jock 211 Posted April 24 Author Share Posted April 24 1 hour ago, Hoangtnt Nguyen said: log show 9 apr 2020, but i dont have rom that at 9 apr, perhap it show that because i get it from multitool bash shell, i alway boot with multitool and install with first page instructions. i flashed many box with rk322x but that box is new version with emcp not with emmc and ram separate, and failed :(. after flash and shutdown it cant boot and only go to Mask Rom mode flash one rom with rk322x ( I use H96 Mini H8 rom ) , it can boot and i use Multitool to restore orginal ROM. Perhap i must use libreelec temporary with that box version. thx Ah ok, now I understand that the four logs you posted before are all produced by the Multitool...! I never encountered any box with eMCP. Looking at the Multitool log, both eMMC and DRAM parts of eMCP are detected and everything is working as usual. It is possible that the problem involves u-boot somehow, so the serial log would be really useful to understand what is really going on. As long as you can flash the image using the regular instructions means that the kernel is able to use the eMCP the same way it does with eMMC with no differences, and the fact that LibreELEC works proves this also. If you could share the serial log, the original firmware (or the device tree binary/source), and some photos of board and chips I can try to guess what is going on. Link to post Share on other sites More sharing options...
jock 211 Posted April 24 Author Share Posted April 24 2 hours ago, nickbox said: your bootloader is ok,i have two same boxes,the other is bricked before i get it,i try rk factory tools,it failed also,the RK factory tools manual said this situation maybe emmc is broken. unless i replace emmc,but it is difficult. thk for your reply I don't think that the eMMC is broken, I have a bad feeling that something is still wrong with memory initialization. Only the serial debug log can tell us what is really going on. As usual, original dtb, photos and serial log are useful. Link to post Share on other sites More sharing options...
Hoangtnt Nguyen 0 Posted April 25 Share Posted April 25 16 hours ago, jock said: Ah ok, now I understand that the four logs you posted before are all produced by the Multitool...! I never encountered any box with eMCP. Looking at the Multitool log, both eMMC and DRAM parts of eMCP are detected and everything is working as usual. It is possible that the problem involves u-boot somehow, so the serial log would be really useful to understand what is really going on. As long as you can flash the image using the regular instructions means that the kernel is able to use the eMCP the same way it does with eMMC with no differences, and the fact that LibreELEC works proves this also. If you could share the serial log, the original firmware (or the device tree binary/source), and some photos of board and chips I can try to guess what is going on. I used that rom to restore with MASK Rom mode: https://drive.google.com/drive/folders/1mxqba_lReweZw9IQCfI_LceVfj2nUYj7 Serial log when use original Rom: DDR Version V1.09 20190628 In ID:0xFFF 300MHz LPDDR3 Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB mach:2 OUT Boot1 Release Time: May 4 2018 15:21:31, version: 2.49 ChipType = 0xc, 342 mmc2:cmd19,256 SdmmcInit=2 0 BootCapSize=2000 UserCapSize=7376MB FwPartOffset=2000 , 2000 SdmmcInit=0 NOT PRESENT StorageInit ok = 36740 SecureMode = 0 GPT 00@0x00012000(kernel),0x0000a000@0x00018000(boot),0x00010000@0x00022000(recovery),0x00020000@0x00032000(backup),0x00040000@0x00052000(cache),0x00008000@0x00092000(metadata),0x00002000@0x0009a000(kpanic),0x00400000@0x0009c000(system),-@0x0049c000(userdata) ?I▒▒ signature is wrong LOADER Check OK! 0x60000000, 55134 TOS Check OK! 0x68400000, 65932 Enter Trust OS INF TEE-CORE:init_primary_helper:319: Initializing (1.0.1-72-gf230aa2 #2 Fri Sep 29 10:22:10 UTC 2017 arm) INF TEE-CORE:init_primary_helper:320: Release version: 2.0 INF TEE-CORE:init_teecore:79: teecore inits done <hit enter to activate fiq debugger> [ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.104 (lsh@ubuntu1) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #21 SMP PREEMPT Wed Mar 24 17:08:09 CST 2021 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3229, model: rockchip,rk3229 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x9dc00000, offset:0x01000000 [ 0.000000] hdmi init vic is 16 [ 0.000000] cvbs init tve.format is -1 [ 0.000000] cvbs init tve.format is -1 [ 0.000000] cvbs init tve.format is -1 [ 0.000000] cvbs init tve.format is 0 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x9dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(0) align(0) [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 16 MiB at 7f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] psci: probing function IDs from device-tree [ 0.000000] PERCPU: Embedded 9 pages/cpu @c16ca000 s13440 r8192 d15232 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260864 [ 0.000000] Kernel command line: vmalloc=496M psci=enable rockchip_jtag console=ttyFIQ0 androidboot.selinux=disabled androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00004000@0x00004000(trust),0x00002000@0x00008000(misc),0x00000800@0x0000A000(baseparamer),0x00007800@0x0000A800(resource),0x00006000@0x00012000(kernel),0x0000a000@0x00018000(boot),0x00010000@0x00022000(recovery),0x00020000@0x00032000(backup),0x00040000@0x00052000(cache),0x00008000@0x00092000(metadata),0x00002000@0x0009a000(kpanic),0x00400000@0x0009c000(system),-@0x0049c000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x9dc00000:0x01000000 loader.timestamp=2021-03-24_17:08:36 hdmi.vic=16 tve.format=-1 SecureBootCheckOk=0 [ 0.000000] rockchip jtag enabled [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 132MB 891MB = 1023MB total [ 0.000000] Memory: 970908k/970908k available, 76644k reserved, 491516K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0c208ec (12387 kB) [ 0.000000] .init : 0xc0c21000 - 0xc0c81480 ( 386 kB) [ 0.000000] .data : 0xc0c82000 - 0xc0d69120 ( 925 kB) [ 0.000000] .bss : 0xc0d69120 - 0xc0e8eea4 (1176 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 13 [ 0.000000] rkclk_init_clks: cnt_rate = 19 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:5 [ 0.000000] target-temp:95 [ 0.000000] channel:2, lkg:4 [ 0.000000] target-temp:0 [ 0.000000] channel:2, lkg:4 [ 0.000000] target-temp:95 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 2.259200] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 2.259227] pid_max: default: 32768 minimum: 301 [ 2.259460] Security Framework initialized [ 2.259494] SELinux: Initializing. [ 2.259627] Mount-cache hash table entries: 512 [ 2.260786] Initializing cgroup subsys debug [ 2.260817] Initializing cgroup subsys memory [ 2.260866] Initializing cgroup subsys freezer [ 2.260933] CPU: Testing write buffer coherency: ok [ 2.261508] /cpus/cpu@0 missing clock-frequency property [ 2.261537] /cpus/cpu@1 missing clock-frequency property [ 2.261555] /cpus/cpu@2 missing clock-frequency property [ 2.261573] /cpus/cpu@3 missing clock-frequency property [ 2.261691] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 2.261741] Setting up static identity map for 0xc086f670 - 0xc086f6c8 [ 2.264036] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1838 (version 3.1) [ 2.337272] CPU1: Booted secondary processor [ 2.337340] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 2.356968] CPU2: Booted secondary processor [ 2.357015] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 2.376693] CPU3: Booted secondary processor [ 2.376738] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 2.376917] Brought up 4 CPUs [ 2.376966] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 2.376980] CPU: All CPU(s) started in SVC mode. [ 2.378495] devtmpfs: initialized [ 2.386447] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 2.388329] pinctrl core: initialized pinctrl subsystem [ 2.388869] regulator-dummy: no parameters [ 2.409172] NET: Registered protocol family 16 [ 2.412368] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 2.413214] ion_snapshot: 0x7ea60000 map to 0xe0907000 and copy to 0xc0e624b4 (version 0.1) [ 2.413459] Registered FIQ tty driver [ 2.415837] console [ttyFIQ0] enabled [ 2.416398] Registered fiq debugger ttyFIQ0 [ 2.418686] syscon 10140000.syscon: regmap [mem 0x10140000-0x10140fff] registered [ 2.419024] syscon 11000000.syscon: regmap [mem 0x11000000-0x11000fff] registered [ 2.419362] syscon 110e0000.syscon: regmap [mem 0x110e0000-0x110e0fff] registered [ 2.419676] syscon 11200000.syscon: regmap [mem 0x11200000-0x112003ff] registered [ 2.419984] syscon 31020000.syscon: regmap [mem 0x31020000-0x31022fff] registered [ 2.425861] rk_iommu 20053f00.vop_mmu: (vop) Enter [ 2.426025] rk_iommu 20053f00.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.426052] rk_iommu 20053f00.vop_mmu: (vop) Initialized [ 2.426330] rk_iommu 20020800.vpu_mmu: (vpu) Enter [ 2.426451] rk_iommu 20020800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.426475] rk_iommu 20020800.vpu_mmu: (vpu) Initialized [ 2.426730] rk_iommu 20070800.iep_mmu: (iep) Enter [ 2.426849] rk_iommu 20070800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.426874] rk_iommu 20070800.iep_mmu: (iep) Initialized [ 2.427146] rk_iommu 20030480.vdec_mmu: (vdec) Enter [ 2.427265] rk_iommu 20030480.vdec_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 2.427292] rk_iommu 20030480.vdec_mmu: (vdec) Initialized [ 2.437229] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 2.437263] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 2.437307] rockchip sip version v1 [ 2.438020] rk3368_init_rohing to clocksource arch_sys_counter [ 2.538146] rga: Module initialized. [ 2.539045] rga2 20060000.rga: rga ion client create success! [ 2.539433] rga: Driver loaded succesfully [ 2.539794] fb disp policy is box [ 2.539837] uboot-logo-on:1 [ 2.539907] rk-fb rockchip-fb: rk fb ion client create success! [ 2.539931] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 2.540526] can't find screen_init node [ 2.540556] rk-screen rk_screen.15: rockchip screen probe success [ 2.542577] rk322x-lcdc 20050000.vop: vop_dev->regs=0xe0930000 [ 2.542729] rk322x-lcdc vop0: can't find power_ctr node for lcdc0 [ 2.543250] graphics fb0: rockchip framebuffer registerd:fb0 [ 2.544020] graphics fb1: rockchip framebuffer registerd:fb1 [ 2.544427] graphics fb2: rockchip framebuffer registerd:fb2 [ 2.545556] rk322x-lcdc vop0: lcdc0: dclk:148500000>>fps:60 [ 2.562525] alloc_buffer:ion_phy_addr=0x10000000 [ 2.569380] fb0:phy:10000000>>vir:e0937000>>len:0xb00000 [ 2.619926] rk_iommu 20053f00.vop_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x7e9db000 [ 2.620004] rk322x-lcdc vop0: lcdc0 probe ok, iommu enabled [ 2.623727] NET: Registered protocol family 2 [ 2.625098] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 2.625249] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 2.625349] TCP: Hash tables configured (established 4096 bind 4096) [ 2.625456] TCP: reno registered [ 2.625481] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 2.625523] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 2.625879] NET: Registered protocol family 1 [ 2.626484] RPC: Registered named UNIX socket transport module. [ 2.626515] RPC: Registered udp transport module. [ 2.626532] RPC: Registered tcp transport module. [ 2.626549] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.627966] Unpacking initramfs... [ 2.763006] Freeing initrd memory: 1436K (c5bf0000 - c5d57000) [ 2.764612] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available [ 2.769404] audit: initializing netlink socket (disabled) [ 2.769575] type=2000 audit(0.510:1): initialized [ 2.771093] bounce pool size: 64 pages [ 2.780487] NFS: Registering the id_resolver key type [ 2.780630] Key type id_resolver registered [ 2.780652] Key type id_legacy registered [ 2.781506] fuse init (API version 7.22) [ 2.782384] msgmni has been set to 971 [ 2.782986] [ 2.782986] TEE Core Framework initialization (ver 1:0.1) [ 2.783071] TEE armv7 Driver initialization [ 2.783691] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 2.783724] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 2.784131] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=58) [ 2.787238] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248) [ 2.787286] io scheduler noop registered [ 2.787308] io scheduler deadline registered [ 2.787545] io scheduler cfq registered (default) [ 2.790351] HDMI: no pull up gpio [ 2.791615] input: hdmi_cec_key as /devices/virtual/input/input0 [ 2.792111] rockchip-hdmiv2 200a0000.hdmi: rockchip hdmiv2 probe success. [ 2.792926] iep: failed to find iep power down clock source. [ 2.793605] iep ion client create success! [ 2.793633] IEP Power ON [ 2.794119] rk_iommu 20070800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x7ea50000 [ 2.794165] IEP Power OFF [ 2.794198] IEP Driver loaded succesfully [ 2.794407] Module initialized. [ 2.795460] rk3036-tve 20053e00.tve: Can not read det_io [ 2.795639] rk3036-tve 20053e00.tve: rockchip,rk322x-tve tv encoder probe ok [ 2.798925] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-2364208 [ 2.798982] dma-pl330 110f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 2.799670] vdd_arm: 950 <--> 1400 mV at 1100 mV [ 2.800273] vdd_logic: 1000 <--> 1300 mV at 1200 mV [ 2.800976] rk_serial.c v2.0 2017-06-30 [ 2.801623] 11020000.serial: ttyS1 at MMIO 0x11020000 (irq = 88) is a rk29_serial.1 [ 2.802141] serial 11020000.serial: membase e244e000 [ 2.802516] ++++++++cyx_led_init [ 2.802776] <melvin> drivers/char/cyx_led/cyx_led.c(38) cyx_led_probe: ..........