NOBL Posted January 4, 2020 Share Posted January 4, 2020 (edited) Happy new year and thanks for the good work ! I see there is a (buster) image available for my Odroid N2 with kernel 5.4. A few weeks ago I set up the build environment and started building my own images. First images were build using the 4.9 kernel from Hardkernel. Later the images were build with kernel 5.1 (and BRANCH=default). However, the image with kernel 5.4 was not build today but the kernel 5.1 is still used for the image, although I changed the BRANCH=default (as it was before) to BRANCH=dev. How can I create a new armbian image with kernel 5.4 ? I read some posts about a new u-boot. Is this new u-boot required for the new kernel ? I would like to boot, e.g. from USB as well. Kind regards Norbert Edited January 4, 2020 by NOBL typo Link to comment Share on other sites More sharing options...
Igor Posted January 4, 2020 Share Posted January 4, 2020 4 minutes ago, NOBL said: However, the image with kernel 5.4 was not build today but the kernel 5.1 is Update your build environment with "git pull" (and use menu for a while rather than build parameters). Branch names has been changed, default=legacy, next=current ... Link to comment Share on other sites More sharing options...
NOBL Posted January 4, 2020 Author Share Posted January 4, 2020 Thanks a lot for your quick response Igor ! What a shame that I didn't come myself with this easy solution. Link to comment Share on other sites More sharing options...
NOBL Posted January 5, 2020 Author Share Posted January 5, 2020 Thank you for the hint to use the menu. Yes, it did work fine :-) I'm very happy that the Odroid N2 is now supported and can run the mainline kernel. Link to comment Share on other sites More sharing options...
