Hello guys,
I am experiencing such a problem:
When I boot my orangepi it starts and it is visible in the router's page view getting IP with dhcp. As soon as I connect over ssh (at least this is the way to trigger it, not sure if it is hapening automatically after a while), the device disappears from the network and it is no more available! I have seen this behaviour happening on 2 different routers.
Then I rebooted the device again and in the router config I put the same IP statically linked to the device and I tried to connect over ssh and it worked without disappearing anymore.
So it sounds like a bug somewhere using dhcp protocol.
Is someone else experienced such problem?
How I can help to definitely fix this annoying bug?
Thanks,
Gianni
