wanriz Posted May 23, 2016 Posted May 23, 2016 opi pc arm 5.10 ALSA no output from speakers but output only available through hdmi. when installed pulse audio able get and change audio hdmi to analog but when switched to HDMI playback hangs and freezes. Any solution?
supercoollbob Posted May 23, 2016 Posted May 23, 2016 mpv player analog work hdmi not work, kodi analog work hdmi through time , usb external speaker workalways great
Eng-Shien Wu Posted May 23, 2016 Posted May 23, 2016 If you mean the AV port, you need to unmute: amixer set -c 0 'Audio lineout' unmute Then test it by speaker-test -twav -c2 -Dhw:0 (need to sudo if your user isn't member of audio group)
