Alex83 1 Posted March 20, 2021 Share Posted March 20, 2021 I tried to turn it on with remote control and also deattached the device a few times... no chance it just says: root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd 3 Reset Device failed! root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd 3 Reset Device failed! root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd 3 Reset Device failed! Actually I remember some dark sparks about shorting some point on the board to get into "MASK ROM MODE". Unfortunately I just wrote it into freaktab board and this is unfortunately down now... so maybe you can remember it. I did this already on some other V88 devices with other pcb... so I am not sure if it was just on the devices with eMMC, but I remember some tweezers shorting on the backside if i am right... *f...* that's so long ago... Link to post Share on other sites More sharing options...
Alex83 1 Posted March 20, 2021 Share Posted March 20, 2021 (edited) By the way I noticed if you forget SD card the device don't get recognized from PC. It just loads into multitool then. Here are some pictures of my board Edited March 20, 2021 by Alex83 I can't remember if the red or blue circle needs to be shorted... Link to post Share on other sites More sharing options...
jock 398 Posted March 20, 2021 Author Share Posted March 20, 2021 @Alex83 nope, the bootloader was uploaded correctly, it just made some mistakes about some kind on incompatibility or maybe issuing reset garbled the NAND status somehow. As I suggested, repeat the procedure skipping the first rkdeveloptool ef command. If it still does not work, repeat the procedure using the v2.51 and v2.47 loaders. If nothing works yet, the last resort is RkDevTool for windows (formerly known as AndroidTool) you can download from here Link to post Share on other sites More sharing options...
jock 398 Posted March 20, 2021 Author Share Posted March 20, 2021 57 minutes ago, Alex83 said: I tried to turn it on with remote control and also deattached the device a few times... no chance it just says: root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd 3 Reset Device failed! root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd 3 Reset Device failed! root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd 3 Reset Device failed! Actually I remember some dark sparks about shorting some point on the board to get into "MASK ROM MODE". Unfortunately I just wrote it into freaktab board and this is unfortunately down now... so maybe you can remember it. I did this already on some other V88 devices with other pcb... so I am not sure if it was just on the devices with eMMC, but I remember some tweezers shorting on the backside if i am right... *f...* that's so long ago... Ok, so let's see if I understood: you plug the USB cable lsusb is telling that the device is there if you run rkdeveloptool rd 3 it tells you "Reset Device failed!" If so, believe it or not this is the best condition Repeat the procedure starting from upgrade_tool, hope this time works 1 Link to post Share on other sites More sharing options...
Alex83 1 Posted March 20, 2021 Share Posted March 20, 2021 13 minutes ago, jock said: Ok, so let's see if I understood: you plug the USB cable lsusb is telling that the device is there if you run rkdeveloptool rd 3 it tells you "Reset Device failed!" If so, believe it or not this is the best condition Repeat the procedure starting from upgrade_tool, hope this time works ok. It worked so far! root@alex-ThinkPad-T510 /home/alex/Downloads > upgrade_tool ul rk322x_loader_v1.10.256.bin Not found config.ini Program Data in /usr/local/bin Loading loader... Support Type:RK322A Loader ver:2.56 Loader Time:2021-03-13 16:06:57 Upgrade loader ok. root@alex-ThinkPad-T510 /home/alex/Downloads > dmesg [ 4788.722591] usb 1-1.1: new high-speed USB device number 5 using ehci-pci [ 4788.831239] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 4788.831248] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 5114.936216] usb 1-1.1: USB disconnect, device number 5 [ 5115.229255] usb 1-1.1: new high-speed USB device number 6 using ehci-pci [ 5115.341606] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 5115.341611] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 5233.720230] usb 1-1.1: USB disconnect, device number 6 [ 5235.782011] usb 1-1.1: new high-speed USB device number 7 using ehci-pci [ 5235.890832] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 5235.890836] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 5235.890837] usb 1-1.1: Product: USB-MSC [ 5235.890838] usb 1-1.1: Manufacturer: RockChip [ 5235.890839] usb 1-1.1: SerialNumber: rockchip [ 5433.199976] usb 1-1.1: USB disconnect, device number 7 [ 5435.424812] usb 1-1.1: new high-speed USB device number 8 using ehci-pci [ 5435.537960] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 5435.537963] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 5435.537965] usb 1-1.1: Product: USB-MSC [ 5435.537966] usb 1-1.1: Manufacturer: RockChip [ 5435.537967] usb 1-1.1: SerialNumber: rockchip [ 5589.455455] mmc0: new high speed SD card at address 1234 [ 5589.455947] mmcblk0: mmc0:1234 SA02G 1.83 GiB [ 5589.475283] mmcblk0: p1 p2 [ 5589.475291] mmcblk0: p1 size 4069376 extends beyond EOD, truncated [ 6823.457926] mmc0: card 1234 removed [ 6827.632405] usb 1-1.1: USB disconnect, device number 8 [ 7161.190702] perf: interrupt took too long (8087 > 7976), lowering kernel.perf_event_max_sample_rate to 24500 [ 8052.060956] usb 1-1.1: new high-speed USB device number 9 using ehci-pci [ 8052.173680] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 8052.173684] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 9843.620378] usb 1-1.1: USB disconnect, device number 9 [ 9844.693535] usb 1-1.1: new high-speed USB device number 10 using ehci-pci [ 9844.802106] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 9844.802111] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 9906.976740] usb 1-1.1: USB disconnect, device number 10 [ 9911.099750] usb 1-1.1: new high-speed USB device number 11 using ehci-pci [ 9911.212514] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 9911.212520] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 9954.693004] usb 1-1.1: USB disconnect, device number 11 [ 9976.686026] usb 1-1.1: new high-speed USB device number 12 using ehci-pci [ 9976.802683] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 9976.802688] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [10149.048626] usb 1-1.1: USB disconnect, device number 12 [12689.280101] usb 1-1.1: new high-speed USB device number 13 using ehci-pci [12689.396666] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [12689.396671] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [13350.089526] usb 1-1.1: USB disconnect, device number 13 [13901.020137] usb 1-1.1: new high-speed USB device number 14 using ehci-pci [13901.128760] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [13901.128765] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [14005.542754] usb 1-1.1: USB disconnect, device number 14 [14007.721213] usb 1-1.1: new high-speed USB device number 15 using ehci-pci [14007.830795] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [14007.830799] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [14007.830802] usb 1-1.1: Product: USB-MSC [14007.830805] usb 1-1.1: Manufacturer: RockChip [14007.830808] usb 1-1.1: SerialNumber: rockchip root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd Reset Device OK. root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool ef Erasing flash complete. root@alex-ThinkPad-T510 /home/alex/Downloads > So I'll give it a try and report in a minute back. Link to post Share on other sites More sharing options...
jock 398 Posted March 20, 2021 Author Share Posted March 20, 2021 8 minutes ago, Alex83 said: ok. It worked so far! root@alex-ThinkPad-T510 /home/alex/Downloads > upgrade_tool ul rk322x_loader_v1.10.256.bin Not found config.ini Program Data in /usr/local/bin Loading loader... Support Type:RK322A Loader ver:2.56 Loader Time:2021-03-13 16:06:57 Upgrade loader ok. root@alex-ThinkPad-T510 /home/alex/Downloads > dmesg [ 4788.722591] usb 1-1.1: new high-speed USB device number 5 using ehci-pci [ 4788.831239] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 4788.831248] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 5114.936216] usb 1-1.1: USB disconnect, device number 5 [ 5115.229255] usb 1-1.1: new high-speed USB device number 6 using ehci-pci [ 5115.341606] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 5115.341611] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 5233.720230] usb 1-1.1: USB disconnect, device number 6 [ 5235.782011] usb 1-1.1: new high-speed USB device number 7 using ehci-pci [ 5235.890832] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 5235.890836] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 5235.890837] usb 1-1.1: Product: USB-MSC [ 5235.890838] usb 1-1.1: Manufacturer: RockChip [ 5235.890839] usb 1-1.1: SerialNumber: rockchip [ 5433.199976] usb 1-1.1: USB disconnect, device number 7 [ 5435.424812] usb 1-1.1: new high-speed USB device number 8 using ehci-pci [ 5435.537960] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 5435.537963] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 5435.537965] usb 1-1.1: Product: USB-MSC [ 5435.537966] usb 1-1.1: Manufacturer: RockChip [ 5435.537967] usb 1-1.1: SerialNumber: rockchip [ 5589.455455] mmc0: new high speed SD card at address 1234 [ 5589.455947] mmcblk0: mmc0:1234 SA02G 1.83 GiB [ 5589.475283] mmcblk0: p1 p2 [ 5589.475291] mmcblk0: p1 size 4069376 extends beyond EOD, truncated [ 6823.457926] mmc0: card 1234 removed [ 6827.632405] usb 1-1.1: USB disconnect, device number 8 [ 7161.190702] perf: interrupt took too long (8087 > 7976), lowering kernel.perf_event_max_sample_rate to 24500 [ 8052.060956] usb 1-1.1: new high-speed USB device number 9 using ehci-pci [ 8052.173680] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 8052.173684] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 9843.620378] usb 1-1.1: USB disconnect, device number 9 [ 9844.693535] usb 1-1.1: new high-speed USB device number 10 using ehci-pci [ 9844.802106] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 9844.802111] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 9906.976740] usb 1-1.1: USB disconnect, device number 10 [ 9911.099750] usb 1-1.1: new high-speed USB device number 11 using ehci-pci [ 9911.212514] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 9911.212520] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 9954.693004] usb 1-1.1: USB disconnect, device number 11 [ 9976.686026] usb 1-1.1: new high-speed USB device number 12 using ehci-pci [ 9976.802683] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [ 9976.802688] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [10149.048626] usb 1-1.1: USB disconnect, device number 12 [12689.280101] usb 1-1.1: new high-speed USB device number 13 using ehci-pci [12689.396666] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [12689.396671] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [13350.089526] usb 1-1.1: USB disconnect, device number 13 [13901.020137] usb 1-1.1: new high-speed USB device number 14 using ehci-pci [13901.128760] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [13901.128765] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [14005.542754] usb 1-1.1: USB disconnect, device number 14 [14007.721213] usb 1-1.1: new high-speed USB device number 15 using ehci-pci [14007.830795] usb 1-1.1: New USB device found, idVendor=2207, idProduct=320b, bcdDevice= 1.00 [14007.830799] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [14007.830802] usb 1-1.1: Product: USB-MSC [14007.830805] usb 1-1.1: Manufacturer: RockChip [14007.830808] usb 1-1.1: SerialNumber: rockchip root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd Reset Device OK. root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool ef Erasing flash complete. root@alex-ThinkPad-T510 /home/alex/Downloads > So I'll give it a try and report in a minute back. Ahah, no wait a second. I just spotted a mistake in the instructions! The rkdeveloptool ef is removing again the bootloader you just installed sorry for that... (I'm going to fix them) Let's try again: Unplug the USB cable Plug the USB cable run upgrade_tool Wait for a minute Unplug the USB cable Then finally it should work as expected edit: going to give you credits on first page if this madness works 1 Link to post Share on other sites More sharing options...
Alex83 1 Posted March 20, 2021 Share Posted March 20, 2021 (edited) Hi Jock, actually i did it as you said and it recognises the NAND again. - I just don't know if I did a mistake again because I read somehow something with "NAND Jump" and did this in multitool. - Afterwards I installed as usual Armbian with legacy-Kernel 4.19 to NANA via sTep... Anyway... after finishing the device does not boot. The HDMI output stays black. I just do a minimal buster installation with 4.19 kernel now and write back in a minute... Maybe if the device works again I can provide you dmesg from armbian there... or I would also provide you serial output, but don't know where to connect via serial. If you find some points, I have also soldering skills root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool ef Erasing flash complete. root@alex-ThinkPad-T510 /home/alex/Downloads > rkdeveloptool rd 3 Reset Device OK. root@alex-ThinkPad-T510 /home/alex/Downloads > upgrade_tool ul rk322x_loader_v1.10.256.bin Not found config.ini Program Data in /usr/local/bin Loading loader... Support Type:RK322A Loader ver:2.56 Loader Time:2021-03-13 16:06:57 Upgrade loader ok. root@alex-ThinkPad-T510 /home/alex/Downloads > unplug the device Ok, did it again without the erasing in the end... because the device does not start from NAND installed images unfortunately... I noticed this time the output from "upgrade_tool ..." was very quick and showing "Upgrade loader ok" much faster than before. I waited for 2 minutes after that output. Edited March 20, 2021 by Alex83 no luck with booting the device from NAND Link to post Share on other sites More sharing options...
jock 398 Posted March 20, 2021 Author Share Posted March 20, 2021 13 minutes ago, Alex83 said: Hi Jock, actually i did it as you said and it recognises the NAND again. - I just don't know if I did a mistake again because I read somehow something with "NAND Jump" and did this in multitool. - Afterwards I installed as usual Armbian with legacy-Kernel 4.19 to NANA via sTep... Anyway... after finishing the device does not boot. The HDMI output stays black. I just do a minimal buster installation with 4.19 kernel now and write back in a minute... Maybe if the device works again I can provide you dmesg from armbian there... or I would also provide you serial output, but don't know where to connect via serial. If you find some points, I have also soldering skills About the serial, unfortunately it is not a board I known. I know chiptrip hide the serial pads very well on their boards and I had to ask @fabiobassa (he has much better skills in electronics than me) to find them. Ok, the NAND is back and this is a very good news, now I investigate the issue about the legacy kernel armbian not booting (beware: legacy kernel is 4.4, not 4.19, are you sure you're using the right image?), trying to replicate on my board and will tell you ASAP Link to post Share on other sites More sharing options...
Alex83 1 Posted March 20, 2021 Share Posted March 20, 2021 20 minutes ago, jock said: About the serial, unfortunately it is not a board I known. I know chiptrip hide the serial pads very well on their boards and I had to ask @fabiobassa (he has much better skills in electronics than me) to find them. Ok, the NAND is back and this is a very good news, now I investigate the issue about the legacy kernel armbian not booting (beware: legacy kernel is 4.4, not 4.19, are you sure you're using the right image?), trying to replicate on my board and will tell you ASAP Hey! Good news! Luckily the Buster-minimal-image with kernel 4.19 boots up! You're the master! I'll reply after finishing booting. - Actually my prefered system is always ubuntu because of some ppa for tvheadend and so on... maybe I'll change later again. Link to post Share on other sites More sharing options...
jock 398 Posted March 20, 2021 Author Share Posted March 20, 2021 Just now, Alex83 said: Hey! Good news! Luckily the Buster-minimal-image with kernel 4.19 boots up! You're the master! I'll reply after finishing booting. - Actually my prefered system is always ubuntu because of some ppa for tvheadend and so on... maybe I'll change later again. Maybe you meant kernel 4.4? I just finished installing the legacy kernel image (freshly downloaded from here) on NAND and mine also boots fine I will be waiting for iperf3 and reboot tests Link to post Share on other sites More sharing options...
Alex83 1 Posted March 20, 2021 Share Posted March 20, 2021 (edited) You're really the rk322x-god! Spoiler root@alex-ThinkPad-T510 /home/alex/Downloads > ssh root@192.168.178.161 The authenticity of host '192.168.178.161 (192.168.178.161)' can't be established. ECDSA key fingerprint is SHA256:q9uvOSaM80JnjYWkCZHpQ0gR5lMtYNTuQZr0F+h2QHs. Are you sure you want to continue connecting (yes/no/[fingerprint])? yes Warning: Permanently added '192.168.178.161' (ECDSA) to the list of known hosts. root@192.168.178.161's password: _ _________ ____ _ _ __| | _|___ /___ \|___ \__ __ | |__ _____ __ | '__| |/ / |_ \ __) | __) \ \/ /____| '_ \ / _ \ \/ / | | | < ___) / __/ / __/ > <_____| |_) | (_) > < |_| |_|\_\____/_____|_____/_/\_\ |_.__/ \___/_/\_\ Welcome to Armbian 21.02.3 Buster with Linux 4.4.194-rk322x No end-user support: community creations System load: 134% Up time: 8 min Memory usage: 6% of 993M IP: 192.168.178.161 CPU temp: 63°C Usage of /: 16% of 6.9G [ General system configuration (beta): armbian-config ] Last login: Tue Mar 9 12:25:15 2021 root@rk322x-v88mini4k:~# dmesg [ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.194-rk322x (root@beast) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #12 SMP Tue Mar 9 08:49:10 CET 2021 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: Generic RK322x TV Box board [ 0.000000] earlycon: Early serial console at MMIO32 0x11030000 (options '') [ 0.000000] bootconsole [uart0] enabled [ 0.000000] cma: Reserved 16 MiB at 0x9f000000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000 [ 0.000000] Normal zone: 2304 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 262144 pages, LIFO batch:31 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv65535.65535 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344 [ 0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259840 [ 0.000000] Kernel command line: earlyprintk root=UUID=a1a0625b-8e98-407f-a8a4-e58e138c1391 console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4 consoleblank=0 loglevel=1 ubootpart= usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 earlycon=uart8250,mmio32,0x11030000 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 994692K/1048576K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 37500K reserved, 16384K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xb0000000 - 0xf0000000 (1024 MB) pkmap : 0xafe00000 - 0xb0000000 ( 2 MB) modules : 0xaf000000 - 0xafe00000 ( 14 MB) .text : 0xb0008000 - 0xb0c97c6c (12864 kB) .init : 0xb10b0000 - 0xb117a000 ( 808 kB) .data : 0xb117a000 - 0xb125fe94 ( 920 kB) .bss : 0xb1261000 - 0xb1391f14 (1220 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000022] Switching to timer-based delay loop, resolution 41ns [ 0.001788] Console: colour dummy device 80x30 [ 0.001808] console [tty1] enabled [ 0.001819] bootconsole [uart0] disabled [ 0.001846] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001864] pid_max: default: 32768 minimum: 301 [ 0.001993] Security Framework initialized [ 0.002006] Yama: becoming mindful. [ 0.002081] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002097] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002986] Initializing cgroup subsys io [ 0.003020] Initializing cgroup subsys memory [ 0.003061] Initializing cgroup subsys devices [ 0.003080] Initializing cgroup subsys freezer [ 0.003098] Initializing cgroup subsys net_cls [ 0.003114] Initializing cgroup subsys perf_event [ 0.003131] Initializing cgroup subsys net_prio [ 0.003163] Initializing cgroup subsys pids [ 0.003235] CPU: Testing write buffer coherency: ok [ 0.003282] ftrace: allocating 41892 entries in 123 pages [ 0.082588] /cpus/cpu@f00 missing clock-frequency property [ 0.082620] /cpus/cpu@f01 missing clock-frequency property [ 0.082639] /cpus/cpu@f02 missing clock-frequency property [ 0.082659] /cpus/cpu@f03 missing clock-frequency property [ 0.082671] CPU0: update cpu_capacity 430 [ 0.082682] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.082766] Setting up static identity map for 0x60008280 - 0x600082d8 [ 0.085576] CPU1: update cpu_capacity 430 [ 0.085585] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.086685] CPU2: update cpu_capacity 430 [ 0.086693] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.087717] CPU3: update cpu_capacity 430 [ 0.087724] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.087855] Brought up 4 CPUs [ 0.087893] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.087902] CPU: All CPU(s) started in SVC mode. [ 0.089366] devtmpfs: initialized [ 0.109106] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.109632] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.109674] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.111082] xor: measuring software checksum speed [ 0.150528] arm4regs : 1011.000 MB/sec [ 0.190632] 8regs : 705.000 MB/sec [ 0.230735] 32regs : 684.000 MB/sec [ 0.270836] neon : 1018.000 MB/sec [ 0.270846] xor: using function: neon (1018.000 MB/sec) [ 0.270886] pinctrl core: initialized pinctrl subsystem [ 0.272447] NET: Registered protocol family 16 [ 0.275011] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.286992] cpuidle: using governor ladder [ 0.299007] cpuidle: using governor menu [ 0.315503] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 [ 0.315666] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 [ 0.315816] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 [ 0.315986] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 [ 0.322536] console [pstore-1] enabled [ 0.322548] pstore: Registered ramoops as persistent store backend [ 0.322560] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0 [ 0.325918] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.325939] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.423863] raid6: int32x1 gen() 133 MB/s [ 0.491940] raid6: int32x1 xor() 131 MB/s [ 0.560205] raid6: int32x2 gen() 166 MB/s [ 0.628257] raid6: int32x2 xor() 136 MB/s [ 0.696610] raid6: int32x4 gen() 163 MB/s [ 0.764858] raid6: int32x4 xor() 137 MB/s [ 0.833011] raid6: int32x8 gen() 166 MB/s [ 0.901272] raid6: int32x8 xor() 113 MB/s [ 0.969395] raid6: neonx1 gen() 382 MB/s [ 1.037540] raid6: neonx1 xor() 290 MB/s [ 1.105734] raid6: neonx2 gen() 519 MB/s [ 1.173876] raid6: neonx2 xor() 376 MB/s [ 1.242072] raid6: neonx4 gen() 581 MB/s [ 1.310281] raid6: neonx4 xor() 400 MB/s [ 1.378581] raid6: neonx8 gen() 560 MB/s [ 1.446735] raid6: neonx8 xor() 391 MB/s [ 1.446747] raid6: using algorithm neonx4 gen() 581 MB/s [ 1.446757] raid6: .... xor() 400 MB/s, rmw enabled [ 1.446768] raid6: using intx1 recovery algorithm [ 1.447752] rockchip-pm rockchip-suspend: not set wakeup-config [ 1.447776] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 1.448140] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]' [ 1.448630] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]' [ 1.449260] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0) [ 1.449858] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0) [ 1.450353] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' [ 1.451246] iommu: Adding device 20020000.vpu-service to group 0 [ 1.451353] iommu: Adding device 20030000.rkvdec to group 1 [ 1.451460] iommu: Adding device 20050000.vop to group 2 [ 1.451555] iommu: Adding device 20070000.iep to group 3 [ 1.452080] rk_iommu 20020800.iommu: can't get sclk [ 1.452658] rk_iommu 20030480.iommu: can't get sclk [ 1.452918] rk_iommu 20053f00.iommu: can't get sclk [ 1.453064] rk_iommu 20070800.iommu: can't get aclk [ 1.453083] rk_iommu 20070800.iommu: can't get hclk [ 1.453100] rk_iommu 20070800.iommu: can't get sclk [ 1.453841] SCSI subsystem initialized [ 1.454259] usbcore: registered new interface driver usbfs [ 1.454359] usbcore: registered new interface driver hub [ 1.454479] usbcore: registered new device driver usb [ 1.454693] media: Linux media interface: v0.10 [ 1.454851] Linux video capture interface: v2.00 [ 1.455101] pps_core: LinuxPPS API ver. 1 registered [ 1.455117] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.455160] PTP clock support registered [ 1.457112] Advanced Linux Sound Architecture Driver Initialized. [ 1.458115] Bluetooth: Core ver 2.21 [ 1.458182] NET: Registered protocol family 31 [ 1.458196] Bluetooth: HCI device and connection manager initialized [ 1.458218] Bluetooth: HCI socket layer initialized [ 1.458236] Bluetooth: L2CAP socket layer initialized [ 1.458288] Bluetooth: SCO socket layer initialized [ 1.459094] NetLabel: Initializing [ 1.459115] NetLabel: domain hash size = 128 [ 1.459125] NetLabel: protocols = UNLABELED CIPSOv4 [ 1.459196] NetLabel: unlabeled traffic allowed by default [ 1.460573] clocksource: Switched to clocksource arch_sys_counter [ 1.555492] NET: Registered protocol family 2 [ 1.556354] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 1.556471] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) [ 1.556904] TCP: Hash tables configured (established 8192 bind 8192) [ 1.557006] UDP hash table entries: 512 (order: 2, 24576 bytes) [ 1.557075] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) [ 1.557427] NET: Registered protocol family 1 [ 1.558052] RPC: Registered named UNIX socket transport module. [ 1.558076] RPC: Registered udp transport module. [ 1.558086] RPC: Registered tcp transport module. [ 1.558097] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.558422] Trying to unpack rootfs image as initramfs... [ 1.931103] Freeing initrd memory: 5560K [ 1.932147] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 1.935122] Initialise system trusted keyring [ 1.949049] VFS: Disk quotas dquot_6.6.0 [ 1.949360] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.952019] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.955476] NFS: Registering the id_resolver key type [ 1.955540] Key type id_resolver registered [ 1.955551] Key type id_legacy registered [ 1.955586] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.955696] ntfs: driver 2.1.32 [Flags: R/W]. [ 1.956735] JFS: nTxBlock = 7942, nTxLock = 63539 [ 1.965625] SGI XFS with security attributes, no debug enabled [ 1.974349] NET: Registered protocol family 38 [ 1.974401] Key type asymmetric registered [ 1.974423] Asymmetric key parser 'x509' registered [ 1.974806] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.975158] io scheduler noop registered [ 1.975187] io scheduler deadline registered [ 1.975269] io scheduler cfq registered (default) [ 1.978452] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator [ 1.983413] rk-vcodec 20020000.vpu-service: no regulator for vcodec [ 1.983828] rk-vcodec 20020000.vpu-service: probe device [ 1.984236] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled [ 1.985722] rk-vcodec 20020000.vpu-service: could not find power_model node [ 1.985748] rk-vcodec 20020000.vpu-service: init success [ 1.986070] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry [ 1.990274] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330 [ 1.990301] dma-pl330 110f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.991413] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 1.991882] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable [ 1.991903] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup [ 1.991920] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]' [ 1.991935] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]' [ 1.991948] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup [ 1.991963] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed [ 1.992660] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable [ 1.992683] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup [ 1.992699] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]' [ 1.992714] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]' [ 1.992728] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup [ 1.992743] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed [ 1.993828] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.994619] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A [ 1.995450] console [ttyS2] enabled [ 1.997280] [drm] Initialized drm 1.1.0 20060810 [ 1.999693] [drm] Rockchip DRM driver version: v1.0.1 [ 1.999929] rockchip-drm display-subsystem: devfreq is not set [ 2.000709] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0) [ 2.001136] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports [ 2.001164] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.001269] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy) [ 2.002514] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808) [ 2.002537] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.002548] [drm] No driver support for vblank timestamp query. [ 2.002679] rockchip-drm display-subsystem: failed to parse display resources [ 2.628657] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11 [ 2.629350] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 2.629358] dwhdmi-rockchip 200a0000.hdmi: colorspace: RGB [ 2.629365] dwhdmi-rockchip 200a0000.hdmi: scan mode: Underscan [ 2.629371] dwhdmi-rockchip 200a0000.hdmi: colorimetry: No Data [ 2.629377] dwhdmi-rockchip 200a0000.hdmi: picture aspect: 16:9 [ 2.629384] dwhdmi-rockchip 200a0000.hdmi: active aspect: Same as Picture [ 2.629390] dwhdmi-rockchip 200a0000.hdmi: itc: IT Content [ 2.629397] dwhdmi-rockchip 200a0000.hdmi: extended colorimetry: xvYCC 601 [ 2.629403] dwhdmi-rockchip 200a0000.hdmi: quantization range: Full [ 2.629410] dwhdmi-rockchip 200a0000.hdmi: nups: Unknown Non-uniform Scaling [ 2.629416] dwhdmi-rockchip 200a0000.hdmi: video code: 16 [ 2.629423] dwhdmi-rockchip 200a0000.hdmi: ycc quantization range: Full [ 2.629429] dwhdmi-rockchip 200a0000.hdmi: hdmi content type: Graphics [ 