>>>>>>>> [ 2.802958] id0: 1 id1: 1 id2: 0 [ 2.809279] loop: module loaded [ 2.810065] zram: Created 1 device(s) [ 2.810307] i2c-core: driver [mpu6050B1] using legacy suspend method [ 2.810328] i2c-core: driver [mpu6050B1] using legacy resume method [ 2.810349] mpu_init: Probe name mpu6050B1 [ 2.810654] ak8963_mod_init: Probe name ak8963_mod [ 2.812297] SCSI Media Changer driver v0.25 [ 2.813086] tun: Universal TUN/TAP device driver, 1.6 [ 2.813122] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 2.813434] vmac_init. [ 2.814513] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 2.814544] stmmac_probe_config_dt: clock input/output? (output). [ 2.814565] stmmac_probe_config_dt: TX delay(0x26). [ 2.814583] stmmac_probe_config_dt: RX delay(0x11). [ 2.814601] stmmac_probe_config_dt: internal PHY/external PHY? (internal). [ 2.814789] stmmc_pltfr_init: [ 2.814831] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 2.814850] stmmc_pltfr_init: ERROR: Get reset-gpio failed. [ 2.814911] stmmc_pltfr_init: init for RMII [ 2.815250] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 2.815272] Normal descriptors [ 2.815286] Ring mode enabled [ 2.815303] DMA HW capability register supported [ 2.815321] RX Checksum Offload Engine supported (type 2) [ 2.815338] TX Checksum insertion supported [ 2.815352] Wake-Up On Lan supported [ 2.815438] Enable RX Mitigation via HW Watchdog Timer [ 2.816168] ------------[ cut here ]------------ [ 2.816212] WARNING: at drivers/base/core.c:561 device_create_file+0x68/0x84() [ 2.816231] Attribute eth_reset: read permission without 'show' [ 2.816248] Modules linked in: [ 2.816275] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.104 #21 [ 2.816328] [<c0014088>] (unwind_backtrace+0x0/0xe0) from [<c00118cc>] (show_stack+0x10/0x14) [ 2.816366] [<c00118cc>] (show_stack+0x10/0x14) from [<c003f484>] (warn_slowpath_common+0x4c/0x68) [ 2.816403] [<c003f484>] (warn_slowpath_common+0x4c/0x68) from [<c003f520>] (warn_slowpath_fmt+0x2c/0x3c) [ 2.816438] [<c003f520>] (warn_slowpath_fmt+0x2c/0x3c) from [<c038bea0>] (device_create_file+0x68/0x84) [ 2.816477] [<c038bea0>] (device_create_file+0x68/0x84) from [<c03e6c54>] (stmmac_dvr_probe+0x290/0x318) [ 2.816512] [<c03e6c54>] (stmmac_dvr_probe+0x290/0x318) from [<c03eca24>] (stmmac_pltfr_probe+0xf0/0x1d4) [ 2.816549] [<c03eca24>] (stmmac_pltfr_probe+0xf0/0x1d4) from [<c038ff60>] (platform_drv_probe+0x14/0x18) [ 2.816586] [<c038ff60>] (platform_drv_probe+0x14/0x18) from [<c038ed94>] (really_probe+0xa8/0x20c) [ 2.816621] [<c038ed94>] (really_probe+0xa8/0x20c) from [<c038eff0>] (driver_probe_device+0x30/0x48) [ 2.816654] [<c038eff0>] (driver_probe_device+0x30/0x48) from [<c038f068>] (__driver_attach+0x60/0x84) [ 2.816687] [<c038f068>] (__driver_attach+0x60/0x84) from [<c038d830>] (bus_for_each_dev+0x50/0x90) [ 2.816719] [<c038d830>] (bus_for_each_dev+0x50/0x90) from [<c038e5e4>] (bus_add_driver+0xac/0x20c) [ 2.816752] [<c038e5e4>] (bus_add_driver+0xac/0x20c) from [<c038f54c>] (driver_register+0x9c/0xe0) [ 2.816788] [<c038f54c>] (driver_register+0x9c/0xe0) from [<c0c4c374>] (stmmac_init+0xc/0x38) [ 2.816822] [<c0c4c374>] (stmmac_init+0xc/0x38) from [<c00086a4>] (do_one_initcall+0x34/0xc8) [ 2.816855] [<c00086a4>] (do_one_initcall+0x34/0xc8) from [<c0c21b30>] (do_initcalls+0x70/0xa0) [ 2.816889] [<c0c21b30>] (do_initcalls+0x70/0xa0) from [<c0c21c4c>] (kernel_init_freeable+0xec/0x190) [ 2.816924] [<c0c21c4c>] (kernel_init_freeable+0xec/0x190) from [<c0849d58>] (kernel_init+0x8/0xe4) [ 2.816960] [<c0849d58>] (kernel_init+0x8/0xe4) from [<c000dba0>] (ret_from_fork+0x14/0x34) [ 2.817034] ---[ end trace 447f800f34f48500 ]--- [ 2.817230] PPP generic driver version 2.4.2 [ 2.817631] PPP BSD Compression module registered [ 2.817658] PPP Deflate Compression module registered [ 2.817704] PPP MPPE Compression module registered [ 2.817725] NET: Registered protocol family 24 [ 2.817795] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 2.817816] CSLIP: code copyright 1989 Regents of the University of California. [ 2.817835] Rockchip WiFi SYS interface (V1.00) ... [ 2.817904] esp_mem_init enter date Mar 15 2021 14:48:09 [ 2.817924] esp_mem_init VERSION [V2.5] [ 2.818021] esp_mem_init complete [ 2.818164] usbcore: registered new interface driver catc [ 2.818317] usbcore: registered new interface driver kaweth [ 2.818341] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 2.818429] usbcore: registered new interface driver pegasus [ 2.818506] usbcore: registered new interface driver rtl8150 [ 2.818579] usbcore: registered new interface driver r8152 [ 2.818597] hso: drivers/net/usb/hso.c: Option Wireless [ 2.818736] usbcore: registered new interface driver hso [ 2.818825] usbcore: registered new interface driver asix [ 2.818914] usbcore: registered new interface driver ax88179_178a [ 2.818993] usbcore: registered new interface driver cdc_ether [ 2.819069] usbcore: registered new interface driver cdc_eem [ 2.819143] usbcore: registered new interface driver dm9601 [ 2.819226] usbcore: registered new interface driver dm9620 [ 2.819320] usbcore: registered new interface driver smsc75xx [ 2.819427] usbcore: registered new interface driver smsc95xx [ 2.819502] usbcore: registered new interface driver gl620a [ 2.819578] usbcore: registered new interface driver net1080 [ 2.819653] usbcore: registered new interfde is 3 [ 2.874432] hdmi connect to lcdc0 [ 2.874450] switch:en=1,lcdc_id=0,screen type=6,cur type=1 [ 2.874468] data space: 0, color mode: 3 [ 2.874538] rk322x-lcdc vop0: lcdc0: dclk:148500000>>fps:60 [ 2.874600] pixel clk is 148500000 tmds clk is 148500000 [ 2.874635] hub 3-0:1.0: USB hub found [ 2.874656] rockchip-hdmiv2 200a0000.hdmi: [hdmi_dev_config_video] success output HDMI. [ 2.874699] hub 3-0:1.0: 1 port detected [ 2.875550] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.875841] ohci-platform: OHCI generic platform driver [ 2.876080] ohci-platform 300a0000.ohci0: Generic Platform OHCI controller [ 2.876136] ohci-platform 300a0000.ohci0: new USB bus registered, assigned bus number 4 [ 2.876229] ohci-platform 300a0000.ohci0: irq 49, io mem 0x300a0000 [ 2.936596] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.936645] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.936671] usb usb4: Product: Generic Platform OHCI controller [ 2.936693] usb usb4: Manufacturer: Linux 3.10.104 ohci_hcd [ 2.936714] usb usb4: SerialNumber: 300a0000.ohci0 [ 2.937605] hub 4-0:1.0: USB hub found [ 2.937654] hub 4-0:1.0: 1 port detected [ 2.938126] ohci-platform 300e0000.ohci1: Generic Platform OHCI controller [ 2.938177] ohci-platform 300e0000.ohci1: new USB bus registered, assigned bus number 5 [ 2.938262] ohci-platform 300e0000.ohci1: irq 52, io mem 0x300e0000 [ 2.995643] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.995691] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.995717] usb usb5: Product: Generic Platform OHCI controller [ 2.995738] usb usb5: Manufacturer: Linux 3.10.104 ohci_hcd [ 2.995759] usb usb5: SerialNumber: 300e0000.ohci1 [ 2.996617] hub 5-0:1.0: USB hub found [ 2.996663] hub 5-0:1.0: 1 port detected [ 2.997127] ohci-platform 30120000.ohci2: Generic Platform OHCI controller [ 2.997190] ohci-platform 30120000.ohci2: new USB bus registered, assigned bus number 6 [ 2.997282] ohci-platform 30120000.ohci2: irq 99, io mem 0x30120000 [ 3.054660] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.054706] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.054730] usb usb6: Product: Generic Platform OHCI controller [ 3.054752] usb usb6: Manufacturer: Linux 3.10.104 ohci_hcd [ 3.054774] usb usb6: SerialNumber: 30120000.ohci2 [ 3.055613] hub 6-0:1.0: USB hub found [ 3.055671] hub 6-0:1.0: 1 port detected [ 3.056312] usbcore: registered new interface driver cdc_acm [ 3.056335] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.056455] usbcore: registered new interface driver usblp [ 3.056553] usbcore: registered new interface driver cdc_wdm [ 3.056755] usbcore: registered new interface driver usb-storage [ 3.056840] usbcore: registered new interface driver ums-alauda [ 3.056919] usbcore: registered new interface driver ums-cypress [ 3.057014] usbcore: registered new interface driver ums-datafab [ 3.057095] usbcore: registered new interface driver ums_eneub6250 [ 3.057173] usbcore: registered new interface driver ums-freecom [ 3.057253] usbcore: registered new interface driver ums-isd200 [ 3.057330] usbcore: registered new interface driver ums-jumpshot [ 3.057403] usbcore: registered new interface driver ums-karma [ 3.057480] usbcore: registered new interface driver ums-onetouch [ 3.057558] usbcore: registered new interface driver ums-sddr09 [ 3.057648] usbcore: registered new interface driver ums-sddr55 [ 3.057729] usbcore: registered new interface driver ums-usbat [ 3.057935] usbcore: registered new interface driver usbserial [ 3.058020] usbcore: registered new interface driver usbserial_generic [ 3.058083] usbserial: USB Serial support registered for generic [ 3.058171] usbcore: registered new interface driver option [ 3.058232] usbserial: USB Serial support registered for GSM modem (1-port) [ 3.058647] usbcore: registered new interface driver trancevibrator [ 3.058667] usb20_otg: version 3.10a 21-DEC-2012 [ 3.059683] e2680040 [ 3.059713] Core Release: 3.10a [ 3.059732] Setting default values for core params [ 3.060030] Using Buffer DMA mode [ 3.060052] Periodic Transfer Interrupt Enhancement - disabled [ 3.060071] Multiprocessor Interrupt Enhancement - disabled [ 3.060088] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 3.060105] ^^^^^^^^^^^^^^^^^Device Mode [ 3.060131] Dedicated Tx FIFOs mode [ 3.060168] pcd_init otg_dev = dde34dc0 [ 3.060791] usb20_otg 30040000.otg: DWC OTG Controller [ 3.060855] usb20_otg 30040000.otg: new USB bus registered, assigned bus number 7 [ 3.060923] usb20_otg 30040000.otg: irq 55, io mem 0x00000000 [ 3.061058] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.061085] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.061108] usb usb7: Product: DWC OTG Controller [ 3.061130] usb usb7: Manufacturer: Linux 3.10.104 dwc_otg_hcd [ 3.061152] usb usb7: SerialNumber: 30040000.otg [ 3.062138] hub 7-0:1.0: USB hub found [ 3.062197] hub 7-0:1.0: 1 port detected [ 3.062809] usb20_host: version 3.10a 21-DEC-2012 [ 3.065444] usbcore: registered new interface driver xpad [ 3.065570] usbcore: registered new interface driver usb_acecad [ 3.065672] usbcore: registered new interface driver aiptek [ 3.065767] usbcore: registered new interface driver gtco [ 3.065880] usbcore: registered new interface driver hanwang [ 3.065973] usbcore: registered new interface driver kbtab [ 3.066102] usbcore: registered new interface driver wacom [ 3.066252] ==gsl_ts_init== [ 3.066308] ret=0 [ 3.066363] i2c-core: driver [gslX680] using legacy suspend method [ 3.066381] i2c-core: driver [gslX680] using legacy resume method [ 3.067339] sensor_register_slave:mma8452,id=17 [ 3.067367] sensor_register_slave:mma7660,id=18 [ 3.067385] sensor_register_slave:gs_mc3230,id=23 [ 3.067401] [Gsensor] gsensor_init [ 3.067418] sensor_register_slave:mpu6880_acc,id=24 [ 3.067435] sensor_register_slave:mpu6500_acc,id=25 [ 3.067453] sensor_register_slave:bma2xx_acc,id=26 [ 3.067471] sensor_register_slave:akm8963,id=30 [ 3.067489] sensor_register_slave:cm3217,id=51 [ 3.067505] sensor_register_slave:cm3218,id=52 [ 3.067523] sensor_register_slave:ls_stk3410,id=60 [ 3.068276] .. rk pwm remotectl v1.1 init [ 3.068786] input: 110b0030.pwm as /devices/110b0030.pwm/input/input1 [ 3.069294] remotectl-pwm 110b0030.pwm: Missing psci property in the DT. [ 3.069477] ++++++++shutdown_key_init [ 3.069740] ........shutdown_key_probe [ 3.070028] input: shutdown_key as /devices/shutdown-key.30/input/input2 [ 3.070798] VFD Driver [ 3.071293] vfd: gpio_clk=32, gpio_stb=33, gpio_dio=34 [ 3.072825] input: vfd_keypad as /devices/cyx-vfd.31/input/input3 [ 3.073204] vfd config major:245 [ 3.073730] i2c /dev entries driver [ 3.074142] IR NEC protocol handler initialized [ 3.074166] IR RC5(x) protocol handler initialized [ 3.074182] IR RC6 protocol handler initialized [ 3.074199] IR JVC protocol handler initialized [ 3.074215] IR Sony protocol handler initialized [ 3.074230] IR RC5 (streamzap) protocol handler initialized [ 3.074247] IR SANYO protocol handler initialized [ 3.074263] IR MCE Keyboard/mouse protocol handler initialized [ 3.074592] usbcore: registered new interface driver uvcvideo [ 3.074612] USB Video Class driver (1.1.1) [ 3.074633] CamSys driver version: v0.35.0, CamSys head file version: v0.13.0 [ 3.074655] E:camsys_soc_init(36): camsys isn't support soc: 0x32283002! [ 3.075349] not find test_power_init dev node [ 3.075425] i2c-core: driver [bq27320] using legacy suspend method [ 3.075444] i2c-core: driver [bq27320] using legacy resume method [ 3.076957] rockchip_temp_probe,line=384 [ 3.077641] tsadc 11150000.tsadc: Missing tsadc_low_temp in the DT. [ 3.129350] tsadc 11150000.tsadc: initialized [ 3.130363] device-mapper: uevent: version 1.0.3 [ 3.131017] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com [ 3.131540] Bluetooth: HCI UART driver ver 2.2 [ 3.131566] Bluetooth: HCI H4 protocol initialized [ 3.131584] Bluetooth: HCILL protocol initialized [ 3.131602] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x [ 3.131620] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2 [ 3.131638] rtk_btusb: Register usb char device interface for BT driver [ 3.132068] usbcore: registered new interface driver rtk_btusb [ 3.132568] cpufreq version 1.0, suspend freq 1008 MHz [ 3.133183] cpuidle: using governor ladder [ 3.133206] cpuidle: using governor menu [ 3.133285] Synopsys Designware Multimedia Card Interface Driver [ 3.133304] MHSC version = Ver 2.00 2015-06-10 [ 3.133916] dwmmc_rockchip 30020000.rksdmmc: Version ID is 270a [ 3.134029] dwmmc_rockchip 30020000.rksdmmc: failed to get hpclk_mmc [ 3.134538] dwmmc_rockchip 30020000.rksdmmc: Using PIO mode. [ 3.134936] dwmmc_rockchip 30020000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 3.149068] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 3.158996] dwc_otg_hcd_suspend, usb device mode [ 3.168842] dwmmc_rockchip 30020000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo [ 3.168885] dwmmc_rockchip 30020000.rksdmmc: 1 slots initialized [ 3.169652] dwmmc_rockchip 30000000.rksdmmc: Version ID is 270a [ 3.169765] dwmmc_rockchip 30000000.rksdmmc: failed to get hpclk_mmc [ 3.170175] dwmmc_rockchip 30000000.rksdmmc: Using PIO mode. [ 3.170569] dwmmc_rockchip 30000000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1] [ 3.170866] dwmmc_rockchip 30000000.rksdmmc: mmc1: No udbg pinctrl found! [ 3.188477] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1] [ 3.208234] dwmmc_rockchip 30000000.rksdmmc: DW MMC controller at irq 44, 32 bit host data width, 256 deep fifo [ 3.208303] dwmmc_rockchip 30000000.rksdmmc: 1 slots initialized [ 3.209591] dwmmc_rockchip 30010000.rksdmmc: Version ID is 270a [ 3.209752] dwmmc_rockchip 30010000.rksdmmc: failed to get hpclk_mmc [ 3.210456] dwmmc_rockchip 30010000.rksdmmc: Using PIO mode. [ 3.211065] dwmmc_rockchip 30010000.rksdmmc: dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2] [ 3.227869] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2] [ 3.241069] mmc0: BKOPS_EN bit is not set [ 