Sonarr not installed properly by armbian-config?
OrangePi Zero headless server
Debian Buster with Armbian Linux 4.19.62-sunxi
armbianmonitor http://ix.io/26Dp
Selected to install Sonarr in armbian-config which completes without error, but armbian-config does not indicate that Sonarr is now installed (i.e., I can still select it and do the whole thing again). Appears that armbian-config installs Sonarr as a service, but it doesn't appear to be running after I reboot (http://192.168.1.99:8989 gives error connection refused). Looks like Sonarr relies on mono, but mono has not been installed at /usr/bin/mono. Did I fail to do some required post-armbian-config steps?