2.629435] dwhdmi-rockchip 200a0000.hdmi: pixel repeat: 0 [ 2.629443] dwhdmi-rockchip 200a0000.hdmi: bar top 0, bottom 0, left 0, right 0 [ 2.703640] Console: switching to colour frame buffer device 240x67 [ 2.753680] rockchip-drm display-subsystem: fb0: frame buffer device [ 2.769371] Registered IR keymap rc-cec [ 2.769637] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0 [ 2.770317] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0 [ 2.772629] brd: module loaded [ 2.784423] loop: module loaded [ 2.784496] lkdtm: No crash points registered, enable through debugfs [ 2.787147] libphy: Fixed MDIO Bus: probed [ 2.787182] tun: Universal TUN/TAP device driver, 1.6 [ 2.787193] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 2.787582] CAN device driver interface [ 2.789146] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output). [ 2.789177] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30). [ 2.789193] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10). [ 2.789235] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes). [ 2.789412] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed [ 2.794503] rk_gmac-dwmac 30200000.ethernet: init for RMII [ 2.828703] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 2.828720] Ring mode enabled [ 2.828731] DMA HW capability register supported [ 2.828740] Normal descriptors [ 2.828752] RX Checksum Offload Engine supported (type 2) [ 2.828761] TX Checksum insertion supported [ 2.828770] Wake-Up On Lan supported [ 2.828864] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 06:1a:57:11:bc:e4 [ 2.828879] eth%d: device MAC address 06:1a:57:11:bc:e4 [ 2.828888] Enable RX Mitigation via HW Watchdog Timer [ 2.829108] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0) [ 3.260923] libphy: stmmac: probed [ 3.260956] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active [ 3.260971] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01) [ 3.260983] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02) [ 3.260996] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03) [ 3.261008] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04) [ 3.261020] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05) [ 3.261033] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06) [ 3.261046] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07) [ 3.261058] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08) [ 3.261071] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09) [ 3.261083] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a) [ 3.261096] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b) [ 3.261108] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c) [ 3.261122] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d) [ 3.261135] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e) [ 3.261148] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f) [ 3.261161] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10) [ 3.261173] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11) [ 3.261185] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12) [ 3.261198] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13) [ 3.261211] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14) [ 3.261224] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15) [ 3.261237] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16) [ 3.261250] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17) [ 3.261262] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18) [ 3.261274] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19) [ 3.261287] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a) [ 3.261299] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b) [ 3.261313] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c) [ 3.261326] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d) [ 3.261338] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e) [ 3.261350] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f) [ 3.262893] PPP generic driver version 2.4.2 [ 3.263288] Atmel at76x USB Wireless LAN Driver 0.17 loading [ 3.263434] usbcore: registered new interface driver at76c50x-usb [ 3.263575] usbcore: registered new interface driver rtl8187 [ 3.263692] usbcore: registered new interface driver rndis_wlan [ 3.263815] usbcore: registered new interface driver zd1201 [ 3.264234] usbcore: registered new interface driver rt2800usb [ 3.264358] Rockchip WiFi SYS interface (V1.00) ... [ 3.264433] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 3.264525] usbcore: registered new interface driver pegasus [ 3.264778] usbcore: registered new interface driver rtl8150 [ 3.264874] usbcore: registered new interface driver r8152 [ 3.264999] usbcore: registered new interface driver asix [ 3.265099] usbcore: registered new interface driver ax88179_178a [ 3.265186] usbcore: registered new interface driver cdc_ether [ 3.265272] usbcore: registered new interface driver dm9601 [ 3.265379] usbcore: registered new interface driver smsc75xx [ 3.265481] usbcore: registered new interface driver smsc95xx [ 3.265574] usbcore: registered new interface driver net1080 [ 3.265660] usbcore: registered new interface driver rndis_host [ 3.265743] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 3.265898] usbcore: registered new interface driver cdc_ncm [ 3.265987] usbcore: registered new interface driver cdc_mbim [ 3.266509] 30040000.usb supply vusb_d not found, using dummy regulator [ 3.266645] 30040000.usb supply vusb_a not found, using dummy regulator [ 3.281605] dwc2 30040000.usb: DWC OTG Controller [ 3.281664] dwc2 30040000.usb: new USB bus registered, assigned bus number 1 [ 3.281727] dwc2 30040000.usb: irq 48, io mem 0x30040000 [ 3.282095] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.282115] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.282130] usb usb1: Product: DWC OTG Controller [ 3.282145] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg [ 3.282160] usb usb1: SerialNumber: 30040000.usb [ 3.283224] hub 1-0:1.0: USB hub found [ 3.283296] hub 1-0:1.0: 1 port detected [ 3.284977] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.285009] ehci-platform: EHCI generic platform driver [ 3.287575] ehci-platform 30080000.usb: EHCI Host Controller [ 3.287991] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2 [ 3.288312] ehci-platform 30080000.usb: irq 49, io mem 0x30080000 [ 3.296624] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00 [ 3.296939] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.296958] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.296973] usb usb2: Product: EHCI Host Controller [ 3.296988] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd [ 3.297003] usb usb2: SerialNumber: 30080000.usb [ 3.298055] hub 2-0:1.0: USB hub found [ 3.298130] hub 2-0:1.0: 1 port detected [ 3.301130] ehci-platform 300c0000.usb: EHCI Host Controller [ 3.301578] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3 [ 3.301888] ehci-platform 300c0000.usb: irq 51, io mem 0x300c0000 [ 3.312619] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00 [ 3.312968] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.312987] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.313002] usb usb3: Product: EHCI Host Controller [ 3.313016] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd [ 3.313030] usb usb3: SerialNumber: 300c0000.usb [ 3.314042] hub 3-0:1.0: USB hub found [ 3.314123] hub 3-0:1.0: 1 port detected [ 3.317063] ehci-platform 30100000.usb: EHCI Host Controller [ 3.317488] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4 [ 3.317828] ehci-platform 30100000.usb: irq 53, io mem 0x30100000 [ 3.328621] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00 [ 3.328963] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.328983] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.328998] usb usb4: Product: EHCI Host Controller [ 3.329012] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd [ 3.329026] usb usb4: SerialNumber: 30100000.usb [ 3.330051] hub 4-0:1.0: USB hub found [ 3.330127] hub 4-0:1.0: 1 port detected [ 3.330981] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.331031] ohci-platform: OHCI generic platform driver [ 3.331459] ohci-platform 300a0000.usb: Generic Platform OHCI controller [ 3.331881] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5 [ 3.332171] ohci-platform 300a0000.usb: irq 50, io mem 0x300a0000 [ 3.388867] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.388891] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.388906] usb usb5: Product: Generic Platform OHCI controller [ 3.388920] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd [ 3.388935] usb usb5: SerialNumber: 300a0000.usb [ 3.390025] hub 5-0:1.0: USB hub found [ 3.390102] hub 5-0:1.0: 1 port detected [ 3.391003] ohci-platform 300e0000.usb: Generic Platform OHCI controller [ 3.391412] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6 [ 3.391712] ohci-platform 300e0000.usb: irq 52, io mem 0x300e0000 [ 3.448872] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.448894] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.448909] usb usb6: Product: Generic Platform OHCI controller [ 3.448923] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd [ 3.448936] usb usb6: SerialNumber: 300e0000.usb [ 3.449976] hub 6-0:1.0: USB hub found [ 3.450051] hub 6-0:1.0: 1 port detected [ 3.450901] ohci-platform 30120000.usb: Generic Platform OHCI controller [ 3.451295] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7 [ 3.451551] ohci-platform 30120000.usb: irq 54, io mem 0x30120000 [ 3.508866] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.508892] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.508907] usb usb7: Product: Generic Platform OHCI controller [ 3.508922] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd [ 3.508936] usb usb7: SerialNumber: 30120000.usb [ 3.509970] hub 7-0:1.0: USB hub found [ 3.510045] hub 7-0:1.0: 1 port detected [ 3.511269] usbcore: registered new interface driver cdc_acm [ 3.511289] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.511398] usbcore: registered new interface driver cdc_wdm [ 3.511694] usbcore: registered new interface driver usb-storage [ 3.511892] usbcore: registered new interface driver usbserial [ 3.511976] usbcore: registered new interface driver usbserial_generic [ 3.512042] usbserial: USB Serial support registered for generic [ 3.512153] usbcore: registered new interface driver keyspan [ 3.512212] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 3.512269] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 3.512328] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 3.512387] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 3.512498] usbcore: registered new interface driver option [ 3.512614] usbserial: USB Serial support registered for GSM modem (1-port) [ 3.513384] usbcore: registered new interface driver oti6858 [ 3.513458] usbserial: USB Serial support registered for oti6858 [ 3.513566] usbcore: registered new interface driver qcserial [ 3.513627] usbserial: USB Serial support registered for Qualcomm USB modem [ 3.513786] usbcore: registered new interface driver sierra [ 3.513847] usbserial: USB Serial support registered for Sierra USB modem [ 3.515449] usbcore: registered new interface driver iforce [ 3.515620] usbcore: registered new interface driver xpad [ 3.515934] usbcore: registered new interface driver usbtouchscreen [ 3.517278] i2c /dev entries driver [ 3.519259] IR NEC protocol handler initialized [ 3.519287] IR RC5(x/sz) protocol handler initialized [ 3.519304] IR RC6 protocol handler initialized [ 3.519321] IR JVC protocol handler initialized [ 3.519338] IR Sony protocol handler initialized [ 3.519355] IR SANYO protocol handler initialized [ 3.519372] IR Sharp protocol handler initialized [ 3.519389] IR MCE Keyboard/mouse protocol handler initialized [ 3.519407] IR XMP protocol handler initialized [ 3.521255] usbcore: registered new interface driver uvcvideo [ 3.521273] USB Video Class driver (1.1.1) [ 3.523302] Boot mode: normal [ 3.524522] rockchip-thermal 11150000.tsadc: tsadc is probed successfully! [ 3.526338] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com [ 3.526763] Bluetooth: Virtual HCI driver ver 1.5 [ 3.527042] Bluetooth: HCI UART driver ver 2.3 [ 3.527060] Bluetooth: HCI UART protocol H4 registered [ 3.527072] Bluetooth: HCI UART protocol LL registered [ 3.527082] Bluetooth: HCI UART protocol ATH3K registered [ 3.527094] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 3.527267] Bluetooth: HCI UART protocol BCM registered [ 3.527427] usbcore: registered new interface driver bfusb [ 3.527573] usbcore: registered new interface driver btusb [ 3.527596] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 3.528247] cpu cpu0: leakage=4 [ 3.528278] cpu cpu0: leakage-volt-sel=0 [ 3.528474] cpu cpu0: Failed to get pvtm [ 3.530256] cpu cpu0: avs=0 [ 3.530341] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 [ 3.530367] cpu cpu0: failed to read out thermal zone (-22) [ 3.531052] cpu cpu0: failed to find power_model node [ 3.531688] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset [ 3.531707] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup [ 3.531728] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0) [ 3.532077] Synopsys Designware Multimedia Card Interface Driver [ 3.532818] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode. [ 3.532948] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller. [ 3.532966] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a [ 3.533032] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo [ 3.533087] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found [ 3.533097] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found [ 3.533117] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd [ 3.533126] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup [ 3.533152] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0) [ 3.533193] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations [ 3.533204] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO [ 3.533214] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp [ 3.533223] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup [ 3.533232] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]' [ 3.533240] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]' [ 3.533248] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup [ 3.533257] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed [ 3.544652] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 3.557540] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized [ 3.557921] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available [ 3.558005] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode. [ 3.558115] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller. [ 3.558133] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a [ 3.558191] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo [ 3.558249] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found [ 3.558259] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found [ 3.558277] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp [ 3.558286] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup [ 3.558297] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]' [ 3.558305] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]' [ 3.558314] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup [ 3.558323] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed [ 3.558395] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq [ 3.571206] mmc_host mmc1: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3) [ 3.583803] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized [ 3.584222] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/auxiliary[0]' - status (0) [ 3.584456] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0) [ 3.584781] ledtrig-cpu: registered to indicate activity on CPUs [ 3.584884] hidraw: raw HID events driver (C) Jiri Kosina [ 3.585373] usbcore: registered new interface driver usbhid [ 3.585386] usbhid: USB HID core driver [ 3.585732] ashmem: initialized [ 3.587432] rknandbase v1.2 2018-05-08 [ 3.588066] rknand 30030000.nandc: rknand_probe clk rate = 150000000 [ 3.588271] No.1 FLASH ID:2c 64 44 32 a5 0 [ 3.591782] No.1 FLASH ID:2c 64 44 32 a5 0 [ 3.592308] ECC:60 [ 3.592327] FTL version: 5.0.57 20190828 [ 3.769538] ftl_init 0 [ 3.780321] rknand0: p1 [ 3.781415] vendor storage 0,0,0 [ 3.781465] vendor storage 0,0,0 [ 3.781681] rknand vendor storage init ok ! [ 3.782441] usbcore: registered new interface driver snd-usb-audio [ 3.782541] usbcore: registered new interface driver snd-ua101 [ 3.782629] usbcore: registered new interface driver snd-usb-caiaq [ 3.782705] usbcore: registered new interface driver snd-usb-6fire [ 3.782789] usbcore: registered new interface driver snd-usb-hiface [ 3.782867] usbcore: registered new interface driver snd-bcd2000 [ 3.782943] usbcore: registered new interface driver snd_usb_pod [ 3.783007] usbcore: registered new interface driver snd_usb_podhd [ 3.783073] usbcore: registered new interface driver snd_usb_toneport [ 3.783133] usbcore: registered new interface driver snd_usb_variax [ 3.787191] u32 classifier [ 3.787211] input device check on [ 3.787219] Actions configured [ 3.787236] Netfilter messages via NETLINK v0.30. [ 3.787263] nfnl_acct: registering with nfnetlink. [ 3.787354] nf_conntrack version 0.5.0 (15884 buckets, 63536 max) [ 3.788180] Initializing XFRM netlink socket [ 3.789148] NET: Registered protocol family 10 [ 3.790412] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.790852] sit: IPv6 over IPv4 tunneling driver [ 3.791629] NET: Registered protocol family 17 [ 3.791673] NET: Registered protocol family 15 [ 3.791736] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 3.791773] Bridge firewalling registered [ 3.791784] can: controller area network core (rev 20120528 abi 9) [ 3.791897] NET: Registered protocol family 29 [ 3.791915] can: raw protocol (rev 20120528) [ 3.791927] can: broadcast manager protocol (rev 20120528 t) [ 3.791945] can: netlink gateway (rev 20130117) max_hops=1 [ 3.792362] Bluetooth: RFCOMM TTY layer initialized [ 3.792396] Bluetooth: RFCOMM socket layer initialized [ 3.792437] Bluetooth: RFCOMM ver 1.11 [ 3.792471] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.792502] Bluetooth: HIDP socket layer initialized [ 3.792679] 8021q: 802.1Q VLAN Support v1.8 [ 3.792722] lib80211: common routines for IEEE802.11 drivers [ 3.792732] lib80211_crypt: registered algorithm 'NULL' [ 3.792746] lib80211_crypt: registered algorithm 'WEP' [ 3.792759] lib80211_crypt: registered algorithm 'CCMP' [ 3.792774] lib80211_crypt: registered algorithm 'TKIP' [ 3.792785] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.793108] [BT_RFKILL]: Enter rfkill_rk_init [ 3.793315] Key type dns_resolver registered [ 3.793610] flash vendor_init_thread! [ 3.793627] flash vendor storage:20170308 ret = -1 [ 3.793693] Error: Driver 'sc031gs' is already registered, aborting... [ 3.794435] Registering SWP/SWPB emulation handler [ 3.795347] registered taskstats version 1 [ 3.795372] Loading compiled-in X.509 certificates [ 3.798022] Btrfs loaded [ 3.799135] rga2: Driver loaded successfully ver:4.01 [ 3.799411] rga2: Module initialized. [ 3.799448] pvtm list NULL [ 3.800498] rk-vcodec 20030000.rkvdec: leakage=3 [ 3.800627] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0 [ 3.800741] rk-vcodec 20030000.rkvdec: Failed to get pvtm [ 3.801124] rk-vcodec 20030000.rkvdec: avs=0 [ 3.801392] rk-vcodec 20030000.rkvdec: probe device [ 3.801816] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled [ 3.803047] rk-vcodec 20030000.rkvdec: init success [ 3.803250] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 3.804410] mmc1: new high speed SDIO card at address 0001 [ 3.804414] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' [ 3.804425] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' [ 3.805467] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok [ 3.807073] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' [ 3.807095] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' [ 3.807999] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok [ 3.809936] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/reset[0]' - status (0) [ 3.810021] gpio-121 (reset): gpiod_set_debounce: missing set() or set_debounce() operations [ 3.810330] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 3.810750] hctosys: unable to open rtc device (rtc0) [ 3.822274] ALSA device list: [ 3.822303] #0: DW-I2S-HDMI [ 3.822310] #1: SPDIF [ 3.823309] Freeing unused kernel memory: 808K [ 3.823320] This architecture does not have kernel memory protection. [ 3.908717] usb 5-1: new full-speed USB device number 2 using ohci-platform [ 4.121760] usb 5-1: New USB device found, idVendor=24ae, idProduct=2010 [ 4.121792] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.121803] usb 5-1: Product: Rapoo 2.4G Wireless Device [ 4.121812] usb 5-1: Manufacturer: RAPOO [ 4.130800] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:24AE:2010.0001/input/input2 [ 4.131521] hid-generic 0003:24AE:2010.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-300a0000.usb-1/input0 [ 4.140784] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:24AE:2010.0002/input/input3 [ 4.198116] hid-generic 0003:24AE:2010.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-300a0000.usb-1/input1 [ 4.203827] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.2/0003:24AE:2010.0003/input/input4 [ 4.258000] hid-generic 0003:24AE:2010.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-300a0000.usb-1/input2 [ 4.887051] EXT4-fs (rknand0p1): mounted filesystem with writeback data mode. Opts: (null) [ 5.679131] systemd[1]: System time before build time, advancing clock. [ 5.698526] systemd[1]: Inserted module 'autofs4' [ 5.712744] ip_tables: (C) 2000-2006 Netfilter Core Team [ 5.722571] cgroup: cgroup2: unknown option "nsdelegate" [ 5.739621] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 5.741242] systemd[1]: Detected architecture arm. [ 5.762851] systemd[1]: Set hostname to <rk322x-box>. [ 5.905126] ttyS2 - failed to request DMA, use interrupt mode [ 6.094968] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 6.095008] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 6.510615] random: systemd: uninitialized urandom read (16 bytes read, 115 bits of entropy available) [ 6.523379] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 6.523522] random: systemd: uninitialized urandom read (16 bytes read, 116 bits of entropy available) [ 6.523624] systemd[1]: Reached target Swap. [ 6.524806] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 6.524957] random: systemd: uninitialized urandom read (16 bytes read, 116 bits of entropy available) [ 6.525869] systemd[1]: Listening on Journal Socket. [ 6.528956] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 6.529502] random: systemd: uninitialized urandom read (16 bytes read, 117 bits of entropy available) [ 6.536965] systemd[1]: Mounting Kernel Debug File System... [ 6.538464] random: systemd: uninitialized urandom read (16 bytes read, 117 bits of entropy available) [ 6.546235] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 6.547363] random: systemd: uninitialized urandom read (16 bytes read, 118 bits of entropy available) [ 6.604261] systemd[1]: Starting Restore / save the current clock... [ 6.605222] random: systemd: uninitialized urandom read (16 bytes read, 121 bits of entropy available) [ 6.607250] systemd[1]: Created slice system-getty.slice. [ 6.608264] random: systemd: uninitialized urandom read (16 bytes read, 121 bits of entropy available) [ 6.608395] systemd[1]: Reached target System Time Synchronized. [ 6.621399] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 6.621584] random: systemd: uninitialized urandom read (16 bytes read, 121 bits of entropy available) [ 6.622534] systemd[1]: Listening on fsck to fsckd communication Socket. [ 6.623488] random: systemd: uninitialized urandom read (16 bytes read, 121 bits of entropy available) [ 6.629971] systemd[1]: Starting Set the console keyboard layout... [ 6.638821] systemd[1]: Mounting POSIX Message Queue File System... [ 6.642696] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 6.644187] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.645515] systemd[1]: Reached target Paths. [ 6.646427] systemd[1]: Reached target Local Encrypted Volumes. [ 6.647946] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 6.649916] systemd[1]: Listening on udev Kernel Socket. [ 6.651698] systemd[1]: Listening on udev Control Socket. [ 6.659668] systemd[1]: Starting udev Coldplug all Devices... [ 6.667494] systemd[1]: Starting Nameserver information manager... [ 6.683780] systemd[1]: Starting Load Kernel Modules... [ 6.685089] systemd[1]: Reached target Remote File Systems. [ 6.686895] systemd[1]: Condition check resulted in Huge Pages File System being skipped. [ 6.689623] systemd[1]: Created slice User and Session Slice. [ 6.690574] systemd[1]: Reached target Slices. [ 6.691240] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 6.699089] systemd[1]: Starting Remount Root and Kernel File Systems... [ 6.701732] systemd[1]: Listening on Syslog Socket. [ 6.703465] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.710598] systemd[1]: Mounted Kernel Debug File System. [ 6.717175] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 6.742703] systemd[1]: Started Restore / save the current clock. [ 6.744881] systemd[1]: Mounted POSIX Message Queue File System. [ 6.766566] random: nonblocking pool is initialized [ 6.777553] systemd[1]: Started Nameserver information manager. [ 6.783623] systemd[1]: Started Load Kernel Modules. [ 6.793488] systemd[1]: Starting Apply Kernel Variables... [ 6.795250] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 6.804193] systemd[1]: Mounting Kernel Configuration File System... [ 6.816822] vendor storage:20190527 ret = -1 [ 6.824686] systemd[1]: Mounted Kernel Configuration File System. [ 6.875966] systemd[1]: Started Apply Kernel Variables. [ 6.901658] EXT4-fs (rknand0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 6.911994] systemd[1]: Started Remount Root and Kernel File Systems. [ 6.921087] systemd[1]: Starting Load/Save Random Seed... [ 6.932214] systemd[1]: Starting Create System Users... [ 6.943636] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 7.065383] systemd[1]: Started Load/Save Random Seed. [ 7.090657] systemd[1]: Started Create System Users. [ 7.098398] systemd[1]: Starting Create Static Device Nodes in /dev... [ 7.152021] systemd[1]: Started Set the console keyboard layout. [ 7.199716] systemd[1]: Started Create Static Device Nodes in /dev. [ 7.206319] systemd[1]: Starting udev Kernel Device Manager... [ 7.207288] systemd[1]: Reached target Local File Systems (Pre). [ 7.215638] systemd[1]: Mounting /tmp... [ 7.235979] systemd[1]: Mounted /tmp. [ 7.237815] systemd[1]: Reached target Local File Systems. [ 7.245462] systemd[1]: Starting Armbian ZRAM config... [ 7.252784] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped. [ 7.253324] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 7.260403] systemd[1]: Starting Set console font and keymap... [ 7.300208] systemd[1]: Started Set console font and keymap. [ 7.346837] systemd[1]: Started udev Coldplug all Devices. [ 7.360718] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.396458] systemd[1]: Started udev Kernel Device Manager. [ 7.492000] systemd[1]: Started Helper to synchronize boot up for ifupdown. [ 7.542052] systemd[1]: Starting Raise network interfaces... [ 7.761730] zram: Added device: zram0 [ 7.763319] zram: Added device: zram1 [ 7.767331] zram: Added device: zram2 [ 7.778130] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en [ 7.778160] rk3228-codec 12010000.codec: using device tree for GPIO lookup [ 7.778175] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]' [ 7.778213] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0) [ 7.778306] rk3228-codec 12010000.codec: spk_depop_time use default value. [ 7.780331] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [ 7.780361] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [ 7.787064] systemd[1]: Found device /dev/ttyS2. [ 7.818883] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '08:48:47', on 'Mar 9 2021'. [ 7.819183] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13 [ 7.819206] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000 [ 7.819217] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000 [ 7.819226] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000 [ 7.819236] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000 [ 7.819244] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000 [ 7.819255] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000 [ 7.819264] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000 [ 7.819273] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020 [ 7.819282] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021 [ 7.819291] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022 [ 7.819300] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021 [ 7.819309] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022 [ 7.819317] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021 [ 7.819328] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali. [ 7.819653] mali-utgard 20001000.gpu: leakage=3 [ 7.819684] mali-utgard 20001000.gpu: leakage-volt-sel=0 [ 7.819800] mali-utgard 20001000.gpu: Failed to get pvtm [ 7.820274] mali-utgard 20001000.gpu: avs=0 [ 7.820810] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 [ 7.826555] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok [ 7.831523] Mali: Mali device driver loaded [ 8.043805] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null) [ 8.043835] gpio_ir_recv ir-receiver: using device tree for GPIO lookup [ 8.043885] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0) [ 8.044017] Registered IR keymap rc-rktvbox [ 8.044255] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1 [ 8.044859] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input5 [ 8.064244] generic_wifi_init_module [ 8.336100] zram0: detected capacity change from 0 to 520933376 [ 8.340793] *** sta_cfg_set, (null) *** [ 8.340841] redirect to /lib/firmware/ssv6051-wifi.cfg [ 8.383626] ssv6xxx_sdio_init [ 8.383994] ======================================= [ 8.384017] == RUN SDIO == [ 8.384025] ======================================= [ 8.384040] ssv6xxx_set_sdio_clk:set sdio clk 25000000Hz [ 8.384147] mmc_host mmc1: Bus speed (slot 0) = 25000000Hz (slot req 25000000Hz, actual 25000000HZ div = 0) [ 8.423048] SSV6XXX_SDIO mmc1:0001:1: vendor = 