I have trying to run DMKS for Armbian, but I alway get  this error.
About to run dkms install steps...
Creating symlink /var/lib/dkms/rtl8821CU/5.4.1/source ->
                 /usr/src/rtl8821CU-5.4.1
DKMS: add completed.
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area...
'make' KVER=4.19.62-sunxi....(bad exit status: 2)
Error! Bad return status for module build on kernel: 4.19.62-sunxi (armv7l)
Consult /var/lib/dkms/rtl8821CU/5.4.1/build/make.log for more information.
Building module:
Finished running dkms install steps.
make.log:
DKMS make.log for rtl8821CU-5.4.1 for kernel 4.19.62-sunxi (armv7l)
Thu Dec  5 10:46:21 UTC 2019
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.19.62-sunxi/build M=/var/lib/dkms
make[1]: Entering directory '/usr/src/linux-headers-4.19.62-sunxi'
  CC [M]  /var/lib/dkms/rtl8821CU/5.4.1/build/core/rtw_cmd.o
gcc: error: -mfloat-abi=soft and -mfloat-abi=hard may not be used together
make[2]: *** [scripts/Makefile.build:304: /var/lib/dkms/rtl8821CU/5.4.1/build/c1
make[1]: *** [Makefile:1517: _module_/var/lib/dkms/rtl8821CU/5.4.1/build] Error2
make[1]: Leaving directory '/usr/src/linux-headers-4.19.62-sunxi'
make: *** [Makefile:2183: modules] Error 2
It is a Sunxi H3 armhf CPU, detail is here:
CPU
ARM Cortex-A7 Quad-Core
512KB L2-Cache (shared between four cores)
32 KB (Instruction) / 32KiB (Data) L1-Cache per core
SIMD NEON, VFP4
Virtualization
Large Physical Address Extensions (LPAE) 1TB
GPU
ARM Mali400 MP2
Featuring 1 vertex shader (GP) and 2 fragment shaders (PP).
Complies with OpenGL ES 2.0
Memory
DDR2/DDR2L-DDR3/DDR3L controller
NAND Flash controller and 64-bit ECC
Anyone can help me would me out?
Edited by SpeedWorld
ok, I answer myself:
sudo cp /lib/modules/$(uname -r)/build/arch/arm/Makefile /lib/modules/$(uname -r)/build/arch/arm/Makefile.$(date +%Y%m%d%H%M)
sudo sed -i 's/-msoft-float//' /lib/modules/$(uname -r)/build/arch/arm/Makefile
sudo ln -s /lib/modules/$(uname -r)/build/arch/arm /lib/modules/$(uname -r)/build/arch/armv7l