3.244344] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 3.244417] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 3.245114] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0] [ 3.246428] mmc0: new high speed MMC card at address 0001 [ 3.247649] dwmmc_rockchip 30010000.rksdmmc: DW MMC controller at irq 45, 32 bit host data width, 256 deep fifo [ 3.247686] mmcblk0: mmc0:0001 Biwin 7.20 GiB [ 3.247735] dwmmc_rockchip 30010000.rksdmmc: 1 slots initialized [ 3.248294] mmcblk0rpmb: mmc0:0001 Biwin partition 3 4.00 MiB [ 3.249051] hidraw: raw HID events driver (C) Jiri Kosina [ 3.249616] rkpart: partition size too small (0) [ 3.249674] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 3.249712] trust: 0x000800000 -- 0x001000000 (8 MB) [ 3.249747] misc: 0x001000000 -- 0x001400000 (4 MB) [ 3.249781] baseparamer: 0x001400000 -- 0x001500000 (1 MB) [ 3.249817] resource: 0x001500000 -- 0x002400000 (15 MB) [ 3.249853] kernel: 0x002400000 -- 0x003000000 (12 MB) [ 3.249888] boot: 0x003000000 -- 0x004400000 (20 MB) [ 3.249923] recovery: 0x004400000 -- 0x006400000 (32 MB) [ 3.249959] backup: 0x006400000 -- 0x00a400000 (64 MB) [ 3.249995] cache: 0x00a400000 -- 0x012400000 (128 MB) [ 3.250032] metadata: 0x012400000 -- 0x013400000 (16 MB) [ 3.250068] kpanic: 0x013400000 -- 0x013800000 (4 MB) [ 3.250103] system: 0x013800000 -- 0x093800000 (2048 MB) [ 3.250140] userdata: 0x093800000 -- 0x1ccc00000 (5012 MB) [ 3.250248] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14[ 3.256487] usbcore: registered new interface driver usbhid [ 3.256530] usbhid: USB HID core driver [ 3.257116] ashmem: initialized [ 3.257793] logger: created 256K log 'log_main' [ 3.258298] logger: created 256K log 'log_events' [ 3.258803] logger: created 256K log 'log_radio' [ 3.259309] logger: created 256K log 'log_system' [ 3.261800] rknandbase v1.1 2016-11-08 [ 3.262374] rknand: probe of 30030000.nandc failed with error -1 [ 3.267975] rockchip-spdif 100d0000.spdif: spdif ready. [ 3.292639] rk322x-audio rockchip_audio.26: rk322x-hifi <-> 100b0000.i2s1 mapping ok [ 3.299227] rockchip-hdmi-i2s rockchip_hdmi_i2s.28: rk-hdmi-i2s-hifi <-> 100c0000.i2s0 mapping ok [ 3.300979] u32 classifier [ 3.301029] Actions configured [ 3.301061] Netfilter messages via NETLINK v0.30. [ 3.301214] nf_conntrack version 0.5.0 (15448 buckets, 61792 max) [ 3.302200] ctnetlink v0.93: registering with nfnetlink. [ 3.302360] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 3.302385] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 3.303336] xt_time: kernel timezone is -0000 [ 3.303964] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.304370] arp_tables: (C) 2002 David S. Miller [ 3.304485] TCP: cubic registered [ 3.304506] Initializing XFRM netlink socket [ 3.305333] NET: Registered protocol family 10 [ 3.307045] mip6: Mobile IPv6 [ 3.307131] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.307430] sit: IPv6 over IPv4 tunneling driver [ 3.308385] NET: Registered protocol family 17 [ 3.308454] NET: Registered protocol family 15 [ 3.308602] Bridge firewalling registered [ 3.308665] Ebtables v2.0 registered [ 3.309056] Bluetooth: RFCOMM TTY layer initialized [ 3.309129] Bluetooth: RFCOMM socket layer initialized [ 3.309149] Bluetooth: RFCOMM ver 1.11 [ 3.309167] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.309182] Bluetooth: BNEP filters: protocol multicast [ 3.309210] Bluetooth: BNEP socket layer initialized [ 3.309228] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.309252] Bluetooth: HIDP socket layer initialized [ 3.309404] l2tp_core: L2TP core driver, V2.0 [ 3.309442] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 3.309460] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.309810] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.309836] [WLAN_RFKILL]: can't find rockchip,grf property [ 3.309856] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089 [ 3.309875] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.309892] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 3.309910] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.309997] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 90, flags = 0. [ 3.310069] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 0. [ 3.310088] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.310164] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 3.310184] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized [ 3.310202] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 3.310218] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 3.414802] [WLAN_RFKILL]: wifi turn on power. 90 [ 3.414870] mmc2:mmc host rescan start! [ 3.414922] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 3.415136] [BT_RFKILL]: Enter rfkill_rk_init [ 3.416079] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 102. [ 3.416169] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 93. [ 3.416274] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 123. [ 3.416350] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 122. [ 3.416478] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,lecctl_gpio = 39. [ 3.416562] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,ledctl_gpio_r6 = 117. [ 3.416739] [BT_RFKILL]: Request irq for bt wakeup host [ 3.417063] [BT_RFKILL]: ** disable irq [ 3.417148] [BT_RFKILL]: Failed to get ap6335_ledctl gpio. [ 3.417208] [BT_RFKILL]: Failed to get ap6335_ledctl_r6 gpio. [ 3.417638] [BT_RFKILL]: ap6335 device registered. [ 3.418413] Key type dns_resolver registered [ 3.422982] rk322x_suspend_init: pm_ctrbits = 0x11806 [ 3.423070] Registering SWP/SWPB emulation handler [ 3.423115] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x9dc00000 [ 3.438156] ddrfreq: verion 1.2 20140526 [ 3.438219] ddrfreq: normal 600MHz performance 660MHz low_power 0MHz video_1080p 0MHz video_4k 660MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 600MHz video_4k_10b 660MHz [ 3.439988] ddrfreq: auto-freq=0 [ 3.440025] ddrfreq: auto-freq-table epmty! [ 3.441713] regulator-dummy: disabling [ 3.442294] pcd_pullup, is_on 0 [ 3.442463] file system registered [ 3.444878] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 3.444928] android_usb gadget: Number of LUNs=2 [ 3.444954] lun0: LUN: removable file: (no medium) [ 3.444976] lun1: LUN: removable file: (no medium) [ 3.445723] android_usb gadget: android_usb ready [ 3.445847] sensor_init: Probe name sensors [ 3.445906] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 3.445936] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) [ 3.461744] rockchip-spdif-card rockchip_spdif_card.27: rk-hdmi-spdif-hifi <-> 100d0000.spdif mapping ok [ 3.463495] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-aca6ab02a7', rk_ko_ver is '5', built at '17:08:02', on 'Mar 24 2021'. [ 3.463945] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13 [ 3.463980] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000 [ 3.464009] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000 [ 3.464035] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000 [ 3.464062] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000 [ 3.464088] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000 [ 3.464116] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000 [ 3.464142] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000 [ 3.464170] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000026 [ 3.464196] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000025 [ 3.464222] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000024 [ 3.464249] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000025 [ 3.464275] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000024 [ 3.464301] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000025 [ 3.464432] mali-utgard 20001000.gpu: freq: 200000000, min_threshold: 0, max_threshold: 70 [ 3.464463] mali-utgard 20001000.gpu: freq: 300000000, min_threshold: 61, max_threshold: 85 [ 3.464494] mali-utgard 20001000.gpu: freq: 400000000, min_threshold: 73, max_threshold: 100 [ 3.464630] mali-utgard 20001000.gpu: initial freq = 200000000 [ 3.468067] Mali: Mali device driver loaded [ 3.469051] usbcore: registered new interface driver snd-usb-audio [ 3.469079] ALSA device list: [ 3.469097] #0: RK_RK322x [ 3.469115] #1: RK-HDMI-I2S [ 3.469132] #2: RK-SPDIF-CARD [ 3.470144] Freeing unused kernel memory: 384K (c0c21000 - c0c81000) [ 3.474754] init: init first stage started! [ 3.479830] init: init second stage started! [ 3.488512] init: Setting ro.rk.soc=rk3229 [ 3.488842] init: OK,EMMC DRIVERS INIT OK [ 3.488940] init: property_set("ro.boot.mode", "emmc") failed [ 3.489264] init: property_set("ro.hardware", "rk30board") failed [ 3.489918] init: Running restorecon... [ 3.490199] init: waitpid failed: No child processes [ 3.491392] init: (Loading properties from /default.prop took 0.00s.) [ 3.498311] init: (Parsing /init.environ.rc took 0.00s.) [ 3.500080] init: (Parsing /init.usb.rc took 0.00s.) [ 3.503857] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.) [ 3.508304] init: (Parsing init.rk30board.usb.rc took 0.00s.) [ 3.508561] init: (Parsing init.rk30board.environment.rc took 0.00s.) [ 3.508678] init: could not import file '/init.debug.rc' from 'init.rockchip.rc': No such file or directory [ 3.508732] init: (Parsing init.rockchip.rc took 0.00s.) [ 3.510488] init: (Parsing init.connectivity.rc took 0.00s.) [ 3.510887] init: (Parsing init.box.samba.rc took 0.00s.) [ 3.510994] init: could not import file 'init.rk322x.rc' from '/init.rk30board.rc': No such file or directory [ 3.511504] init: (Parsing init.box.rc took 0.00s.) [ 3.511605] init: could not import file 'init.car.rc' from '/init.rk30board.rc': No such file or directory [ 3.511678] init: could not import file 'init.optee.rc' from '/init.rk30board.rc': No such file or directory [ 3.511734] init: (Parsing /init.rk30board.rc took 0.01s.) [ 3.514651] init: (Parsing /init.usb.configfs.rc took 0.00s.) [ 3.515075] init: (Parsing /init.zygote32.rc took 0.00s.) [ 3.515135] init: (Parsing /init.rc took 0.02s.) [ 3.516057] init: Starting service 'ueventd'... [ 3.518525] init: Waiting for /dev/.coldboot_done... [ 3.521461] ueventd: ueventd started! [ 3.523076] ueventd: invalid gid 'trace' [ 3.631253] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 400000Hz, actual 398936HZ div = 47) [ 3.631311] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2] [ 3.631721] ueventd: Coldboot took 0.11s. [ 3.638538] init: Waiting for /dev/.coldboot_done took 0.12s. [ 3.638682] init: /dev/hw_random not found [ 3.639311] keychord: using input dev hdmi_cec_key for fevent [ 3.639350] keychord: using input dev 110b0030.pwm for fevent [ 3.639363] keychord: using input dev shutdown_key for fevent [ 3.648490] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory [ 3.648957] pm policy 0 -> 1 [ 3.649820] init: /dev/hw_random not found [ 3.651576] fs_mgr: Warning: unknown flag resize [ 3.657391] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option [ 3.665957] EXT4-fs (mmcblk0p13): warning: maximal mount count reached, running e2fsck is recommended [ 3.671005] mmc2 not switch iovel. [ 3.675670] mmc2: queuing unknown CIS tuple 0x01 (3 bytes) [ 3.683169] mmc2: queuing unknown CIS tuple 0x1a (5 bytes) [ 3.686046] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit [ 3.686289] fs_mgr: check_fs(): mount(/dev/block/platform/30020000.rksdmmc/by-name/system,/system,ext4)=0: Success [ 3.686641] mmc2: queuing unknown CIS tuple 0x1b (8 bytes) [ 3.687828] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0) [ 3.687885] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 3.688103] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2] [ 3.690382] mmc2: queuing unknown CIS tuple 0x80 (1 bytes) [ 3.690491] mmc2: queuing unknown CIS tuple 0x81 (1 bytes) [ 3.690607] mmc2: queuing unknown CIS tuple 0x82 (1 bytes) [ 3.690615] fs_mgr: check_fs(): unmount(/system) succeeded [ 3.690677] mmc2: new high speed SDIO card at address 0001 [ 3.690719] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/30020000.rksdmmc/by-name/system (executable not in system image) [ 3.700906] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc [ 3.701045] fs_mgr: __mount(source=/dev/block/platform/30020000.rksdmmc/by-name/system,target=/system,type=ext4)=0 [ 3.719077] EXT4-fs (mmcblk0p10): warning: maximal mount count reached, running e2fsck is recommended [ 3.720214] EXT4-fs (mmcblk0p10): recovery complete [ 3.721036] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 3.721161] fs_mgr: __mount(source=/dev/block/platform/30020000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0 [ 3.722132] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option [ 3.725795] EXT4-fs (mmcblk0p11): recovery complete [ 3.725846] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit [ 3.725957] fs_mgr: check_fs(): mount(/dev/block/platform/30020000.rksdmmc/by-name/metadata,/metadata,ext4)=0: Success [ 3.727694] fs_mgr: check_fs(): unmount(/metadata) succeeded [ 3.729215] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/30020000.rksdmmc/by-name/metadata [ 3.964101] vendor storage:20160801 ret = 0 [ 3.967718] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 3.967718] [ 3.967843] e2fsck: /dev/block/platform/30020000.rksdmmc/by-name/metadata has been mounted 10 times without being checked, check forced. [ 3.967843] [ 3.967893] e2fsck: Pass 1: Checking inodes, blocks, and sizes [ 3.967893] [ 3.967927] e2fsck: Pass 2: Checking directory structure [ 3.967927] [ 3.967962] e2fsck: Pass 3: Checking directory connectivity [ 3.967962] [ 3.967996] e2fsck: Pass 4: Checking reference counts [ 3.967996] [ 3.968029] e2fsck: Pass 5: Checking group summary information [ 3.968029] [ 3.968066] e2fsck: /dev/block/platform/30020000.rksdmmc/by-name/metadata: 11/1024 files (0.0% non-contiguous), 1102/4096 blocks [ 3.968066] [ 3.973703] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 3.973861] fs_mgr: __mount(source=/dev/block/platform/30020000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0 [ 3.974857] EXT4-fs (mmcblk0p14): Ignoring removed nomblk_io_submit option [ 4.048067] EXT4-fs (mmcblk0p14): recovery complete [ 4.048915] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit [ 4.049041] fs_mgr: check_fs(): mount(/dev/block/platform/30020000.rksdmmc/by-name/userdata,/data,ext4)=0: Success [ 4.051776] fs_mgr: check_fs(): unmount(/data) succeeded [ 4.051900] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/30020000.rksdmmc/by-name/userdata [ 4.115099] e2fsck: e2fsck 1.42.9 (28-Dec-2013) [ 4.115099] [ 4.115232] e2fsck: /dev/block/platform/30020000.rksdmmc/by-name/userdata: clean, 2883/321280 files, 331936/1283072 blocks [ 4.115232] [ 4.120996] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic [ 4.121152] fs_mgr: __mount(source=/dev/block/platform/30020000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0 [ 4.137444] init: (Parsing /system/etc/init/atrace.rc took 0.00s.) [ 4.138608] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.) [ 4.139571] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.) [ 4.140772] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.) [ 4.141809] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.) [ 4.142735] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.) [ 4.143935] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.) [ 4.145330] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.) [ 4.146303] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.) [ 4.147301] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.) [ 4.148224] init: (Parsing /system/etc/init/installd.rc took 0.00s.) [ 4.149132] init: (Parsing /system/etc/init/keystore.rc took 0.00s.) [ 4.150047] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.) [ 4.151560] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.) [ 4.152617] init: (Parsing /system/etc/init/logd.rc took 0.00s.) [ 4.153701] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.) [ 4.154704] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.) [ 4.155723] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.) [ 4.156655] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.) [ 4.157637] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.) [ 4.158539] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.) [ 4.159454] init: (Parsing /system/etc/init/netd.rc took 0.00s.) [ 4.160358] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.) [ 4.161257] init: (Parsing /system/etc/init/racoon.rc took 0.00s.) [ 4.162249] init: ignored duplicate definition of service 'ril-daemon'init: (Parsing /system/etc/init/rild.rc took 0.00s.) [ 4.163501] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.) [ 4.164456] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.) [ 4.165462] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.) [ 4.166439] init: (Parsing /system/etc/init/vdc.rc took 0.00s.) [ 4.167407] init: (Parsing /system/etc/init/vold.rc took 0.00s.) [ 4.171555] init: property_set("ro.board.platform", "rk322x") failed [ 4.173125] init: property_set("ro.opengles.version", "196609") failed [ 4.173608] init: property_set("ro.rk.screenoff_time", "2147483647") failed [ 4.174312] init: property_set("ro.rk.screenshot_enable", "true") failed [ 4.175069] init: (Loading properties from /system/build.prop took 0.01s.) [ 4.175292] init: (Loading properties from /vendor/build.prop took 0.00s.) [ 4.175378] init: (Loading properties from /factory/factory.prop took 0.00s.) [ 4.175711] fs_mgr: Warning: unknown flag resize [ 4.176013] init: /recovery not specified in fstab [ 4.176261] init: Starting service 'healthd'... [ 4.177264] init: Starting service 'displayd'... [ 4.178364] init: Starting service 'lmkd'... [ 4.179352] init: Starting service 'servicemanager'... [ 4.182036] init: Starting service 'surfaceflinger'... [ 4.183159] init: Starting service 'vold'... [ 4.186009] binder: 139:139 transaction failed 29189, size 0-0 [ 4.193153] init: insmod: open("/system/lib/modules/ump.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali_kbase.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/rk30_mirroring.ko") failed: No such file or directory [ 4.217060] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ' should be '3.10.104 SMP preempt mod_unload ARMv7 p2v8 ' [ 4.217167] init: finit_module for "/system/lib/modules/rk29-ipp.ko" failed: Exec format errorinit: insmod: open("/system/lib/modules/pvrsrvkm.ko") failed: No such file or directory [ 4.217743] drmboot: module license 'unspecified' taints kernel. [ 4.217761] Disabling lock debugging due to kernel taint [ 4.218518] drm init, 20140910 [ 4.281489] drm init ok [ 4.281844] fs_mgr: Warning: unknown flag resize [ 4.283487] zram: Cannot initialise lz4 compressing backend [ 4.354752] Unable to find swap-space signature [ 4.355437] fs_mgr: swapon failed for /dev/block/zram0 [ 4.371779] vcodec_service: No noc aclk reset resource define [ 4.371827] vcodec_service: No noc hclk reset resource define [ 4.371838] vcodec_service: No core reset resource define [ 4.371848] vcodec_service: No cabac reset resource define [ 4.371978] vcodec 20020000.vpu_service: do not have pd_video [ 4.372029] vcodec_service: probe device 20020000.vpu_service [ 4.372108] vcodec_service: checking hw id 0 [ 4.374185] vcodec_service: init success [ 4.374403] vcodec_service: No noc aclk reset resource define [ 4.374422] vcodec_service: No noc hclk reset resource define [ 4.374432] vcodec_service: No core reset resource define [ 4.374441] vcodec_service: No cabac reset resource define [ 4.374580] vcodec 20030000.rkvdec: do not have pd_video [ 4.374622] vcodec_service: probe device 20030000.rkvdec [ 4.374719] vcodec_service: checking hw id 6876 [ 4.378112] vcodec_service: init success [ 4.383013] init: Starting service 'debuggerd'... [ 4.383731] init: do_start: Service debuggerd64 not found [ 4.391728] init: Not bootcharting. [ 4.773598] fs_mgr: Warning: unknown flag resize [ 4.802089] init: Failed to reload policy [ 4.802635] init: Starting service 'exec 1 (/system/bin/tzdatacheck)'... [ 4.813464] rk_fb_set_par[3407],var->reserved[3]:0x1 [ 4.813479] rk_fb_pan_display[1531],var->reserved[3]:0x1 [ 4.837811] init: Service 'exec 1 (/system/bin/tzdatacheck)' (pid 164) exited with status 0 [ 4.892150] EXT4-fs (mmcblk0p14): Unrecognized mount option "seclabel" or missing value [ 5.012261] init: Starting service 'logd'... [ 5.014811] init: Starting service 'bootanim'... [ 5.016086] init: Starting service 'logd-reinit'... [ 5.016202] <melvin> drivers/video/rockchip/hdmi/rockchip-hdmiv2/rockchip_hdmiv2.c(466) rockchip_hdmiv2_fb_event_notify: ..........>>>>>>>> FB_EARLY_EVENT_BLANK -> FB_BLANK_UNBLANK [ 5.016326] .....................sleep=0 [ 5.017452] rk322x-lcdc vop0: blank mode:0 [ 5.029581] init: write_file: Unable to open '/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold': No such file or directory [ 5.034140] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 5.034242] init: write: cannot expand '${ro.serialno}' [ 5.034970] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead [ 5.043491] init: write_file: Unable to write to '/dev/cpuset/foreground/boost/cpus': Permission denied [ 5.044943] init: Starting service 'adbd'... [ 5.047222] android_usb: already disabled [ 5.049506] init: cannot find '/system/bin/update_verifier' (No such file or directory), disabling 'exec 2 (/system/bin/update_verifier)' [ 5.049781] init: Starting service 'flash_recovery'... [ 5.050751] init: Starting service 'drmservice'... [ 5.051791] init: cannot find '/system/bin/bplus_helper' (No such file or directory), disabling 'bplus_helper' [ 5.051982] init: cannot find '/system/bin/busybox' (No such file or directory), disabling 'up_eth0' [ 5.052084] init: cannot find '/system/bin/rk_store_keybox' (No such file or directory), disabling 'rk_store_keybox' [ 5.052213] init: cannot find '/system/bin/akmd' (No such file or directory), disabling 'akmd' [ 5.052423] init: Starting service 'zygote'... [ 5.053519] init: Starting service 'audioserver'... [ 5.054586] init: Starting service 'cameraserver'... [ 5.055734] init: Starting service 'drm'... [ 5.055980] init: couldn't write 183 to /dev/cpuset/camera-daemon/tasks: No such file or directory [ 5.056836] init: Starting service 'installd'... [ 5.059040] init: Starting service 'keystore'... [ 5.060597] init: Starting service 'mediacodec'... [ 5.062149] init: Starting service 'mediadrm'... [ 5.063848] init: Starting service 'mediaextractor'... [ 5.065548] init: Starting service 'media'... [ 5.067633] init: Starting service 'netd'... [ 5.069548] init: Starting service 'gatekeeperd'... [ 5.153638] logd.auditd: start [ 5.153717] logd.klogd: 2937316459 [ 5.178728] healthd: No battery devices found [ 5.178922] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a [ 5.861305] RKNAND_GET_SN_SECTOR [ 5.861363] return ret = 0 [ 5.932820] fs_mgr: Warning: unknown flag resize [ 6.713462] init: Starting service 'perfprofd'... [ 7.140168] init: Service 'logd-reinit' (pid 177) exited with status 145 [ 7.150223] init: Service 'drmservice' (pid 180) exited with status 0 [ 7.247415] read descriptors [ 7.247521] read descriptors [ 7.247584] read strings [ 7.247666] pcd_pullup, is_on 1 [ 7.333707] init: Service 'perfprofd' (pid 203) exited with status 0 [ 8.816661] init: Service 'flash_recovery' (pid 179) exited with status 0 [ 10.962073] [otg id chg] last id -1 current id 2 [ 10.962130] PortPower off [ 10.962153] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 11.061593] Using Buffer DMA mode [ 11.061647] Periodic Transfer Interrupt Enhancement - disabled [ 11.061658] Multiprocessor Interrupt Enhancement - disabled [ 11.061671] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 11.061682] ^^^^^^^^^^^^^^^^^Device Mode [ 11.061717] dwc_otg_hcd_resume, usb device mode [ 11.168855] dwc_otg_hcd_suspend, usb device mode [ 11.553366] ***************vbus detect***************** [ 11.553565] rk_battery_charger_detect_cb , battery_charger_detect 255 [ 11.745990] Using Buffer DMA mode [ 11.746057] Periodic Transfer Interrupt Enhancement - disabled [ 11.746069] Multiprocessor Interrupt Enhancement - disabled [ 11.746080] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 11.746092] ^^^^^^^^^^^^^^^^^Device Mode [ 11.758325] *******************soft connect!!!******************* [ 12.001078] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 12.536462] **************soft reconnect************** [ 12.722002] Using Buffer DMA mode [ 12.722064] Periodic Transfer Interrupt Enhancement - disabled [ 12.722076] Multiprocessor Interrupt Enhancement - disabled [ 12.722088] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 12.722098] ^^^^^^^^^^^^^^^^^Device Mode [ 12.726169] *******************soft connect!!!******************* [ 13.520458] **************soft reconnect************** [ 13.705026] Using Buffer DMA mode [ 13.705078] Periodic Transfer Interrupt Enhancement - disabled [ 13.705088] Multiprocessor Interrupt Enhancement - disabled [ 13.705101] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 13.705113] ^^^^^^^^^^^^^^^^^Device Mode [ 13.709149] *******************soft connect!!!******************* [ 13.843047] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 14.504411] **************soft reconnect************** [ 14.691514] Using Buffer DMA mode [ 14.691558] Periodic Transfer Interrupt Enhancement - disabled [ 14.691569] Multiprocessor Interrupt Enhancement - disabled [ 14.691582] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 14.691594] ^^^^^^^^^^^^^^^^^Device Mode [ 14.695622] *******************soft connect!!!******************* [ 15.046351] warning: `main' uses 32-bit capabilities (legacy support in use) [ 15.387454] rk322x-lcdc vop0: win0:new_addr:0x10b02000 cur_addr:0x10e88000--1 [ 15.488430] **************soft reconnect************** [ 15.665708] Using Buffer DMA mode [ 15.665758] Periodic Transfer Interrupt Enhancement - disabled [ 15.665770] Multiprocessor Interrupt Enhancement - disabled [ 15.665783] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 15.665794] ^^^^^^^^^^^^^^^^^Device Mode [ 15.669832] *******************soft connect!!!******************* [ 15.714393] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 16.472431] **************soft reconnect************** [ 16.649832] Using Buffer DMA mode [ 16.649881] Periodic Transfer Interrupt Enhancement - disabled [ 16.649895] Multiprocessor Interrupt Enhancement - disabled [ 16.649907] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 16.649919] ^^^^^^^^^^^^^^^^^Device Mode [ 16.653943] *******************soft connect!!!******************* [ 17.649432] rk322x-lcdc vop0: win0:new_addr:0x10b02000 cur_addr:0x10e88000--1 [ 17.697464] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 19.994056] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 21.715962] rk322x-lcdc vop0: win0:new_addr:0x10b02000 cur_addr:0x10e88000--1 [ 21.764092] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 26.310689] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 27.491210] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 30.275331] rk322x-lcdc vop0: win0:new_addr:0x10e88000 cur_addr:0x10b02000--1 [ 30.410397] rk322x-lcdc vop0: win0:new_addr:0x10b02000 cur_addr:0x10e88000--1 [ 33.818314] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a [ 35.434600] acc_open [ 35.434684] acc_release [ 35.928622] phy_power_on: enable = 1 [ 35.928664] use internal PHY [ 35.964251] Read the Ethernet MAC address from IDB:68:1d:ef:0d:9b:cd [ 35.964311] eth0: device MAC address 68:1d:ef:0d:9b:cd [ 35.989972] libphy: stmmac: probed [ 35.990017] eth0: PHY ID 00000000 at 0 IRQ 0 (stmmac-0:00) active [ 35.990032] eth0: PHY ID 1234d400 at 1 IRQ POLL (stmmac-0:01) active [ 35.990044] PHY driver name: Rockchip integrated EPHY [ 35.990056] eth0: PHY ID 00000000 at 2 IRQ 0 (stmmac-0:02) [ 35.990070] eth0: PHY ID 00000000 at 3 IRQ 0 (stmmac-0:03) [ 35.990083] eth0: PHY ID 00000000 at 4 IRQ 0 (stmmac-0:04) [ 35.990095] eth0: PHY ID 00000000 at 5 IRQ 0 (stmmac-0:05) [ 35.990108] eth0: PHY ID 00000000 at 6 IRQ 0 (stmmac-0:06) [ 35.990121] eth0: PHY ID 00000000 at 7 IRQ 0 (stmmac-0:07) [ 35.990133] eth0: PHY ID 00000000 at 8 IRQ 0 (stmmac-0:08) [ 35.990145] eth0: PHY ID 00000000 at 9 IRQ 0 (stmmac-0:09) [ 35.990157] eth0: PHY ID 00000000 at 10 IRQ 0 (stmmac-0:0a) [ 35.990170] eth0: PHY ID 00000000 at 11 IRQ 0 (stmmac-0:0b) [ 35.990182] eth0: PHY ID 00000000 at 12 IRQ 0 (stmmac-0:0c) [ 35.990195] eth0: PHY ID 00000000 at 13 IRQ 0 (stmmac-0:0d) [ 35.990207] eth0: PHY ID 00000000 at 14 IRQ 0 (stmmac-0:0e) [ 35.990220] eth0: PHY ID 00000000 at 15 IRQ 0 (stmmac-0:0f) [ 35.990233] eth0: PHY ID 00000000 at 16 IRQ 0 (stmmac-0:10) [ 35.990245] eth0: PHY ID 00000000 at 17 IRQ 0 (stmmac-0:11) [ 35.990258] eth0: PHY ID 00000000 at 18 IRQ 0 (stmmac-0:12) [ 35.990270] eth0: PHY ID 00000000 at 19 IRQ 0 (stmmac-0:13) [ 35.990283] eth0: PHY ID 00000000 at 20 IRQ 0 (stmmac-0:14) [ 35.990296] eth0: PHY ID 00000000 at 21 IRQ 0 (stmmac-0:15) [ 35.990308] eth0: PHY ID 00000000 at 22 IRQ 0 (stmmac-0:16) [ 35.990321] eth0: PHY ID 00000000 at 23 IRQ 0 (stmmac-0:17) [ 35.990333] eth0: PHY ID 00000000 at 24 IRQ 0 (stmmac-0:18) [ 35.990346] eth0: PHY ID 00000000 at 25 IRQ 0 (stmmac-0:19) [ 35.990359] eth0: PHY ID 00000000 at 26 IRQ 0 (stmmac-0:1a) [ 35.990371] eth0: PHY ID 00000000 at 27 IRQ 0 (stmmac-0:1b) [ 35.990383] eth0: PHY ID 00000000 at 28 IRQ 0 (stmmac-0:1c) [ 35.990396] eth0: PHY ID 00000000 at 29 IRQ 0 (stmmac-0:1d) [ 35.990409] eth0: PHY ID 00000000 at 30 IRQ 0 (stmmac-0:1e) [ 35.990421] eth0: PHY ID 00000000 at 31 IRQ 0 (stmmac-0:1f) [ 36.699212] [ 36.699212] *****Aug 4 2020 16:43:39 EAGLE DRIVER VER:75be56bfbaf7***** [ 36.699212] [ 36.700052] request_init_conf: crystal_26M_en=1 [ 36.700076] request_init_conf: test_xtal=0 [ 36.700092] request_init_conf: sdio_configure=2 [ 36.700142] request_init_conf: bt_configure=0 [ 36.700163] request_init_conf: bt_protocol=0 [ 36.700178] request_init_conf: dual_ant_configure=0 [ 36.700191] request_init_conf: test_uart_configure=2 [ 36.700204] request_init_conf: share_xtal=0 [ 36.700217] request_init_conf: gpio_wake=0 [ 36.700229] request_init_conf: no_auto_sleep=0 [ 36.700241] request_init_conf: ext_rst=0 [ 36.700253] request_init_conf: wakeup_gpio=12 [ 36.700266] request_init_conf: ate_test=0 [ 36.700277] request_init_conf: speed_suspend=1 [ 36.700301] ======================================================= [ 36.700311] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 36.700320] ======================================================= [ 36.700331] Espressif ESP8089 SDIO WiFi driver (Powered by Rockchip, Ver2.26(2016/05/20),Drv: 2.26) init. [ 36.700343] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 36.804354] [WLAN_RFKILL]: wifi shut off power. [ 36.804396] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0 [ 36.804410] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 36.979848] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 36.979895] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 36.979908] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 37.087250] [WLAN_RFKILL]: wifi turn on power. 