0x3030 device = 0x3030 [ 8.460180] ssv6xxx_sdio_power_on [ 8.490971] SSV6XXX_SDIO mmc1:0001:1: dataIOPort 0x10000 regIOPort 0x10020 [ 8.491715] ssv6xxx_dev_probe(): ssv6200 device found ! [ 8.496100] Adding 508720k swap on /dev/zram0. Priority:5 extents:1 across:508720k SS [ 8.513880] ssv6xxx_sdio_irq_disable [ 8.515867] MAC address from e-fuse [ 8.515901] EFUSE configuration [ 8.515918] Read efuse chip identity[75000000] [ 8.515929] r_calbration_result- 0 [ 8.515940] sar_result- 0 [ 8.515948] crystal_frequency_offset- 0 [ 8.515961] tx_power_index_1- 0 [ 8.515970] tx_power_index_2- 0 [ 8.515986] MAC address - 3c:cf:5b:14:0f:b3 [ 8.541140] Registering Vendor80211 [ 8.541175] Register SSV cfg80211 vendor cmd(0x67) interface [ 8.543156] [MT-ENCRYPT]: create kthread ecf1ec80 for CPU 0, ret = 0 [ 8.543440] [MT-ENCRYPT]: create kthread ecf1f440 for CPU 1, ret = 0 [ 8.543502] SSV WLAN driver ssv6200: Crypto task 446 running with priority 120. [ 8.543601] SSV WLAN driver ssv6200: Crypto task 445 running with priority 120. [ 8.543621] [MT-ENCRYPT]: create kthread ecf18000 for CPU 2, ret = 0 [ 8.546339] SSV WLAN driver ssv6200: Crypto task 447 running with priority 120. [ 8.547235] [MT-ENCRYPT]: create kthread ed6b8000 for CPU 3, ret = 0 [ 8.548771] SSV WLAN driver ssv6200: Crypto task 448 running with priority 120. [ 8.552840] SSV6XXX TX Task started. [ 8.561849] Pre-load cipher [ 8.562080] flash_file /tmp/flash.bin not found, disable sar [ 8.562105] SSV6051P setting [ 8.562123] SSV6XXX_IQK_CFG_XTAL_24M [ 8.562141] SSV6051P setting [0x6C726C72] [ 8.562155] TX power setting 0x6c726c72 [ 8.562169] Volt regulator LDO [ 8.562248] SSV6XXX RX Task started. [ 8.565845] reset PLL [ 8.595845] ieee80211 phy0: Selected rate control algorithm 'ssv6xxx_rate_control' [ 8.602350] ieee80211 phy0: SSV6200 of South Silicon Valley [ 8.653282] cfg80211: World regulatory domain updated: [ 8.653297] cfg80211: DFS Master region: unset [ 8.653297] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [ 8.653313] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ 8.653318] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 8.653323] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [ 8.653328] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 8.653333] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [ 8.653339] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [ 8.653343] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [ 8.653346] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [ 8.756468] systemd[1]: Started Raise network interfaces. [ 8.896375] zram1: detected capacity change from 0 to 52428800 [ 8.957992] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 8.967004] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 8.967550] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 8.968249] systemd[1]: Condition check resulted in Huge Pages File System being skipped. [ 8.968399] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 8.968629] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 8.969122] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 8.969384] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 8.969952] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 8.975800] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 8.991922] systemd[1]: Started Armbian ZRAM config. [ 9.005568] systemd[1]: Starting Armbian memory supported logging... [ 9.123949] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 9.151402] systemd[1]: Started Load/Save RF Kill Switch Status. [ 12.404404] systemd[1]: Started Armbian memory supported logging. [ 12.417110] systemd[1]: Starting Journal Service... [ 12.826447] systemd[1]: Started Journal Service. [ 12.899963] systemd-journald[594]: Received request to flush runtime journal from PID 1 [ 14.050105] nr_pdflush_threads exported in /proc is scheduled for removal [ 24.631319] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 24.750779] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 24.752397] SVN version 16529 [ 24.752427] SVN ROOT URL http://192.168.15.30/svn/software/project/release/android/box/rk3x28/6051.Q0.1009.21.400401/ssv6xxx [ 24.752436] COMPILER HOST icomm-buildserver-T320 [ 24.752443] COMPILER DATE 12-08-2017-10:34:54 [ 24.752450] COMPILER OS linux [ 24.752456] COMPILER OS ARCH x86_64-linux-gnu-thread-multi [ 24.752881] CHIP TAG: 2014012420010960 [ 24.753331] CHIP ID: RSV6200A0-201311 [ 24.757051] 0x800e0000 [ 24.800866] ADR_INFO_IDX_ADDR[80000230] ADR_INFO_LEN_ADDR[800002cc] [ 24.803729] Writing firmware to SSV6XXX... [ 24.901168] (block_count << 16) = 500000,reg =500000 [ 24.901226] Firmware "/lib/firmware/ssv6051-sw.bin" loaded [ 24.956763] Firmware check OK.d0000 = d0000 [ 25.012616] Firmware name sh->cfg.firmware_path=/lib/firmware/ssv6051-sw.bin [ 25.012823] Firmware version 16380 [ 25.012832] ssv6xxx_watchdog_controller 6 [ 25.013091] ssv6xxx_sdio_irq_enable [ 25.013291] # Do init_cali (iq) [ 25.013724] FW TX LOOPBACK OK [ 25.013756] +++++++++++++++++++++++++++222222222222222!! [ 25.013909] ssv6200_start(): current channel: 1,sc->ps_status=0 [ 25.015932] ssv6200_add_interface(): vif->type = 2, NL80211_IFTYPE_AP=3 [ 25.015949] ssv6xxx_config_vif_res id[0]. [ 25.015970] SSV WLAN driver ssv6200: VIF 3c:cf:5b:14:0f:b3 of type 2 is added. [ 25.016012] BSS Changed use_short_preamble[0] [ 25.016021] BSS_CHANGED_ERP_SLOT: use_short_slot[0] [ 25.016201] NL80211_IFTYPE_STATION!! [ 25.016214] ssv6200_bss_info_changed(): leave [ 25.016241] sv6200_conf_tx vif[0] qos[0] queue[0] aifsn[2] cwmin[15] cwmax[1023] txop[0] [ 25.016377] sv6200_conf_tx vif[0] qos[0] queue[1] aifsn[2] cwmin[15] cwmax[1023] txop[0] [ 25.016624] sv6200_conf_tx vif[0] qos[0] queue[2] aifsn[2] cwmin[15] cwmax[1023] txop[0] [ 25.016770] sv6200_conf_tx vif[0] qos[0] queue[3] aifsn[2] cwmin[15] cwmax[1023] txop[0] [ 25.016927] NL80211_IFTYPE_STATION!! [ 25.016943] ssv6200_bss_info_changed(): leave [ 25.016957] Disable IEEE80211_CONF_PS ps_aid=0 [ 25.017126] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 25.182898] FW TX LOOPBACK OK [ 25.452398] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 26.808739] rc rc1: two consecutive events of type space [ 73.870923] wlan0: authenticate with 38:10:d5:66:ca:e0 [ 73.870988] ssv6xxx_rate_alloc_sta(): use index 0 [ 73.874201] NL80211_IFTYPE_STATION!! [ 73.874229] ssv6200_bss_info_changed(): leave [ 73.874238] NL80211_IFTYPE_STATION!! [ 73.874244] ssv6200_bss_info_changed(): leave [ 73.874339] BSS_CHANGED_BSSID: 38:10:d5:66:ca:e0 [ 73.874350] ssv6xxx_rc_update_basic_rate!! [ 73.875371] NL80211_IFTYPE_STATION!! [ 73.875389] ssv6200_bss_info_changed(): leave [ 73.875556] wlan0: send auth to 38:10:d5:66:ca:e0 (try 1/3) [ 73.879325] wlan0: authenticated [ 73.880692] wlan0: associate with 38:10:d5:66:ca:e0 (try 1/3) [ 73.898933] wlan0: RX AssocResp from 38:10:d5:66:ca:e0 (capab=0x1431 status=0 aid=1) [ 73.898973] ssv6xxx_rate_update_rc_type(): [ 73.898981] [RC init ]HT support wsid [ 73.898989] [RC]HT duration[0][13295] [ 73.898995] [RC]HT duration[1][6650] [ 73.899001] [RC]HT duration[2][4432] [ 73.899006] [RC]HT duration[3][3327] [ 73.899013] [RC]HT duration[4][2218] [ 73.899018] [RC]HT duration[5][1664] [ 73.899024] [RC]HT duration[6][1480] [ 73.899029] [RC]HT duration[7][1332] [ 73.899371] [RC]Init perfect_tx_time[0][1901] [ 73.899379] [RC]Init perfect_tx_time[1][1041] [ 73.899385] [RC]Init perfect_tx_time[2][749] [ 73.899391] [RC]Init perfect_tx_time[3][609] [ 73.899398] [RC]Init perfect_tx_time[4][461] [ 73.899403] [RC]Init perfect_tx_time[5][393] [ 73.899409] [RC]Init perfect_tx_time[6][369] [ 73.899415] [RC]Init perfect_tx_time[7][349] [ 73.899426] ssv6200_sta_add(): vif[0] rc_wsid[0] rc_idx[0] [ 73.899732] SSV WLAN driver ssv6200: Creating AMPDU TX debugfs. [ 73.901532] cmd=5 for fw wsid list, wsid 0 [ 73.901655] hw_update_watch_wsid: wsid_idx = 0 [ 73.901672] cmd=6 for fw wsid list, wsid 0 [ 73.902229] hw_update_watch_wsid: wsid_idx = 0 [ 73.902262] Add 38:10:d5:66:ca:e0 to VIF 0 sw_idx=0, wsid=0 [ 73.902281] sv6200_conf_tx vif[0] qos[0] queue[0] aifsn[2] cwmin[3] cwmax[7] txop[47] [ 73.902423] sv6200_conf_tx vif[0] qos[0] queue[1] aifsn[2] cwmin[7] cwmax[15] txop[94] [ 73.902568] sv6200_conf_tx vif[0] qos[0] queue[2] aifsn[3] cwmin[15] cwmax[1023] txop[0] [ 73.902688] sv6200_conf_tx vif[0] qos[0] queue[3] aifsn[7] cwmin[15] cwmax[1023] txop[0] [ 73.902879] BSS Changed use_short_preamble[1] [ 73.902890] BSS_CHANGED_ERP_SLOT: use_short_slot[1] [ 73.903041] NL80211_IFTYPE_STATION!! [ 73.903051] !!info->aid = 1 [ 73.903059] ssv6200_bss_info_changed(): leave [ 73.903104] wlan0: associated [ 73.903159] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 73.915204] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 38:10:d5:66:ca:e0 [ 73.915237] BSS_CHANGED_HT: Untreated!! [ 73.915244] NL80211_IFTYPE_STATION!! [ 73.915252] ssv6200_bss_info_changed(): leave [ 74.005176] SSV WLAN driver ssv6200: Set key VIF 0 VIF type 2 STA 0 algorithm = 4, key->keyidx = 0, cmd = 0 [ 74.005203] SSV WLAN driver ssv6200: Use WPA2 HW security mode only. [ 74.005212] first sta idx 0, current sta idx 0 [ 74.005373] ==>ssv6200_hw_set_pair_type: write cipher type 4 into hw [ 74.005816] ==>ssv6200_hw_get_pair_type: read cipher type 4 from hw [ 74.005909] cmd=5 for fw wsid list, wsid 0 [ 74.005967] hw_update_watch_wsid: wsid_idx = 0 [ 74.005981] set hw wsid 0 cipher mode to HW cipher for pairwise key [ 74.005989] sta: hw_en:0, sw_en:0, hw_de:1, sw_de:0, [ 74.005996] vif: hw_en:0, sw_en:0, hw_de:0, sw_de:0, use_mac80211 0, valid:0 [ 74.006002] SET KEY -95 [ 74.006915] SSV WLAN driver ssv6200: Set key VIF 0 VIF type 2 STA -1 algorithm = 4, key->keyidx = 2, cmd = 0 [ 74.006937] SSV WLAN driver ssv6200: Use WPA2 HW security mode only. [ 74.007123] Set group key type 4 [ 74.007479] cmd=6 for fw wsid list, wsid 0 [ 74.007492] set hw wsid 0 cipher mode to HW cipher for group key [ 74.007501] vif: hw_en:1, sw_en:0, hw_de:1, sw_de:0, use_mac80211 0, valid:1 [ 74.007507] SET KEY 0 [ 74.007588] cfg80211: Regulatory domain changed to country: DE [ 74.007603] cfg80211: DFS Master region: ETSI [ 74.007611] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [ 74.007624] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ 74.007635] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 74.007645] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s) [ 74.007654] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s) [ 74.007662] cfg80211: (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm), (N/A) [ 74.007671] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A) [ 74.068682] AMPDU_TX_START 38:10:D5:66:CA:E0 0. [ 74.071222] AMPDU_TX_OPERATIONAL 38:10:D5:66:CA:E0 0. [ 74.071246] ssv6200_ampdu_tx_operation:buffer_size=64 [ 74.110279] IEEE80211_AMPDU_RX_START 38:10:D5:66:CA:E0 0. [ 74.150520] NL80211_IFTYPE_STATION!! [ 74.150560] ssv6200_bss_info_changed(): leave [ 114.466768] GC des block 2cd done root@rk322x-v88mini4k:~# Reboot worked the first time. After I ran rk322x-config I haven't tried, but will reply if reboot is still working then. Unfortunately the wifi-issue is still onging... I need to ping my wanted remote device from V88-box before I can get ssh into it. So that's still very annoying, but guessing it is because of the good ssv6051 chipset... Yes, you are right. I meant of course kernel 4.4 I also tried the iperf3-test again and guess!! root@rk322x-v88mini4k:~# iperf3 -sD root@rk322x-v88mini4k:~# iperf3 -c localhost Connecting to host localhost, port 5201 [ 5] local ::1 port 54390 connected to ::1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 172 MBytes 1.44 Gbits/sec 0 895 KBytes [ 5] 1.00-2.01 sec 174 MBytes 1.45 Gbits/sec 0 895 KBytes [ 5] 2.01-3.00 sec 172 MBytes 1.45 Gbits/sec 0 1.31 MBytes [ 5] 3.00-4.00 sec 174 MBytes 1.45 Gbits/sec 0 1.31 MBytes [ 5] 4.00-5.00 sec 172 MBytes 1.45 Gbits/sec 0 1.31 MBytes [ 5] 5.00-6.01 sec 174 MBytes 1.45 Gbits/sec 0 1.31 MBytes [ 5] 6.01-7.00 sec 172 MBytes 1.45 Gbits/sec 0 1.31 MBytes [ 5] 7.00-8.00 sec 174 MBytes 1.45 Gbits/sec 0 1.31 MBytes [ 5] 8.00-9.00 sec 172 MBytes 1.45 Gbits/sec 0 1.31 MBytes [ 5] 9.00-10.01 sec 174 MBytes 1.45 Gbits/sec 0 1.31 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.01 sec 1.69 GBytes 1.45 Gbits/sec 0 sender [ 5] 0.00-10.01 sec 1.69 GBytes 1.45 Gbits/sec receiver iperf Done. Bammm... doubled the speed! Great work man! root@rk322x-v88mini4k:~# iperf3 -c 192.168.178.193 Connecting to host 192.168.178.193, port 5201 [ 5] local 192.168.178.161 port 57850 connected to 192.168.178.193 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 4.96 MBytes 41.6 Mbits/sec 0 280 KBytes [ 5] 1.00-2.03 sec 4.78 MBytes 39.0 Mbits/sec 0 366 KBytes [ 5] 2.03-3.00 sec 4.05 MBytes 34.9 Mbits/sec 0 378 KBytes [ 5] 3.00-4.00 sec 4.61 MBytes 38.6 Mbits/sec 0 378 KBytes [ 5] 4.00-5.00 sec 4.49 MBytes 37.7 Mbits/sec 0 397 KBytes [ 5] 5.00-6.00 sec 4.04 MBytes 33.9 Mbits/sec 0 397 KBytes [ 5] 6.00-7.00 sec 4.60 MBytes 38.7 Mbits/sec 0 397 KBytes [ 5] 7.00-8.00 sec 4.22 MBytes 35.3 Mbits/sec 0 397 KBytes [ 5] 8.00-9.00 sec 4.39 MBytes 37.0 Mbits/sec 0 397 KBytes [ 5] 9.00-10.00 sec 4.21 MBytes 35.3 Mbits/sec 0 397 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 44.4 MBytes 37.2 Mbits/sec 0 sender [ 5] 0.00-10.11 sec 43.9 MBytes 36.4 Mbits/sec receiver iperf Done. root@rk322x-v88mini4k:~# iperf3 -c 192.168.178.193 -R Connecting to host 192.168.178.193, port 5201 Reverse mode, remote host 192.168.178.193 is sending [ 5] local 192.168.178.161 port 57854 connected to 192.168.178.193 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 4.06 MBytes 34.0 Mbits/sec [ 5] 1.00-2.00 sec 4.94 MBytes 41.4 Mbits/sec [ 5] 2.00-3.00 sec 5.28 MBytes 44.3 Mbits/sec [ 5] 3.00-4.00 sec 5.21 MBytes 43.7 Mbits/sec [ 5] 4.00-5.00 sec 5.25 MBytes 44.0 Mbits/sec [ 5] 5.00-6.00 sec 5.09 MBytes 42.7 Mbits/sec [ 5] 6.00-7.00 sec 5.14 MBytes 43.1 Mbits/sec [ 5] 7.00-8.00 sec 4.92 MBytes 41.3 Mbits/sec [ 5] 8.00-9.00 sec 5.18 MBytes 43.5 Mbits/sec [ 5] 9.00-10.00 sec 4.88 MBytes 40.9 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.10 sec 52.0 MBytes 43.2 Mbits/sec 38 sender [ 5] 0.00-10.00 sec 49.9 MBytes 41.9 Mbits/sec receiver iperf Done. root@rk322x-v88mini4k:~# FritzBox says the device could connect just with 20 MHz bandwith, that means that maximum data rate is 72 Mbit/s. So in this case 44 Mbit/s is ok in my opinion for now... I use 40 MHz bandwith on my FritzBox7490, but output about rk322x device is here: WLAN-Eigenschaften (2,4 GHz) Signalstärke-50dBm max. mögliche Datenrate72 / 72 Mbit/s aktuelle Datenrate71 / 72 Mbit/s WLAN-StandardWLAN-b+g+n / Wi-Fi 4 Frequenzband2,4 GHz Kanalbandbreite20 MHz Streams1 x 1 WLAN-Eigenschaften VerschlüsselungWPA2 Signaleigenschaften QoS (Quality of Service)WMM Repeaterbetriebnein So it's connected with it's maximum speed the v88 mini 4k Edited March 22, 2021 by SteeMan moved log file to 'spoiler' Link to post Share on other sites More sharing options...
jock 398 Posted March 20, 2021 Author Share Posted March 20, 2021 @Alex83 Very good! I'm very pleased to read that finally we got the best out of the board The wifi benchmark is excellent for a 72Mbit/s link,I'm not totally sure the chip is able to establish 40 Mhz links, I think it is a single stream chip so that is the maximum you can get from it, but nonetheless it is quite above the benchmarks I did in the past that were around 37Mbit/s. Thanks again for the patience, now I go to put credits on first page and a link to the instructions for people who wants to upgrade the NAND bootloader 1 Link to post Share on other sites More sharing options...
fabiobassa 100 Posted March 20, 2021 Share Posted March 20, 2021 OHHHH and finally here it goes Bravo Alex, but more bravo Jock 1 Link to post Share on other sites More sharing options...
gurzixo 5 Posted March 21, 2021 Share Posted March 21, 2021 (edited) Dear all, I have a few TV boxes, both amlogic and rockchip, and was able to install Armbian on many of them (with lots of blood, sweat and tears... Thanks a lot to Balbes150, Jock and Fabiobassa for all the superb work and the gold nuggets that they left in the various threads!!!). I am struggling now with a T96mini_V1.0 ( see https://pasteboard.co/JTEA7XS.jpg - I don't know why I can't insert pic in post...) which has an RK3228A (2G-16G). And has NO sdcard, I followed advice from the 1st post, but black screen... I want to use it as a headless linux server, so I don't care about media performance, but WIFI would be appreciable (see pic of chip: https://pasteboard.co/JTELgqj.jpg ) OK, so I found the serial console, soldered some wires, and saw a boot entirely in chinese... so no cues about dtb. I still have an android image that boots ok, so maybe I could extract DTB?. (Very) long story short, I was able to burn multitlool in emmc, and boot either from usb or emmc, but I get kernel panics every time (see below). I suspect that I have a wrong DTB, which does bad things... Here is the boot log, using a toothpick to boot the multitool image from usb: Spoiler Script started on 2021-03-21 15:38:14+00:00 [TERM="xterm-256color" TTY="/dev/pts/0" COLUMNS="168" LINES="99"] microcom -p /dev/ttyUSB0 -s 115200 connected to /dev/ttyUSB0 Escape character: Ctrl-\ Type the escape character to get to the prompt. DDR Version V1.10 20190926 In ID:0xFFF 660MHz DDR3 Bus Width=16 Col=11 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB mach:3 OUT Boot1 Release Time: May 13 2019 17:02:59, version: 2.56 ChipType = 0xc, 268 WR_REL_SET is 0 4 mmc2:cmd19,100 SdmmcInit=2 0 BootCapSize=2000 UserCapSize=14800MB FwPartOffset=2000 , 2000 SdmmcInit=0 NOT PRESENT StorageInit ok = 170836 SecureMode = 0 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x63337df8 signature is wrong recovery gpt... GPT 0x63337df8 signature is wrong recovery gpt fail! LOADER Check OK! 0x61000000, 253161 TOS Check OK! 0x68400000, 275234 Enter Trust OS INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-333-gc9d95d1 #2 2018年 08月 17日 星期五 03:32:22 UTC arm) INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 2.0 INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x61000000 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done U-Boot 2020.10-armbian+ (Mar 12 2021 - 13:38:05 +0000) Model: Generic Rockchip rk322x TV Box board DRAM: 2 GiB MMC: dwmmc@30000000: 1, dwmmc@30020000: 0 Loading Environment from EXT4... ** Unable to use mmc 0:auto for loading the env ** In: serial@11030000 Out: serial@11030000 Err: serial@11030000 Model: Generic Rockchip rk322x TV Box board Net: eth0: ethernet@30200000 starting USB... Bus usb@30040000: USB DWC2 Bus usb@30080000: USB EHCI 1.00 Bus usb@300c0000: USB EHCI 1.00 Bus usb@30100000: USB EHCI 1.00 scanning bus usb@30040000 for devices... 2 USB Device(s) found scanning bus usb@30080000 for devices... 1 USB Device(s) found scanning bus usb@300c0000 for devices... 1 USB Device(s) found scanning bus usb@30100000 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Hit any key to stop autoboot: 0 Card did not respond to voltage select! Device 0: Vendor: SteelRam Rev: PMAP Prod: A01 Type: Removable Hard Disk Capacity: 118272.0 MB = 115.5 GB (242221056 x 512) ... is now current device Scanning usb 0:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 175 bytes read in 13 ms (12.7 KiB/s) 1: Multitool Retrieving file: /kernel.img 8719272 bytes read in 258 ms (32.2 MiB/s) append: boot=PARTUUID=35cf475d-01 root=PARTUUID=35cf475d-02 rootwait console=ttyS2,115200 verbose=1 consoleblank=0 Retrieving file: /rk322x-box.dtb 46636 bytes read in 10 ms (4.4 MiB/s) ## Flattened Device Tree blob at 61f00000 Booting using the fdt blob at 0x61f00000 EHCI failed to shut down host controller. EHCI failed to shut down host controller. Loading Device Tree to 683f1000, end 683ff62b ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47 SMP Thu Apr 9 17:37:46 UTC 2020 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: Generic RK322x TV Box board [ 0.000000] cma: Reserved 128 MiB at 0xd8000000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 520704 [ 0.000000] free_area_init_node: node 0, pgdat b1236b40, node_mem_map eedfa000 [ 0.000000] Normal zone: 2304 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 258560 pages, LIFO batch:31 [ 0.000000] HighMem zone: 262144 pages, LIFO batch:31 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv65535.65535 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 14 pages/cpu @eed94000 s24856 r8192 d24296 u57344 [ 0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 518400 [ 0.000000] Kernel command line: boot=PARTUUID=35cf475d-01 root=PARTUUID=35cf475d-02 rootwait console=ttyS2,115200 verbose=1 consoleblank=0 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1911292K/2082816K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 40452K reserved, 131072K cma-reserved, 917504K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB) [ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB) [ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB) [ 0.000000] .text : 0xb0008000 - 0xb0c8d53c (12822 kB) [ 0.000000] .init : 0xb10a1000 - 0xb1168000 ( 796 kB) [ 0.000000] .data : 0xb1168000 - 0xb1242e94 ( 876 kB) [ 0.000000] .bss : 0xb1244000 - 0xb1374ee4 (1220 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000023] Switching to timer-based delay loop, resolution 41ns [ 0.001666] Console: colour dummy device 80x30 [ 0.001703] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001724] pid_max: default: 32768 minimum: 301 [ 0.001854] Security Framework initialized [ 0.001868] Yama: becoming mindful. [ 0.001945] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001961] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002841] Initializing cgroup subsys io [ 0.002878] Initializing cgroup subsys memory [ 0.002919] Initializing cgroup subsys devices [ 0.002939] Initializing cgroup subsys freezer [ 0.002957] Initializing cgroup subsys net_cls [ 0.002973] Initializing cgroup subsys perf_event [ 0.002991] Initializing cgroup subsys net_prio [ 0.003019] Initializing cgroup subsys pids [ 0.003088] CPU: Testing write buffer coherency: ok [ 0.003135] ftrace: allocating 41720 entries in 123 pages [ 0.082000] /cpus/cpu@f00 missing clock-frequency property [ 0.082031] /cpus/cpu@f01 missing clock-frequency property [ 0.082049] /cpus/cpu@f02 missing clock-frequency property [ 0.082069] /cpus/cpu@f03 missing clock-frequency property [ 0.082081] CPU0: update cpu_capacity 430 [ 0.082092] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.082170] Setting up static identity map for 0x60008280 - 0x600082d8 [ 0.084972] CPU1: update cpu_capacity 430 [ 0.084981] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.086076] CPU2: update cpu_capacity 430 [ 0.086084] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.087099] CPU3: update cpu_capacity 430 [ 0.087106] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.087241] Brought up 4 CPUs [ 0.087278] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.087287] CPU: All CPU(s) started in SVC mode. [ 0.088755] devtmpfs: initialized [ 0.106081] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.106599] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.106636] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.112611] xor: measuring software checksum speed [ 0.149973] arm4regs : 1011.000 MB/sec [ 0.190081] 8regs : 705.000 MB/sec [ 0.230186] 32regs : 684.000 MB/sec [ 0.270287] neon : 1018.000 MB/sec [ 0.270297] xor: using function: neon (1018.000 MB/sec) [ 0.270335] pinctrl core: initialized pinctrl subsystem [ 0.271890] NET: Registered protocol family 16 [ 0.274614] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.286444] cpuidle: using governor ladder [ 0.298457] cpuidle: using governor menu [ 0.314528] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 [ 0.314736] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 [ 0.314882] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 [ 0.315036] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 [ 0.320654] console [pstore-1] enabled [ 0.320666] pstore: Registered ramoops as persistent store backend [ 0.320679] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0 [ 0.323549] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.323568] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.419291] raid6: int32x1 gen() 133 MB/s [ 0.487363] raid6: int32x1 xor() 131 MB/s [ 0.555636] raid6: int32x2 gen() 166 MB/s [ 0.623705] raid6: int32x2 xor() 136 MB/s [ 0.692057] raid6: int32x4 gen() 163 MB/s [ 0.760317] raid6: int32x4 xor() 137 MB/s [ 0.828474] raid6: int32x8 gen() 166 MB/s [ 0.896737] raid6: int32x8 xor() 113 MB/s [ 0.964878] raid6: neonx1 gen() 382 MB/s [ 1.033018] raid6: neonx1 xor() 290 MB/s [ 1.101243] raid6: neonx2 gen() 519 MB/s [ 1.169377] raid6: neonx2 xor() 376 MB/s [ 1.237588] raid6: neonx4 gen() 581 MB/s [ 1.305812] raid6: neonx4 xor() 400 MB/s [ 1.374105] raid6: neonx8 gen() 560 MB/s [ 1.442290] raid6: neonx8 xor() 391 MB/s [ 1.442303] raid6: using algorithm neonx4 gen() 581 MB/s [ 1.442313] raid6: .... xor() 400 MB/s, rmw enabled [ 1.442323] raid6: using intx1 recovery algorithm [ 1.443269] rockchip-pm rockchip-suspend: not set wakeup-config [ 1.443290] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 1.443631] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]' [ 1.444114] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]' [ 1.444716] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0) [ 1.445326] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0) [ 1.445809] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' [ 1.446681] iommu: Adding device 20020000.vpu-service to group 0 [ 1.446783] iommu: Adding device 20030000.rkvdec to group 1 [ 1.446874] iommu: Adding device 20050000.vop to group 2 [ 1.446962] iommu: Adding device 20070000.iep to group 3 [ 1.447492] rk_iommu 20020800.iommu: can't get sclk [ 1.448068] rk_iommu 20030480.iommu: can't get sclk [ 1.448304] rk_iommu 20053f00.iommu: can't get sclk [ 1.448448] rk_iommu 20070800.iommu: can't get aclk [ 1.448467] rk_iommu 20070800.iommu: can't get hclk [ 1.448483] rk_iommu 20070800.iommu: can't get sclk [ 1.449214] SCSI subsystem initialized [ 1.449612] usbcore: registered new interface driver usbfs [ 1.449712] usbcore: registered new interface driver hub [ 1.449831] usbcore: registered new device driver usb [ 1.450042] media: Linux media interface: v0.10 [ 1.450120] Linux video capture interface: v2.00 [ 1.450385] pps_core: LinuxPPS API ver. 1 registered [ 1.450399] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.450440] PTP clock support registered [ 1.452303] Advanced Linux Sound Architecture Driver Initialized. [ 1.453364] Bluetooth: Core ver 2.21 [ 1.453432] NET: Registered protocol family 31 [ 1.453445] Bluetooth: HCI device and connection manager initialized [ 1.453467] Bluetooth: HCI socket layer initialized [ 1.453484] Bluetooth: L2CAP socket layer initialized [ 1.453538] Bluetooth: SCO socket layer initialized [ 1.454406] NetLabel: Initializing [ 1.454426] NetLabel: domain hash size = 128 [ 1.454435] NetLabel: protocols = UNLABELED CIPSOv4 [ 1.454509] NetLabel: unlabeled traffic allowed by default [ 1.455499] clocksource: Switched to clocksource arch_sys_counter [ 1.550263] NET: Registered protocol family 2 [ 1.551115] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 1.551229] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) [ 1.551665] TCP: Hash tables configured (established 8192 bind 8192) [ 1.551776] UDP hash table entries: 512 (order: 2, 24576 bytes) [ 1.551846] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) [ 1.552194] NET: Registered protocol family 1 [ 1.552855] RPC: Registered named UNIX socket transport module. [ 1.552877] RPC: Registered udp transport module. [ 1.552888] RPC: Registered tcp transport module. [ 1.552898] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.553751] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 1.556685] Initialise system trusted keyring [ 1.570718] VFS: Disk quotas dquot_6.6.0 [ 1.571030] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.573821] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.577334] NFS: Registering the id_resolver key type [ 1.577400] Key type id_resolver registered [ 1.577412] Key type id_legacy registered [ 1.577445] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.577537] ntfs: driver 2.1.32 [Flags: R/W]. [ 1.578460] JFS: nTxBlock = 8192, nTxLock = 65536 [ 1.587750] SGI XFS with security attributes, no debug enabled [ 1.596454] NET: Registered protocol family 38 [ 1.596509] Key type asymmetric registered [ 1.596531] Asymmetric key parser 'x509' registered [ 1.596658] bounce: pool size: 64 pages [ 1.597007] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.597353] io scheduler noop registered [ 1.597385] io scheduler deadline registered [ 1.597465] io scheduler cfq registered (default) [ 1.600655] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator [ 1.605545] rk-vcodec 20020000.vpu-service: no regulator for vcodec [ 1.605974] rk-vcodec 20020000.vpu-service: probe device [ 1.606394] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled [ 1.607643] rk-vcodec 20020000.vpu-service: could not find power_model node [ 1.607672] rk-vcodec 20020000.vpu-service: init success [ 1.608000] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry [ 1.612013] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330 [ 1.612040] dma-pl330 110f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.613098] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 1.613549] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable [ 1.613569] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup [ 1.613586] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]' [ 1.613600] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]' [ 1.613614] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup [ 1.613628] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed [ 1.614246] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable [ 1.614267] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup [ 1.614283] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]' [ 1.614298] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]' [ 1.614311] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup [ 1.614325] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed [ 1.615306] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.616189] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A [ 1.619508] Unable to handle kernel paging request at virtual address aff54678 [ 1.619512] pgd = b0004000 [ 1.619524] [aff54678] *pgd=9fffc811, *pte=00000000, *ppte=00000000 [ 1.619534] Internal error: Oops: 80000007 [#1] SMP ARM [ 1.619541] Modules linked in: [ 