micropad Posted July 9, 2015 Posted July 9, 2015 Hi, How i can find information for set the fex file, kernel, etc. etc. for use the spi in userspace? i don't see in /dev any spidevx.0 device
Igor Posted July 12, 2015 Posted July 12, 2015 The spipart in fex should look like this: [spi0_para] spi_used = 1 spi_cs_bitmap = 3 spi_cs0 = port:PI10<2><default><default><default> spi_cs1 = port:PI14<2><default><default><default> spi_sclk = port:PI11<2><default><default><default> spi_mosi = port:PI12<2><default><default><default> spi_miso = port:PI13<2><default><default><default> [spi1_para] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PA00<3><default><default><default> spi_cs1 = port:PA04<3><default><default><default> spi_sclk = port:PA01<3><default><default><default> spi_mosi = port:PA02<3><default><default><default> spi_miso = port:PA03<3><default><default><default> [spi2_para] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PC19<3><default><default><default> spi_cs1 = port:PB13<2><default><default><default> spi_sclk = port:PC20<3><default><default><default> spi_mosi = port:PC21<3><default><default><default> spi_miso = port:PC22<3><default><default><default> [spi3_para] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PA05<3><default><default><default> spi_cs1 = port:PA09<3><default><default><default> spi_sclk = port:PA06<3><default><default><default> spi_mosi = port:PA07<3><default><default><default> spi_miso = port:PA08<3><default><default><default> [spi_devices] spi_dev_num = 1 [spi_board0] modalias = "spidev" max_speed_hz = 12000000 bus_num = 0 chip_select = 0 mode = 3 full_duplex = 0 manual_cs = 0 [spi_board1] modalias = "spidev" max_speed_hz = 12000000 bus_num = 0 chip_select = 1 mode = 3 full_duplex = 0 manual_cs = 0 Driver is built into kernel, so you only need to alter fex file. Further you might need to check / alter port numbers - they are not exactly from Micro configuration.
ChrisB Posted July 23, 2015 Posted July 23, 2015 I have attached the corect micro.fex for Olinuxino A20 Micro. On UEXT1: /dev/spidev2.0 /dev/ttyS1 /dev/i2c_2 On UEXT2: /dev/spidev1.0 /dev/ttyS2 /dev/i2c_1 micro.fex.tar.gz 1
