is there a parameter one can pass to ./compile.sh in order to limit which toolchains are being downloaded? I just checked and cache/toolchains is taking up 14 GB on my VM and given that I only ever build odroidxu4 kernels this is quite an overkill. I could of course delete the cache manually but this would mean that the toolchains need to be re-downloaded for the next rebuild. Thanks!
Expand
Not supported / developed. Its one of those: quite some work, little gain ...  if you find the time to do the bulk of the refactoring job, I will review.
