Nguyen Huu Posted July 7, 2015 Posted July 7, 2015 //Update2: is there anyone have sunxi_cedar_mod.ko module for 3.4.107 kernel? //Update1: I've changed and recompiled script.bin file and now screen turn on, great! Hi, I tried 3.4.107 wheezy on my Micro with HDMI screen. It show some image and message at boot, and then there's no signal to display. I also tried to change display resolution in "boot.scr" file, and tried "a10disp changehdmimodeforce 4" command, and ssh terminal show: sunxi disp kernel module version is 1.0 Cannot change HDMI mode because HDMI is not enabled.
Igor Posted July 8, 2015 Posted July 8, 2015 Cedarx is build in all, just define memory reservation and it will start working. Wrote on mobile phone
Nguyen Huu Posted July 8, 2015 Author Posted July 8, 2015 Thank you, I've add memory for cedar, and /dev/cedar_dev appear in /dev/. But I still can't find sunxi_cedar_mod module inside kernel driver and when run lsmod
micropad Posted July 8, 2015 Posted July 8, 2015 Hi, i have the same problem with Micro_Ubuntu_1.8_trusty_3.4.107, i'm a newbie, can you give me a correct steps for make my micro to work? thanks
Igor Posted July 8, 2015 Posted July 8, 2015 if you see a device it's o.k. there is no module because it's build in.
micropad Posted July 8, 2015 Posted July 8, 2015 i don't understand, how i can "//Update1: I've changed and recompiled script.bin file and now screen turn on, great!" ? how i see the device? i don't get the terminal. EDIT: ok, with ssh i can login, now i try to see the device.
Nguyen Huu Posted July 8, 2015 Author Posted July 8, 2015 Thanks, I've read again at linux-sunxi page.
Nguyen Huu Posted July 8, 2015 Author Posted July 8, 2015 i don't understand, how i can "//Update1: I've changed and recompiled script.bin file and now screen turn on, great!" ? how i see the device? i don't get the terminal. EDIT: ok, with ssh i can login, now i try to see the device. if you use Windows, you could use winscp along with putty to make changes to system
micropad Posted July 8, 2015 Posted July 8, 2015 i don't see /dev/cedar_dev . Where do i add memory for cedar? Yes, thanks, now with putty i can login with ssh. but i don't see anything on monitor after boot.
Nguyen Huu Posted July 8, 2015 Author Posted July 8, 2015 i don't see /dev/cedar_dev . Where do i add memory for cedar? Yes, thanks, now with putty i can login with ssh. but i don't see anything on monitor after boot. download this file, extract and use winscp to replace file in "boot" folder, and reboot. https://onedrive.live.com/redir?resid=91CD9585C0907EF6!46503&authkey=!AIDixu3SllA5LbQ&ithint=file%2crar
Nguyen Huu Posted July 9, 2015 Author Posted July 9, 2015 this is my debian whezzy image with hwa and xfce4 gui https://onedrive.live.com/redir?resid=91CD9585C0907EF6!46504&authkey=!ANxyHjRYWq_9fVM&ithint=file%2c7z
micropad Posted July 9, 2015 Posted July 9, 2015 Oh Thanks! what is user/pass for login? what is hwa?
Nguyen Huu Posted July 9, 2015 Author Posted July 9, 2015 sr, user/pass is: root/0987654321 hwa is hardware accelerator (for video).
micropad Posted July 9, 2015 Posted July 9, 2015 it's possible to auto-login on start? i've searched for editing the lighdm's settings... without success EDIT: maybe searching for slim... it's better
micropad Posted July 13, 2015 Posted July 13, 2015 is it possible to change the resolution? i have a 7" hdmi display with 1024x600 screen, but when it's connected with the micro seems that is set to 1280x720. If i try to change settings with xfce settings panel, i don't find 1024x600 but only 1280x720