1.619550] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.194-rk322x #47 [ 1.619553] Hardware name: Generic DT based system [ 1.619557] task: ee94d540 task.stack: ee974000 [ 1.619568] PC is at update_rq_clock+0x20/0x28 [ 1.619577] LR is at update_blocked_averages+0x54/0x1d24 [ 1.619584] pc : [<b005466c>] lr : [<b0060268>] psr: 60000193 [ 1.619584] sp : ee975c90 ip : ee975ca0 fp : ee975c9c [ 1.619588] r10: b11664c0 r9 : 00000003 r8 : b116f75c [ 1.619593] r7 : ffff172d r6 : b116a100 r5 : eedc34c0 r4 : 00000003 [ 1.619598] r3 : 00000000 r2 : 00000002 r1 : 02c002bf r0 : eedc34c0 [ 1.619604] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none [ 1.619610] Control: 10c5387d Table: 6000406a DAC: 00000051 [ 1.619614] Process swapper/2 (pid: 0, stack limit = 0xee974250) [ 1.619619] Stack: (0xee975c90 to 0xee976000) [ 1.619628] 5c80: ee975d8c ee975ca0 b0060268 b0054658 [ 1.619639] 5ca0: b005cda4 b0c8cdd4 00000000 000001ae ee975ccc ee975cc0 b0c8cdd4 b0086350 [ 1.619649] 5cc0: ee975d8c ee975cd0 b0072f2c b0c8cdc8 eedb03bc 00000002 ee803200 60000113 [ 1.619660] 5ce0: eedc34c0 ee803200 00000000 b116e60c b116a100 b11664c0 20000113 eed994c0 [ 1.619670] 5d00: eed99a4c 00000000 fffedc90 00000000 b11664c0 ee803200 eed994c0 00000000 [ 1.619680] 5d20: 00000002 eedb54c0 ee8ab114 00000000 00000000 0000020a 00000002 eedb03bc [ 1.619690] 5d40: 00000008 00000003 00000020 00000002 00000002 00000003 ee975d58 b0c8cd18 [ 1.619701] 5d60: 60000193 00000003 ffff172d b116a100 ffff172d b116f75c 00000003 b11664c0 [ 1.619711] 5d80: ee975dec ee975d90 b00734c4 b0060220 b116a100 b116f75c 00000003 b11664c0 [ 1.619722] 5da0: 00000003 ee975db0 eedc34c0 b00b3a84 00000000 ee975dc0 b0052328 00000001 [ 1.619732] 5dc0: eedc34c0 eedc34c0 ffff172d eedb54c0 b116a100 b116f75c 00000003 b11664c0 [ 1.619743] 5de0: ee975e3c ee975df0 b00738c8 b0073484 ffffe000 b1245500 b116eeac 00000001 [ 1.619753] 5e00: 00000000 00000000 00000000 00000002 ee975e2c b116a09c 00000007 b123c92c [ 1.619763] 5e20: 00000008 00000100 ffffe000 00000080 ee975e9c ee975e40 b0009614 b0073778 [ 1.619774] 5e40: 00000000 20000193 00000000 00200040 b0c8f73c b116a100 fffedc96 b0c8f730 [ 1.619784] 5e60: 0000000a b1244940 b1161390 b116a080 ffffe000 ffffe000 b116f75c eedb54c0 [ 1.619795] 5e80: ee974000 00000002 f0805000 00000000 ee975eb4 ee975ea0 b002c650 b00094e4 [ 1.619805] 5ea0: b11664c0 b116f75c ee975edc ee975eb8 b0057fe4 b002c5d8 b116364c 00000002 [ 1.619816] 5ec0: 00000000 00000002 b123c8c8 f0805000 ee975f14 ee975ee0 b0016dbc b0057f68 [ 1.619826] 5ee0: ee975f58 20000093 00000000 b116f9a0 b11d2540 f080400c f0804000 ee975f40 [ 1.619837] 5f00: f0805000 00000000 ee975f3c ee975f18 b00094d4 b0016cec b0010aec 60000013 [ 1.619847] 5f20: ffffffff ee975f74 b116e634 b116e63c ee975f9c ee975f40 b0014dd4 b0009448 [ 1.619857] 5f40: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730 [ 1.619868] 5f60: b116e634 b116e63c 00000000 ee975f9c ee975fa0 ee975f90 b0010ae8 b0010aec [ 1.619879] 5f80: 60000013 ffffffff 00000051 b007cdbc ee975fac ee975fa0 b007cdbc b0010ab0 [ 1.619889] 5fa0: ee975fdc ee975fb0 b007d150 b007cd90 ee975fdc b0e68ea8 b11613e8 b1165930 [ 1.619900] 5fc0: b116e5d4 b123c56e 10c0387d b1244300 ee975ff4 ee975fe0 b0016a6c b007ce28 [ 1.619910] 5fe0: 9e96006a 00000051 00000000 ee975ff8 600098cc b0016924 00000000 00000000 [ 1.619934] [<b005466c>] (update_rq_clock) from [<b0060268>] (update_blocked_averages+0x54/0x1d24) [ 1.619948] [<b0060268>] (update_blocked_averages) from [<b00734c4>] (rebalance_domains+0x4c/0x2f4) [ 1.619960] [<b00734c4>] (rebalance_domains) from [<b00738c8>] (run_rebalance_domains+0x15c/0x1d8) [ 1.619972] [<b00738c8>] (run_rebalance_domains) from [<b0009614>] (__do_softirq+0x13c/0x368) [ 1.619985] [<b0009614>] (__do_softirq) from [<b002c650>] (irq_exit+0x84/0x12c) [ 1.619998] [<b002c650>] (irq_exit) from [<b0057fe4>] (scheduler_ipi+0x88/0x144) [ 1.620010] [<b0057fe4>] (scheduler_ipi) from [<b0016dbc>] (handle_IPI+0xdc/0x2bc) [ 1.620021] [<b0016dbc>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0x98/0x9c) [ 1.620032] [<b00094d4>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70) [ 1.620037] Exception stack(0xee975f40 to 0xee975f88) [ 1.620048] 5f40: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730 [ 1.620058] 5f60: b116e634 b116e63c 00000000 ee975f9c ee975fa0 ee975f90 b0010ae8 b0010aec [ 1.620063] 5f80: 60000013 ffffffff [ 1.620077] [<b0014dd4>] (__irq_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c) [ 1.620092] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c) [ 1.620105] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374) [ 1.620118] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (secondary_start_kernel+0x154/0x160) [ 1.620129] [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600098cc) [ 1.620141] Code: e8bd4000 e5903534 e3130002 189da800 (ebfff725) [ 1.620174] ---[ end trace 6d85e22c3794cdf2 ]--- [ 1.621531] Kernel panic - not syncing: Fatal exception in interrupt [ 1.621543] CPU1: stopping [ 1.621554] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.194-rk322x #47 [ 1.621557] Hardware name: Generic DT based system [ 1.621581] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24) [ 1.621598] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4) [ 1.621612] [<b052e520>] (dump_stack) from [<b0016f70>] (handle_IPI+0x290/0x2bc) [ 1.621623] [<b0016f70>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0x98/0x9c) [ 1.621633] [<b00094d4>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70) [ 1.621638] Exception stack(0xee973f40 to 0xee973f88) [ 1.621650] 3f40: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730 [ 1.621661] 3f60: b116e634 b116e63c 00000000 ee973f9c ee973fa0 ee973f90 b0010ae8 b0010aec [ 1.621666] 3f80: 60000013 ffffffff [ 1.621679] [<b0014dd4>] (__irq_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c) [ 1.621692] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c) [ 1.621706] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374) [ 1.621718] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (secondary_start_kernel+0x154/0x160) [ 1.621729] [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600098cc) [ 1.625820] CPU0: stopping [ 1.625828] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G D 4.4.194-rk322x #47 [ 1.625831] Hardware name: Generic DT based system [ 1.625850] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24) [ 1.625864] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4) [ 1.625876] [<b052e520>] (dump_stack) from [<b0016f70>] (handle_IPI+0x290/0x2bc) [ 1.625887] [<b0016f70>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0x98/0x9c) [ 1.625898] [<b00094d4>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70) [ 1.625902] Exception stack(0xee8b7a80 to 0xee8b7ac8) [ 1.625914] 7a80: b1350968 ee948000 00000095 60000013 b1249638 00000000 b1246848 00000006 [ 1.625924] 7aa0: 00000031 00000000 b1247178 ee8b7b2c ee8b7a00 ee8b7ad0 b0c8cdf4 b008cd00 [ 1.625929] 7ac0: 60000013 ffffffff [ 1.625943] [<b0014dd4>] (__irq_svc) from [<b008cd00>] (console_unlock+0x36c/0x4c8) [ 1.625956] [<b008cd00>] (console_unlock) from [<b008d884>] (register_console+0x1dc/0x3b8) [ 1.625972] [<b008d884>] (register_console) from [<b05e7fe8>] (uart_add_one_port+0x3c8/0x498) [ 1.625988] [<b05e7fe8>] (uart_add_one_port) from [<b05e9edc>] (serial8250_register_8250_port+0x27c/0x3b4) [ 1.626003] [<b05e9edc>] (serial8250_register_8250_port) from [<b05ef980>] (dw8250_probe+0x408/0x668) [ 1.626016] [<b05ef980>] (dw8250_probe) from [<b0668f9c>] (platform_drv_probe+0x60/0xbc) [ 1.626028] [<b0668f9c>] (platform_drv_probe) from [<b066713c>] (driver_probe_device+0x1e0/0x2ec) [ 1.626040] [<b066713c>] (driver_probe_device) from [<b06672dc>] (__driver_attach+0x94/0x98) [ 1.626053] [<b06672dc>] (__driver_attach) from [<b0665254>] (bus_for_each_dev+0x88/0xac) [ 1.626068] [<b0665254>] (bus_for_each_dev) from [<b06669e8>] (driver_attach+0x2c/0x30) [ 1.626082] [<b06669e8>] (driver_attach) from [<b0666624>] (bus_add_driver+0x1d0/0x214) [ 1.626095] [<b0666624>] (bus_add_driver) from [<b0667d10>] (driver_register+0x88/0x104) [ 1.626106] [<b0667d10>] (driver_register) from [<b0668ee8>] (__platform_driver_register+0x50/0x58) [ 1.626120] [<b0668ee8>] (__platform_driver_register) from [<b10d7c20>] (dw8250_platform_driver_init+0x1c/0x20) [ 1.626133] [<b10d7c20>] (dw8250_platform_driver_init) from [<b0009a68>] (do_one_initcall+0xa0/0x1f8) [ 1.626148] [<b0009a68>] (do_one_initcall) from [<b10a1f78>] (kernel_init_freeable+0x1d0/0x264) [ 1.626162] [<b10a1f78>] (kernel_init_freeable) from [<b0c88020>] (kernel_init+0x18/0x100) [ 1.626176] [<b0c88020>] (kernel_init) from [<b00101e8>] (ret_from_fork+0x14/0x2c) [ 2.788203] SMP: failed to stop secondary CPUs [ 2.788207] CRU: [ 2.788225] 00000000: 00002044 00001441 00000000 00001037 00001441 00000001 0000307d 00001442 [ 2.788238] 00000020: 00000001 00001032 00001441 00000000 00000000 00000000 00000000 00000000 [ 2.788251] 00000040: 00001111 00002700 00001013 00004203 0000001f 00000003 00000309 0000021f [ 2.788265] 00000060: 0bb8ea60 0bb8ea60 0000001f 00001407 0000121d 00000517 0000021f 0000021f [ 2.788278] 00000080: 0000021f 0000001f 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0000c2dc 00000f01 [ 2.788291] 000000a0: 0000412f 000003e2 0000011f 00000000 00000100 00004141 00000000 0bb8ea60 [ 2.788303] 000000c0: 00002121 0000001f 00002122 00002121 00000000 00000000 00000000 00000000 [ 2.788315] 000000e0: 00000000 00000000 00000000 00000000 00004000 00000f00 00000000 00001540 [ 2.788327] 00000100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788340] 00000120: 00000000 00000000 00000000 00000000 00000000 0000a000 00000000 00000000 [ 2.788352] 00000140: 3a980064 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788364] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788376] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788388] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788400] 000001c0: 00000004 00000000 00000004 00000000 00000000 00000000 00000004 00000000 [ 2.788410] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788413] PMU: [ 2.788426] 00000000: 00000000 00000000 00004000 00002000 00000000 00004228 0000a551 0000aaaa [ 2.788438] 00000020: 00009955 00002002 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788451] 00000040: 00000000 00000000 00000000 00000000 00008106 00000000 00000000 00000000 [ 2.788463] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788474] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788486] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788498] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 2.788510] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 5.077457] ---[ end Kernel panic - not syncing: Fatal exception in interrupt [ 8.619503] BUG: spinlock lockup suspected on CPU#3, swapper/3/0 [ 8.625517] lock: 0xeedc34c0, .magic: dead4ead, .owner: swapper/2/0, .owner_cpu: 2 [ 8.633169] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.194-rk322x #47 [ 8.641077] Hardware name: Generic DT based system [ 8.645884] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24) [ 8.653632] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4) [ 8.660859] [<b052e520>] (dump_stack) from [<b01112f8>] (spin_dump+0x98/0xa0) [ 8.668001] [<b01112f8>] (spin_dump) from [<b0086210>] (do_raw_spin_lock+0x10c/0x1d8) [ 8.675836] [<b0086210>] (do_raw_spin_lock) from [<b0c8cd58>] (_raw_spin_lock+0x18/0x1c) [ 8.683928] [<b0c8cd58>] (_raw_spin_lock) from [<b005608c>] (try_to_wake_up+0xc8/0x3f0) [ 8.691932] [<b005608c>] (try_to_wake_up) from [<b0056488>] (wake_up_process+0x24/0x28) [ 8.699935] [<b0056488>] (wake_up_process) from [<b00a0ab0>] (process_timeout+0x18/0x1c) [ 8.708026] [<b00a0ab0>] (process_timeout) from [<b00a0b04>] (call_timer_fn+0x50/0x1a0) [ 8.716030] [<b00a0b04>] (call_timer_fn) from [<b00a0e38>] (run_timer_softirq+0x1e4/0x304) [ 8.724293] [<b00a0e38>] (run_timer_softirq) from [<b0009614>] (__do_softirq+0x13c/0x368) [ 8.732471] [<b0009614>] (__do_softirq) from [<b002c650>] (irq_exit+0x84/0x12c) [ 8.739784] [<b002c650>] (irq_exit) from [<b008e230>] (__handle_domain_irq+0x70/0xc4) [ 8.747614] [<b008e230>] (__handle_domain_irq) from [<b0009494>] (gic_handle_irq+0x58/0x9c) [ 8.755965] [<b0009494>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70) [ 8.763441] Exception stack(0xee977f40 to 0xee977f88) [ 8.768497] 7f40: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730 [ 8.776671] 7f60: b116e634 b116e63c 00000000 ee977f9c ee977fa0 ee977f90 b0010ae8 b0010aec [ 8.784842] 7f80: 60000013 ffffffff [ 8.788339] [<b0014dd4>] (__irq_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c) [ 8.795737] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c) [ 8.803828] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374) [ 8.812439] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (secondary_start_kernel+0x154/0x160) [ 8.821481] [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600098cc) [ 8.828872] Sending NMI to all CPUs: [ 8.833731] NMI backtrace for cpu 2 [ 8.837222] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.194-rk322x #47 [ 8.845129] Hardware name: Generic DT based system [ 8.849916] task: ee94d540 task.stack: ee974000 [ 8.854444] PC is at arch_timer_read_counter_long+0x4/0x28 [ 8.859923] LR is at __timer_delay+0x4c/0x68 [ 8.864190] pc : [<b0017cd4>] lr : [<b052c2a8>] psr: a0000113 [ 8.870451] sp : ee975a70 ip : ee975a70 fp : ee975a8c [ 8.875671] r10: 0ffffe38 r9 : 00000035 r8 : b11d21cc [ 8.880891] r7 : 00000ed8 r6 : 00005dbf r5 : 17f3db8c r4 : b12b02a8 [ 8.887411] r3 : b0017cd0 r2 : fd640800 r1 : 00000000 r0 : b1244324 [ 8.893931] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none [ 8.901058] Control: 10c5387d Table: 6000406a DAC: 00000051 [ 8.906799] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.194-rk322x #47 [ 8.914706] Hardware name: Generic DT based system [ 8.919493] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24) [ 8.927227] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4) [ 8.934442] [<b052e520>] (dump_stack) from [<b0010d88>] (show_regs+0x1c/0x20) [ 8.941569] [<b0010d88>] (show_regs) from [<b0532c30>] (nmi_cpu_backtrace+0xa0/0xd4) [ 8.949303] [<b0532c30>] (nmi_cpu_backtrace) from [<b0016da4>] (handle_IPI+0xc4/0x2bc) [ 8.957211] [<b0016da4>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0x98/0x9c) [ 8.964772] [<b00094d4>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70) [ 8.972246] Exception stack(0xee975a20 to 0xee975a68) [ 8.977293] 5a20: b1244324 00000000 fd640800 b0017cd0 b12b02a8 17f3db8c 00005dbf 00000ed8 [ 8.985461] 5a40: b11d21cc 00000035 0ffffe38 ee975a8c ee975a70 ee975a70 b052c2a8 b0017cd4 [ 8.993627] 5a60: a0000113 ffffffff [ 8.997115] [<b0014dd4>] (__irq_svc) from [<b0017cd4>] (arch_timer_read_counter_long+0x4/0x28) [ 9.005716] [<b0017cd4>] (arch_timer_read_counter_long) from [<b052c2f4>] (__timer_const_udelay+0x30/0x34) [ 9.015358] [<b052c2f4>] (__timer_const_udelay) from [<b0110d20>] (panic+0x1f8/0x210) [ 9.023179] [<b0110d20>] (panic) from [<b0014680>] (die+0x214/0x354) [ 9.029527] [<b0014680>] (die) from [<b001ec9c>] (__do_kernel_fault.part.0+0x74/0x84) [ 9.037349] [<b001ec9c>] (__do_kernel_fault.part.0) from [<b001f058>] (do_pabt_page_fault+0x0/0x84) [ 9.046383] [<b001f058>] (do_pabt_page_fault) from [<b001f0b8>] (do_pabt_page_fault+0x60/0x84) [ 9.054983] [<b001f0b8>] (do_pabt_page_fault) from [<b0009304>] (do_PrefetchAbort+0x48/0xa8) [ 9.063410] [<b0009304>] (do_PrefetchAbort) from [<b0014ecc>] (__pabt_svc+0x4c/0x80) [ 9.071143] Exception stack(0xee975c40 to 0xee975c88) [ 9.076191] 5c40: eedc34c0 02c002bf 00000002 00000000 00000003 eedc34c0 b116a100 ffff172d [ 9.084358] 5c60: b116f75c 00000003 b11664c0 ee975c9c ee975ca0 ee975c90 b0060268 b005466c [ 9.092525] 5c80: 60000193 ffffffff [ 9.096011] [<b0014ecc>] (__pabt_svc) from [<b005466c>] (update_rq_clock+0x20/0x28) [ 9.103659] [<b005466c>] (update_rq_clock) from [<b0060268>] (update_blocked_averages+0x54/0x1d24) [ 9.112606] [<b0060268>] (update_blocked_averages) from [<b00734c4>] (rebalance_domains+0x4c/0x2f4) [ 9.121641] [<b00734c4>] (rebalance_domains) from [<b00738c8>] (run_rebalance_domains+0x15c/0x1d8) [ 9.130588] [<b00738c8>] (run_rebalance_domains) from [<b0009614>] (__do_softirq+0x13c/0x368) [ 9.139102] [<b0009614>] (__do_softirq) from [<b002c650>] (irq_exit+0x84/0x12c) [ 9.146403] [<b002c650>] (irq_exit) from [<b0057fe4>] (scheduler_ipi+0x88/0x144) [ 9.153790] [<b0057fe4>] (scheduler_ipi) from [<b0016dbc>] (handle_IPI+0xdc/0x2bc) [ 9.161351] [<b0016dbc>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0x98/0x9c) [ 9.168912] [<b00094d4>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70) [ 9.176386] Exception stack(0xee975f40 to 0xee975f88) [ 9.181433] 5f40: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730 [ 9.189601] 5f60: b116e634 b116e63c 00000000 ee975f9c ee975fa0 ee975f90 b0010ae8 b0010aec [ 9.197767] 5f80: 60000013 ffffffff [ 9.201255] [<b0014dd4>] (__irq_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c) [ 9.208643] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c) [ 9.216723] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374) [ 9.225324] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (secondary_start_kernel+0x154/0x160) [ 9.234358] [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600098cc) [ 9.241745] NMI backtrace for cpu 3 [ 9.245233] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.194-rk322x #47 [ 9.253140] Hardware name: Generic DT based system [ 9.257927] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24) [ 9.265661] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4) [ 9.272876] [<b052e520>] (dump_stack) from [<b0532c60>] (nmi_cpu_backtrace+0xd0/0xd4) [ 9.280697] [<b0532c60>] (nmi_cpu_backtrace) from [<b001656c>] (raise_nmi+0x70/0x74) [ 9.288431] [<b001656c>] (raise_nmi) from [<b0532a48>] (nmi_trigger_all_cpu_backtrace+0x128/0x270) [ 9.297379] [<b0532a48>] (nmi_trigger_all_cpu_backtrace) from [<b001710c>] (arch_trigger_all_cpu_backtrace+0x20/0x24) [ 9.307974] [<b001710c>] (arch_trigger_all_cpu_backtrace) from [<b0086218>] (do_raw_spin_lock+0x114/0x1d8) [ 9.317615] [<b0086218>] (do_raw_spin_lock) from [<b0c8cd58>] (_raw_spin_lock+0x18/0x1c) [ 9.325696] [<b0c8cd58>] (_raw_spin_lock) from [<b005608c>] (try_to_wake_up+0xc8/0x3f0) [ 9.333690] [<b005608c>] (try_to_wake_up) from [<b0056488>] (wake_up_process+0x24/0x28) [ 9.341685] [<b0056488>] (wake_up_process) from [<b00a0ab0>] (process_timeout+0x18/0x1c) [ 9.349765] [<b00a0ab0>] (process_timeout) from [<b00a0b04>] (call_timer_fn+0x50/0x1a0) [ 9.357760] [<b00a0b04>] (call_timer_fn) from [<b00a0e38>] (run_timer_softirq+0x1e4/0x304) [ 9.366014] [<b00a0e38>] (run_timer_softirq) from [<b0009614>] (__do_softirq+0x13c/0x368) [ 9.374181] [<b0009614>] (__do_softirq) from [<b002c650>] (irq_exit+0x84/0x12c) [ 9.381483] [<b002c650>] (irq_exit) from [<b008e230>] (__handle_domain_irq+0x70/0xc4) [ 9.389303] [<b008e230>] (__handle_domain_irq) from [<b0009494>] (gic_handle_irq+0x58/0x9c) [ 9.397644] [<b0009494>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70) [ 9.405118] Exception stack(0xee977f40 to 0xee977f88) [ 9.410165] 7f40: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730 [ 9.418332] 7f60: b116e634 b116e63c 00000000 ee977f9c ee977fa0 ee977f90 b0010ae8 b0010aec [ 9.426498] 7f80: 60000013 ffffffff [ 9.429985] [<b0014dd4>] (__irq_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c) [ 9.437373] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c) [ 9.445454] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374) [ 9.454055] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (secondary_start_kernel+0x154/0x160) [ 9.463088] [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600098cc) Enter command. Try 'help' for a list of builtin commands -> quit exiting exit Script done on 2021-03-21 15:38:58+00:00 [COMMAND_EXIT_CODE="0"] When booting from emmc, most of the time I have nothing after "Booting kernel, and sometimes some kernel traps. Any suggestions or pointers? Cheers, Michel Edited March 21, 2021 by TRS-80 put long output inside spoiler Link to post Share on other sites More sharing options...
fabiobassa 100 Posted March 21, 2021 Share Posted March 21, 2021 @gurzixo Ciao Michel, welcome in this valley of tears lol lol lol Well, another lovely board with no SD reader and this makes the whole story a bit complicated , but not impossible to solve. Ant thank you so much for photos and serial uart log, this really helps The kernel as you can see is starting and the kernel panic could be for wrong trust_os, wrong dtb, not mounting the root fs ,one only or all 3 causes lol If you have original firmware you can extract the pieces and in particular dtb with this tool RK3xxx_firmware_tools_5.23.1_by_SergioPoverony.zip (google for it ) but I guess you have nothing of different from other boards with ddr3 and emmc Let's wait @jock for further infos on how to approach at this rare study case but I can say to you for sure that it will boot You are new so cannot post many posts in the first days , you must wait I believe one day for other post. And don't forget to click a " like" ( the heart icon) for helping good reputation of authors Where are you from if I can ask , and have you some skills on linux so it will be in some manner easier? EDIT: I attached a command line CLI only windows tool to extract pieces from a firmware , try it please imgRePackerRK_106.zip 1 Link to post Share on other sites More sharing options...
jock 398 Posted March 21, 2021 Author Share Posted March 21, 2021 @gurzixo hello. Yes, your board is doing absolutely weird things. This is a rare situation I yet have to understand why it happens. I have a board with rk3228a that runs for days without any issue on legacy 4.4 kernel, but crashes immediately with messages similar to yours if I use the mainline kernel. I tried almost everything I could think about on that board to solve or at least mitigate the issue, but with no success. If you could extract the DTB, it would very helpful for clues that may explain what is happening. The multitool DTB is a very basic DTB that should work on all boards, it is designed to be very compatible and usually works on most boards without complaints; the only testing thing I can imagine is to disable the vdd_log and vdd_arm regulators and removing/disabling the cpu operating frequency table to avoid frequency scaling. I already did such experiments on my rk3228a board, but it did not improve stability at all, suggesting the issue is probably elsewhere. 1 Link to post Share on other sites More sharing options...
Alex83 1 Posted March 21, 2021 Share Posted March 21, 2021 23 hours ago, jock said: @Alex83 Very good! I'm very pleased to read that finally we got the best out of the board The wifi benchmark is excellent for a 72Mbit/s link,I'm not totally sure the chip is able to establish 40 Mhz links, I think it is a single stream chip so that is the maximum you can get from it, but nonetheless it is quite above the benchmarks I did in the past that were around 37Mbit/s. Thanks again for the patience, now I go to put credits on first page and a link to the instructions for people who wants to upgrade the NAND bootloader Thank you very much to both of you! Unfortunately even if I use now the Ethernet Interface instead of wifi there are constantly Kernel Panic Informations; root@rk322x-v88mini4k /tmp > docker pull ghcr.io/linuxserver/tvheadend:version-dbaa0f85 version-dbaa0f85: Pulling from linuxserver/tvheadend a40841fad2a0: Already exists acbbceb19698: Already exists 56eb82dc2361: Already exists 402d271dd404: Already exists 7041d1197031: Already exists 369be319bd57: Pull complete 6d5d33f3b1b3: Extracting 122.6MB/134.4MB 3049e89ec5b4: Download complete a5727aec668b: Download complete c0fbe37b9349: Download complete 354c8a31be5a: Download complete 31630dad9f91: Download complete 3487ab2c89e1: Download complete 3bb370f7506f: Download complete Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.608874] Internal error: : 1c06 [#1] SMP ARM Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.764392] Process exe (pid: 2644, stack limit = 0xed6bc250) Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.773751] Stack: (0xed6bdbc4 to 0xed6be000) Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.781691] dbc0: b01a7af8 ba220dc0 00000001 00000001 b0e84ffc ed6bdbf8 ba2bd518 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.793560] dbe0: ba220dc0 ee835000 00000000 00000699 b024f418 ba220dc0 00000002 00000af7 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.805457] dc00: 00000000 ee835000 ba2bd518 ba21a040 00000000 ba2bd61c b021b9f4 b0cae638 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.817404] dc20: ed6bdd8c ed6bdc30 b0221afc b01a77f0 00000699 b021b9f4 60010013 60010013 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.829397] dc40: ed6bdc64 00000009 00009699 00000000 00009000 00000000 ed6bdc94 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.841435] dc60: b007c260 b0273e50 00000000 00000000 b0cae6b0 cfff8600 ba21a040 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.853482] dc80: ec336c00 00000000 ed6bdd1c ed6bdc98 b0273e50 b015b130 ba2bd518 ba21a040 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.865550] dca0: b125a444 00000000 ed6bdcd4 ed6bdcb8 b0223b48 b024f4b0 00000000 00001000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.877620] dcc0: 00000007 ba2bd518 ed6bdcfc ed6bdcd8 b019cbf4 b0223ae8 ba2bd518 ee846fdc Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.889707] dce0: 00008000 00000000 00008000 00000000 ed6bdd3c 00000000 b0cae65c 00000b6f Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.901824] dd00: ebc81000 ec3dc300 b0cae494 00001000 ed6bdd3c ed6bdd20 b024f4e8 b0273cbc Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.913979] dd20: 00001000 00001000 ba2bd61c ba21a040 ed6bdd8c ed6bdd40 b0222474 b024f4b0 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.926141] dd40: 00001000 00001000 ee846fdc 00000000 00009000 00000000 00008000 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.938328] dd60: ed6bdd94 00000699 ed6bdeec ba2bd61c 00001000 00000000 b0cae494 b02219f8 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.950558] dd80: ed6bddec ed6bdd90 b0113580 b0221a04 00000699 00000000 ed6bddb8 ed6bddbc Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.962823] dda0: 00000000 ed6bc000 00003600 ec3dc300 00009000 00000000 ee846fdc 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.975084] ddc0: 60579483 ec3dc300 00000000 ed6bdf00 ba2bd61c ed6bdeec ec3dc300 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.987342] dde0: ed6bde34 ed6bddf0 b0114bf4 b01134b0 ee3b0800 00000c99 ed6bde34 b009e6f0 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 221.999650] de00: 60579483 b0c95678 ebccd540 ba2bd518 ed6bdf00 00000000 ed6bdeec ba2bd5a0 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.012001] de20: ec3dc300 00003c99 ed6bded4 ed6bde38 b0215e28 b0114a98 ed6bde58 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.024366] de40: 00000000 b018a4e8 ed6bde84 ed6bde58 b018a4e8 b016f638 60579483 28332cdc Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.036719] de60: 60579483 28332cdc 00000c99 00000000 ebc2cc90 00000000 ed6bdedc ed6bde88 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.049095] de80: b0175ec4 b018a424 00020002 eb9bcd24 ebfaa700 ed6bdef4 ed6bc000 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.061503] dea0: 00000006 00000090 ebc2cc00 ec3dc300 00000000 ed6bdf78 00003c99 00005a00 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.073943] dec0: 00000000 00000004 ed6bdf44 ed6bded8 b016cb30 b0215d4c 00003c99 b016d364 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.086398] dee0: 00003c99 54e78000 00003c99 00000001 00003600 00000699 ed6bdee4 00000001 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.098894] df00: ec3dc300 00000000 00005a00 00000000 00000000 ed6bde74 00000000 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.111382] df20: ec3dc300 54e78000 ed6bdf78 00003c99 00005a00 00000000 ed6bdf74 ed6bdf48 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.123908] df40: b016d420 b016ca80 ec3dc303 00000000 ec3dc300 ec3dc303 54e78000 00003c99 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.136490] df60: 00005a00 00000000 ed6bdfa4 ed6bdf78 b016dde4 b016d38c 00005a00 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.149066] df80: 00000000 00000000 54e78000 00000004 b0010304 ed6bc000 00000000 ed6bdfa8 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.161536] dfa0: b0010100 b016dd94 00000000 00000000 00000005 54e78000 00003c99 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.173897] dfc0: 00000000 00000000 54e78000 00000004 00000006 00000040 548000e0 77cefec0 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.186156] dfe0: 00000000 548528d8 74f93714 7504c4f0 60010010 00000005 00000000 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:46:28 ... kernel:[ 222.312594] Code: e1a0c002 e1a0e002 e2511040 a8a0500c (a8a0500c) Message from syslogd@rk322x-v88mini4k at Mar 21 19:47:01 ... kernel:[ 255.360152] Internal error: : 1c06 [#2] SMP ARM Message from syslogd@rk322x-v88mini4k at Mar 21 19:47:01 ... kernel:[ 255.547588] Process systemctl (pid: 2897, stack limit = 0xd26c2250) Message from syslogd@rk322x-v88mini4k at Mar 21 19:47:01 ... kernel:[ 255.558613] Stack: (0xd26c3fa8 to 0xd26c4000) Message from syslogd@rk322x-v88mini4k at Mar 21 19:47:01 ... kernel:[ 255.567661] 3fa0: 00000000 000e7bc4 00000003 00000000 000e7bc4 aee8e668 Message from syslogd@rk322x-v88mini4k at Mar 21 19:47:01 ... kernel:[ 255.580588] 3fc0: 00000000 000e7bc4 00000003 0000008c 00000003 aee8f294 a6f83fdc aee8f2a0 Message from syslogd@rk322x-v88mini4k at Mar 21 19:47:01 ... kernel:[ 255.593501] 3fe0: 0000008c aee8e660 a6f7fa55 a6f7efc6 400f0030 00000003 00000000 00000000 Message from syslogd@rk322x-v88mini4k at Mar 21 19:47:01 ... kernel:[ 255.606447] Code: 1a00000d e3a01055 ee031f10 e1a0200d (e5921048) Would you mind to help me to get TVHeadend 4.3 (unstable) to work on this device? I need it for armhf architecture and can't find any good resource. Only for Ubuntu Focal there are Repositories and the reson why I usually use Ubuntu. Unfortunately there is no minimal Image for Ubuntu and that's why I installed Buster image. Link to post Share on other sites More sharing options...
fabiobassa 100 Posted March 21, 2021 Share Posted March 21, 2021 @Alex83 tell me if I am correct : will You use a tv dongle to receive dtt tv ? what is for tvheadend ??? I guess you want use it for this purpose ... I did some experiments to receive DAB and DMR radios on a 322x and..... well hope your project will be functional, mine was not Link to post Share on other sites More sharing options...