90 [ 37.087299] mmc2:mmc host rescan start! [ 37.087518] eagle_sdio_dummy: probe of mmc2:0001:1 failed with error -110 [ 37.209993] rk322x-lcdc vop0: win0:new_addr:0x10b02000 cur_addr:0x10e88000--1 [ 37.225667] dwc_otg_hcd_resume, usb device mode [ 37.226052] dwc_otg_hcd_suspend, usb device mode [ 37.285190] mmc2: card 0001 removed [ 37.303773] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 400000Hz, actual 398936HZ div = 47) [ 37.303827] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2] [ 37.363275] mmc2 not switch iovel. [ 37.372033] mmc2: queuing unknown CIS tuple 0x01 (3 bytes) [ 37.380030] mmc2: queuing unknown CIS tuple 0x1a (5 bytes) [ 37.393992] mmc2: queuing unknown CIS tuple 0x1b (8 bytes) [ 37.395770] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0) [ 37.395824] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 37.396675] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2] [ 37.457761] mmc2: queuing unknown CIS tuple 0x80 (1 bytes) [ 37.457893] mmc2: queuing unknown CIS tuple 0x81 (1 bytes) [ 37.457982] mmc2: queuing unknown CIS tuple 0x82 (1 bytes) [ 37.458637] mmc2: new high speed SDIO card at address 0001 [ 37.459552] esp_sdio_dummy_probe enter [ 37.667783] esp_sdio_init power up OK [ 38.650754] esp_host:75be56bfbaf7 [ 38.650754] esp_target: 2cefb7b78636 77 18204 [ 38.650754] [ 38.652375] esp_readwrite_file: file /system/lib/modules/test_results filp_open error [ 38.655120] first normal exit [ 38.655706] esp_sdio_remove enter [ 38.656553] sif_disable_irq release irq failed [ 38.656993] mmc2:mmc host rescan start! [ 38.760033] mmc2:mmc host rescan start! [ 38.760271] eagle_sdio: probe of mmc2:0001:1 failed with error -110 [ 38.849133] mmc2: card 0001 removed [ 38.878117] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 400000Hz, actual 398936HZ div = 47) [ 38.878163] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2] [ 38.918812] mmc2 not switch iovel. [ 38.923704] mmc2: queuing unknown CIS tuple 0x01 (3 bytes) [ 38.935624] mmc2: queuing unknown CIS tuple 0x1a (5 bytes) [ 38.939483] mmc2: queuing unknown CIS tuple 0x1b (8 bytes) [ 38.940778] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0) [ 38.940826] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 38.942731] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2] [ 38.944733] mmc2: queuing unknown CIS tuple 0x80 (1 bytes) [ 38.945530] mmc2: new high speed SDIO card at address 0001 [ 39.384694] Wifi Efuse Mac => 54:5a:a6:30:1a:a4 [ 39.384729] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter. [ 39.384735] esp_host:75be56bfbaf7 [ 39.384735] esp_target: 2cefb7b78636 77 18204 [ 39.384735] [ 39.384764] [WLAN_RFKILL]: get_wifi_addr_vendor_storage: rk_vendor_read wifi mac address failed (-1) [ 39.384783] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00] [ 39.384796] [WLAN_RFKILL]: This mac address is not valid, ignored... [ 39.387547] Try to set ioctl callback [ 39.387573] interface name wlan0 [ 39.387582] dev name wlan0 [ 39.387591] Set Ioctl Function Callback [ 39.387599] interface name p2p0 [ 39.387607] dev name p2p0 [ 39.387616] Set Ioctl Function Callback [ 39.387627] esp_sdio: initializing netlink [ 39.670014] esp_op_add_interface STA [ 39.670275] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 39.677639] init: Starting service 'p2p_supp_esp'... [ 39.807680] rk322x-lcdc vop0: win0:new_addr:0x10b02000 cur_addr:0x10e88000--1 [ 40.418669] esp_op_add_interface STA [ 40.420019] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready [ 41.674249] init: write_file: Unable to open '/sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq': No such file or directory [ 41.699846] init: cannot find '/system/bin/glgps' (No such file or directory), disabling 'gpsd' [ 41.702485] init: Starting service 'exec 3 (/system/bin/bootstat)'... [ 41.756667] init: Service 'exec 3 (/system/bin/bootstat)' (pid 885) exited with status 0 [ 41.757745] init: Starting service 'exec 4 (/system/bin/bootstat)'... [ 41.786170] init: Service 'exec 4 (/system/bin/bootstat)' (pid 894) exited with status 0 [ 41.787198] init: Starting service 'exec 5 (/system/bin/bootstat)'... [ 41.829852] init: Service 'exec 5 (/system/bin/bootstat)' (pid 895) exited with status 0 [ 41.830890] init: Starting service 'exec 6 (/system/bin/bootstat)'... [ 42.013096] init: Service 'exec 6 (/system/bin/bootstat)' (pid 896) exited with status 0 [ 44.561056] init: Service 'bootanim' is being killed... [ 44.586610] init: Service 'bootanim' (pid 176) killed by signal 9 [ 48.357538] wlan0: authenticate with a0:65:18:aa:fa:9f [ 48.358421] wlan0: send auth to a0:65:18:aa:fa:9f (try 1/3) [ 48.362460] wlan0: authenticated [ 48.373800] wlan0: associate with a0:65:18:aa:fa:9f (try 1/3) [ 48.377539] wlan0: RX AssocResp from a0:65:18:aa:fa:9f (capab=0x11 status=0 aid=16) [ 48.377692] wlan0: associated [ 48.377983] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 48.380195] esp_op_ampdu_action RX START a0:65:18:aa:fa:9f tid 0 0 [ 49.062234] esp_op_ampdu_action RX START a0:65:18:aa:fa:9f tid 1 0 [ 49.153765] start tx ba session,addr:a0:65:18:aa:fa:9f,tid:1 [ 49.220081] esp_op_ampdu_action TX START, addr:a0:65:18:aa:fa:9f,tid:1,state:1 [ 49.221673] esp_op_ampdu_action TX OPERATION, addr:a0:65:18:aa:fa:9f,tid:1,state:2 [ 56.174301] qtaguid: ctrl_tag(t -1 3458768941931823104 -1): failed to lookup sock_fd=-1 err=-9 pid=1232 tgid=797 uid=10010 [ 56.177443] start tx ba session,addr:a0:65:18:aa:fa:9f,tid:0 [ 56.206869] esp_op_ampdu_action TX START, addr:a0:65:18:aa:fa:9f,tid:0,state:1 [ 56.208720] esp_op_ampdu_action TX OPERATION, addr:a0:65:18:aa:fa:9f,tid:0,state:2 [ 60.538024] force_usb_mode_store 0->1 [ 60.637507] Using Buffer DMA mode [ 60.637551] Periodic Transfer Interrupt Enhancement - disabled [ 60.637563] Multiprocessor Interrupt Enhancement - disabled [ 60.637575] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 60.637586] ^^^^^^^^^^^^^^^^^^Host Mode [ 60.683680] Init: Power Port (0) [ 60.683808] 30040000.otg resume, HPRT0:0x1000 [ 60.684348] 30040000.otg suspend, HPRT0:0x1000 [ 62.877411] esp_op_ampdu_action RX START a0:65:18:aa:fa:9f tid 4 0 [ 77.566830] binder: 797: binder_alloc_buf size 1056768 failed, no address space [ 77.566899] binder: 1073:1598 transaction failed 29201, size 1056768-0 [ 271.342346] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead. [ 298.093176] ........key_timer_func And when flash armbian: DDR Version V1.10 20190926 In ID:0xFFF unknow device ERR Some image: https://drive.google.com/file/d/108AjAhe43UYbFO6yjalZATMmx5PqeVjI/view https://drive.google.com/file/d/101P8nWXoasDUqAlbsHjxg4CbKjCYgjvp/view?usp=sharing] https://drive.google.com/file/d/100TjHiN-FLp0UtJjVYp9u0mUSRbcQXTR/view?usp=sharing https://drive.google.com/file/d/10-a1Xr0dAXy-2OgsLMVKCjocWh03_zrh/view?usp=sharing https://drive.google.com/file/d/1-p9jXeCyiqnPFe9KINODN5oANLszQX-P/view Link to post Share on other sites More sharing options...
jock 211 Posted April 25 Author Share Posted April 25 @Hoangtnt Nguyen Mmmh, your issue seems to raise another problem... The fix we introduced for memory initialization seems to break your board. This Debian minimal image should work on your board: https://drive.google.com/file/d/1Ydu92YjIB_yFz9AYcDFaTmqqZ2yjQAZi/view?usp=sharing Link to post Share on other sites More sharing options...
Hoangtnt Nguyen 0 Posted April 25 Share Posted April 25 1 hour ago, jock said: @Hoangtnt Nguyen Mmmh, your issue seems to raise another problem... The fix we introduced for memory initialization seems to break your board. This Debian minimal image should work on your board: https://drive.google.com/file/d/1Ydu92YjIB_yFz9AYcDFaTmqqZ2yjQAZi/view?usp=sharing thx, it work. Now box can boot, but no wifi , can u teach me how to get wifi work. I use sudo modprobe esp8089 but nothing, get these from dmesg: [ 3.875575] 8021q: 802.1Q VLAN Support v1.8 [ 3.875677] lib80211: common routines for IEEE802.11 drivers [ 3.875699] lib80211_crypt: registered algorithm 'NULL' [ 3.875731] lib80211_crypt: registered algorithm 'WEP' [ 3.875763] lib80211_crypt: registered algorithm 'CCMP' [ 3.875795] lib80211_crypt: registered algorithm 'TKIP' [ 3.875826] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.876735] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.877026] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 3.877082] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089 [ 3.877115] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.877136] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.877163] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]' [ 3.877184] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]' [ 3.877207] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]' [ 3.877290] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0) [ 3.877312] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1. [ 3.877348] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 3.877368] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.877394] [WLAN_RFKILL]: Exit rfkill_wlan_probe and esp8089: unknown parameter 'crystal_26M_en' ignored thx a lot. Link to post Share on other sites More sharing options...
jock 211 Posted April 25 Author Share Posted April 25 16 minutes ago, Hoangtnt Nguyen said: thx, it work. Now box can boot, but no wifi , can u teach me how to get wifi work. I use sudo modprobe esp8089 but nothing, get these from dmesg: [ 3.875575] 8021q: 802.1Q VLAN Support v1.8 [ 3.875677] lib80211: common routines for IEEE802.11 drivers [ 3.875699] lib80211_crypt: registered algorithm 'NULL' [ 3.875731] lib80211_crypt: registered algorithm 'WEP' [ 3.875763] lib80211_crypt: registered algorithm 'CCMP' [ 3.875795] lib80211_crypt: registered algorithm 'TKIP' [ 3.875826] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.876735] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.877026] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 3.877082] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089 [ 3.877115] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.877136] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.877163] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]' [ 3.877184] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]' [ 3.877207] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]' [ 3.877290] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0) [ 3.877312] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1. [ 3.877348] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 3.877368] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.877394] [WLAN_RFKILL]: Exit rfkill_wlan_probe thx a lot. If you ran rk322x-config, it automatically added wlan-esp8089 overlay, but on your board the dtbo misconfigures the power on pin of the wifi chip. What you can do is remove wlan-esp8089 from overlays= line in /boot/armbianEnv.txt and then reboot. It should work automatically, no need to manually load the driver. Link to post Share on other sites More sharing options...
Hoangtnt Nguyen 0 Posted April 25 Share Posted April 25 1 hour ago, jock said: If you ran rk322x-config, it automatically added wlan-esp8089 overlay, but on your board the dtbo misconfigures the power on pin of the wifi chip. What you can do is remove wlan-esp8089 from overlays= line in /boot/armbianEnv.txt and then reboot. It should work automatically, no need to manually load the driver. after reboot it not work, i try modprobe esp8089 but not success: [ 285.560355] esp8089: unknown parameter 'crystal_26M_en' ignored tried sudo modprobe esp8089 config=crystal_26M_en=1 still have above message, I saw crystal is 26Mhz Link to post Share on other sites More sharing options...
jock 211 Posted April 25 Author Share Posted April 25 1 hour ago, Hoangtnt Nguyen said: after reboot it not work, i try modprobe esp8089 but not success: [ 285.560355] esp8089: unknown parameter 'crystal_26M_en' ignored tried sudo modprobe esp8089 config=crystal_26M_en=2 or =1 is nothing appear and dont see any wifi From the photo you posted, it looks to me that the crystal is 26Mhz, so the option should be set to 1 Modprobe the module is useless if the module is already loaded during boot, you have to change the value in /etc/modprobe.d/esp8089.conf and then reboot. Also please provide the full dmesg log in a spoiler section, few lines don't help at all. Link to post Share on other sites More sharing options...
