gounthar Posted January 7, 2020 Posted January 7, 2020 Hi there, I'm looking for a USB power supply that would be mounted into a rack, so that I can power up quite a few boards at the same time. These boards would also be in the same rack. I found a big rackable USB hub, but that's not what I am looking for, and 2.4A max per slot may be too weak for some of the boards. I could hosts several smaller USB hubs too, but that does not sound really enticing. My other option is to make it by myself with salvaged server power supplies, a patch panel, bits and bobs, but it will take longer... Would you have any recommendation? Thanks.
Igor Posted January 8, 2020 Posted January 8, 2020 9 hours ago, gounthar said: I found a big rackable USB hub, but that's not what I am looking for, and 2.4A max per slot may be too weak for some of the boards. Perhaps something like this? https://www.pimfg.com/product-detail/POWER-USB-18-RK I doubt you will find more powerful USB hub. Then you will also have a few 12V boards which you have to power separate (or power non-standard way). I "solved" this with having switches and kvm in the rack, but PSU - except 2 x 7 powered USB hub, 1.5A per port. But I don't actually need permanent solution - boards - up to around 25 can be connected/powered at once - are changing all the time. 1
gounthar Posted January 8, 2020 Author Posted January 8, 2020 This one looks better suited to my needs, thanks Igor. Yes, I also have quite a few 12V boards, so I have to figure it out too... I guess I will go the server PSU way. As I am trying to build some kind of farm, the boards have to be powered all at the same time.
Igor Posted March 23, 2020 Posted March 23, 2020 16 x max. 2,1 A per port https://www.reichelt.de/steckdosenleiste-19-16-usb-ladeports-int-164580-p248713.html?&nbc=1
gounthar Posted March 23, 2020 Author Posted March 23, 2020 Not bad, thanks a lot! Too bad I made an order at Reichelt yesterday... It wouldn't fit all my boards because of the 2.1A limitation, but nice for the price!
Igor Posted March 23, 2020 Posted March 23, 2020 33 minutes ago, gounthar said: Too bad I made an order at Reichelt yesterday... I just ordered two units 33 minutes ago, gounthar said: It wouldn't fit all my boards because of the 2.1A limitation, but nice for the price! I know for some I will still need to use something else, but most it will cover. The price is reasonable, yes. ... not working anymore Spoiler 1