Alex83 1 Posted March 21, 2021 Share Posted March 21, 2021 Hi, I already use it with focal images on my Banana PI, but wanted to replace it to 322x. I don't know why the paic appears it seems like this always happens if a lot of data get extracted, but the RAM shouldn't overflow. I start wie 100MB of 1GB RAM usage and pull around 200 MB. So it shouldn't be full and the panic happens on diffrent stages of pulling. Link to post Share on other sites More sharing options...
jock 398 Posted March 21, 2021 Author Share Posted March 21, 2021 @Alex83 I have no experience with tvheadend, I don't even know what it is. It looks to me that the error is somehow related to bad architecture. Try to post a question in the general chit chat forum on how to compile it for armhf if it is your necessity. 1 Link to post Share on other sites More sharing options...
fabiobassa 100 Posted March 21, 2021 Share Posted March 21, 2021 But @Alex83 you still continue to compare things lol lol maybe the one for banana pi is compiled with flags for banana pi, the error you have is may be and i say maybe related to things that tries to download and it doesn't find on repository since even if are both ARM may be some processor instructions are not the same. I told you, you want to port on this box things made for other box: of course you will get it but be ready to tears and blood And as @jock said it seems more a problem of architecture and compatibility than a kernel related problem have you tried apt update && apt install tvheadend maybe are in official repository ? Link to post Share on other sites More sharing options...
Alex83 1 Posted March 21, 2021 Share Posted March 21, 2021 Hey guys, thank you very much for your replies! I don't wanna continue off-topic discussions even if I would love to discuss with you longer. But just a hint that in armbian-config menue there is a Point for "Softy" and there you can directly install Tvheadend. Unfortunately it is stable release, that means Version 4.2 and I wanted to try unstable 4.3. There is a possibility for transcoding via VAAPI and hoped maybe it works since VAAPI should work with that devices, don't they? Link to post Share on other sites More sharing options...
jock 398 Posted March 21, 2021 Author Share Posted March 21, 2021 3 minutes ago, Alex83 said: Hey guys, thank you very much for your replies! I don't wanna continue off-topic discussions even if I would love to discuss with you longer. But just a hint that in armbian-config menue there is a Point for "Softy" and there you can directly install Tvheadend. Unfortunately it is stable release, that means Version 4.2 and I wanted to try unstable 4.3. There is a possibility for transcoding via VAAPI and hoped maybe it works since VAAPI should work with that devices, don't they? Uhm... I don't know the state of VA-API for hardware decoding and encoding with rockchip on legacy kernel. Maybe there's a driver and it works, but surely there is nothing already cooked for that. The media script pointed in the first page does not install any va-api driver (it installs rkmpp, 3d support via armsoc + mali drivers, kodi and ffmpeg), and I don't know if there is some kind of wrapper to do so, but I guess not. On mainline kernel, things are materializing right now, but it is still too early for va-api support - it is not yet planned AFAIK. Link to post Share on other sites More sharing options...
Alex83 1 Posted March 21, 2021 Share Posted March 21, 2021 Hey guys, don't wanna bother you, but independent of my tvheadend topic there appear more and more storage errors like the ones I posted... Any ideas what could be wrong? The device looses it's accessability also then... root@rk322x-v88mini4k ~ > df -h Dateisystem Gr��e Benutzt Verf. Verw% Eingeh�ngt auf udev 486M 0 486M 0% /dev tmpfs 100M 5,2M 95M 6% /run /dev/rknand0p1 6,9G 1,5G 5,3G 22% / tmpfs 497M 0 497M 0% /dev/shm tmpfs 5,0M 4,0K 5,0M 1% /run/lock tmpfs 497M 0 497M 0% /sys/fs/cgroup tmpfs 497M 20K 497M 1% /tmp /dev/zram1 49M 3,9M 42M 9% /var/log tmpfs 100M 0 100M 0% /run/user/0 root@rk322x-v88mini4k ~ > Link to post Share on other sites More sharing options...
fabiobassa 100 Posted March 22, 2021 Share Posted March 22, 2021 @Alex83 This is my df -h df -h Filesystem Size Used Avail Use% Mounted on udev 991M 0 991M 0% /dev tmpfs 201M 5.5M 195M 3% /run /dev/mmcblk2p6 15G 1.9G 12G 14% / tmpfs 1001M 0 1001M 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 1001M 0 1001M 0% /sys/fs/cgroup tmpfs 201M 0 201M 0% /run/user/0 tmpfs 201M 8.0K 201M 1% /run/user/1000 and conside mine is emmc of 16 gb. Which kind of errors do you believe have ??? And if it loose accessibility is because this thing you are trying to download/install goes in wrong places and/or break something in booting process Anyway in my little opinion is you want to give a try it should be this: https://github.com/orgs/linuxserver/packages/container/tvheadend/1613987 this is for arm7 32 bit But if you encounter problems I will not go to answer you since this is a more specific question and not a general problem of board Link to post Share on other sites More sharing options...
Alex83 1 Posted March 22, 2021 Share Posted March 22, 2021 Hey, thanks for your answer @fabiobassa! As I said I use now the offer of "Softy" in armbian-config. This includes also Tvheadend Version 4.2. I also noticed if I limit the maximum CPU speed to the second highest then the box becomes more stable and haven't seen an error like in my above post yet. The device works overnight already without errors. I also noticed that wifi issue is still ongoing and TX performance is usually worse than RX even when it's connected with full speed (72 Mbit/s up and down @50dBm). Well it seems like I need to cut my speed @1,3GHz for the box unfortunately... I noticed that CPU usage is showing often more than 100% on one process. This is still a bit confusing for me, but I think even when there are 4 cores shown in htop maybe it's handling is different than the boxes I know ( * pi series) with this topic. The speed on the right side is just shown once the CPU speed of 1,3GHz and in *pi boxes you see the speed 4 times and no single process is shown >100% CPU load. But I will now test a bit around and give you feedback about the stability. Thanks a lot for now! Link to post Share on other sites More sharing options...
jock 398 Posted March 22, 2021 Author Share Posted March 22, 2021 5 hours ago, Alex83 said: Hey, thanks for your answer @fabiobassa! As I said I use now the offer of "Softy" in armbian-config. This includes also Tvheadend Version 4.2. I also noticed if I limit the maximum CPU speed to the second highest then the box becomes more stable and haven't seen an error like in my above post yet. The device works overnight already without errors. I also noticed that wifi issue is still ongoing and TX performance is usually worse than RX even when it's connected with full speed (72 Mbit/s up and down @50dBm). Well it seems like I need to cut my speed @1,3GHz for the box unfortunately... I noticed that CPU usage is showing often more than 100% on one process. This is still a bit confusing for me, but I think even when there are 4 cores shown in htop maybe it's handling is different than the boxes I know ( * pi series) with this topic. The speed on the right side is just shown once the CPU speed of 1,3GHz and in *pi boxes you see the speed 4 times and no single process is shown >100% CPU load. But I will now test a bit around and give you feedback about the stability. Thanks a lot for now! rk322x-config sets the maximum cpu frequency to 1.2Ghz in case you have an rk3228a because it is their rated speed. Maybe your board has a rk3228a but you choose rk3228b or rk3229. About wifi performance, it is perfectly normal that TX and RX performance differs. Usually TX is a bit higher than RX, but that depends a lot on the setup and the connected devices. If a process is using more than 100% of the cpu (I guess you mean using top or htop) it means that the process is using more than one core. This is perfectly normal although. The only issue with legacy 4.4 kernel is the load average, which has its baseline at 4.00: that's a bug, because the baseline should be 0.00. Link to post Share on other sites More sharing options...
gurzixo 5 Posted March 22, 2021 Share Posted March 22, 2021 Thanks to all of you for your kind words! I also forget to thank all the other who helped FYI I am French, 62, living now in Portugal, *soldered* my first computer (a Z80 Nascom ) at 19, and I have a good experience in embedded systems, electronics, network and system programming on various OSes. @fabiobassa @Jock : I tried to extract the dtb using PabloCastellano's extract_dtb.py, but it gave weird things. Thanks for your tool (I work on Linux and there was also a Linux version!). Using it with 2nd level decoding, and then using linux's dtc on Image/resource.img.dump/rk-kernel.dtb for my working android image gave: Spoiler <stdout>: Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /clocks: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /clocks/clock_regs: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /gpu: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /vop_mmu: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /vpu_mmu: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /iep_mmu: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /vdec_mmu: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /tve: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /phy/usb-phy0: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /phy/usb-phy1: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /phy/usb-phy2: node has a reg or ranges property, but no unit name <stdout>: Warning (unit_address_vs_reg): /regulators/regulator@0: node has a unit name, but no reg property <stdout>: Warning (unit_address_vs_reg): /regulators/regulator@1: node has a unit name, but no reg property <stdout>: Warning (unit_address_vs_reg): /pwm-regulator1/regulators/regulator@0: node has a unit name, but no reg property <stdout>: Warning (unit_address_vs_reg): /pwm-regulator2/regulators/regulator@1: node has a unit name, but no reg property <stdout>: Warning (unit_address_format): /clocks/clock_regs/pll_cons/pll-clk@0000: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/pll_cons/pll-clk@000c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/pll_cons/pll-clk@0018: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/pll_cons/pll-clk@0024: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0044: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0048: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@004c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0050: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0054: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0058: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@005c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0060: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0064: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0068: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@006c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0070: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0074: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0078: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@007c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0080: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0084: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0088: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@008c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0090: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0094: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0098: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@009c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00a0: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00a4: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00a8: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00ac: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00b0: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00b4: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00b8: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00bc: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00c0: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00c4: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00c8: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@00cc: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_sel_cons/sel-con@0134: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00d0: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00d4: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00d8: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00dc: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00e0: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00e4: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00e8: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00ec: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00f0: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00f4: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00f8: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@00fc: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@0100: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@0104: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@0108: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /clocks/clock_regs/clk_gate_cons/gate-clk@010c: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /spi@11090000/spi_test@00: unit name should not have leading 0s <stdout>: Warning (unit_address_format): /spi@11090000/spi_test@01: unit name should not have leading 0s <stdout>: Warning (simple_bus_reg): /regulators/regulator@0: missing or empty reg/ranges property <stdout>: Warning (simple_bus_reg): /regulators/regulator@1: missing or empty reg/ranges property <stdout>: Warning (spi_bus_reg): /spi@11090000/spi_test@00: SPI bus unit address format error, expected "0" <stdout>: Warning (spi_bus_reg): /spi@11090000/spi_test@01: SPI bus unit address format error, expected "1" <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0044: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0048: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@004c: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0050: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0054: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0058: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@005c: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0060: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0064: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0068: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@006c: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0070: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0074: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0078: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@007c: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0080: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0084: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0088: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@008c: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0090: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0094: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0098: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@009c: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00a0: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00a4: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00a8: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00ac: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00b0: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00b4: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00b8: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00bc: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00c0: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00c4: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00c8: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@00cc: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /clocks/clock_regs/clk_sel_cons/sel-con@0134: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /rockchip-ion: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /regulators: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /pwm-regulator1/regulators: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property <stdout>: Warning (avoid_unnecessary_addr_size): /pwm-regulator2/regulators: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property /dts-v1/; / { #address-cells = <0x01>; #size-cells = <0x01>; compatible = "rockchip,rk3229"; interrupt-parent = <0x01>; chosen { bootargs = "vmalloc=496M psci=enable rockchip_jtag"; }; aliases { serial0 = "/serial@11010000"; serial1 = "/serial@11020000"; serial2 = "/serial@11030000"; i2c0 = "/i2c@11050000"; i2c1 = "/i2c@11060000"; i2c2 = "/i2c@11070000"; i2c3 = "/i2c@11080000"; lcdc0 = "/vop@20050000"; spi0 = "/spi@11090000"; }; memory { device_type = "memory"; reg = <0x00 0x00>; }; clocks { compatible = "rockchip,rk-clocks"; #address-cells = <0x01>; #size-cells = <0x01>; ranges = <0x00 0x110e0000 0x1000>; fixed_rate_cons { compatible = "rockchip,rk-fixed-rate-cons"; xin24m { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "xin24m"; clock-frequency = <0x16e3600>; #clock-cells = <0x00>; linux,phandle = <0x02>; phandle = <0x02>; }; xin12m { compatible = "rockchip,rk-fixed-clock"; clocks = <0x02>; clock-output-names = "xin12m"; clock-frequency = <0xb71b00>; #clock-cells = <0x00>; linux,phandle = <0x14>; phandle = <0x14>; }; hdmiphy_out { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "hdmiphy_out"; clock-frequency = <0x2367b880>; #clock-cells = <0x00>; linux,phandle = <0x45>; phandle = <0x45>; }; usbphy0_480m { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "usbphy0_480m"; clock-frequency = <0x1c9c3800>; #clock-cells = <0x00>; linux,phandle = <0x46>; phandle = <0x46>; }; usbphy1_480m { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "usbphy1_480m"; clock-frequency = <0x1c9c3800>; #clock-cells = <0x00>; linux,phandle = <0x47>; phandle = <0x47>; }; jtag_clkin { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "jtag_clkin"; clock-frequency = <0x00>; #clock-cells = <0x00>; linux,phandle = <0x4c>; phandle = <0x4c>; }; dummy { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "dummy"; clock-frequency = <0x00>; #clock-cells = <0x00>; linux,phandle = <0x19>; phandle = <0x19>; }; gmac_clkin { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "gmac_clkin"; clock-frequency = <0x7735940>; #clock-cells = <0x00>; linux,phandle = <0x3c>; phandle = <0x3c>; }; phy_50m_out { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "phy_50m_out"; clock-frequency = <0x00>; #clock-cells = <0x00>; linux,phandle = <0x3d>; phandle = <0x3d>; }; phy_rx_out { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "phy_rx_out"; clock-frequency = <0x00>; #clock-cells = <0x00>; }; phy_tx_out { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "phy_tx_out"; clock-frequency = <0x00>; #clock-cells = <0x00>; }; clkin_hsadc_tsp { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "clkin_hsadc_tsp"; clock-frequency = <0x00>; #clock-cells = <0x00>; linux,phandle = <0x53>; phandle = <0x53>; }; i2s_clkin { compatible = "rockchip,rk-fixed-clock"; clock-output-names = "i2s_clkin"; clock-frequency = <0x00>; #clock-cells = <0x00>; linux,phandle = <0x13>; phandle = <0x13>; }; }; fixed_factor_cons { compatible = "rockchip,rk-fixed-factor-cons"; hclk_rkvdec { compatible = "rockchip,rk-fixed-factor-clock"; clocks = <0x03>; clock-output-names = "hclk_rkvdec"; clock-div = <0x04>; clock-mult = <0x01>; #clock-cells = <0x00>; linux,phandle = <0x58>; phandle = <0x58>; }; hclk_vpu { compatible = "rockchip,rk-fixed-factor-clock"; clocks = <0x04>; clock-output-names = "hclk_vpu"; clock-div = <0x04>; clock-mult = <0x01>; #clock-cells = <0x00>; linux,phandle = <0x96>; phandle = <0x96>; }; xin32k_out { compatible = "rockchip,rk-fixed-clock"; clocks = <0x05>; clock-output-names = "xin32k_out"; clock-div = <0x01>; clock-mult = <0x01>; #clock-cells = <0x00>; }; }; clock_regs { compatible = "rockchip,rk-clock-regs"; #address-cells = <0x01>; #size-cells = <0x01>; reg = <0x00 0x1000>; ranges; pll_cons { compatible = "rockchip,rk-pll-cons"; #address-cells = <0x01>; #size-cells = <0x01>; ranges; pll-clk@0000 { compatible = "rockchip,rk3188-pll-clk"; reg = <0x00 0x10>; mode-reg = <0x40 0x00>; status-reg = <0x04 0x0a>; clocks = <0x02>; clock-output-names = "clk_apll"; rockchip,pll-type = <0x40>; #clock-cells = <0x00>; linux,phandle = <0x07>; phandle = <0x07>; }; pll-clk@000c { compatible = "rockchip,rk3188-pll-clk"; reg = <0x0c 0x10>; mode-reg = <0x40 0x04>; status-reg = <0x10 0x0a>; clocks = <0x02>; clock-output-names = "clk_dpll"; rockchip,pll-type = <0x80>; #clock-cells = <0x00>; linux,phandle = <0x09>; phandle = <0x09>; }; pll-clk@0018 { compatible = "rockchip,rk3188-pll-clk"; reg = <0x18 0x10>; mode-reg = <0x40 0x08>; status-reg = <0x1c 0x0a>; clocks = <0x02>; clock-output-names = "clk_cpll"; rockchip,pll-type = <0x100>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x0b>; phandle = <0x0b>; }; pll-clk@0024 { compatible = "rockchip,rk3188-pll-clk"; reg = <0x24 0x10>; mode-reg = <0x40 0x0c>; status-reg = <0x28 0x0a>; clocks = <0x02>; clock-output-names = "clk_gpll"; rockchip,pll-type = <0x100>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x08>; phandle = <0x08>; }; }; clk_sel_cons { compatible = "rockchip,rk-sel-cons"; #address-cells = <0x01>; #size-cells = <0x01>; ranges; sel-con@0044 { compatible = "rockchip,rk3188-selcon"; reg = <0x44 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_core_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x06>; clock-output-names = "clk_core"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0b>; rockchip,flags = <0xc0>; }; clk_core_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x06 0x02>; clocks = <0x07 0x08 0x09>; clock-output-names = "clk_core"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x06>; phandle = <0x06>; }; aclk_bus_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x0a>; clock-output-names = "aclk_bus"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; linux,phandle = <0x0d>; phandle = <0x0d>; }; aclk_bus_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0d 0x02>; clocks = <0x0b 0x08 0x0c>; clock-output-names = "aclk_bus"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x0a>; phandle = <0x0a>; }; }; sel-con@0048 { compatible = "rockchip,rk3188-selcon"; reg = <0x48 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; pclk_dbg_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x04>; clocks = <0x06>; clock-output-names = "pclk_dbg"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0c>; linux,phandle = <0x60>; phandle = <0x60>; }; aclk_core_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x04 0x03>; clocks = <0x06>; clock-output-names = "aclk_core"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0c>; linux,phandle = <0x44>; phandle = <0x44>; }; hclk_bus_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x02>; clocks = <0x0d>; clock-output-names = "hclk_bus"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x51>; phandle = <0x51>; }; pclk_bus_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x0c 0x03>; clocks = <0x0d>; clock-output-names = "pclk_bus"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x4f>; phandle = <0x4f>; }; }; sel-con@004c { compatible = "rockchip,rk3188-selcon"; reg = <0x4c 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; hclk_vio_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x0e>; clock-output-names = "hclk_vio"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x57>; phandle = <0x57>; }; clk_nandc_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x0f>; clock-output-names = "clk_nandc"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_nandc_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0e 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_nandc"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x0f>; phandle = <0x0f>; }; }; sel-con@0050 { compatible = "rockchip,rk3188-selcon"; reg = <0x50 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_i2s1_pll_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x10>; clock-output-names = "clk_i2s1_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x180>; linux,phandle = <0x11>; phandle = <0x11>; }; clk_i2s1_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x11 0x12 0x13 0x14>; clock-output-names = "clk_i2s1"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0e>; rockchip,flags = <0x04>; linux,phandle = <0x15>; phandle = <0x15>; }; clk_i2s1_out_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0c 0x01>; clocks = <0x15 0x14>; clock-output-names = "clk_i2s1_out"; #clock-cells = <0x00>; linux,phandle = <0x4b>; phandle = <0x4b>; }; i2s1_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0f 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_i2s1_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x10>; phandle = <0x10>; }; }; sel-con@0054 { compatible = "rockchip,rk3188-selcon"; reg = <0x54 