Hoangtnt Nguyen 0 Posted April 25 Share Posted April 25 1 minute ago, jock said: From the photo you posted, it looks to me that the crystal is 26Mhz, so the option should be set to 1 Modprobe the module is useless if the module is already loaded during boot, you have to change the value in /etc/modprobe.d/esp8089.conf and then reboot. Also please provide the full dmesg log in a spoiler section, few lines don't help at all. i changed value in /etc/modprobe.d/esp8089.conf to 1 then reboot but nothing change [ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #23 SMP Sun Apr 25 08:23:48 UTC 2021 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: Generic RK322x TV Box board [ 0.000000] cma: Reserved 16 MiB at 0x9f000000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 253952 [ 0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000 [ 0.000000] Normal zone: 2304 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 253952 pages, LIFO batch:31 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344 [ 0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 251648 [ 0.000000] Kernel command line: earlyprintk root=UUID=c0c5bb98-92be-493c-877d-d3be49b2c66f console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4 consoleblank=0 loglevel=1 ubootpart=4c420d14-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 963660K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 35764K reserved, 16384K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xb0000000 - 0xf0000000 (1024 MB) pkmap : 0xafe00000 - 0xb0000000 ( 2 MB) modules : 0xaf000000 - 0xafe00000 ( 14 MB) .text : 0xb0008000 - 0xb0c97c6c (12864 kB) .init : 0xb10b0000 - 0xb117a000 ( 808 kB) .data : 0xb117a000 - 0xb125fe94 ( 920 kB) .bss : 0xb1261000 - 0xb1391f14 (1220 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000024] Switching to timer-based delay loop, resolution 41ns [ 0.001893] Console: colour dummy device 80x30 [ 0.002082] console [tty1] enabled [ 0.002113] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.002134] pid_max: default: 32768 minimum: 301 [ 0.002288] Security Framework initialized [ 0.002304] Yama: becoming mindful. [ 0.002393] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002410] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.003453] Initializing cgroup subsys io [ 0.003496] Initializing cgroup subsys memory [ 0.003548] Initializing cgroup subsys devices [ 0.003571] Initializing cgroup subsys freezer [ 0.003592] Initializing cgroup subsys net_cls [ 0.003705] Initializing cgroup subsys perf_event [ 0.003731] Initializing cgroup subsys net_prio [ 0.003775] Initializing cgroup subsys pids [ 0.003865] CPU: Testing write buffer coherency: ok [ 0.003929] ftrace: allocating 41892 entries in 123 pages [ 0.087980] /cpus/cpu@f00 missing clock-frequency property [ 0.088024] /cpus/cpu@f01 missing clock-frequency property [ 0.088045] /cpus/cpu@f02 missing clock-frequency property [ 0.088065] /cpus/cpu@f03 missing clock-frequency property [ 0.088079] CPU0: update cpu_capacity 430 [ 0.088091] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00 [ 0.088202] Setting up static identity map for 0x60008280 - 0x600082d8 [ 0.100466] CPU1: update cpu_capacity 430 [ 0.100477] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01 [ 0.110440] CPU2: update cpu_capacity 430 [ 0.110449] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02 [ 0.120491] CPU3: update cpu_capacity 430 [ 0.120500] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03 [ 0.120672] Brought up 4 CPUs [ 0.120717] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.120726] CPU: All CPU(s) started in SVC mode. [ 0.122500] devtmpfs: initialized [ 0.143263] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.143992] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.144043] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.145687] xor: measuring software checksum speed [ 0.184045] arm4regs : 1011.000 MB/sec [ 0.224148] 8regs : 705.000 MB/sec [ 0.264253] 32regs : 684.000 MB/sec [ 0.304356] neon : 1018.000 MB/sec [ 0.304367] xor: using function: neon (1018.000 MB/sec) [ 0.304417] pinctrl core: initialized pinctrl subsystem [ 0.306289] NET: Registered protocol family 16 [ 0.309098] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.320569] cpuidle: using governor ladder [ 0.332579] cpuidle: using governor menu [ 0.349827] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0 [ 0.350001] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1 [ 0.350158] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2 [ 0.350337] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3 [ 0.356937] console [pstore-1] enabled [ 0.356951] pstore: Registered ramoops as persistent store backend [ 0.356963] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0 [ 0.360370] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.360395] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.360661] sip_firmware_init: set rockchip sip version v2 failed [ 0.457778] raid6: int32x1 gen() 133 MB/s [ 0.525797] raid6: int32x1 xor() 131 MB/s [ 0.593997] raid6: int32x2 gen() 166 MB/s [ 0.662225] raid6: int32x2 xor() 137 MB/s [ 0.730397] raid6: int32x4 gen() 163 MB/s [ 0.798504] raid6: int32x4 xor() 136 MB/s [ 0.866808] raid6: int32x8 gen() 166 MB/s [ 0.935058] raid6: int32x8 xor() 113 MB/s [ 1.003198] raid6: neonx1 gen() 382 MB/s [ 1.071310] raid6: neonx1 xor() 290 MB/s [ 1.139545] raid6: neonx2 gen() 519 MB/s [ 1.207675] raid6: neonx2 xor() 376 MB/s [ 1.275945] raid6: neonx4 gen() 581 MB/s [ 1.344109] raid6: neonx4 xor() 400 MB/s [ 1.412389] raid6: neonx8 gen() 559 MB/s [ 1.480570] raid6: neonx8 xor() 391 MB/s [ 1.480583] raid6: using algorithm neonx4 gen() 581 MB/s [ 1.480593] raid6: .... xor() 400 MB/s, rmw enabled [ 1.480604] raid6: using intx1 recovery algorithm [ 1.481795] rockchip-pm rockchip-suspend: not set wakeup-config [ 1.481822] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 1.482226] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]' [ 1.482798] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]' [ 1.483550] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0) [ 1.484232] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0) [ 1.484887] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' [ 1.485857] iommu: Adding device 20020000.vpu-service to group 0 [ 1.485977] iommu: Adding device 20030000.rkvdec to group 1 [ 1.486095] iommu: Adding device 20050000.vop to group 2 [ 1.486194] iommu: Adding device 20070000.iep to group 3 [ 1.486816] rk_iommu 20020800.iommu: can't get sclk [ 1.487574] rk_iommu 20030480.iommu: can't get sclk [ 1.487871] rk_iommu 20053f00.iommu: can't get sclk [ 1.488033] rk_iommu 20070800.iommu: can't get aclk [ 1.488052] rk_iommu 20070800.iommu: can't get hclk [ 1.488070] rk_iommu 20070800.iommu: can't get sclk [ 1.489072] SCSI subsystem initialized [ 1.489547] usbcore: registered new interface driver usbfs [ 1.489652] usbcore: registered new interface driver hub [ 1.489797] usbcore: registered new device driver usb [ 1.490035] media: Linux media interface: v0.10 [ 1.490140] Linux video capture interface: v2.00 [ 1.490412] pps_core: LinuxPPS API ver. 1 registered [ 1.490429] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.490475] PTP clock support registered [ 1.492742] Advanced Linux Sound Architecture Driver Initialized. [ 1.493870] Bluetooth: Core ver 2.21 [ 1.493956] NET: Registered protocol family 31 [ 1.493972] Bluetooth: HCI device and connection manager initialized [ 1.493998] Bluetooth: HCI socket layer initialized [ 1.494016] Bluetooth: L2CAP socket layer initialized [ 1.494079] Bluetooth: SCO socket layer initialized [ 1.495075] NetLabel: Initializing [ 1.495102] NetLabel: domain hash size = 128 [ 1.495112] NetLabel: protocols = UNLABELED CIPSOv4 [ 1.495200] NetLabel: unlabeled traffic allowed by default [ 1.496813] clocksource: Switched to clocksource arch_sys_counter [ 1.601561] NET: Registered protocol family 2 [ 1.602614] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 1.602742] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) [ 1.603100] TCP: Hash tables configured (established 8192 bind 8192) [ 1.603216] UDP hash table entries: 512 (order: 2, 24576 bytes) [ 1.603286] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) [ 1.603686] NET: Registered protocol family 1 [ 1.604580] RPC: Registered named UNIX socket transport module. [ 1.604613] RPC: Registered udp transport module. [ 1.604625] RPC: Registered tcp transport module. [ 1.604635] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.605139] Trying to unpack rootfs image as initramfs... [ 1.944881] Freeing initrd memory: 4568K [ 1.946065] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 1.949437] Initialise system trusted keyring [ 1.963958] VFS: Disk quotas dquot_6.6.0 [ 1.964300] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.967330] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.971126] NFS: Registering the id_resolver key type [ 1.971221] Key type id_resolver registered [ 1.971234] Key type id_legacy registered [ 1.971273] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.971395] ntfs: driver 2.1.32 [Flags: R/W]. [ 1.972396] JFS: nTxBlock = 7692, nTxLock = 61538 [ 1.985467] SGI XFS with security attributes, no debug enabled [ 1.995264] NET: Registered protocol family 38 [ 1.995328] Key type asymmetric registered [ 1.995351] Asymmetric key parser 'x509' registered [ 1.995803] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.996273] io scheduler noop registered [ 1.996307] io scheduler deadline registered [ 1.996410] io scheduler cfq registered (default) [ 2.000275] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator [ 2.006119] rk-vcodec 20020000.vpu-service: no regulator for vcodec [ 2.006728] rk-vcodec 20020000.vpu-service: probe device [ 2.007245] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled [ 2.008821] rk-vcodec 20020000.vpu-service: could not find power_model node [ 2.008861] rk-vcodec 20020000.vpu-service: init success [ 2.009291] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry [ 2.013864] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330 [ 2.013899] dma-pl330 110f0000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 2.015172] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 2.015694] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable [ 2.015715] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup [ 2.015734] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]' [ 2.015750] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]' [ 2.015764] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup [ 2.015780] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed [ 2.016544] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable [ 2.016570] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup [ 2.016587] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]' [ 2.016602] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]' [ 2.016616] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup [ 2.016631] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed [ 2.018034] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 2.019006] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A [ 2.019878] console [ttyS2] enabled [ 2.022010] [drm] Initialized drm 1.1.0 20060810 [ 2.024634] [drm] Rockchip DRM driver version: v1.0.1 [ 2.025040] rockchip-drm display-subsystem: devfreq is not set [ 2.025920] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0) [ 2.026406] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports [ 2.026439] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.026567] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy) [ 2.028078] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808) [ 2.028112] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.028123] [drm] No driver support for vblank timestamp query. [ 2.028296] rockchip-drm display-subsystem: failed to parse display resources [ 2.028377] rockchip-drm display-subsystem: No connectors reported connected with modes [ 2.028490] [drm] Cannot find any crtc or sizes - going 1024x768 [ 2.051860] Console: switching to colour frame buffer device 128x48 [ 2.067342] rockchip-drm display-subsystem: fb0: frame buffer device [ 2.081910] Registered IR keymap rc-cec [ 2.082189] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0 [ 2.082877] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0 [ 2.085460] brd: module loaded [ 2.098328] loop: module loaded [ 2.098421] lkdtm: No crash points registered, enable through debugfs [ 2.101332] libphy: Fixed MDIO Bus: probed [ 2.101371] tun: Universal TUN/TAP device driver, 1.6 [ 2.101384] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 2.101797] CAN device driver interface [ 2.103458] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output). [ 2.103494] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30). [ 2.103511] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10). [ 2.103560] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes). [ 2.103740] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed [ 2.108828] rk_gmac-dwmac 30200000.ethernet: init for RMII [ 2.144886] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 2.144906] Ring mode enabled [ 2.144918] DMA HW capability register supported [ 2.144929] Normal descriptors [ 2.144942] RX Checksum Offload Engine supported (type 2) [ 2.144951] TX Checksum insertion supported [ 2.144960] Wake-Up On Lan supported [ 2.145067] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 9e:82:a9:62:b7:35 [ 2.145082] eth%d: device MAC address 9e:82:a9:62:b7:35 [ 2.145093] Enable RX Mitigation via HW Watchdog Timer [ 2.145320] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0) [ 2.621710] libphy: stmmac: probed [ 2.621749] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active [ 2.621765] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01) [ 2.621778] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02) [ 2.621791] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03) [ 2.621804] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04) [ 2.621816] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05) [ 2.621829] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06) [ 2.621842] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07) [ 2.621855] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08) [ 2.621867] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09) [ 2.621880] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a) [ 2.621893] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b) [ 2.621906] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c) [ 2.621919] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d) [ 2.621932] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e) [ 2.621945] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f) [ 2.621957] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10) [ 2.621971] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11) [ 2.621984] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12) [ 2.621996] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13) [ 2.622010] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14) [ 2.622022] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15) [ 2.622035] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16) [ 2.622048] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17) [ 2.622061] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18) [ 2.622074] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19) [ 2.622086] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a) [ 2.622099] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b) [ 2.622112] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c) [ 2.622125] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d) [ 2.622137] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e) [ 2.622149] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f) [ 2.623762] PPP generic driver version 2.4.2 [ 2.624299] Atmel at76x USB Wireless LAN Driver 0.17 loading [ 2.624470] usbcore: registered new interface driver at76c50x-usb [ 2.624619] usbcore: registered new interface driver rtl8187 [ 2.624832] usbcore: registered new interface driver rndis_wlan [ 2.624962] usbcore: registered new interface driver zd1201 [ 2.625483] usbcore: registered new interface driver rt2800usb [ 2.625639] Rockchip WiFi SYS interface (V1.00) ... [ 2.625717] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 2.625818] usbcore: registered new interface driver pegasus [ 2.625907] usbcore: registered new interface driver rtl8150 [ 2.625993] usbcore: registered new interface driver r8152 [ 2.626095] usbcore: registered new interface driver asix [ 2.626179] usbcore: registered new interface driver ax88179_178a [ 2.626261] usbcore: registered new interface driver cdc_ether [ 2.626343] usbcore: registered new interface driver dm9601 [ 2.626460] usbcore: registered new interface driver smsc75xx [ 2.626571] usbcore: registered new interface driver smsc95xx [ 2.626656] usbcore: registered new interface driver net1080 [ 2.626741] usbcore: registered new interface driver rndis_host [ 2.626853] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 2.627007] usbcore: registered new interface driver cdc_ncm [ 2.627095] usbcore: registered new interface driver cdc_mbim [ 2.627694] 30040000.usb supply vusb_d not found, using dummy regulator [ 2.627853] 30040000.usb supply vusb_a not found, using dummy regulator [ 2.641365] dwc2 30040000.usb: DWC OTG Controller [ 2.641428] dwc2 30040000.usb: new USB bus registered, assigned bus number 1 [ 2.641499] dwc2 30040000.usb: irq 48, io mem 0x30040000 [ 2.641911] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.641932] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.641948] usb usb1: Product: DWC OTG Controller [ 2.641962] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg [ 2.641977] usb usb1: SerialNumber: 30040000.usb [ 2.643184] hub 1-0:1.0: USB hub found [ 2.643276] hub 1-0:1.0: 1 port detected [ 2.645134] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.645170] ehci-platform: EHCI generic platform driver [ 2.647842] ehci-platform 30080000.usb: EHCI Host Controller [ 2.648315] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2 [ 2.648711] ehci-platform 30080000.usb: irq 49, io mem 0x30080000 [ 2.660777] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00 [ 2.661122] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.661143] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.661159] usb usb2: Product: EHCI Host Controller [ 2.661173] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd [ 2.661187] usb usb2: SerialNumber: 30080000.usb [ 2.662324] hub 2-0:1.0: USB hub found [ 2.662419] hub 2-0:1.0: 1 port detected [ 2.665479] ehci-platform 300c0000.usb: EHCI Host Controller [ 2.665976] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3 [ 2.666334] ehci-platform 300c0000.usb: irq 51, io mem 0x300c0000 [ 2.676785] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00 [ 2.677123] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.677143] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.677158] usb usb3: Product: EHCI Host Controller [ 2.677172] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd [ 2.677186] usb usb3: SerialNumber: 300c0000.usb [ 2.678323] hub 3-0:1.0: USB hub found [ 2.678405] hub 3-0:1.0: 1 port detected [ 2.681444] ehci-platform 30100000.usb: EHCI Host Controller [ 2.681899] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4 [ 2.682269] ehci-platform 30100000.usb: irq 53, io mem 0x30100000 [ 2.692787] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00 [ 2.693155] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.693176] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.693191] usb usb4: Product: EHCI Host Controller [ 2.693205] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd [ 2.693219] usb usb4: SerialNumber: 30100000.usb [ 2.694323] hub 4-0:1.0: USB hub found [ 2.694408] hub 4-0:1.0: 1 port detected [ 2.695296] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.695354] ohci-platform: OHCI generic platform driver [ 2.695870] ohci-platform 300a0000.usb: Generic Platform OHCI controller [ 2.696354] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5 [ 2.696693] ohci-platform 300a0000.usb: irq 50, io mem 0x300a0000 [ 2.757066] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.757093] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.757108] usb usb5: Product: Generic Platform OHCI controller [ 2.757123] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd [ 2.757137] usb usb5: SerialNumber: 300a0000.usb [ 2.758288] hub 5-0:1.0: USB hub found [ 2.758376] hub 5-0:1.0: 1 port detected [ 2.759323] ohci-platform 300e0000.usb: Generic Platform OHCI controller [ 2.759782] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6 [ 2.760138] ohci-platform 300e0000.usb: irq 52, io mem 0x300e0000 [ 2.817056] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.817085] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.817101] usb usb6: Product: Generic Platform OHCI controller [ 2.817115] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd [ 2.817129] usb usb6: SerialNumber: 300e0000.usb [ 2.818230] hub 6-0:1.0: USB hub found [ 2.818309] hub 6-0:1.0: 1 port detected [ 2.819243] ohci-platform 30120000.usb: Generic Platform OHCI controller [ 2.819700] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7 [ 2.820037] ohci-platform 30120000.usb: irq 54, io mem 0x30120000 [ 