Virtual BananaPi? Emulator for Armbian?
is there something like a VirtualBox that can emulate a BP(M1) hardware, that can run Armbian inside?
I'm looking for a way to set up a new Armbian system for a BPM1, without having to shut down the running one longer than absolutely necessary. I have done this before with Linux servers: I installed and configured a hole server inside a VirtualBox alongside my normal computer work, then I copied the image to the real disk and swapped the disks, with a downtime of only about 5 minutes. So I was wondering if this was possible with the BananaPi as well.
You will need to make support. The only (Armbian) image that I manage to boot with actual kernel under QEMU was Cubieboard 1 (A10):
https://wiki.qemu.org/Documentation/Platforms/ARM
https://lists.gnu.org/archive/html/qemu-devel/2015-10/msg01401.html
Setting up a NFS boot with or without FEL or using special kernel
https://docs.armbian.com/Developer-Guide_FEL-boot/
is the only way to get closer to this.
Welcome to non x86 world :)