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; testclk_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x16>; clock-output-names = "testclk"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; }; clk_24m_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x02>; clock-output-names = "clk_24m"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; }; }; sel-con@0058 { compatible = "rockchip,rk3188-selcon"; reg = <0x58 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_mac_pll_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x17>; clock-output-names = "clk_mac_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; linux,phandle = <0x3e>; phandle = <0x3e>; }; clk_mac_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x05 0x01>; clocks = <0x17 0x18>; clock-output-names = "clk_mac"; #clock-cells = <0x00>; rockchip,flags = <0x04>; #clock-init-cells = <0x01>; linux,phandle = <0x4e>; phandle = <0x4e>; }; clk_mac_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x07 0x01>; clocks = <0x19 0x08>; clock-output-names = "clk_mac_pll"; #clock-cells = <0x00>; linux,phandle = <0x17>; phandle = <0x17>; }; clk_gmac_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x1a>; clock-output-names = "clk_gmac"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_gmac_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0f 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_gmac"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x1a>; phandle = <0x1a>; }; }; sel-con@005c { compatible = "rockchip,rk3188-selcon"; reg = <0x5c 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; spdif_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x1b>; clock-output-names = "clk_spdif_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x180>; linux,phandle = <0x1c>; phandle = <0x1c>; }; spdif_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x1c 0x1d 0x14>; clock-output-names = "clk_spdif"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0e>; rockchip,flags = <0x04>; linux,phandle = <0x8b>; phandle = <0x8b>; }; spdif_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0f 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_spdif_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x1b>; phandle = <0x1b>; }; }; sel-con@0060 { compatible = "rockchip,rk3188-selcon"; reg = <0x60 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; i2s1_frac { compatible = "rockchip,rk3188-frac-con"; clocks = <0x11>; clock-output-names = "i2s1_frac"; rockchip,bits = <0x00 0x20>; rockchip,clkops-idx = <0x05>; #clock-cells = <0x00>; linux,phandle = <0x12>; phandle = <0x12>; }; }; sel-con@0064 { compatible = "rockchip,rk3188-selcon"; reg = <0x64 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; i2s0_frac { compatible = "rockchip,rk3188-frac-con"; clocks = <0x1e>; clock-output-names = "i2s0_frac"; rockchip,bits = <0x00 0x20>; rockchip,clkops-idx = <0x05>; #clock-cells = <0x00>; linux,phandle = <0x20>; phandle = <0x20>; }; }; sel-con@0068 { compatible = "rockchip,rk3188-selcon"; reg = <0x68 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_i2s0_pll_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x1f>; clock-output-names = "clk_i2s0_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x180>; linux,phandle = <0x1e>; phandle = <0x1e>; }; clk_i2s0_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x1e 0x20 0x13 0x14>; clock-output-names = "clk_i2s0"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0e>; rockchip,flags = <0x04>; linux,phandle = <0x49>; phandle = <0x49>; }; i2s0_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0f 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_i2s0_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x1f>; phandle = <0x1f>; }; }; sel-con@006c { compatible = "rockchip,rk3188-selcon"; reg = <0x6c 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; aclk_peri_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x21>; clock-output-names = "aclk_peri"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; hclk_peri_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x02>; clocks = <0x21>; clock-output-names = "hclk_peri"; rockchip,div-type = <0x80>; rockchip,div-relations = <0x00 0x01 0x01 0x02 0x02 0x04>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x54>; phandle = <0x54>; }; aclk_peri_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0a 0x02>; clocks = <0x0b 0x08 0x0c>; clock-output-names = "aclk_peri"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x21>; phandle = <0x21>; }; pclk_peri_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x0c 0x02>; clocks = <0x21>; clock-output-names = "pclk_peri"; rockchip,div-type = <0x80>; rockchip,div-relations = <0x00 0x01 0x01 0x02 0x02 0x04 0x03 0x08>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x55>; phandle = <0x55>; }; }; sel-con@0070 { compatible = "rockchip,rk3188-selcon"; reg = <0x70 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_sdmmc0_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x08>; clocks = <0x22>; clock-output-names = "clk_sdmmc0"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x03>; rockchip,flags = <0x100>; }; clk_sdmmc0_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x0b 0x08 0x02 0x23>; clock-output-names = "clk_sdmmc0"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x22>; phandle = <0x22>; }; clk_sdio_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0a 0x02>; clocks = <0x0b 0x08 0x02 0x23>; clock-output-names = "clk_sdio"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x24>; phandle = <0x24>; }; clk_emmc_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0c 0x02>; clocks = <0x0b 0x08 0x02 0x23>; clock-output-names = "clk_emmc"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x25>; phandle = <0x25>; }; }; sel-con@0074 { compatible = "rockchip,rk3188-selcon"; reg = <0x74 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_sdio_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x08>; clocks = <0x24>; clock-output-names = "clk_sdio"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x03>; rockchip,flags = <0x100>; }; clk_emmc_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x08>; clocks = <0x25>; clock-output-names = "clk_emmc"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x03>; rockchip,flags = <0x100>; }; }; sel-con@0078 { compatible = "rockchip,rk3188-selcon"; reg = <0x78 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_uart0_pll_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x26>; clock-output-names = "clk_uart0_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,flags = <0x100>; linux,phandle = <0x27>; phandle = <0x27>; }; clk_uart0_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x27 0x28 0x02>; clock-output-names = "clk_uart0"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0e>; rockchip,flags = <0x04>; linux,phandle = <0x69>; phandle = <0x69>; }; clk_uart0_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0c 0x02>; clocks = <0x0b 0x08 0x23>; clock-output-names = "clk_uart0_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x26>; phandle = <0x26>; }; }; sel-con@007c { compatible = "rockchip,rk3188-selcon"; reg = <0x7c 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_uart1_pll_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x29>; clock-output-names = "clk_uart1_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,flags = <0x100>; linux,phandle = <0x2a>; phandle = <0x2a>; }; clk_uart1_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x2a 0x2b 0x02>; clock-output-names = "clk_uart1"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0e>; rockchip,flags = <0x04>; linux,phandle = <0x6e>; phandle = <0x6e>; }; clk_uart1_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0c 0x02>; clocks = <0x0b 0x08 0x23>; clock-output-names = "clk_uart1_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x29>; phandle = <0x29>; }; }; sel-con@0080 { compatible = "rockchip,rk3188-selcon"; reg = <0x80 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_uart2_pll_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x2c>; clock-output-names = "clk_uart2_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,flags = <0x100>; linux,phandle = <0x31>; phandle = <0x31>; }; clk_uart2_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x2c 0x2d 0x02>; clock-output-names = "clk_uart2"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0e>; rockchip,flags = <0x04>; linux,phandle = <0x71>; phandle = <0x71>; }; clk_uart2_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0c 0x02>; clocks = <0x0b 0x08 0x23>; clock-output-names = "clk_uart2_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x2c>; phandle = <0x2c>; }; }; sel-con@0084 { compatible = "rockchip,rk3188-selcon"; reg = <0x84 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; i2s2_pll_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x2e>; clock-output-names = "clk_i2s2_pll"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x180>; linux,phandle = <0x2f>; phandle = <0x2f>; }; clk_i2s2_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x2f 0x30 0x13 0x14>; clock-output-names = "clk_i2s2"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0e>; rockchip,flags = <0x04>; linux,phandle = <0x4a>; phandle = <0x4a>; }; i2s2_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0f 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_i2s2_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x2e>; phandle = <0x2e>; }; }; sel-con@0088 { compatible = "rockchip,rk3188-selcon"; reg = <0x88 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; uart0_frac { compatible = "rockchip,rk3188-frac-con"; clocks = <0x27>; clock-output-names = "uart0_frac"; rockchip,bits = <0x00 0x20>; rockchip,clkops-idx = <0x05>; #clock-cells = <0x00>; linux,phandle = <0x28>; phandle = <0x28>; }; }; sel-con@008c { compatible = "rockchip,rk3188-selcon"; reg = <0x8c 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; uart1_frac { compatible = "rockchip,rk3188-frac-con"; clocks = <0x2a>; clock-output-names = "uart1_frac"; rockchip,bits = <0x00 0x20>; rockchip,clkops-idx = <0x05>; #clock-cells = <0x00>; linux,phandle = <0x2b>; phandle = <0x2b>; }; }; sel-con@0090 { compatible = "rockchip,rk3188-selcon"; reg = <0x90 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; uart2_frac { compatible = "rockchip,rk3188-frac-con"; clocks = <0x31>; clock-output-names = "uart2_frac"; rockchip,bits = <0x00 0x20>; rockchip,clkops-idx = <0x05>; #clock-cells = <0x00>; linux,phandle = <0x2d>; phandle = <0x2d>; }; }; sel-con@0094 { compatible = "rockchip,rk3188-selcon"; reg = <0x94 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; spdif_frac { compatible = "rockchip,rk3188-frac-con"; clocks = <0x1c>; clock-output-names = "spdif_frac"; rockchip,bits = <0x00 0x20>; rockchip,clkops-idx = <0x05>; #clock-cells = <0x00>; linux,phandle = <0x1d>; phandle = <0x1d>; }; }; sel-con@0098 { compatible = "rockchip,rk3188-selcon"; reg = <0x98 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_hdmi_cec_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x0e>; clocks = <0x02>; clock-output-names = "clk_hdmi_cec"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; linux,phandle = <0x05>; phandle = <0x05>; }; }; sel-con@009c { compatible = "rockchip,rk3188-selcon"; reg = <0x9c 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_rga_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x32>; clock-output-names = "clk_rga"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_tsp_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x33>; clock-output-names = "clk_tsp"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_tsp_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0f 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_tsp"; #clock-cells = <0x00>; linux,phandle = <0x33>; phandle = <0x33>; }; }; sel-con@00a0 { compatible = "rockchip,rk3188-selcon"; reg = <0xa0 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_wifi_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x34>; clock-output-names = "clk_wifi"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_wifi_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x05 0x02>; clocks = <0x0b 0x08 0x23>; clock-output-names = "clk_wifi"; #clock-cells = <0x00>; linux,phandle = <0x34>; phandle = <0x34>; }; clk_hdcp_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x06>; clocks = <0x35>; clock-output-names = "clk_hdcp"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_hdcp_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0e 0x02>; clocks = <0x0b 0x08 0x0c>; clock-output-names = "clk_hdcp"; #clock-cells = <0x00>; linux,phandle = <0x35>; phandle = <0x35>; }; }; sel-con@00a4 { compatible = "rockchip,rk3188-selcon"; reg = <0xa4 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_crypto_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x36>; clock-output-names = "clk_crypto"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; rockchip,flags = <0x100>; }; clk_crypto_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x05 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_crypto"; #clock-cells = <0x00>; linux,phandle = <0x36>; phandle = <0x36>; }; clk_tsadc_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x06 0x0a>; clocks = <0x02>; clock-output-names = "clk_tsadc"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x4d>; phandle = <0x4d>; }; }; sel-con@00a8 { compatible = "rockchip,rk3188-selcon"; reg = <0xa8 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_spi0_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x07>; clocks = <0x37>; clock-output-names = "clk_spi0"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_spi0_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x01>; clocks = <0x0b 0x08>; clock-output-names = "clk_spi0"; #clock-cells = <0x00>; linux,phandle = <0x37>; phandle = <0x37>; }; }; sel-con@00ac { compatible = "rockchip,rk3188-selcon"; reg = <0xac 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_ddr_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x02>; clocks = <0x38>; clock-output-names = "clk_ddr"; rockchip,div-type = <0x80>; rockchip,div-relations = <0x00 0x01 0x01 0x02 0x03 0x04>; #clock-cells = <0x00>; rockchip,flags = <0xc0>; rockchip,clkops-idx = <0x12>; linux,phandle = <0x50>; phandle = <0x50>; }; clk_ddr_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x02>; clocks = <0x09 0x08 0x07>; clock-output-names = "clk_ddr"; #clock-cells = <0x00>; linux,phandle = <0x38>; phandle = <0x38>; }; }; sel-con@00b0 { compatible = "rockchip,rk3188-selcon"; reg = <0xb0 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; dclk_vop0_pll_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x00 0x01>; clocks = <0x08 0x0b>; clock-output-names = "dclk_vop0_pll"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x39>; phandle = <0x39>; }; dclk_vop0_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x01 0x01>; clocks = <0x0c 0x19>; clock-output-names = "dclk_vop0"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x5f>; phandle = <0x5f>; }; dclk_vop0_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x08>; clocks = <0x39>; clock-output-names = "dclk_vop0"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; }; }; sel-con@00b4 { compatible = "rockchip,rk3188-selcon"; reg = <0xb4 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; aclk_rkvdec_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x03>; clock-output-names = "aclk_rkvdec"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; aclk_rkvdec_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x06 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "aclk_rkvdec"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x03>; phandle = <0x03>; }; clk_vdec_cabac_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x3a>; clock-output-names = "clk_vdec_cabac"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_vdec_cabac_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0e 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "clk_vdec_cabac"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x3a>; phandle = <0x3a>; }; }; sel-con@00b8 { compatible = "rockchip,rk3188-selcon"; reg = <0xb8 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; dclk_hdmiphy_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x03>; clocks = <0x39>; clock-output-names = "dclk_hdmiphy"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; }; clk_macphy_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x03>; clocks = <0x3b>; clock-output-names = "clk_macphy"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; }; mac_clkin { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0a 0x01>; clocks = <0x3c 0x3d>; clock-output-names = "mac_clkin"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x18>; phandle = <0x18>; }; clk_macphy_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0c 0x01>; clocks = <0x3e 0x3c>; clock-output-names = "clk_macphy"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x3b>; phandle = <0x3b>; }; }; sel-con@00bc { compatible = "rockchip,rk3188-selcon"; reg = <0xbc 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; i2s2_frac { compatible = "rockchip,rk3188-frac-con"; clocks = <0x2f>; clock-output-names = "i2s2_frac"; rockchip,bits = <0x00 0x20>; rockchip,clkops-idx = <0x05>; #clock-cells = <0x00>; linux,phandle = <0x30>; phandle = <0x30>; }; }; sel-con@00c0 { compatible = "rockchip,rk3188-selcon"; reg = <0xc0 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; aclk_iep_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x0e>; clock-output-names = "aclk_iep"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; aclk_iep_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x05 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "aclk_iep"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x0e>; phandle = <0x0e>; }; aclk_hdcp_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x3f>; clock-output-names = "aclk_hdcp"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; aclk_hdcp_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0d 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "aclk_hdcp"; #clock-cells = <0x00>; linux,phandle = <0x3f>; phandle = <0x3f>; }; }; sel-con@00c4 { compatible = "rockchip,rk3188-selcon"; reg = <0xc4 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; aclk_vpu_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x04>; clock-output-names = "aclk_vpu"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; aclk_vpu_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x05 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "aclk_vpu"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x04>; phandle = <0x04>; }; }; sel-con@00c8 { compatible = "rockchip,rk3188-selcon"; reg = <0xc8 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; aclk_vop_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x40>; clock-output-names = "aclk_vop"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; aclk_vop_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x05 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "aclk_vop"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x40>; phandle = <0x40>; }; aclk_rga_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x32>; clock-output-names = "aclk_rga"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; aclk_rga_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0d 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "aclk_rga"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x32>; phandle = <0x32>; }; }; sel-con@00cc { compatible = "rockchip,rk3188-selcon"; reg = <0xcc 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; clk_gpu_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x00 0x05>; clocks = <0x41>; clock-output-names = "clk_gpu"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_gpu_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x05 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "clk_gpu"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x41>; phandle = <0x41>; }; clk_vdec_core_div { compatible = "rockchip,rk3188-div-con"; rockchip,bits = <0x08 0x05>; clocks = <0x42>; clock-output-names = "clk_vdec_core"; rockchip,div-type = <0x00>; #clock-cells = <0x00>; rockchip,clkops-idx = <0x01>; rockchip,flags = <0x100>; }; clk_vdec_core_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0d 0x02>; clocks = <0x0b 0x08 0x0c 0x23>; clock-output-names = "clk_vdec_core"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x42>; phandle = <0x42>; }; }; sel-con@0134 { compatible = "rockchip,rk3188-selcon"; reg = <0x134 0x04>; #address-cells = <0x01>; #size-cells = <0x01>; testclk_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x08 0x04>; clocks = <0x34 0x19 0x06 0x43 0x00 0x0e 0x41 0x21 0x44>; clock-output-names = "testclk"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x16>; phandle = <0x16>; }; hdmi_phy_clk_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0d 0x01>; clocks = <0x45 0x02>; clock-output-names = "hdmi_phy_clk"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x0c>; phandle = <0x0c>; }; usb480m_phy_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0e 0x01>; clocks = <0x46 0x47>; clock-output-names = "usb480m_phy"; #clock-cells = <0x00>; #clock-init-cells = <0x01>; linux,phandle = <0x48>; phandle = <0x48>; }; usb480m_mux { compatible = "rockchip,rk3188-mux-con"; rockchip,bits = <0x0f 0x01>; clocks = <0x48 0x02>; clock-output-names = "usb480m"; #clock-cells = <0x00>; rockchip,clkops-idx = <0x0f>; #clock-init-cells = <0x01>; linux,phandle = <0x23>; phandle = <0x23>; }; }; }; clk_gate_cons { compatible = "rockchip,rk-gate-cons"; #address-cells = <0x01>; #size-cells = <0x01>; ranges; gate-clk@00d0 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xd0 0x04>; clocks = <0x19 0x19 0x19 0x1f 0x20 0x49 0x19 0x2e 0x30 0x4a 0x10 0x12 0x19 0x4b 0x15 0x16>; clock-output-names = "reserved\0reserved\0reserved\0clk_i2s0_pll\0i2s0_frac\0clk_i2s0\0reserved\0clk_i2s2_pll\0i2s2_frac\0clk_i2s2\0clk_i2s1_pll\0i2s1_frac\0reserved\0clk_i2s1_out\0clk_i2s1\0testclk"; #clock-cells = <0x01>; }; gate-clk@00d4 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xd4 0x04>; clocks = <0x0f 0x40 0x32 0x4c 0x3f 0x02 0x02 0x17 0x26 0x28 0x29 0x2b 0x2c 0x2d 0x19 0x19>; clock-output-names = "clk_nandc\0aclk_vop\0aclk_rga\0clk_jtag\0aclk_hdcp\0clk_otgphy0\0clk_otgphy1\0clk_mac_pll\0clk_uart0_pll\0uart0_frac\0clk_uart1_pll\0uart1_frac\0clk_uart2_pll\0uart2_frac\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x68>; phandle = <0x68>; }; gate-clk@00d8 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xd8 0x04>; clocks = <0x19 0x19 0x1a 0x19 0x19 0x19 0x33 0x36 0x4d 0x37 0x1b 0x22 0x1d 0x24 0x25 0x34>; clock-output-names = "reserved\0clk_ddrmon\0clk_gmac\0reserved\0reserved\0reserved\0clk_tsp\0clk_crypto\0clk_tsadc\0clk_spi0\0clk_spdif_pll\0clk_sdmmc0\0spdif_frac\0clk_sdio\0clk_emmc\0clk_wifi"; #clock-cells = <0x01>; linux,phandle = <0x85>; phandle = <0x85>; }; gate-clk@00dc { compatible = "rockchip,rk3188-gate-clk"; reg = <0xdc 0x04>; clocks = <0x0e 0x19 0x03 0x3a 0x42 0x35 0x32 0x02 0x05 0x19 0x19 0x04 0x19 0x19 0x19 0x19>; clock-output-names = "aclk_iep\0dclk_vop0\0aclk_rkvdec\0clk_vdec_cabac\0clk_vdec_core\0clk_hdcp\0clk_rga\0clk_hdmi_hdcp\0clk_hdmi_cec\0reserved\0reserved\0aclk_vpu\0reserved\0clk_gpu\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x97>; phandle = <0x97>; }; gate-clk@00e0 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xe0 0x04>; clocks = <0x06 0x06 0x44 0x19 0x04 0x03 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19>; clock-output-names = "aclk_core\0pclk_dbg\0aclk_gic400\0reserved\0hclk_vpu\0hclk_rkvdec\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x61>; phandle = <0x61>; }; gate-clk@00e4 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xe4 0x04>; clocks = <0x21 0x21 0x21 0x4e 0x4e 0x4e 0x4e 0x3b 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19>; clock-output-names = "aclk_peri\0hclk_peri\0pclk_peri\0clk_mac_ref\0clk_mac_refout\0clk_mac_rx\0clk_mac_tx\0clk_macphy\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0xa8>; phandle = <0xa8>; }; gate-clk@00e8 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xe8 0x04>; clocks = <0x0d 0x0d 0x0d 0x4f 0x4f 0x02 0x02 0x02 0x02 0x02 0x02 0x19 0x19 0x4f 0x19 0x19>; clock-output-names = "aclk_bus\0hclk_bus\0pclk_bus\0pclk_bus_pre\0pclk_phy\0clk_timer0\0clk_timer1\0clk_timer2\0clk_timer3\0clk_timer4\0clk_timer5\0reserved\0reserved\0pclk_ddr\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x52>; phandle = <0x52>; }; gate-clk@00ec { compatible = "rockchip,rk3188-gate-clk"; reg = <0xec 0x04>; clocks = <0x50 0x50 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x43 0x0e>; clock-output-names = "clk_ddrphy\0clk4x_ddrphy\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0g_aclk_gpu\0g_aclk_gpu_noc"; #clock-cells = <0x01>; linux,phandle = <0x43>; phandle = <0x43>; }; gate-clk@00f0 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xf0 0x04>; clocks = <0x0d 0x0d 0x0d 0x51 0x52 0x0d 0x43 0x00 0x52 0x0d 0x51 0x51 0x51 0x51 0x51 0x51 0x4f 0x4f 0x4f>; clock-output-names = "g_aclk_intmem\0g_intmem_mbist\0g_aclk_dmac_bus\0g_hclk_rom\0g_p_ddrupctl\0g_clk_ddrupctl\0g_p_ddrmon\0g_h_i2s0_8ch\0g_h_i2s1_8ch\0g_h_i2s2_2ch\0g_h_spdif_8ch\0g_h_crypto_mst\0g_h_crypto_slv\0g_p_efuse_1024\0g_p_efuse_256\0g_pclk_i2c0"; #clock-cells = <0x01>; linux,phandle = <0x62>; phandle = <0x62>; }; gate-clk@00f4 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xf4 