmc device 0:1 xxa1
** File not found /boot/dtb/meson8b_odroidc.dtb
Loading file "dtb/meson8b_odroidc.dtb" from mmc device 0:1 xxa1
** File not found dtb/meson8b_odroidc.dtb
ext4load mmc 0:1 0x21800000 /boot/dtb/meson8b-odroidc1.dtb
Loading file "/boot/dtb/meson8b-odroidc1.dtb" from mmc device 0:1 xxa1
17254 bytes read
fdt addr 21800000
if test "${vpu}" = "0"; then fdt rm /mesonstream; fdt rm /vdec; fdt rm /ppmgr; fi
if test "${hdmioutput}" = "0"; then fdt rm /mesonfb; fi
bootm 0x21000000 0x22000000 0x21800000
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Unknown command '▒' - try 'help'
MMC read: dev # 0, block # 1216, count 16384 ... 16384 blocks read: OK
MMC read: dev # 0, block # 1088, count 128 ... 128 blocks read: OK
odroidc#
Does anyone have an idea on what is the problem and how to fix it?
Thanks in advance
*Ciao
Piero
Use LIB_TAG=v19.08 or fix broken/add new packaging patch. I simply don't have time to deal with this board ...