2.877106] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.877137] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.877153] usb usb7: Product: Generic Platform OHCI controller [ 2.877167] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd [ 2.877181] usb usb7: SerialNumber: 30120000.usb [ 2.878347] hub 7-0:1.0: USB hub found [ 2.878458] hub 7-0:1.0: 1 port detected [ 2.879520] usbcore: registered new interface driver cdc_acm [ 2.879540] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 2.879657] usbcore: registered new interface driver cdc_wdm [ 2.879964] usbcore: registered new interface driver usb-storage [ 2.880147] usbcore: registered new interface driver usbserial [ 2.880230] usbcore: registered new interface driver usbserial_generic [ 2.880297] usbserial: USB Serial support registered for generic [ 2.880432] usbcore: registered new interface driver keyspan [ 2.880499] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 2.880559] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 2.880618] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 2.880677] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 2.880909] usbcore: registered new interface driver option [ 2.880985] usbserial: USB Serial support registered for GSM modem (1-port) [ 2.881692] usbcore: registered new interface driver oti6858 [ 2.881761] usbserial: USB Serial support registered for oti6858 [ 2.881865] usbcore: registered new interface driver qcserial [ 2.881928] usbserial: USB Serial support registered for Qualcomm USB modem [ 2.882114] usbcore: registered new interface driver sierra [ 2.882177] usbserial: USB Serial support registered for Sierra USB modem [ 2.883981] usbcore: registered new interface driver iforce [ 2.884160] usbcore: registered new interface driver xpad [ 2.884484] usbcore: registered new interface driver usbtouchscreen [ 2.885910] i2c /dev entries driver [ 2.887969] IR NEC protocol handler initialized [ 2.888000] IR RC5(x/sz) protocol handler initialized [ 2.888018] IR RC6 protocol handler initialized [ 2.888035] IR JVC protocol handler initialized [ 2.888053] IR Sony protocol handler initialized [ 2.888071] IR SANYO protocol handler initialized [ 2.888088] IR Sharp protocol handler initialized [ 2.888106] IR MCE Keyboard/mouse protocol handler initialized [ 2.888123] IR XMP protocol handler initialized [ 2.890052] usbcore: registered new interface driver uvcvideo [ 2.890074] USB Video Class driver (1.1.1) [ 2.892155] Boot mode: normal [ 2.893602] rockchip-thermal 11150000.tsadc: tsadc is probed successfully! [ 2.895591] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com [ 2.896036] Bluetooth: Virtual HCI driver ver 1.5 [ 2.896366] Bluetooth: HCI UART driver ver 2.3 [ 2.896387] Bluetooth: HCI UART protocol H4 registered [ 2.896399] Bluetooth: HCI UART protocol LL registered [ 2.896410] Bluetooth: HCI UART protocol ATH3K registered [ 2.896421] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 2.896625] Bluetooth: HCI UART protocol BCM registered [ 2.896897] usbcore: registered new interface driver bfusb [ 2.897060] usbcore: registered new interface driver btusb [ 2.897084] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 2.897813] cpu cpu0: leakage=5 [ 2.897850] cpu cpu0: leakage-volt-sel=0 [ 2.898086] cpu cpu0: Failed to get pvtm [ 2.899705] cpu cpu0: avs=0 [ 2.899799] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 [ 2.899826] cpu cpu0: failed to read out thermal zone (-22) [ 2.900596] cpu cpu0: failed to find power_model node [ 2.901593] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset [ 2.901621] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup [ 2.901647] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0) [ 2.902071] Synopsys Designware Multimedia Card Interface Driver [ 2.902768] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode. [ 2.902936] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller. [ 2.902959] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a [ 2.903041] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo [ 2.903110] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found [ 2.903122] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found [ 2.903148] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd [ 2.903158] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup [ 2.903189] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0) [ 2.903236] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations [ 2.903249] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO [ 2.903262] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp [ 2.903271] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup [ 2.903282] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]' [ 2.903292] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]' [ 2.903301] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup [ 2.903312] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed [ 2.916137] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.929166] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized [ 2.929659] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available [ 2.929763] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode. [ 2.929888] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller. [ 2.929910] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a [ 2.929979] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo [ 2.930047] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found [ 2.930059] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found [ 2.930080] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp [ 2.930091] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup [ 2.930105] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]' [ 2.930115] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]' [ 2.930125] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup [ 2.930136] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed [ 2.930226] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq [ 2.941797] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2) [ 2.954484] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized [ 2.955107] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode. [ 2.955253] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller. [ 2.955274] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a [ 2.955347] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo [ 2.955410] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found [ 2.955421] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found [ 2.955443] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp [ 2.955454] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup [ 2.955467] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]' [ 2.955478] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]' [ 2.955487] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup [ 2.955498] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed [ 2.968292] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3) [ 2.981048] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized [ 2.982154] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/auxiliary[0]' - status (0) [ 2.982993] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0) [ 2.983794] ledtrig-cpu: registered to indicate activity on CPUs [ 2.984078] hidraw: raw HID events driver (C) Jiri Kosina [ 2.985465] usbcore: registered new interface driver usbhid [ 2.985499] usbhid: USB HID core driver [ 2.986541] ashmem: initialized [ 2.992103] rknandbase v1.2 2018-05-08 [ 2.993034] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2) [ 2.995513] usbcore: registered new interface driver snd-usb-audio [ 2.995806] usbcore: registered new interface driver snd-ua101 [ 2.996095] usbcore: registered new interface driver snd-usb-caiaq [ 2.996349] usbcore: registered new interface driver snd-usb-6fire [ 2.996856] usbcore: registered new interface driver snd-usb-hiface [ 2.997298] usbcore: registered new interface driver snd-bcd2000 [ 2.997520] usbcore: registered new interface driver snd_usb_pod [ 2.997724] usbcore: registered new interface driver snd_usb_podhd [ 2.997929] usbcore: registered new interface driver snd_usb_toneport [ 2.998153] usbcore: registered new interface driver snd_usb_variax [ 3.012353] u32 classifier [ 3.012397] input device check on [ 3.012462] Actions configured [ 3.012620] Netfilter messages via NETLINK v0.30. [ 3.012885] nfnl_acct: registering with nfnetlink. [ 3.013124] nf_conntrack version 0.5.0 (15384 buckets, 61536 max) [ 3.014102] Initializing XFRM netlink socket [ 3.014991] NET: Registered protocol family 10 [ 3.016855] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.017303] sit: IPv6 over IPv4 tunneling driver [ 3.018271] NET: Registered protocol family 17 [ 3.018328] NET: Registered protocol family 15 [ 3.018404] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 3.018449] Bridge firewalling registered [ 3.018462] can: controller area network core (rev 20120528 abi 9) [ 3.018536] NET: Registered protocol family 29 [ 3.018558] can: raw protocol (rev 20120528) [ 3.018572] can: broadcast manager protocol (rev 20120528 t) [ 3.018593] can: netlink gateway (rev 20130117) max_hops=1 [ 3.019112] Bluetooth: RFCOMM TTY layer initialized [ 3.019158] Bluetooth: RFCOMM socket layer initialized [ 3.019209] Bluetooth: RFCOMM ver 1.11 [ 3.019244] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.019264] Bluetooth: HIDP socket layer initialized [ 3.019479] 8021q: 802.1Q VLAN Support v1.8 [ 3.019538] lib80211: common routines for IEEE802.11 drivers [ 3.019551] lib80211_crypt: registered algorithm 'NULL' [ 3.019568] lib80211_crypt: registered algorithm 'WEP' [ 3.019583] lib80211_crypt: registered algorithm 'CCMP' [ 3.019598] lib80211_crypt: registered algorithm 'TKIP' [ 3.019612] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.019964] [BT_RFKILL]: Enter rfkill_rk_init [ 3.020426] Key type dns_resolver registered [ 3.021076] flash vendor_init_thread! [ 3.021104] flash vendor storage:20170308 ret = -1 [ 3.021192] Error: Driver 'sc031gs' is already registered, aborting... [ 3.022363] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0) [ 3.023097] Registering SWP/SWPB emulation handler [ 3.024538] mmc_host mmc2: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 3.025297] mmc2: new DDR MMC card at address 0001 [ 3.025774] registered taskstats version 1 [ 3.025813] Loading compiled-in X.509 certificates [ 3.026500] mmcblk2: mmc2:0001 Biwin 7.20 GiB [ 3.027177] mmcblk2boot0: mmc2:0001 Biwin partition 1 4.00 MiB [ 3.027815] mmcblk2boot1: mmc2:0001 Biwin partition 2 4.00 MiB [ 3.028463] mmcblk2rpmb: mmc2:0001 Biwin partition 3 4.00 MiB [ 3.029443] Btrfs loaded [ 3.030645] mmcblk2: p1 [ 3.030942] rga2: Driver loaded successfully ver:4.01 [ 3.031195] rga2: Module initialized. [ 3.031244] pvtm list NULL [ 3.032558] rk-vcodec 20030000.rkvdec: leakage=4 [ 3.032598] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0 [ 3.032833] rk-vcodec 20030000.rkvdec: Failed to get pvtm [ 3.033273] rk-vcodec 20030000.rkvdec: avs=0 [ 3.033570] rk-vcodec 20030000.rkvdec: probe device [ 3.034091] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled [ 3.036319] rk-vcodec 20030000.rkvdec: init success [ 3.037533] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' [ 3.037561] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' [ 3.038586] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok [ 3.041644] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' [ 3.041674] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' [ 3.042689] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok [ 3.045073] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-keys/reset[0]' - status (0) [ 3.045186] gpio-121 (reset): gpiod_set_debounce: missing set() or set_debounce() operations [ 3.045591] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 3.046102] hctosys: unable to open rtc device (rtc0) [ 3.048468] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3) [ 3.059380] ALSA device list: [ 3.059420] #0: DW-I2S-HDMI [ 3.059429] #1: SPDIF [ 3.060445] Freeing unused kernel memory: 808K [ 3.060459] This architecture does not have kernel memory protection. [ 3.104985] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5) [ 3.532162] vendor storage:20190527 ret = 0 [ 4.514402] random: nonblocking pool is initialized [ 4.650269] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null) [ 5.112970] systemd[1]: System time before build time, advancing clock. [ 5.125708] systemd[1]: Inserted module 'autofs4' [ 5.134968] ip_tables: (C) 2000-2006 Netfilter Core Team [ 5.144137] cgroup: cgroup2: unknown option "nsdelegate" [ 5.157642] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 5.159243] systemd[1]: Detected architecture arm. [ 5.175037] systemd[1]: Set hostname to <rk322x-box>. [ 5.385575] ttyS2 - failed to request DMA, use interrupt mode [ 5.516565] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 5.516620] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 5.904647] systemd[1]: Reached target Remote File Systems. [ 5.906303] systemd[1]: Reached target System Time Synchronized. [ 5.911215] systemd[1]: Created slice system-getty.slice. [ 5.912483] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 5.913436] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 5.914323] systemd[1]: Listening on fsck to fsckd communication Socket. [ 5.916841] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 5.918671] systemd[1]: Listening on Journal Socket. [ 5.931144] systemd[1]: Starting Restore / save the current clock... [ 5.932346] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 5.940975] systemd[1]: Starting Remount Root and Kernel File Systems... [ 5.952633] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 5.954564] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 5.956640] systemd[1]: Listening on udev Kernel Socket. [ 5.974328] systemd[1]: Starting Load Kernel Modules... [ 5.977314] systemd[1]: Listening on Syslog Socket. [ 5.990095] systemd[1]: Mounting Kernel Debug File System... [ 5.997603] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 6.015049] systemd[1]: Starting Set the console keyboard layout... [ 6.017698] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 6.024555] systemd[1]: Reached target Local Encrypted Volumes. [ 6.026128] systemd[1]: Reached target Paths. [ 6.031648] systemd[1]: Created slice User and Session Slice. [ 6.033091] systemd[1]: Reached target Slices. [ 6.035127] systemd[1]: Condition check resulted in Huge Pages File System being skipped. [ 6.037085] systemd[1]: Listening on udev Control Socket. [ 6.044466] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro [ 6.049067] systemd[1]: Starting udev Coldplug all Devices... [ 6.061414] systemd[1]: Starting Nameserver information manager... [ 6.064557] systemd[1]: Listening on Journal Socket (/dev/log). [ 6.066017] systemd[1]: Reached target Swap. [ 6.079617] systemd[1]: Mounting POSIX Message Queue File System... [ 6.116188] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 6.127033] systemd[1]: Started Restore / save the current clock. [ 6.148913] systemd[1]: Started Remount Root and Kernel File Systems. [ 6.154963] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 6.160059] systemd[1]: Started Load Kernel Modules. [ 6.162090] systemd[1]: Mounted Kernel Debug File System. [ 6.173934] systemd[1]: Mounted POSIX Message Queue File System. [ 6.192059] systemd[1]: Starting Apply Kernel Variables... [ 6.210283] systemd[1]: Mounting Kernel Configuration File System... [ 6.225353] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 6.247196] systemd[1]: Starting Create System Users... [ 6.269426] systemd[1]: Starting Load/Save Random Seed... [ 6.290854] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 6.316453] systemd[1]: Started Nameserver information manager. [ 6.327262] systemd[1]: Started Apply Kernel Variables. [ 6.334394] systemd[1]: Mounted Kernel Configuration File System. [ 6.387986] systemd[1]: Started Load/Save Random Seed. [ 6.399155] systemd[1]: Started Create System Users. [ 6.414972] systemd[1]: Starting Create Static Device Nodes in /dev... [ 6.538478] systemd[1]: Started Create Static Device Nodes in /dev. [ 6.554013] systemd[1]: Starting udev Kernel Device Manager... [ 6.575295] systemd[1]: Started Set the console keyboard layout. [ 6.581462] systemd[1]: Reached target Local File Systems (Pre). [ 6.596175] systemd[1]: Mounting /tmp... [ 6.622308] systemd[1]: Mounted /tmp. [ 6.628510] systemd[1]: Reached target Local File Systems. [ 6.641678] systemd[1]: Starting Set console font and keymap... [ 6.658256] systemd[1]: Starting Armbian ZRAM config... [ 6.664173] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 6.691470] systemd[1]: Started Set console font and keymap. [ 6.761914] systemd[1]: Started udev Kernel Device Manager. [ 6.916258] systemd[1]: Started udev Coldplug all Devices. [ 6.951291] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 7.009844] systemd[1]: Started Helper to synchronize boot up for ifupdown. [ 7.044019] systemd[1]: Starting Raise network interfaces... [ 7.106934] zram: Added device: zram0 [ 7.108560] zram: Added device: zram1 [ 7.111538] zram: Added device: zram2 [ 7.284281] systemd[1]: Found device /dev/ttyS2. [ 7.291162] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en [ 7.291176] rk3228-codec 12010000.codec: using device tree for GPIO lookup [ 7.291190] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]' [ 7.291247] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0) [ 7.291347] rk3228-codec 12010000.codec: spk_depop_time use default value. [ 7.292998] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [ 7.293099] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [ 7.337521] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '08:21:05', on 'Apr 25 2021'. [ 7.337974] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13 [ 7.338006] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000 [ 7.338020] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000 [ 7.338033] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000 [ 7.338044] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000 [ 7.338055] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000 [ 7.338065] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000 [ 7.338077] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000 [ 7.338089] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020 [ 7.338102] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021 [ 7.338112] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022 [ 7.338123] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021 [ 7.338135] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022 [ 7.338146] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021 [ 7.338162] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali. [ 7.338739] mali-utgard 20001000.gpu: leakage=4 [ 7.338804] mali-utgard 20001000.gpu: leakage-volt-sel=0 [ 7.339032] mali-utgard 20001000.gpu: Failed to get pvtm [ 7.339668] mali-utgard 20001000.gpu: avs=0 [ 7.340260] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 [ 7.354159] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok [ 7.378221] Mali: Mali device driver loaded [ 7.437102] devfreq 20001000.gpu: Couldn't update frequency transition information. [ 7.643596] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null) [ 7.643655] gpio_ir_recv ir-receiver: using device tree for GPIO lookup [ 7.643725] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0) [ 7.643894] Registered IR keymap rc-rktvbox [ 7.644271] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1 [ 7.645826] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input2 [ 7.668208] zram0: detected capacity change from 0 to 504537088 [ 7.839088] Adding 492708k swap on /dev/zram0. Priority:5 extents:1 across:492708k SS [ 8.151187] systemd[1]: Started Raise network interfaces. [ 8.199517] cfg80211: World regulatory domain updated: [ 8.199586] cfg80211: DFS Master region: unset [ 8.199605] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [ 8.199638] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ 8.199666] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 8.199696] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [ 8.199723] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 8.199757] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [ 8.199775] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [ 8.199801] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [ 8.199826] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [ 8.399643] zram1: detected capacity change from 0 to 52428800 [ 8.497950] systemd[1]: Started Armbian ZRAM config. [ 8.660152] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 8.672089] systemd[1]: Starting Armbian memory supported logging... [ 8.677322] systemd[1]: Reached target Sound Card. [ 8.814356] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 12.817421] systemd[1]: Started Armbian memory supported logging. [ 12.829714] systemd[1]: Starting Journal Service... [ 13.279270] systemd[1]: Started Journal Service. [ 13.369066] systemd-journald[541]: Received request to flush runtime journal from PID 1 [ 16.096440] nr_pdflush_threads exported in /proc is scheduled for removal [ 16.881189] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 18.945345] rk_gmac-dwmac 30200000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx sorry for bothering you but because i'm just noob . thx Link to post Share on other sites More sharing options...
