24.mara Posted December 30, 2019 Posted December 30, 2019 Hi, I'm using Orange Pi One board for Octoprint, but it's slow sometimes, because of max cpu frequency at 1 GHz. Under full load cpu temp is not higher than 30 °C, so I would like to set higher frequency, but all images looks like their max cpu frequency is just 1 GHz. So, is there any image with higher max cpu frequency? Thanks
Werner Posted December 31, 2019 Posted December 31, 2019 Quote [ 6.869660] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 6.869678] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) [ 6.869789] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 6.869797] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000) [ 6.869880] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 6.869887] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) [ 6.869990] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator [ 6.869996] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000) I think this is the reason for the cap. This is the same in all kernels from 4.19.84 up to 5.5.0-rc2 Edit: Interesting. On 4.19.35 it is still capped, though more information in dmesg [ 5.745212] cpu cpu0: Linked as a consumer to regulator.5 [ 5.745277] cpu cpu0: Dropping the link to regulator.5 [ 5.745464] cpu cpu0: Linked as a consumer to regulator.5 [ 5.746315] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 5.746328] cpu cpu0: _opp_add: OPP not supported by regulators (1056000000) [ 5.746436] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 5.746443] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000) [ 5.746569] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 5.746579] cpu cpu0: _opp_add: OPP not supported by regulators (1152000000) [ 5.746669] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator [ 5.746676] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000) [ 5.746783] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 5.746790] cpu cpu0: _opp_add: OPP not supported by regulators (1224000000) [ 5.746926] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 5.746935] cpu cpu0: _opp_add: OPP not supported by regulators (1248000000) [ 5.747030] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator [ 5.747038] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000) [ 5.747155] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator [ 5.747163] cpu cpu0: _opp_add: OPP not supported by regulators (1344000000) [ 5.747290] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator [ 5.747299] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000) 2