0x04>; clocks = <0x4f 0x4f 0x4f 0x19 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f 0x4f>; clock-output-names = "g_pclk_i2c1\0g_pclk_i2c2\0g_pclk_i2c3\0reserved\0g_pclk_timer0\0g_pclk_stimer\0g_pclk_spi0\0g_pclk_rk_pwm\0g_pclk_gpio0\0g_pclk_gpio1\0g_pclk_gpio2\0g_pclk_gpio3\0g_pclk_uart0\0g_pclk_uart1\0g_pclk_uart2\0g_pclk_tsadc"; #clock-cells = <0x01>; linux,phandle = <0x64>; phandle = <0x64>; }; gate-clk@00f8 { compatible = "rockchip,rk3188-gate-clk"; reg = <0xf8 0x04>; clocks = <0x4f 0x0d 0x52 0x0d 0x52 0x04 0x4f 0x52 0x04 0x4f 0x52 0x04 0x52 0x04 0x52 0x04 0x4f 0x51 0x53 0x19 0x19 0x19>; clock-output-names = "g_pclk_grf\0g_aclk_bus\0g_p_mschniu\0g_p_ddrphy\0g_pclk_cru\0g_p_acodecphy\0g_pclk_sgrf\0g_p_hdmiphy\0g_p_vdacphy\0g_p_phy_noc\0g_pclk_sim\0g_hclk_tsp\0clk_hsadc_tsp\0reserved\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x63>; phandle = <0x63>; }; gate-clk@00fc { compatible = "rockchip,rk3188-gate-clk"; reg = <0xfc 0x04>; clocks = <0x54 0x54 0x54 0x54 0x21 0x55 0x54 0x54 0x54 0x54 0x54 0x19 0x54 0x54 0x54 0x19>; clock-output-names = "g_hclk_sdmmc\0g_hclk_sdio\0g_clk_emmc\0g_clk_nandc\0g_aclk_gmac\0g_pclk_gmac\0g_hclk_host0\0g_h_host0_arb\0g_hclk_host1\0g_h_host1_arb\0g_hclk_host2\0reserved\0g_hclk_otg\0g_hclk_otg_pmu\0g_h_host2_arb\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x66>; phandle = <0x66>; }; gate-clk@0100 { compatible = "rockchip,rk3188-gate-clk"; reg = <0x100 0x04>; clocks = <0x21 0x54 0x55 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19>; clock-output-names = "g_a_peri_noc\0g_h_peri_noc\0g_p_peri_noc\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x65>; phandle = <0x65>; }; gate-clk@0104 { compatible = "rockchip,rk3188-gate-clk"; reg = <0x104 0x04>; clocks = <0x56 0x0b 0x57 0x56 0x09 0x57 0x19 0x40 0x57 0x56 0x08 0x57 0x0e 0x3f 0x32 0x40 0x57 0x19 0x19>; clock-output-names = "g_aclk_rga\0g_hclk_rga\0g_aclk_iep\0g_hclk_iep\0reserved\0g_aclk_vop\0g_hclk_vop\0g_h_vio_ahbarbi\0g_h_vio_noc\0g_a_iep_noc\0g_a_hdcp_noc\0g_a_rga_noc\0g_a_vop_noc\0g_h_vop_noc\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x56>; phandle = <0x56>; }; gate-clk@0108 { compatible = "rockchip,rk3188-gate-clk"; reg = <0x108 0x04>; clocks = <0x19 0x19 0x19 0x19 0x19 0x19 0x57 0x57 0x19 0x19 0x3f 0x57 0x57 0x19 0x19 0x19>; clock-output-names = "reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0g_p_hdmi_ctrl\0g_h_vio_h2p\0reserved\0reserved\0g_aclk_hdcp\0g_pclk_hdcp\0g_h_hdcp_mmu\0reserved\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x67>; phandle = <0x67>; }; gate-clk@010c { compatible = "rockchip,rk3188-gate-clk"; reg = <0x10c 0x04>; clocks = <0x19 0x19 0x03 0x58 0x59 0x00 0x59 0x01 0x59 0x02 0x59 0x03 0x19 0x19 0x19 0x19 0x19 0x19 0x19 0x19>; clock-output-names = "g_aclk_vpu\0g_hclk_vpu\0g_a_rkvdec\0g_h_rkvdec\0g_a_vpu_noc\0g_h_vpu_noc\0g_a_rkvdec_noc\0g_h_rkvdec_noc\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved\0reserved"; #clock-cells = <0x01>; linux,phandle = <0x59>; phandle = <0x59>; }; }; }; }; dram_timing { compatible = "rockchip,dram-timing"; dram_spd_bin = <0x15>; sr_idle = <0x18>; pd_idle = <0x20>; dram_dll_disb_freq = <0xc8>; phy_dll_disb_freq = <0xc8>; dram_odt_disb_freq = <0x85>; phy_odt_disb_freq = <0x85>; ddr3_drv = <0x02>; ddr3_odt = <0x40>; lpddr3_drv = <0x01>; lpddr3_odt = <0x03>; lpddr2_drv = <0x01>; phy_ddr3_clk_drv = <0x15>; phy_ddr3_cmd_drv = <0x15>; phy_ddr3_dqs_drv = <0x15>; phy_ddr3_odt = <0x02>; phy_lp23_clk_drv = <0x13>; phy_lp23_cmd_drv = <0x16>; phy_lp23_dqs_drv = <0x16>; phy_lp3_odt = <0x02>; linux,phandle = <0x5e>; phandle = <0x5e>; }; cpus { #address-cells = <0x01>; #size-cells = <0x00>; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a7"; reg = <0xf00>; }; cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a7"; reg = <0xf01>; }; cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a7"; reg = <0xf02>; }; cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a7"; reg = <0xf03>; }; }; psci { compatible = "arm,psci"; method = "smc"; cpu_suspend = <0x84000001>; cpu_off = <0x84000002>; cpu_on = <0x84000003>; }; interrupt-controller@32010000 { compatible = "arm,cortex-a15-gic"; interrupt-controller; #interrupt-cells = <0x03>; #address-cells = <0x00>; reg = <0x32011000 0x1000 0x32012000 0x1000>; linux,phandle = <0x01>; phandle = <0x01>; }; syscon@10140000 { compatible = "rockchip,rk322x-sgrf\0rockchip,sgrf\0syscon"; reg = <0x10140000 0x1000>; }; syscon@11000000 { compatible = "rockchip,rk322x-grf\0rockchip,grf\0syscon"; reg = <0x11000000 0x1000>; linux,phandle = <0x5b>; phandle = <0x5b>; }; syscon@110e0000 { compatible = "rockchip,rk322x-cru\0rockchip,cru\0syscon"; reg = <0x110e0000 0x1000>; }; syscon@11200000 { compatible = "rockchip,rk322x-ddrpctl\0syscon"; reg = <0x11200000 0x400>; }; syscon@31020000 { compatible = "rockchip,rk322x-msch\0rockchip,msch\0syscon"; reg = <0x31020000 0x3000>; }; arm-pmu { compatible = "arm,cortex-a7-pmu"; interrupts = <0x00 0x4c 0x04 0x00 0x4d 0x04 0x00 0x4e 0x04 0x00 0x4f 0x04>; }; reset@110e0110 { compatible = "rockchip,reset"; reg = <0x110e0110 0x20>; rockchip,reset-flag = <0x01>; #reset-cells = <0x01>; linux,phandle = <0x8e>; phandle = <0x8e>; }; timer { compatible = "arm,armv7-timer"; interrupts = <0x01 0x0d 0xf04 0x01 0x0e 0xf04>; clock-frequency = <0x16e3600>; }; timer@110c0000 { compatible = "rockchip,timer"; reg = <0x110c0000 0x20>; interrupts = <0x00 0x2b 0x04>; rockchip,broadcast = <0x01>; }; fiq-debugger { compatible = "rockchip,fiq-debugger"; rockchip,serial-id = <0x02>; rockchip,signal-irq = <0x9f>; rockchip,wake-irq = <0x00>; rockchip,irq-mode-enable = <0x00>; rockchip,baudrate = <0x16e360>; pinctrl-names = "default"; pinctrl-0 = <0x5a>; status = "okay"; }; io-domains { compatible = "rockchip,rk322x-io-voltage-domain"; rockchip,grf = <0x5b>; status = "okay"; vccio1-supply = <0x5c>; vccio2-supply = <0x5d>; vccio4-supply = <0x5c>; }; dvfs { vd_arm { regulator_name = "vdd_arm"; pd_core { clk_core { operating-points = <0x927c0 0xf4240 0xc7380 0xf4240 0xf6180 0x11edd8 0x124f80 0x137478 0x13c680 0x1437c8 0x153d80 0x14fb18 0x1656c0 0x155cc0>; max-volt = <0x1437c8>; temp-limit-enable = <0x01>; target-temp = <0x61>; min_temp_limit = <0x639c0>; normal-temp-limit = <0x03 0x17700 0x06 0x23280 0x09 0x2ee00 0x0f 0x5dc00>; performance-temp-limit = <0x6e 0xc7380>; status = "okay"; regu-mode-table = <0xf6180 0x04 0x00 0x03>; regu-mode-en = <0x00>; lkg_adjust_volt_en = <0x01>; channel = <0x00>; tsadc-ch = <0x00>; def_table_lkg = <0x08>; min_adjust_freq = <0xf6180>; lkg_adjust_volt_table = <0x14 0xc350 0x3c 0x124f8>; }; }; }; vd_logic { regulator_name = "vdd_logic"; pd_ddr { clk_ddr { operating-points = <0x493e0 0x112a88 0x9a8a8 0x112a88 0xaae60 0x118c30 0xc3500 0x118c30>; lkg_adjust_volt_en = <0x01>; channel = <0x02>; def_table_lkg = <0x05>; min_adjust_freq = <0x493e0>; lkg_adjust_volt_table = <0x07 0xc350 0x3c 0x186a0>; temp-limit-enable = <0x01>; status = "okay"; freq-table = <0x01 0x9a8a8 0x10 0xaae60 0x10000 0xbfe50>; }; }; pd_gpu { clk_gpu { operating-points = <0x30d40 0x100590 0x493e0 0x100590 0x7a120 0x118c30>; temp-limit-enable = <0x01>; target-temp = <0x5f>; min_temp_limit = <0x186a0>; normal-temp-limit = <0x03 0x186a0>; channel = <0x02>; status = "okay"; regu-mode-table = <0x30d40 0x04 0x00 0x03>; regu-mode-en = <0x00>; }; }; }; }; rockchip-ion { compatible = "rockchip,ion"; #address-cells = <0x01>; #size-cells = <0x00>; system-heap { compatible = "rockchip,ion-heap"; rockchip,ion_heap = <0x00>; }; }; dram { compatible = "rockchip,rk322x-dram"; status = "okay"; dram_freq = <0x1dcd6500>; rockchip,dram_timing = <0x5e>; }; clocks-init { compatible = "rockchip,clocks-init"; rockchip,clocks-init-parent = <0x1f 0x08 0x10 0x08 0x2e 0x08 0x1b 0x08 0x41 0x0b 0x5f 0x0c 0x22 0x0b 0x25 0x0b 0x24 0x0b 0x04 0x0b 0x0c 0x45 0x23 0x48 0x03 0x0b>; rockchip,clocks-init-rate = <0x08 0x47868c00 0x06 0x29b92700 0x0b 0x1dcd6500 0x0d 0x8f0d180 0x51 0x8f0d180 0x4f 0x47868c0 0x21 0x8f0d180 0x54 0x8f0d180 0x55 0x47868c0 0x4e 0x7735940 0x0e 0xee6b280 0x57 0x7735940 0x32 0xee6b280 0x41 0xee6b280 0x04 0x17d7840 0x42 0xee6b280 0x3a 0xee6b280 0x03 0xf42400 0x40 0x17d78400>; }; clocks-enable { compatible = "rockchip,clocks-enable"; clocks = <0x07 0x09 0x08 0x0b 0x06 0x60 0x44 0x61 0x02 0x52 0x03 0x43 0x01 0x62 0x05 0x62 0x00 0x62 0x01 0x62 0x02 0x63 0x01 0x62 0x03 0x62 0x04 0x62 0x06 0x64 0x04 0x64 0x05 0x64 0x08 0x63 0x00 0x63 0x04 0x63 0x06 0x63 0x03 0x63 0x09 0x63 0x02 0x65 0x00 0x65 0x01 0x65 0x02 0x66 0x0d 0x56 0x07 0x67 0x07 0x52 0x05 0x52 0x06 0x59 0x04 0x59 0x06 0x59 0x05 0x59 0x07 0x56 0x0b 0x43 0x0f 0x56 0x09 0x56 0x0c 0x56 0x0a 0x56 0x08 0x56 0x0d 0x68 0x03>; }; serial@11010000 { compatible = "rockchip,serial"; reg = <0x11010000 0x100>; interrupts = <0x00 0x37 0x04>; clock-frequency = <0x16e3600>; clocks = <0x69 0x64 0x0c>; clock-names = "sclk_uart\0pclk_uart"; reg-shift = <0x02>; reg-io-width = <0x04>; dmas = <0x6a 0x02 0x6a 0x03>; #dma-cells = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x6b 0x6c 0x6d>; status = "disabled"; }; serial@11020000 { compatible = "rockchip,serial"; reg = <0x11020000 0x100>; interrupts = <0x00 0x38 0x04>; clock-frequency = <0x16e3600>; clocks = <0x6e 0x64 0x0d>; clock-names = "sclk_uart\0pclk_uart"; reg-shift = <0x02>; reg-io-width = <0x04>; dmas = <0x6a 0x04 0x6a 0x05>; #dma-cells = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x6f 0x70>; status = "okay"; dma-names = "!tx\0!rx"; }; serial@11030000 { compatible = "rockchip,serial"; reg = <0x11030000 0x100>; interrupts = <0x00 0x39 0x04>; clock-frequency = <0x16e3600>; clocks = <0x71 0x64 0x0e>; clock-names = "sclk_uart\0pclk_uart"; reg-shift = <0x02>; reg-io-width = <0x04>; dmas = <0x6a 0x06 0x6a 0x07>; #dma-cells = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x5a>; status = "disabled"; }; i2c@11050000 { compatible = "rockchip,rk30-i2c"; reg = <0x11050000 0x1000>; interrupts = <0x00 0x24 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default\0gpio\0sleep"; pinctrl-0 = <0x72>; pinctrl-1 = <0x73>; pinctrl-2 = <0x74>; gpios = <0x75 0x01 0x01 0x75 0x00 0x01>; clocks = <0x62 0x0f>; rockchip,check-idle = <0x01>; status = "okay"; rtc@51 { compatible = "rtc,hym8563"; reg = <0x51>; }; }; i2c@11060000 { compatible = "rockchip,rk30-i2c"; reg = <0x11060000 0x1000>; interrupts = <0x00 0x25 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default\0gpio\0sleep"; pinctrl-0 = <0x76>; pinctrl-1 = <0x77>; pinctrl-2 = <0x78>; gpios = <0x75 0x03 0x01 0x75 0x02 0x01>; clocks = <0x64 0x00>; rockchip,check-idle = <0x01>; status = "disabled"; nau8540@1c { compatible = "nuvoton,nau8540"; reg = <0x1c>; linux,phandle = <0xbe>; phandle = <0xbe>; }; nau8540@1d { compatible = "nuvoton,nau8540"; reg = <0x1d>; }; }; i2c@11070000 { compatible = "rockchip,rk30-i2c"; reg = <0x11070000 0x1000>; interrupts = <0x00 0x26 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default\0gpio\0sleep"; pinctrl-0 = <0x79>; pinctrl-1 = <0x7a>; pinctrl-2 = <0x7b>; gpios = <0x7c 0x14 0x01 0x7c 0x15 0x01>; clocks = <0x64 0x01>; rockchip,check-idle = <0x01>; status = "disabled"; }; i2c@11080000 { compatible = "rockchip,rk30-i2c"; reg = <0x11080000 0x1000>; interrupts = <0x00 0x27 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default\0gpio\0sleep"; pinctrl-0 = <0x7d>; pinctrl-1 = <0x7e>; pinctrl-2 = <0x7f>; gpios = <0x75 0x07 0x01 0x75 0x06 0x01>; clocks = <0x64 0x02>; rockchip,check-idle = <0x01>; status = "disabled"; }; spi@11090000 { compatible = "rockchip,rockchip-spi"; reg = <0x11090000 0x1000>; interrupts = <0x00 0x31 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default"; pinctrl-0 = <0x80 0x81 0x82 0x83 0x84>; rockchip,spi-src-clk = <0x00>; num-cs = <0x02>; clocks = <0x85 0x09 0x64 0x06>; clock-names = "spi\0pclk_spi0"; status = "disabled"; max-freq = <0x2dc6c00>; spi_test@00 { compatible = "rockchip,spi_test_bus0_cs0"; reg = <0x00>; spi-max-frequency = <0xb71b00>; poll_mode = <0x00>; type = <0x00>; }; spi_test@01 { compatible = "rockchip,spi_test_bus0_cs1"; reg = <0x01>; spi-max-frequency = <0xb71b00>; spi-cpha; spi-cpol; poll_mode = <0x00>; type = <0x00>; }; }; wdt@110a0000 { compatible = "rockchip,watch dog"; reg = <0x110a0000 0x100>; clocks = <0x52 0x03>; clock-names = "pclk_wdt"; interrupts = <0x00 0x28 0x04>; rockchip,irq = <0x01>; rockchip,timeout = <0x3c>; rockchip,atboot = <0x01>; rockchip,debug = <0x00>; status = "disabled"; }; amba { #address-cells = <0x01>; #size-cells = <0x01>; compatible = "arm,amba-bus"; interrupt-parent = <0x01>; ranges; pdma@110f0000 { compatible = "arm,pl330\0arm,primecell"; reg = <0x110f0000 0x4000>; clocks = <0x62 0x02>; clock-names = "apb_pclk"; interrupts = <0x00 0x00 0x04 0x00 0x01 0x04>; #dma-cells = <0x01>; linux,phandle = <0x6a>; phandle = <0x6a>; }; }; crypto@100a0000 { compatible = "rockchip-crypto"; reg = <0x100a0000 0x10000>; interrupts = <0x00 0x1e 0x04>; interrupt-names = "irq_crypto"; clocks = <0x36 0x62 0x0c 0x62 0x0b>; clock-names = "clk_crypto\0hclk_crypto\0aclk_crypto"; status = "disabled"; }; i2s0@100c0000 { compatible = "rockchip-i2s"; reg = <0x100c0000 0x1000>; i2s-id = <0x00>; clocks = <0x49 0x62 0x07>; clock-names = "i2s_clk\0i2s_hclk"; interrupts = <0x00 0x1a 0x04>; dmas = <0x6a 0x0b 0x6a 0x0c>; #dma-cells = <0x02>; dma-names = "tx\0rx"; status = "okay"; linux,phandle = <0xbd>; phandle = <0xbd>; }; i2s1@100b0000 { compatible = "rockchip-i2s"; reg = <0x100b0000 0x1000>; i2s-id = <0x01>; clocks = <0x15 0x4b 0x62 0x08>; clock-names = "i2s_clk\0i2s_mclk\0i2s_hclk"; interrupts = <0x00 0x1b 0x04>; dmas = <0x6a 0x0e 0x6a 0x0f>; #dma-cells = <0x02>; dma-names = "tx\0rx"; status = "okay"; linux,phandle = <0xb9>; phandle = <0xb9>; }; i2s2@100e0000 { compatible = "rockchip-i2s"; reg = <0x100e0000 0x1000>; i2s-id = <0x02>; clocks = <0x4a 0x62 0x09>; clock-names = "i2s_clk\0i2s_hclk"; interrupts = <0x00 0x1c 0x04>; dmas = <0x6a 0x00 0x6a 0x01>; #dma-cells = <0x02>; dma-names = "tx\0rx"; pinctrl-names = "default\0sleep"; pinctrl-0 = <0x86 0x87 0x88 0x89>; pinctrl-1 = <0x8a>; status = "disabled"; }; spdif@100d0000 { compatible = "rockchip-spdif"; reg = <0x100d0000 0x1000>; clocks = <0x8b 0x62 0x0a>; clock-names = "spdif_mclk\0spdif_hclk"; interrupts = <0x00 0x1d 0x04>; dmas = <0x6a 0x0a>; #dma-cells = <0x01>; dma-names = "tx"; pinctrl-names = "default"; pinctrl-0 = <0x8c>; status = "okay"; linux,phandle = <0xbb>; phandle = <0xbb>; }; codec@12010000 { compatible = "rockchip,rk322x-codec"; reg = <0x12010000 0x1000>; clocks = <0x63 0x05>; clock-names = "g_pclk_acodec"; spk_ctl_io = <0x8d 0x03 0x00>; status = "okay"; spk_depop_time = <0x64>; linux,phandle = <0xb8>; phandle = <0xb8>; }; codec-spdif { compatible = "hdmi-spdif"; status = "okay"; linux,phandle = <0xba>; phandle = <0xba>; }; codec-hdmi-i2s { compatible = "hdmi-i2s"; status = "okay"; linux,phandle = <0xbc>; phandle = <0xbc>; }; tsadc@11150000 { compatible = "rockchip,rk322x-tsadc"; reg = <0x11150000 0x100>; interrupts = <0x00 0x3a 0x04>; clock-frequency = <0x8000>; clocks = <0x4d 0x64 0x0f>; clock-names = "tsadc\0pclk_tsadc"; resets = <0x8e 0x57>; reset-names = "tsadc-apb"; #io-channel-cells = <0x01>; io-channel-ranges; pinctrl-names = "default"; pinctrl-0 = <0x8f>; tsadc-ht-temp = <0x78>; tsadc-ht-reset-cru = <0x01>; tsadc-ht-pull-gpio = <0x00>; status = "okay"; }; gpu { compatible = "arm,mali400"; reg = <0x20001000 0x200 0x20000000 0x100 0x20003000 0x100 0x20008000 0x1100 0x20004000 0x100 0x2000a000 0x1100 0x20005000 0x100>; reg-names = "Mali_L2\0Mali_GP\0Mali_GP_MMU\0Mali_PP0\0Mali_PP0_MMU\0Mali_PP1\0Mali_PP1_MMU"; interrupts = <0x00 0x06 0x04 0x00 0x05 0x04 0x00 0x04 0x04 0x00 0x05 0x04 0x00 0x04 0x04 0x00 0x05 0x04>; interrupt-names = "Mali_GP_IRQ\0Mali_GP_MMU_IRQ\0Mali_PP0_IRQ\0Mali_PP0_MMU_IRQ\0Mali_PP1_IRQ\0Mali_PP1_MMU_IRQ"; }; fb { compatible = "rockchip,rk-fb"; rockchip,disp-mode = <0x00>; rockchip,disp-policy = <0x01>; rockchip,uboot-logo-on = <0x01>; }; rk_screen { compatible = "rockchip,screen"; display-timings = <0x90>; }; pwm@110b0000 { compatible = "rockchip,rk-pwm"; reg = <0x110b0000 0x10>; interrupts = <0x00 0x32 0x04>; #pwm-cells = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x91>; clocks = <0x64 0x07>; clock-names = "pclk_pwm"; status = "disabled"; }; pwm@110b0010 { compatible = "rockchip,rk-pwm"; reg = <0x110b0010 0x10>; interrupts = <0x00 0x32 0x04>; #pwm-cells = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x92>; clocks = <0x64 0x07>; clock-names = "pclk_pwm"; status = "okay"; linux,phandle = <0xb6>; phandle = <0xb6>; }; pwm@110b0020 { compatible = "rockchip,rk-pwm"; reg = <0x110b0020 0x10>; interrupts = <0x00 0x32 0x04>; #pwm-cells = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x93>; clocks = <0x64 0x07>; clock-names = "pclk_pwm"; status = "okay"; linux,phandle = <0xb7>; phandle = <0xb7>; }; pwm@110b0030 { compatible = "rockchip,remotectl-pwm"; reg = <0x110b0030 0x10>; interrupts = <0x00 0x32 0x04>; #pwm-cells = <0x02>; pinctrl-names = "default"; pinctrl-0 = <0x94>; clocks = <0x64 0x07>; clock-names = "pclk_pwm"; remote-gpios = <0x75 0x03 0x00>; suspend1-gpios = <0x8d 0x07 0x00>; suspend2-gpios = <0x95 0x15 0x01>; net1-gpios = <0x7c 0x0e 0x01>; status = "okay"; remote_pwm_id = <0x03>; handle_cpu_id = <0x01>; ir_key1 { rockchip,usercode = <0xfd01>; rockchip,key_table = <0x31 0xe8 0x29 0x9e 0x2e 0x9e 0x35 0x67 0x2d 0x6c 0x66 0x69 0x3e 0x6a 0x6a 0x66 0x7a 0x73 0x79 0x72 0x23 0x74 0x76 0x71 0x3a 0x8b 0x72 0x184 0x6d 0x02 0x6c 0x03 0x33 0x04 0x71 0x05 0x70 0x06 0x37 0x07 0x75 0x08 0x74 0x09 0x3b 0x0a 0x78 0x0b 0x2c 0x0e 0x65 0x8d 0x22 0x67 0x73 0x6c>; }; ir_key2 { rockchip,usercode = <0x7f80>; rockchip,key_table = <0xec 0xe8 0xd8 0x9e 0xc7 0x67 0xbf 0x6c 0xc8 0x69 0xc6 0x6a 0x8c 0x66 0x78 0x73 0x76 0x72 0x7e 0x74 0x7c 0x8b 0xb7 0x184>; }; ir_key3 { rockchip,usercode = <0x1dcc>; rockchip,key_table = <0xee 0xe8 0xf0 0x9e 0xf8 0x67 0xbb 0x6c 0xef 0x69 0xed 0x6a 0xfc 0x66 0xf1 0x73 0xfd 0x72 0xb7 0xd9 0xff 0x74 0xf3 0x71 0xbf 0x8b 0xf9 0x191 0xf5 0x192 0xb3 0x184 0xbe 0x02 0xba 0x03 0xb2 0x04 0xbd 0x05 0xf9 0x06 0xb1 0x07 0xfc 0x08 0xf8 0x09 0xb0 0x0a 0xb6 0x0b 0xb5 0x0e>; }; ir_key4 { rockchip,usercode = <0xfe01>; rockchip,key_table = <0xec 0xe8 0xe6 0x9e 0xe9 0x67 0xe5 0x6c 0xae 0x69 0xaf 0x6a 0xee 0x66 0xe7 0x73 0xef 0x72 0xea 0xd9 0xbf 0x74 0xbe 0x71 0xb3 0x8b 0xf9 0x191 0xf5 0x192 0xff 0x184 0xb1 0x02 0xf2 0x03 0xf3 0x04 0xb5 0x05 0xf6 0x06 0xf7 0x07 0xb9 0x08 0xfa 0x09 0xfb 0x0a 0xfe 0x0b 0xbd 0x0e 0xbc 0x8d 0xb4 0xf2 0xb0 0xf1 0xf0 0x3b 0xbb 0x3c 0xaa 0xa8 0xab 0x9f 0xa5 0xa4 0xad 0x80>; }; }; net_power_led { compatible = "net_led"; net_power,pin1 = <0x7c 0x0e 0x01>; status = "okay"; }; remote_power_led { compatible = "remote_led"; remote_power,pin = <0x75 0x03 0x00>; status = "okay"; }; suspend_power_led { compatible = "suspend_led"; suspend_power,pin1 = <0x8d 0x07 0x00>; suspend_power,pin2 = <0x95 0x15 0x01>; status = "okay"; }; vpu_service@20020000 { compatible = "vpu_service"; rockchip,grf = <0x5b>; iommu_enabled = <0x01>; reg = <0x20020000 0x800>; interrupts = <0x00 0x09 0x04 0x00 0x0b 0x04>; interrupt-names = "irq_dec\0irq_enc"; clocks = <0x04 0x96>; clock-names = "aclk_vcodec\0hclk_vcodec"; resets = <0x8e 0x71 0x8e 0x70>; reset-names = "video_h\0video_a"; dev_mode = <0x00>; status = "okay"; }; rkvdec@20030000 { compatible = "rockchip,rkvdec"; rockchip,grf = <0x5b>; iommu_enabled = <0x01>; reg = <0x20030000 0x400>; interrupts = <0x00 0x07 0x04>; interrupt-names = "irq_dec"; clocks = <0x03 0x58 0x3a 0x42>; clock-names = "aclk_vcodec\0hclk_vcodec\0clk_cabac\0clk_core"; resets = <0x8e 0x78 0x8e 0x76>; reset-names = "video_h\0video_a"; dev_mode = <0x02>; status = "okay"; }; vop@20050000 { compatible = "rockchip,rk322x-lcdc"; rockchip,prop = <0x01>; rockchip,cabc_mode = <0x00>; rockchip,pwr18 = <0x00>; rockchip,iommu-enabled = <0x01>; reg = <0x20050000 0x2000>; interrupts = <0x00 0x20 0x04>; clocks = <0x56 0x05 0x5f 0x56 0x06 0x56 0x0c 0x56 0x0d>; clock-names = "aclk_vop\0dclk_vop\0hclk_vop\0aclk_vop_noc\0hclk_vop_noc"; }; rga@20060000 { compatible = "rockchip,rga2"; reg = <0x20060000 0x1000>; interrupts = <0x00 0x21 0x04>; clocks = <0x56 0x00 0x56 0x01 0x32>; clock-names = "aclk_rga\0hclk_rga\0pd_rga"; }; iep@20070000 { compatible = "rockchip,iep"; iommu_enabled = <0x01>; reg = <0x20070000 0x800>; interrupts = <0x00 0x1f 0x04>; clocks = <0x56 0x02 0x56 0x03>; clock-names = "aclk_iep\0hclk_iep"; version = <0x03>; status = "okay"; }; vop_mmu { dbgname = "vop"; compatible = "rockchip,vop_mmu"; reg = <0x20053f00 0x100>; interrupts = <0x00 0x20 0x04>; interrupt-names = "vop_mmu"; }; vpu_mmu { dbgname = "vpu"; compatible = "rockchip,vpu_mmu"; reg = <0x20020800 0x100>; interrupts = <0x00 0x0a 0x04>; interrupt-names = "vpu_mmu"; }; iep_mmu { dbgname = "iep"; compatible = "rockchip,iep_mmu"; reg = <0x20070800 0x100>; interrupts = <0x00 0x1f 0x04>; interrupt-names = "iep_mmu"; }; vdec_mmu { dbgname = "vdec"; compatible = "rockchip,vdec_mmu"; reg = <0x20030480 0x40 0x200304c0 0x40>; interrupts = <0x00 0x08 0x04>; interrupt-names = "vdec_mmu"; }; hdmi@200a0000 { compatible = "rockchip,rk322x-hdmi"; reg = <0x200a0000 0x20000 0x12030000 0x10000>; interrupts = <0x00 0x23 0x04 0x00 0x47 0x04>; clocks = <0x97 0x07 0x67 0x06 0x63 0x07 0x05>; clock-names = "hdcp_clk_hdmi\0pclk_hdmi\0pclk_hdmi_phy\0cec_clk_hdmi"; pinctrl-names = "default\0gpio"; pinctrl-0 = <0x98 0x99 0x9a>; pinctrl-1 = <0x7e>; resets = <0x8e 0x60>; reset-names = "hdmi"; rockchip,grf = <0x5b>; rockchip,hdmi_audio_source = <0x00>; rockchip,hdcp_enable = <0x00>; rockchip,cec_enable = <0x00>; status = "okay"; rockchip,phy_table = <0x9d5b340 0x00 0x00 0x04 0x04 0x04 0x04 0xd693a40 0x00 0x00 0x06 0x06 0x06 0x06 0x1443fd00 0x01 0x00 0x06 0x0a 0x0a 0x0a 0x2367b880 0x01 0x00 0x07 0x0a 0x0a 0x0a>; }; hdmi_hdcp2@20090000 { compatible = "rockchip,rk322x-hdmi-hdcp2"; reg = <0x20090000 0x10000>; interrupts = <0x00 0x22 0x04>; clocks = <0x56 0x0a 0x67 0x0c 0x67 0x0b 0x67 0x0a 0x35>; clock-names = "aclk_noc_hdcp2\0hclk_hdcp2_mmu\0pclk_hdcp2\0aclk_hdcp2\0hdcp2_clk_hdmi"; status = "disabled"; }; tve { compatible = "rockchip,rk322x-tve"; reg = <0x20053e00 0x100 0x12020000 0x10000>; clocks = <0x63 0x08>; clock-names = "pclk_vdac"; saturation = <0x305b46>; brightcontrast = <0x9900>; adjtiming = <0xd6c00880>; lumafilter0 = <0x2ff0001>; lumafilter1 = <0xf40200fe>; lumafilter2 = <0xf332d910>; daclevel = <0x15>; dac1level = <0x07>; status = "okay"; }; rksdmmc@30020000 { compatible = "rockchip,rk_mmc\0rockchip,rk322x-sdmmc"; reg = <0x30020000 0x10000>; interrupts = <0x00 0x0e 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; clocks = <0x25 0x66 0x02>; clock-names = "clk_mmc\0hclk_mmc"; num-slots = <0x01>; fifo-depth = <0x100>; bus-width = <0x08>; tune_regsbase = <0x1d8>; resets = <0x8e 0x53>; reset-names = "mmc_ahb_reset"; clock-frequency = <0x7735940>; clock-freq-min-max = <0x61a80 0x7735940>; supports-highspeed; supports-emmc; bootpart-no-access; supports-DDR_MODE; caps2-mmc-hs200; ignore-pm-notify; keep-power-in-suspend; status = "okay"; }; rksdmmc@30000000 { compatible = "rockchip,rk_mmc\0rockchip,rk322x-sdmmc"; reg = <0x30000000 0x10000>; interrupts = <0x00 0x0c 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default\0idle"; pinctrl-0 = <0x9b 0x9c 0x9d 0x9e 0x9f>; pinctrl-1 = <0xa0>; cd-gpios = <0x8d 0x11 0x00>; clocks = <0x22 0x66 0x00>; clock-names = "clk_mmc\0hclk_mmc"; num-slots = <0x01>; fifo-depth = <0x100>; bus-width = <0x04>; resets = <0x8e 0x51>; reset-names = "mmc_ahb_reset"; clock-frequency = <0x23c3460>; clock-freq-min-max = <0x61a80 0x23c3460>; supports-highspeed; supports-sd; broken-cd; card-detect-delay = <0xc8>; ignore-pm-notify; keep-power-in-suspend; power-inverted; status = "okay"; }; rksdmmc@30010000 { compatible = "rockchip,rk_mmc\0rockchip,rk322x-sdmmc"; reg = <0x30010000 0x10000>; interrupts = <0x00 0x0d 0x04>; #address-cells = <0x01>; #size-cells = <0x00>; pinctrl-names = "default\0idle"; pinctrl-0 = <0xa1 0xa2 0xa3>; pinctrl-1 = <0xa4>; clocks = <0x24 0x66 0x01>; clock-names = "clk_mmc\0hclk_mmc"; num-slots = <0x01>; fifo-depth = <0x100>; bus-width = <0x04>; tune_regsbase = <0x1c8>; resets = <0x8e 0x52>; reset-names = "mmc_ahb_reset"; clock-frequency = <0x23c3460>; clock-freq-min-max = <0x30d40 0x23c3460>; supports-highspeed; supports-sdio; ignore-pm-notify; keep-power-in-suspend; cap-sdio-irq; status = "okay"; }; nandc@30030000 { compatible = "rockchip,rk-nandc"; reg = <0x30030000 0x4000>; interrupts = <0x00 0x0f 0x04>; nandc_id = <0x00>; clocks = <0x0f 0x68 0x00 0x66 0x03>; clock-names = "clk_nandc\0g_clk_nandc\0hclk_nandc"; status = "okay"; }; phy { compatible = "rockchip,rk322x-usb-phy"; rockchip,grf = <0x5b>; #address-cells = <0x01>; #size-cells = <0x00>; usb-phy0 { #phy-cells = <0x00>; reg = <0x764>; linux,phandle = <0xa5>; phandle = <0xa5>; }; usb-phy1 { #phy-cells = <0x00>; reg = <0x800>; linux,phandle = <0xa6>; phandle = <0xa6>; }; usb-phy2 { #phy-cells = <0x00>; reg = <0x804>; linux,phandle = <0xa7>; phandle = <0xa7>; }; }; otg@30040000 { compatible = "rockchip,rk322x_usb20_otg"; reg = <0x30040000 0x40000>; interrupts = <0x00 0x17 0x04>; clocks = <0x68 0x05 0x66 0x0c 0x66 0x0d>; clock-names = "clk_usbphy0\0hclk_otg\0hclk_otg_pmu"; resets = <0x8e 0x45 0x8e 0x67 0x8e 0x46>; reset-names = "otg_ahb\0otg_phy\0otg_controller"; rockchip,usb-mode = <0x01>; }; ehci0@30080000 { compatible = "generic-ehci"; reg = <0x30080000 0x20000>; interrupts = <0x00 0x10 0x04>; clocks = <0x68 0x05 0x66 0x06 0x66 0x07>; clock-names = "clk_usbphy0\0hclk_host0\0hclk_host0_arb"; phys = <0xa5>; phy-names = "usb"; resets = <0x8e 0x47 0x8e 0x68 0x8e 0x48>; reset-names = "host_ahb\0host_phy\0host_controller"; }; ohci0@300a0000 { compatible = "generic-ohci"; reg = <0x300a0000 0x20000>; interrupts = <0x00 0x11 0x04>; }; ehci1@300c0000 { compatible = "generic-ehci"; reg = <0x300c0000 0x20000>; interrupts = <0x00 0x13 0x04>; clocks = <0x68 0x06 0x66 0x08 0x66 0x09>; clock-names = "clk_usbphy1\0hclk_host1\0hclk_host1_arb"; phys = <0xa6>; phy-names = "usb"; resets = <0x8e 0x49 0x8e 0x69 0x8e 0x4a>; reset-names = "host_ahb\0host_phy\0host_controller"; }; ohci1@300e0000 { compatible = "generic-ohci"; reg = <0x300e0000 0x20000>; interrupts = <0x00 0x14 0x04>; }; ehci2@30100000 { compatible = "generic-ehci"; reg = <0x30100000 0x20000>; interrupts = <0x00 0x42 0x04>; clocks = <0x68 0x06 0x66 0x0a 0x66 0x0e>; clock-names = "clk_usbphy1\0hclk_host2\0hck_host2_arb"; phys = <0xa7>; phy-names = "usb"; resets = <0x8e 0x4b 0x8e 0x6a 0x8e 0x4c>; reset-names = "host_ahb\0host_phy\0host_controller"; }; ohci2@30120000 { compatible = "generic-ohci"; reg = <0x30120000 0x20000>; interrupts = <0x00 0x43 0x04>; }; eth@30200000 { compatible = "rockchip,rk322x-gmac"; reg = <0x30200000 0x10000>; rockchip,grf = <0x5b>; interrupts = <0x00 0x18 0x04>; interrupt-names = "macirq"; clocks = <0x4e 0xa8 0x05 0xa8 0x06 0xa8 0x03 0xa8 0x04 0x66 0x04 0x66 0x05>; clock-names = "clk_mac\0mac_clk_rx\0mac_clk_tx\0clk_mac_ref\0clk_mac_refout\0aclk_mac\0pclk_mac"; resets = <0x8e 0x3f>; reset-names = "mac-phy"; phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <0xa9>; status = "okay"; link-gpio = <0x75 0x0e 0x00>; led-gpio = <0x7c 0x08 0x00>; clock_in_out = "output"; tx_delay = <0x26>; rx_delay = <0x11>; phy-type = "internal"; }; rockchip_suspend { rockchip,ctrbits = <0x11806>; }; pinctrl { compatible = "rockchip,rk322x-pinctrl"; rockchip,grf = <0x5b>; #address-cells = <0x01>; #size-cells = <0x01>; ranges; gpio0@11110000 { compatible = "rockchip,gpio-bank"; reg = <0x11110000 0x100>; interrupts = <0x00 0x33 0x04>; clocks = <0x64 0x09>; gpio-controller; #gpio-cells = <0x02>; interrupt-controller; #interrupt-cells = <0x02>; linux,phandle = <0x75>; phandle = <0x75>; }; gpio1@11120000 { compatible = "rockchip,gpio-bank"; reg = <0x11120000 0x100>; interrupts = <0x00 0x34 0x04>; clocks = <0x64 0x09>; gpio-controller; #gpio-cells = <0x02>; interrupt-controller; #interrupt-cells = <0x02>; linux,phandle = <0x8d>; phandle = <0x8d>; }; gpio2@11130000 { compatible = "rockchip,gpio-bank"; reg = <0x11130000 0x100>; interrupts = <0x00 0x35 0x04>; clocks = <0x64 0x0a>; gpio-controller; #gpio-cells = <0x02>; interrupt-controller; #interrupt-cells = <0x02>; linux,phandle = <0x7c>; phandle = <0x7c>; }; gpio3@11140000 { compatible = "rockchip,gpio-bank"; reg = <0x11140000 0x100>; interrupts = <0x00 0x36 0x04>; clocks = <0x64 0x0b>; gpio-controller; #gpio-cells = <0x02>; interrupt-controller; #interrupt-cells = <0x02>; linux,phandle = <0x95>; phandle = <0x95>; }; pcfg-pull-up { bias-pull-up; linux,phandle = <0xac>; phandle = <0xac>; }; pcfg-pull-down { bias-pull-down; linux,phandle = <0xb2>; phandle = <0xb2>; }; pcfg-pull-none { bias-disable; linux,phandle = <0xaa>; phandle = <0xaa>; }; pcfg-pull-none-drv-8ma { drive-strength = <0x08>; linux,phandle = <0xaf>; phandle = <0xaf>; }; pcfg-pull-none-drv-12ma { drive-strength = <0x0c>; linux,phandle = <0xb1>; phandle = <0xb1>; }; pcfg-pull-up-drv-8ma { bias-pull-up; drive-strength = <0x08>; linux,phandle = <0xb0>; phandle = <0xb0>; }; pcfg-pull-none-drv-4ma { drive-strength = <0x04>; linux,phandle = <0xad>; phandle = <0xad>; }; pcfg-pull-up-drv-4ma { bias-pull-up; drive-strength = <0x04>; linux,phandle = <0xae>; phandle = <0xae>; }; pcfg-pull-down-drv-12ma { bias-pull-down; drive-strength = <0x0c>; }; pcfg-output-high { output-high; }; pcfg-output-low { output-low; }; pcfg-input-high { bias-pull-up; input-enable; linux,phandle = <0xab>; phandle = <0xab>; }; i2c0 { i2c0-xfer { rockchip,pins = <0x00 0x00 0x01 0xaa 0x00 0x01 0x01 0xaa>; linux,phandle = <0x72>; phandle = <0x72>; }; i2c0-gpio { rockchip,pins = <0x00 0x00 0x00 0xaa 0x00 0x01 0x00 0xaa>; linux,phandle = <0x73>; phandle = <0x73>; }; i2c0-sleep { rockchip,pins = <0x00 0x00 0x00 0xab 0x00 0x01 0x00 0xab>; linux,phandle = <0x74>; phandle = <0x74>; }; }; i2c1 { i2c1-xfer { rockchip,pins = <0x00 0x02 0x01 0xaa 0x00 0x03 0x01 0xaa>; linux,phandle = <0x76>; phandle = <0x76>; }; i2c1-gpio { rockchip,pins = <0x00 0x02 0x00 0xaa 0x00 0x03 0x00 0xaa>; linux,phandle = <0x77>; phandle = <0x77>; }; i2c1-sleep { rockchip,pins = <0x00 0x02 0x00 0xab 0x00 0x03 0x00 0xab>; linux,phandle = <0x78>; phandle = <0x78>; }; }; i2c2 { i2c2-xfer { rockchip,pins = <0x02 0x15 0x01 0xaa 0x02 0x14 0x01 0xaa>; linux,phandle = <0x79>; phandle = <0x79>; }; i2c2-gpio { rockchip,pins = <0x02 0x15 0x00 0xaa 0x02 0x14 0x00 0xaa>; linux,phandle = <0x7a>; phandle = <0x7a>; }; i2c2-sleep { rockchip,pins = <0x02 0x15 0x00 0xab 0x02 0x14 0x00 0xab>; linux,phandle = <0x7b>; phandle = <0x7b>; }; }; i2c3 { i2c3-xfer { rockchip,pins = <0x00 0x06 0x01 0xaa 0x00 0x07 0x01 0xaa>; linux,phandle = <0x7d>; phandle = <0x7d>; }; i2c3-gpio { rockchip,pins = <0x00 0x06 0x00 0xaa 0x00 0x07 0x00 0xaa>; linux,phandle = <0x7e>; phandle = <0x7e>; }; i2c3-sleep { rockchip,pins = <0x00 0x06 0x00 0xab 0x00 0x07 0x00 0xab>; linux,phandle = <0x7f>; phandle = <0x7f>; }; }; uart0 { uart0-xfer { rockchip,pins = <0x02 0x1a 0x01 0xac 0x02 0x1b 0x01 0xaa>; linux,phandle = <0x6b>; phandle = <0x6b>; }; uart0-cts { rockchip,pins = <0x02 0x1d 0x01 0xaa>; linux,phandle = <0x6c>; phandle = <0x6c>; }; uart0-rts { rockchip,pins = <0x00 0x11 0x01 0xaa>; linux,phandle = <0x6d>; phandle = <0x6d>; }; uart0-rts-gpio { rockchip,pins = <0x00 0x11 0x00 0xaa>; }; }; uart1-0 { uart1-xfer { rockchip,pins = <0x01 0x0a 0x01 0xac 0x01 0x09 0x01 0xaa>; }; uart1-cts { rockchip,pins = <0x01 0x08 0x01 0xaa>; }; uart1-rts { rockchip,pins = <0x01 0x0b 0x01 0xaa>; }; uart1-rts-gpio { rockchip,pins = <0x01 0x0b 0x00 0xaa>; }; }; uart1-1 { uart11-xfer { rockchip,pins = <0x03 0x0e 0x01 0xac 0x03 0x0d 0x01 0xaa>; linux,phandle = <0x6f>; phandle = <0x6f>; }; uart11-cts { rockchip,pins = <0x03 0x07 0x01 0xaa>; linux,phandle = <0x70>; phandle = <0x70>; }; uart11-rts { rockchip,pins = <0x03 0x06 0x01 0xaa>; linux,phandle = <0xb4>; phandle = <0xb4>; }; uart11-rts-gpio { rockchip,pins = <0x03 0x06 0x00 0xaa>; linux,phandle = <0xb5>; phandle = <0xb5>; }; }; uart2-0 { uart2-xfer { rockchip,pins = <0x01 0x12 0x02 0xac 0x01 0x13 0x02 0xaa>; }; uart2-cts { rockchip,pins = <0x00 0x19 0x01 0xaa>; }; uart2-rts { rockchip,pins = <0x00 0x18 0x01 0xaa>; }; }; uart2-1 { uart21-xfer { rockchip,pins = <0x01 0x0a 0x02 0xac 0x01 0x09 0x02 0xaa>; linux,phandle = <0x5a>; phandle = <0x5a>; }; }; spi-0 { spi0-clk { rockchip,pins = <0x00 0x09 0x02 0xac>; linux,phandle = <0x80>; phandle = <0x80>; }; spi0-cs0 { rockchip,pins = <0x00 0x0e 0x02 0xac>; linux,phandle = <0x83>; phandle = <0x83>; }; spi0-tx { rockchip,pins = <0x00 0x0b 0x02 0xac>; linux,phandle = <0x81>; phandle = <0x81>; }; spi0-rx { rockchip,pins = <0x00 0x0d 0x02 0xac>; linux,phandle = <0x82>; phandle = <0x82>; }; spi0-cs1 { rockchip,pins = <0x01 0x0c 0x01 0xac>; linux,phandle = <0x84>; phandle = <0x84>; }; }; spi-1 { spi1-clk { rockchip,pins = <0x00 0x17 0x02 0xac>; }; spi1-cs0 { rockchip,pins = <0x02 0x02 0x02 0xac>; }; spi1-rx { rockchip,pins = <0x02 0x00 0x02 0xac>; }; spi1-tx { rockchip,pins = <0x02 0x01 0x02 0xac>; }; spi1-cs1 { rockchip,pins = <0x02 0x03 0x02 0xac>; }; }; i2s { i2s-mclk { rockchip,pins = <0x00 0x08 0x01 0xaa>; }; i2s-sclk { rockchip,pins = <0x00 0x09 0x01 0xaa>; }; i2s-lrckrx { rockchip,pins = <0x00 0x0b 0x01 0xaa>; }; i2s-lrcktx { rockchip,pins = <0x00 0x0c 0x01 0xaa>; }; i2s-sdi { rockchip,pins = <0x00 0x0e 0x01 0xaa>; }; i2s-sdo0 { rockchip,pins = <0x00 0x0d 0x01 0xaa>; }; i2s-sdo1 { rockchip,pins = <0x01 0x02 0x02 0xaa>; }; i2s-sdo2 { rockchip,pins = <0x01 0x04 0x02 0xaa>; }; i2s-sdo3 { rockchip,pins = <0x01 0x05 0x02 0xaa>; }; i2s-sleep { rockchip,pins = <0x00 0x08 0x00 0xab 0x00 0x09 0x00 0xab 0x00 0x0b 0x00 0xab 0x00 0x0c 0x00 0xab 0x00 0x0e 0x00 0xab 0x00 0x0d 0x00 0xab 0x01 0x02 0x00 0xab 0x01 0x04 0x00 0xab 0x01 0x05 0x00 0xab>; }; }; pcm { pcm-rx { rockchip,pins = <0x00 0x1a 0x02 0xaa>; linux,phandle = <0x86>; phandle = <0x86>; }; pcm-tx { rockchip,pins = <0x00 0x1b 0x02 0xaa>; linux,phandle = <0x87>; phandle = <0x87>; }; pcm-clk { rockchip,pins = <0x03 0x0b 0x01 0xaa>; linux,phandle = <0x88>; phandle = <0x88>; }; pcm-sync { rockchip,pins = <0x03 0x0c 0x01 0xaa>; linux,phandle = <0x89>; phandle = <0x89>; }; pcm-sleep { rockchip,pins = <0x00 0x1a 0x00 0xab 0x00 0x1b 0x00 0xab 0x03 0x0b 0x00 0xab 0x03 0x0c 0x00 0xab>; linux,phandle = <0x8a>; phandle = <0x8a>; }; }; spdif0 { spdif0-tx { rockchip,pins = <0x03 0x1b 0x01 0xaa>; }; }; spdif1 { spdif1-tx { rockchip,pins = <0x03 0x1f 0x02 0xaa>; linux,phandle = <0x8c>; phandle = <0x8c>; }; }; sdmmc { sdmmc-clk { rockchip,pins = <0x01 0x10 0x01 0xad>; linux,phandle = <0x9b>; phandle = <0x9b>; }; sdmmc-cmd { rockchip,pins = <0x01 0x0f 0x01 0xae>; linux,phandle = <0x9c>; phandle = <0x9c>; }; sdmmc-dectn { rockchip,pins = <0x01 0x11 0x01 0xae>; linux,phandle = <0x9d>; phandle = <0x9d>; }; sdmmc-wrprt { rockchip,pins = <0x01 0x07 0x01 0xae>; }; sdmmc-pwren { rockchip,pins = <0x01 0x0e 0x01 0xae>; linux,phandle = <0x9f>; phandle = <0x9f>; }; sdmmc-bus1 { rockchip,pins = <0x01 0x12 0x01 0xae>; }; sdmmc-bus4 { rockchip,pins = <0x01 0x12 0x01 0xae 0x01 0x13 0x01 0xae 0x01 0x14 0x01 0xae 0x01 0x15 0x01 0xae>; linux,phandle = <0x9e>; phandle = <0x9e>; }; sdmmc-gpio { rockchip,pins = <0x01 0x10 0x00 0xae 0x01 0x0f 0x00 0xae 0x01 0x11 0x00 0xae 0x01 0x07 0x00 0xae 0x01 0x0e 0x00 0xae 0x01 0x12 0x00 0xae 0x01 0x13 0x00 0xae 0x01 0x14 0x00 0xae 0x01 0x15 0x00 0xae>; linux,phandle = <0xa0>; phandle = <0xa0>; }; }; sdio-0 { sdio-bus1 { rockchip,pins = <0x01 0x01 0x01 0xae>; }; sdio-bus4 { rockchip,pins = <0x01 0x01 0x01 0xae 0x01 0x02 0x01 0xae 0x01 0x04 0x01 0xae 0x01 0x05 0x01 0xae>; }; sdio-cmd { rockchip,pins = <0x00 0x03 0x02 0xae>; }; sdio-clk { rockchip,pins = <0x01 0x00 0x01 0xad>; }; sdio-pwren { rockchip,pins = <0x00 0x1e 0x01 0xac>; }; sdio-gpio { rockchip,pins = <0x00 0x03 0x00 0xae 0x01 0x00 0x00 0xae 0x00 0x1e 0x00 0xae 0x01 0x01 0x00 0xae 0x01 0x02 0x00 0xae 0x01 0x03 0x00 0xae 0x01 0x04 0x00 0xae>; }; }; sdio-1 { sdio1-bus1 { rockchip,pins = <0x03 0x02 0x01 0xae>; }; sdio1-bus4 { rockchip,pins = <0x03 0x02 0x01 0xae 0x03 0x03 0x01 0xae 0x03 0x04 0x01 0xae 0x03 0x05 0x01 0xae>; linux,phandle = <0xa3>; phandle = <0xa3>; }; sdio1-cmd { rockchip,pins = <0x03 0x01 0x01 0xae>; linux,phandle = <0xa1>; phandle = <0xa1>; }; sdio1-clk { rockchip,pins = <0x03 0x00 0x01 0xad>; linux,phandle = <0xa2>; phandle = <0xa2>; }; sdio1-gpio { rockchip,pins = <0x03 0x03 0x00 0xae 0x03 0x00 0x00 0xae 0x03 0x01 0x00 0xae 0x03 0x02 0x00 0xae 0x03 0x03 0x00 0xae 0x03 0x04 0x00 0xae>; linux,phandle = <0xa4>; phandle = <0xa4>; }; }; emmc-0 { emmc-clk { rockchip,pins = <0x02 0x07 0x02 0xaf>; }; emmc-cmd { rockchip,pins = <0x01 0x16 0x02 0xb0>; }; emmc-pwren { rockchip,pins = <0x02 0x05 0x02 0xaa>; }; emmc_rstnout { rockchip,pins = <0x01 0x17 0x02 0xaa>; }; emmc-bus1 { rockchip,pins = <0x01 0x18 0x02 0xb0>; }; emmc-bus4 { rockchip,pins = <0x01 0x18 0x02 0xb0 0x01 0x19 0x02 0xb0 0x01 0x1a 0x02 0xb0 0x01 0x1b 0x02 0xb0>; }; emmc-bus8 { rockchip,pins = <0x01 0x18 0x02 0xb0 0x01 0x19 0x02 0xb0 0x01 0x1a 0x02 0xb0 0x01 0x1b 0x02 0xb0 0x01 0x1c 0x02 0xb0 0x01 0x1d 0x02 0xb0 0x01 0x1e 0x02 0xb0 0x01 0x1f 0x02 0xb0>; }; }; emmc-1 { emmc1-clk { rockchip,pins = <0x02 0x07 0x02 0xaf>; }; emmc1-cmd { rockchip,pins = <0x02 0x04 0x02 0xb0>; }; emmc1-pwren { rockchip,pins = <0x02 0x05 0x02 0xaa>; }; emmc1_rstnout { rockchip,pins = <0x01 0x17 0x02 0xaa>; }; emmc1-bus1 { rockchip,pins = <0x01 0x18 0x02 0xb0>; }; emmc1-bus4 { rockchip,pins = <0x01 0x18 0x02 0xb0 0x01 0x19 0x02 0xb0 0x01 0x1a 0x02 0xb0 0x01 0x1b 0x02 0xb0>; }; emmc1-bus8 { rockchip,pins = <0x01 0x18 0x02 0xb0 0x01 0x19 0x02 0xb0 0x01 0x1a 0x02 0xb0 0x01 0x1b 0x02 0xb0 0x01 0x1c 0x02 0xb0 0x01 0x1d 0x02 0xb0 0x01 0x1e 0x02 0xb0 0x01 0x1f 0x02 0xb0>; }; }; pwm0-0 { pwm0-pin { rockchip,pins = <0x00 0x1a 0x01 0xaa>; }; }; pwm0-1 { pwm01-pin { rockchip,pins = <0x03 0x15 0x01 0xaa>; linux,phandle = <0x91>; phandle = <0x91>; }; }; pwm1-0 { pwm1-pin { rockchip,pins = <0x00 0x1b 0x01 0xaa>; }; }; pwm1-1 { pwm11-pin { rockchip,pins = <0x00 0x1e 0x02 0xaa>; linux,phandle = <0x92>; phandle = <0x92>; }; }; pwm2-0 { pwm2-pin { rockchip,pins = <0x00 0x1c 0x01 0xaa>; }; }; pwm2-1 { pwm21-pin { rockchip,pins = <0x01 0x0c 0x02 0xaa>; linux,phandle = <0x93>; phandle = <0x93>; }; }; pwmir-0 { pwmir-pin { rockchip,pins = <0x03 0x1a 0x01 0xaa>; }; }; pwmir-1 { pwmir1-pin { rockchip,pins = <0x01 0x0b 0x02 0xaa>; linux,phandle = <0x94>; phandle = <0x94>; }; }; gmac { rgmii-pins { rockchip,pins = <0x02 0x0e 0x01 0xaa 0x02 0x0c 0x01 0xaa 0x02 0x19 0x01 0xaa 0x02 0x13 0x01 0xb1 0x02 0x12 0x01 0xb1 0x02 0x16 0x01 0xb1 0x02 0x17 0x01 0xb1 0x02 0x09 0x01 0xb1 0x02 0x0d 0x01 0xb1 0x02 0x11 0x01 0xaa 0x02 0x10 0x01 0xaa 0x02 0x15 0x02 0xaa 0x02 0x14 0x02 0xaa 0x02 0x0b 0x01 0xaa 0x02 0x08 0x01 0xaa>; }; rmii-pins { rockchip,pins = <0x02 0x0e 0x01 0xaa 0x02 0x0c 0x01 0xaa 0x02 0x19 0x01 0xaa 0x02 0x13 0x01 0xb1 0x02 0x12 0x01 0xb1 0x02 0x0d 0x01 0xb1 0x02 0x11 0x01 0xaa 0x02 0x10 0x01 0xaa 0x02 0x08 0x01 0xaa 0x02 0x0f 0x01 0xaa>; }; phy-pins { rockchip,pins = <0x02 0x0e 0x02 0xaa 0x02 0x08 0x02 0xaa>; linux,phandle = <0xa9>; phandle = <0xa9>; }; }; tsadc_pin { tsadc-int { rockchip,pins = <0x00 0x18 0x02 0xaa>; }; tsadc-gpio { rockchip,pins = <0x00 0x18 0x00 0xaa>; linux,phandle = <0x8f>; phandle = <0x8f>; }; }; hdmi_pin { hdmi-cec { rockchip,pins = <0x00 0x14 0x01 0xaa>; linux,phandle = <0x98>; phandle = <0x98>; }; hdmi-hpd { rockchip,pins = <0x00 0x0f 0x01 0xb2>; linux,phandle = <0x9a>; phandle = <0x9a>; }; }; hdmi_i2c { hdmii2c-xfer { rockchip,pins = <0x00 0x06 0x02 0xaa 0x00 0x07 0x02 0xaa>; linux,phandle = <0x99>; phandle = <0x99>; }; }; }; power_ctr { }; display-timings { native-mode = <0xb3>; linux,phandle = <0x90>; phandle = <0x90>; timing0 { screen-type = <0x01>; out-face = <0x00>; color-mode = <0x02>; clock-frequency = <0x46cf710>; hactive = <0x780>; vactive = <0x438>; hback-porch = <0xdc>; hfront-porch = <0x6e>; vback-porch = <0x14>; vfront-porch = <0x05>; hsync-len = <0x28>; vsync-len = <0x05>; hsync-active = <0x01>; vsync-active = <0x01>; de-active = <0x00>; pixelclk-active = <0x00>; swap-rb = <0x00>; swap-rg = <0x00>; swap-gb = <0x00>; linux,phandle = <0xb3>; phandle = <0xb3>; }; timing1 { screen-type = <0x01>; out-face = <0x00>; color-mode = <0x02>; clock-frequency = <0x8d9ee20>; hactive = <0x780>; vactive = <0x438>; hback-porch = <0x94>; hfront-porch = <0x58>; vback-porch = <0x24>; vfront-porch = <0x04>; hsync-len = <0x2c>; vsync-len = <0x05>; hsync-active = <0x01>; vsync-active = <0x01>; de-active = <0x00>; pixelclk-active = <0x00>; swap-rb = <0x00>; swap-rg = <0x00>; swap-gb = <0x00>; }; timing2 { screen-type = <0x01>; out-face = <0x00>; color-mode = <0x02>; clock-frequency = <0x11b3dc40>; hactive = <0xf00>; vactive = <0x870>; hback-porch = <0x128>; hfront-porch = <0xb0>; vback-porch = <0x48>; vfront-porch = <0x08>; hsync-len = <0x58>; vsync-len = <0x0a>; hsync-active = <0x01>; vsync-active = <0x01>; de-active = <0x00>; pixelclk-active = <0x00>; swap-rb = <0x00>; swap-rg = <0x00>; swap-gb = <0x00>; }; timing3 { screen-type = <0x05>; out-face = <0x00>; color-mode = <0x02>; clock-frequency = <0x19bfcc0>; hactive = <0x2d0>; vactive = <0x1e0>; hback-porch = <0x2b>; hfront-porch = <0x21>; vback-porch = <0x13>; vfront-porch = <0x00>; hsync-len = <0x3e>; vsync-len = <0x03>; hsync-active = <0x01>; vsync-active = <0x01>; de-active = <0x00>; pixelclk-active = <0x01>; swap-rb = <0x00>; swap-rg = <0x00>; swap-gb = <0x00>; interlaced; }; timing4 { screen-type = <0x05>; out-face = <0x00>; color-mode = <0x02>; clock-frequency = <0x19bfcc0>; hactive = <0x2d0>; vactive = <0x240>; hback-porch = <0x30>; hfront-porch = <0x21>; vback-porch = <0x13>; vfront-porch = <0x02>; hsync-len = <0x3f>; vsync-len = <0x03>; hsync-active = <0x01>; vsync-active = <0x01>; de-active = <0x00>; pixelclk-active = <0x01>; swap-rb = <0x00>; swap-rg = <0x00>; swap-gb = <0x00>; interlaced; }; }; wireless-wlan { compatible = "wlan-platdata"; wifi_chip_type = "rtl8189es"; sdio_vref = <0x708>; WIFI,poweren_gpio = <0x7c 0x1a 0x00>; WIFI,host_wake_irq = <0x75 0x1c 0x00>; status = "okay"; }; wireless-bluetooth { compatible = "bluetooth-platdata"; uart_rts_gpios = <0x95 0x06 0x01>; pinctrl-names = "default\0rts_gpio"; pinctrl-0 = <0xb4>; pinctrl-1 = <0xb5>; BT,power_gpio = <0x7c 0x1d 0x00>; BT,wake_gpio = <0x95 0x1b 0x00>; BT,wake_host_irq = <0x95 0x1a 0x00>; status = "disabled"; }; regulators { compatible = "simple-bus"; #address-cells = <0x01>; #size-cells = <0x00>; regulator@0 { compatible = "regulator-fixed"; regulator-name = "vccio_1v8"; regulator-min-microvolt = <0x1b7740>; regulator-max-microvolt = <0x1b7740>; regulator-always-on; linux,phandle = <0x5d>; phandle = <0x5d>; }; regulator@1 { compatible = "regulator-fixed"; regulator-name = "vccio_3v3"; regulator-min-microvolt = <0x325aa0>; regulator-max-microvolt = <0x325aa0>; regulator-always-on; linux,phandle = <0x5c>; phandle = <0x5c>; }; }; pwm-regulator1 { compatible = "rockchip_pwm_regulator"; pwms = <0xb6 0x00 0x1388>; rockchip,pwm_id = <0x01>; rockchip,pwm_voltage_map = <0xe7ef0 0xee098 0xf4240 0xfa3e8 0x100590 0x106738 0x10c8e0 0x112a88 0x118c30 0x11edd8 0x124f80 0x12b128 0x1312d0 0x137478 0x13d620 0x1437c8 0x149970 0x14fb18 0x155cc0>; rockchip,pwm_voltage = <0x10c8e0>; rockchip,pwm_min_voltage = <0xe7ef0>; rockchip,pwm_max_voltage = <0x155cc0>; rockchip,pwm_suspend_voltage = <0xe7ef0>; rockchip,pwm_coefficient = <0x1c2>; status = "okay"; regulators { #address-cells = <0x01>; #size-cells = <0x00>; regulator@0 { regulator-compatible = "pwm_dcdc1"; regulator-name = "vdd_arm"; regulator-min-microvolt = <0xe7ef0>; regulator-max-microvolt = <0x155cc0>; regulator-always-on; regulator-boot-on; }; }; }; pwm-regulator2 { compatible = "rockchip_pwm_regulator"; pwms = <0xb7 0x00 0x1388>; rockchip,pwm_id = <0x02>; rockchip,pwm_voltage_map = <0xf4240 0xfa3e8 0x100590 0x106738 0x10c8e0 0x112a88 0x118c30 0x11edd8 0x124f80 0x12b128 0x1312d0 0x137478 0x13d620>; rockchip,pwm_voltage = <0x124f80>; rockchip,pwm_min_voltage = <0xf4240>; rockchip,pwm_max_voltage = <0x13d620>; rockchip,pwm_suspend_voltage = <0x1312d0>; rockchip,pwm_coefficient = <0x12c>; status = "okay"; regulators { #address-cells = <0x01>; #size-cells = <0x00>; regulator@1 { regulator-compatible = "pwm_dcdc2"; regulator-name = "vdd_logic"; regulator-min-microvolt = <0xf4240>; regulator-max-microvolt = <0x13d620>; regulator-always-on; regulator-boot-on; }; }; }; usb_control { compatible = "rockchip,rk322x-usb-control"; rockchip,remote_wakeup; rockchip,usb_irq_wakeup; host_drv_gpio = <0x95 0x14 0x01>; otg_drv_gpio = <0x95 0x16 0x01>; }; rockchip_audio { compatible = "rockchip,rk322x-audio"; dais { dai0 { audio-codec = <0xb8>; audio-controller = <0xb9>; format = "i2s"; }; }; }; rockchip_spdif_card { compatible = "rockchip-spdif-card"; dais { dai0 { audio-codec = <0xba>; audio-controller = <0xbb>; }; }; }; rockchip_hdmi_i2s { compatible = "rockchip-hdmi-i2s"; dais { dai0 { audio-codec = <0xbc>; audio-controller = <0xbd>; format = "i2s"; }; }; }; rockchip_nau8540 { status = "disabled"; compatible = "rockchip,nau8540-audio"; dais { dai0 { audio-codec = <0xbe>; audio-controller = <0xb9>; format = "i2s"; }; }; }; power-led { compatible = "gpio-leds"; green { gpios = <0x95 0x15 0x00>; default-state = "on"; }; red { gpios = <0x75 0x08 0x00>; default-state = "off"; }; }; }; But before taking the dtb route, I would like to fully reprogram this board from scratch, as I am sure that I did some mistakes somewhere. especially: GPT 0x63337df8 signature is wrong recovery gpt... GPT 0x63337df8 signature is wrong recovery gpt fail! At the beginning of the boot seems very bad! I am new to those boards, knowing nothing from them 2 weeks ago, and the information is scattered in lots of places (is there a WIKI somewhere, as it is BADLY needed?), so this is what I understood: The RK322X chips are done by Rockchip which assembles IP blocs licenced by ARM to make a SoC. ARM and the communauty provides compilers, linkers and the like. The box is intended by Rockchip to run under Android, and Rockchip tools are heavily biaised toward this environnement, with a lot of specific tools, and an old kernel (3.x and maybe 4.x). Armbian is a Debian distribution, adapted to run on Arm chips, which makes for a very diverse ecosystem, and follows the Linux track (new kernels, etc). Both environments do the same job, but there are many places where armbian and rk/android tools are not compatible. The box has a (set of) processors, RAM and flash plus various peripherals, some of them being integrated in the SoC. The flash can be Nand, or eMMC (which is nand plus a controller taking care of many details, including bad blocks and wear levelling). As seen from the software, flash is a linear vector of blocks (of typically 512K each) which can be R/W with only this granularity. All of them have a (usually hidden) serial line, that runs @ 115200 bauds, and gives lots of system information. Putting Linux on this box consists in reprogramming fully the flash, and this is done using an *image* (extension ".img"). It can be flashed using RK tools (rkdeveloptool for linux) directly on the chip through USB, or by crafting an sdCard which will do the job. The RK322X has 2 reset modes: Loader mode which allows only access to flash above 0x2000*0x200 maskrom mode which allows for full access. The chip enters maskrom mode when it cannot read flash; that can be accomplished in a wild way by shorting pins 8 and 9 of the eMMC chip at boot (which is why RK322X chips are nearly unbrickable) The boot sequence is complex: Execution starts first with a miniloader (? at a certain offset in flash?) whose job is to load a 2nd level loader (?located at another offset in flash?) called u-boot. U-boot is based on Das U-Boot modified by many people. All of them are more or less compatible, with subtle differences. They have one thing in common, which is that a ^C on the serial line stops the boot and gives a CLI. The Job of uboot is to load the Linux kernel in memory, and start it using a command line with various parameters. One important parameter is the DTB, which indicates to the kernel (drivers) the hardware details. This is a binary blob (.dtb) compiled from various source modules (.dts). The armbian and android dtb are similar but not compatible. They can be decompiled by (mostly uncompatible) compilers (dtc in linux). Another important parameter is the offset in flash of various filesystems. Then he kernel starts... An image is the concatenation of various blobs according to a certain format. Armbian and RK images are NOT compatible, as they don't have the same numbers and type of blobs, and so require different sets of tools (?which ones?) Is the 1st-level loader (?located at offset 0 in flash?) part of the armbian image So, in order in order to *fully* reflash my box: Manage to enter maskrom rkdeveloptool db rk322x_loader.bin rkdeveloptool ul rk322x_loader.bin rkdeveloptool wl 0 multitool.img Am I right or should I have missed something? Michel 1 Link to post Share on other sites More sharing options...
fabiobassa 100 Posted March 22, 2021 Share Posted March 22, 2021 @gurzixo hello Michel , yes to ALL your questions except for Quote maskrom mode which allows for full access this is true for emmc. For nand since them charateristic the discussion is little little different, but let's assume is quite the same for our purpose: It is good idea and safe approach DON'T TOUCH idbloader , the very very very first stage of loading something in ram and go modify starting from address 2000 Will follow a different approach for your board so please be patient some hours so i can give you more details EDIT : Quote or by crafting an sdCard which will do the job this also is half half correct: the sd card will do the job if there is a uboot and a trust ALSO in sd card at right places . It will happena " jump" from the internal uboot to sd uboot and then continue bootng from sd. But don't worry we wil go back from scratch 1 Link to post Share on other sites More sharing options...
gurzixo 5 Posted March 22, 2021 Share Posted March 22, 2021 I have a couple of questions: - Is this storage map the one used by android, multitool, legacy and up-to-date armbian, or are they each using different maps? - I found very few information about the GPT partition table, what to put inside and how to build the parameter_gpt.txt file used by rkdeveloptool. Are there some pointers available? I have also a strange thing: I am able to enter loader mode by wiping emmc, and everything works well (ie. test chip, read id, etc.). But when I enter maskrom mode, I have the correct PID/VID on USB, but all rkdevelop commands block (ie I have to press ^C to come back to shell). This is the case either when I reboot by software (rkdevelop rd 3) or by hardware (ie. short emmc pins) And when I reload multitool in emmc, it still gives kernel panic. strange... 1 Link to post Share on other sites More sharing options...