jock 211 Posted April 25 Author Share Posted April 25 @Hoangtnt Nguyen Hmm, the problem is that the wifi chip is not detected at all, in fact you can see that the mmc1 device is probed four times and then the kernel gives up. Are you sure you removed the wlan-esp8089 overlay from /boot/armbianEnv.txt? I need to check better the device tree because I may have missed something, I'll do that in a few hours! Link to post Share on other sites More sharing options...
Hoangtnt Nguyen 0 Posted April 25 Share Posted April 25 14 minutes ago, jock said: @Hoangtnt Nguyen Hmm, the problem is that the wifi chip is not detected at all, in fact you can see that the mmc1 device is probed four times and then the kernel gives up. Are you sure you removed the wlan-esp8089 overlay from /boot/armbianEnv.txt? I need to check better the device tree because I may have missed something, I'll do that in a few hours! yes, i removed wlan-esp8089 overlay from /boot/armbianEnv.txt. I notice when it boot 1st when i type rk322x-config. it show: Wifi Device: not available Link to post Share on other sites More sharing options...
jock 211 Posted April 26 Author Share Posted April 26 On 4/25/2021 at 4:00 PM, Hoangtnt Nguyen said: yes, i removed wlan-esp8089 overlay from /boot/armbianEnv.txt. I notice when it boot 1st when i type rk322x-config. it show: Wifi Device: not available I took a look into the original dtb and the configuration looks the same to me. There is something I can't spot that turns off the wifi. Also the wifi device: not available on first reboot means that there is really something missing Link to post Share on other sites More sharing options...
RaptorSDS 17 Posted April 30 Share Posted April 30 Hallo team first thanks for the good work i am now a long time active with balbes150 on the Amlogic S805/S812 forum side , but last week i bought two Rockchip box for small amount . i am very happy for this good support on this box my box Leelbox Q2 Pro RK3229 2gb ddr3 / 16GB emmc , Ap6255 but i have two problems first is that both trigger of the rk322x-config tool ->emmc and nand are stop the initramfs script to boot the box i always get stuck that the uuid of emmc is missing or incorrect , without the emmc or nand config the box works great !!!! secound the high idle temperature of the box , i have long time a M8S Box with a Amlogic S812 and the idle temp is around 30-35 celcius , this rockchip box are idle at around 55-60 celcius , some load and the box hit the 75 celcius and shut down ( also the other rockchip box with rk3328 idle around 55 celcius on android) is that normal or do i have a faulty chip ? both problem on latest buster minimal 20.04 kernel 5.10 and bionic desktop 20.04 kernel 5.10 rom i dont use the lagecy kernel 4.4 rom because i didnt not get wifi running Link to post Share on other sites More sharing options...
jock 211 Posted May 1 Author Share Posted May 1 Hi @Hoangtnt Nguyen, I searched through the dtb for some faults but everything looks correct to me. The fact that rk322x-config does not show you the wifi device means that it is not properly powered, so the kernel is not even able to discover it. Looking at the original android log you provided I stumbled upon something suspicious, so I ask you to replace /boot/dtb/rk322x-box.dtb with this one: rk322x-box.dtb and then reboot Link to post Share on other sites More sharing options...
jock 211 Posted May 1 Author Share Posted May 1 18 hours ago, RaptorSDS said: first is that both trigger of the rk322x-config tool ->emmc and nand are stop the initramfs script to boot the box i always get stuck that the uuid of emmc is missing or incorrect , without the emmc or nand config the box works great !!!! rk322x-config proposes three choices, the first one (eMMC or NAND) is the most compatible but does not enable any optional speed optimization; The second choice (eMMC) enables DDR mode for eMMC, but not all boards are able to drive the eMMC this way. The third choice (NAND) disables the eMMC at all and enables the NAND gpio pins configuration for use with NAND only. 18 hours ago, RaptorSDS said: secound the high idle temperature of the box , i have long time a M8S Box with a Amlogic S812 and the idle temp is around 30-35 celcius , this rockchip box are idle at around 55-60 celcius , some load and the box hit the 75 celcius and shut down ( also the other rockchip box with rk3328 idle around 55 celcius on android) is that normal or do i have a faulty chip ? The "high" idle temperature is quite normal; many things influence it, from the manufacturing process to the position of the thermistor on the SoC die, to the board dissipation capacity and ambient temperature. Yours is pretty in the average (a board I have here is idling at 52°C with 20°C ambient temperature). it is not an absolute temperature and cannot be related among various chips even from the same manufacturer. The abnormal thing is that it shut downs at 75°C: the shutdown temperature is configured in the dtb to 120°C and there are various trip points in the middle (the first one is at 90°C) that reduce the maximum frequency to prevent overheating. Boxes I have here, but also some from other people reporting around, can go above 90°C with no particular issues. The original dtb of your box may be helpful to understand if your board has particular settings or gpio configurations. Photos of the board are always welcome! Link to post Share on other sites More sharing options...
Hoangtnt Nguyen 0 Posted May 1 Share Posted May 1 1 hour ago, jock said: Hi @Hoangtnt Nguyen, I searched through the dtb for some faults but everything looks correct to me. The fact that rk322x-config does not show you the wifi device means that it is not properly powered, so the kernel is not even able to discover it. Looking at the original android log you provided I stumbled upon something suspicious, so I ask you to replace /boot/dtb/rk322x-box.dtb with this one: rk322x-box.dtb and then reboot i tried but still failed. thx. i think just use with wifi dongle and ethernet is ok. Link to post Share on other sites More sharing options...
RaptorSDS 17 Posted May 1 Share Posted May 1 Zitat The original dtb of your box may be helpful to understand if your board has particular settings or gpio configurations i did not want back to android , the box works great with linux . is there a way to extract dtb from backup file ? Zitat Photos of the board are always welcome! i attached the pic of the board Spoiler Spoiler Link to post Share on other sites More sharing options...
fabiobassa 50 Posted May 1 Share Posted May 1 @RaptorSDS Quote i did not want back to android , the box works great with linux . is there a way to extract dtb from backup file if you have original rom image you can use some tools ( if you scroll and read the whole 3ad those tools have been published several times ) to extract the dtb . Not sure i those tools work even on a backup img but I guess yes ! It seems to me it is a board sometimes called SARDINE , I have on but different wifi, all is working on mine About temperature .. put finger CLOSE to heatsink or even touch it .. if you are not burned and feel the temperature quite confortable, well is just an error in temperature reading. Consider that temperature higher of 60 celsius are unconfortable for persons Link to post Share on other sites More sharing options...
RaptorSDS 17 Posted May 1 Share Posted May 1 @fabiobassa thanks for fast answer , i know some tools from amlogic when android still at internal memoryy ->read boot partition , extract file , convert dtb to dts . but i have no instruction for read boot partition from a image ( and no i have no orginal image leelbox-tech.com is only a placeholder) , i have also no clou how read that from backup file my infrared thermo meter say also around 45-50 degree , also my finger say it get warm Link to post Share on other sites More sharing options...
fabiobassa 50 Posted May 1 Share Posted May 1 I know that tools for amlogic too and those mentioned in this 3ad aren't so different. Basically they " open" the img by searching some " headers" in the bin and extract the righ information. Scroll back to search for these tools on this forum and give them a try on the backup you have . I guess something will come out About 45/50 is ok then the strike points for temperature protection are already been mentioned by @jock Link to post Share on other sites More sharing options...
RaptorSDS 17 Posted May 1 Share Posted May 1 i found the leelbox blog with a image for my box attached dtb and dts , and dts with child -@ rk-kernel.dts rk-kernel.dtb rk-kernel2.dts Link to post Share on other sites More sharing options...
jock 211 Posted May 2 Author Share Posted May 2 @Hoangtnt Nguyen I'm sorry it did not work, I really can't try anything more to help without having the board on my desk @RaptorSDSI took a quick look at the dts you provided, it looks quite usual to me, the shutdown temperature is set to 120°C in the original dts too. It looks very strange the board shuts down at 75°C, even because that temperature is not set anywhere in the dtb or in the linux system. You board (T95N_RK3229) is similar to another one we encountered in the past from @Maker39 (see this post https://forum.armbian.com/profile/14842-maker39/), but he never told about temperature issues so far. Link to post Share on other sites More sharing options...
Ngo Thang 1 Posted May 6 Share Posted May 6 I buy a TV Box Mxq pro 4k 5G, Soc Rk3229. I chose model 4GB Ram and 32GB Rom (emmc). First time I turn on it and run Android OS, I install Cpu-z tool in this Android and check, it's correct that it has 4GB Ram and 32GB Rom But after I install Armbian OS in emmc, and login in Armbian screen, it shows system has only 1GB Ram and 8GB Rom. So why are they (ram and rom) are difference like that? Tks and Best regards Link to post Share on other sites More sharing options...
Alex83 1 Posted May 6 Share Posted May 6 I guess you got an usual rk3229 box with fake Android OS. 😉 Link to post Share on other sites More sharing options...
jock 211 Posted May 7 Author Share Posted May 7 @Ngo Thang I agree with @Alex83, you probably got a device with fake specs, even because the rk3229 in not able to use more than 2gb of RAM due to its hardware capabilities. Link to post Share on other sites More sharing options...
Ngo Thang 1 Posted May 7 Share Posted May 7 You may be right. I bought it via shop online from China. But why I check in CPU-Z app in its original Android firmware, CPU-Z still shows 4G/32G ? Link to post Share on other sites More sharing options...
jock 211 Posted May 7 Author Share Posted May 7 6 minutes ago, Ngo Thang said: You may be right. I bought it via shop online from China. But why I check in CPU-Z app in its original Android firmware, CPU-Z still shows 4G/32G ? You should ask to the online shop from China, I have my own personal opinion but I like the keep it for mine. Link to post Share on other sites More sharing options...
SteeMan 108 Posted May 7 Share Posted May 7 13 minutes ago, Ngo Thang said: But why I check in CPU-Z app in its original Android firmware, CPU-Z still shows 4G/32G ? Sometimes disreputable manufacturers will modify the kernel in the android firmware to provide false information. (easy way to cut costs by not actually including the memory/storage advertized). 3 Link to post Share on other sites More sharing options...
fabiobassa 50 Posted May 7 Share Posted May 7 one of the best approach ever is open the box and see the ddr chip name and google for it. In the hope that our proucer didn't re-brand even the chip Link to post Share on other sites More sharing options...
ArkhanLK 2 Posted May 8 Share Posted May 8 Quote This is only for Ubuntu Focal Legacy 4.4.194 Kernel builds. <thanks> Hey @jock, let me start by saying I love you. Thank you so much for this. I know it is not only you, but still: huge thanks!</thanks> <purpose> Now, I am VERY new to linux. I have been reading and researching for the past month about setting up Linux on a TV Box and I'm typing this from a rk322x (possibly 3228a) thanks to the efforts of you amazing guys. My purpose is to have it as an "usable" desktop. I know, probably hard, too slow and all that. I get it. But I am managing. I can watch YouTube at 360p, browse the web... It's a work in progress and I think I'm going places. I am running Debian Legacy with iceWM (well, it's not well configured but it's something to start!)</purpose> <questions> But I am struggling with videos. I tried using Focal Legacy but it is not worth it, it's just too slow. Is there a way to use your media framework on Debian legacy? I tried but it doesn't install. Also, if it is not too much to ask, is there a trusty tutorial on overclocking the CPU/GPU/RAM? It may not be worth it nor make a significant difference, but then again it might! </questions><tip> I even might have something to add: running the rk322x-config is a MUST to enable the ssv6051p. However, regardless of what I choose, it will always force me back to a "UUID=xxx does not exist Dropping to a shell" boot error (and I tried a shit ton of combinations...). Yet, I figured out that if I edit "/boot/armbianEnv.txt" right after running rk322x-config and delete whatever "overlays" line is there, I "fix" it: Wi-Fi works and I can boot normally! Not a single clue as to why it happens, but hope this can help someone...</tip> Link to post Share on other sites More sharing options...
