RudiO Posted January 22, 2020 Posted January 22, 2020 (edited) Rock Pi S @%^ Mb Ram no WiFi not starting with Armbian. Got this as output Spoiler Resetting CPU ... INFO: PSCI Power Domain Map: INFO: Domain Node : Level 2, parent_node -1, State ON (0x0) INFO: Domain Node : Level 1, parent_node 0, State ON (0x0) INFO: Domain Node : Level 0, parent_node 0, State ON (0x0) INFO: Domain Node : Level 0, parent_node 0, State ON (0x0) INFO: CPU Node : MPID 0x0, parent_node 1, State ON (0x0) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2) INFO: CPU Node : MPID 0xffffffffffffffff, parent_node 1, State OFF (0x2) DDR Version V1.26 REGFB: 0x00000032, 0x00000032 In 589MHz DDR3 Col=10 Bank=8 Row=14 Size=256MB msch:1 Returning to boot ROM... Boot1 Release Time: Mar 12 2019 11:59:07, version: 1.12 chip_id:330800,0 ChipType = 0x13, 35791008 DPLL = 1300 MHz sfc_ver 3 sfc nor id: ff ff ff sfc_nand_init DPLL = 1300 MHz sfc_ver 3 sfc_nand id: ff ff ff DPLL = 1300 MHz NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz mmc2:cmd1,20 NeedKHz=200KHz,clock=12000KHz emmc reinit NeedKHz=200KHz,clock=12000KHz mmc2:cmd1,20 NeedKHz=200KHz,clock=12000KHz emmc reinit NeedKHz=200KHz,clock=12000KHz mmc2:cmd1,20 NeedKHz=200KHz,clock=12000KHz SdmmcInit=2 1 NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz NeedKHz=200KHz,clock=12000KHz mmc0:cmd5,20 DPLL = 1300 MHz NeedKHz=24000KHz,clock=650000KHz DPLL = 1300 MHz NeedKHz=40000KHz,clock=650000KHz SdmmcInit=0 0 BootCapSize=0 UserCapSize=15193MB FwPartOffset=2000 , 0 StorageInit ok = 35754844 SecureMode = 0 Secure read PBA: 0x4 Secure read PBA: 0x404 Secure read PBA: 0x804 Secure read PBA: 0xc04 Secure read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x330b9c0 signature is wrong recovery gpt... GPT 0x330b9c0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x600000, size=0x9d4bc RunBL31 0x10000 INFO: Preloader serial: 0 NOTICE: BL31: v1.3(release):3a579d3 NOTICE: BL31: Built : 09:09:17, Jan 29 2019 INFO: Lastlog: last=0x100000, realtime=0x102000, size=0x2000 INFO: ARM GICv2 driver initialized INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe b INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x600000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Jan 20 2020 - 04:19:49 +0100) Model: Radxa ROCK Pi S PreSerial: 0 DRAM: 254 MiB Sysmem: init Relocation Offset is: 0f919000 vdd-core init 1044000 uV MMC: dwmmc@ff480000: 0, dwmmc@ff490000: 1 Using default environment In: serial@ff0c0000 Out: serial@ff0c0000 Err: serial@ff0c0000 Model: Radxa ROCK Pi S Card did not respond to voltage select! mmc_init: -95, time 9 Card did not respond to voltage select! mmc_init: -95, time 9 do_rkimg_test: dev_desc is NULL! Bootdev(atags): mmc 0 MMC0: Legacy, 50Mhz PartType: DOS rockchip_get_boot_mode: Could not found misc partition boot mode: None CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 1300000 KHz vpll0 1179647 KHz vpll1 903167 KHz aclk_bus 185714 KHz hclk_bus 100000 KHz pclk_bus 100000 KHz aclk_peri 185714 KHz hclk_peri 100000 KHz pclk_peri 100000 KHz hclk_audio 98303 KHz pclk_audio 98303 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 Could not find misc partition ANDROID: reboot reason: "(none)" load_android_image: Can't find part: boot Android image load failed Android boot failed, error -1. do_boot_rockchip: Could not find mmcsda1 part Card did not respond to voltage select! mmc_init: -95, time 9 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2940 bytes read in 21 ms (136.7 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0 125 bytes read in 17 ms (6.8 KiB/s) "Synchronous Abort" handler, esr 0x96000010 * Relocate offset = 000000000f919000 * ELR(PC) = 000000000065ca30 * LR = 000000000065afc4 * SP = 000000000f508020 * ESR_EL2 = 0000000096000010 EC[31:26] == 100101, Exception from a Data abort, from current exception level IL[25] == 1, 32-bit instruction trapped * DAIF = 00000000000003c0 D[9] == 1, DBG masked A[8] == 1, ABORT masked I[7] == 1, IRQ masked F[6] == 1, FIQ masked * SPSR_EL2 = 0000000020000349 D[9] == 1, DBG masked A[8] == 1, ABORT masked I[7] == 0, IRQ not masked F[6] == 1, FIQ masked M[4] == 0, Exception taken from AArch64 M[3:0] == 1001, EL2h * SCTLR_EL2 = 0000000030c51835 I[12] == 1, Icaches enabled C[2] == 1, Dcache enabled M[0] == 1, MMU enabled * HCR_EL2 = 000000000800003a * VBAR_EL2 = 000000000ff19800 * TTBR0_EL2 = 000000000fff0000 x0 : 000000000f5312a0 x1 : 0000000019000000 x2 : 000000000000007d x3 : 0000000000000000 x4 : 000000000000007d x5 : 0000000000000000 x6 : 0000000000000000 x7 : 0000000000000000 x8 : 0000000000000044 x9 : 0000000000000008 x10: 000000000f5312b0 x11: 000000000f5291b0 x12: 0000000000000000 x13: 0000000000000200 x14: 000000000f50a1ec x15: 00000000ffffffff x16: 00000000e65c9a5b x17: 00000000a3c01010 x18: 000000000f510d28 x19: 0000000000000000 x20: 000000000000007d x21: 000000000f5312a0 x22: 000000000ff9fb98 x23: 0000000000000000 x24: 0000000000000000 x25: 000000000000000a x26: 0000000000000001 x27: 0000000000000000 x28: 0000000000000000 x29: 000000000f508200 SP: 0f508020: 00000000 00000000 00000000 00000000 0f508030: 00000000 00000000 0ff920ff 00000000 0f508040: 00000000 00000000 00000000 00000000 0f508050: 0ff92146 00000000 0ff9216c 00000000 0f508060: 0ff921b9 00000000 0ff92206 00000000 0f508070: 0ff92246 00000000 0ff92286 00000000 0f508080: 0ff922c3 00000000 00000000 00000000 0f508090: 00000000 00000000 0ff92300 00000000 0f5080a0: 0f508200 00000000 0ff19a0c 00000000 0f5080b0: 00000000 00000000 0ff891de 00000000 0f5080c0: 0fff0000 00000000 0800003a 00000000 0f5080d0: 30c51835 00000000 0f508020 00000000 0f5080e0: 20000349 00000000 0ff19800 00000000 0f5080f0: 000003c0 00000000 96000010 00000000 0f508100: 0ff75a30 00000000 0f5312a0 00000000 0f508110: 19000000 00000000 0000007d 00000000 Call trace: PC: [< 0065ca30 >] LR: [< 0065afc4 >] Stack: [< 0065ca30 >] [< 0060ecb0 >] [< 0061d604 >] [< 00611a7c >] [< 00611c1c >] [< 0061137c >] [< 00611930 >] [< 0061170c >] [< 00611c1c >] [< 00611340 >] [< 0061cb0c >] [< 006063fc >] [< 00606504 >] [< 0061d604 >] [< 00611a7c >] [< 00611c1c >] [< 0061137c >] [< 00611930 >] [< 00611c1c >] [< 00611340 >] [< 0061cba8 >] [< 0061d604 >] [< 00611a7c >] [< 0061170c >] [< 0061170c >] [< 00611c1c >] [< 00611340 >] [< 0061cba8 >] [< 0061d604 >] [< 00611a7c >] [< 0061170c >] [< 00611c1c >] [< 00611340 >] [< 0061cba8 >] [< 0061d604 >] [< 00611a7c >] [< 0061170c >] [< 0061170c >] [< 00611c1c >] [< 00611340 >] [< 0061cba8 >] [< 0061d604 >] [< 00611a7c >] [< 0061170c >] [< 00611c1c >] [< 00611340 >] [< 0061cba8 >] [< 0061d604 >] [< 00611a7c >] [< 00611c1c >] [< 00611340 >] [< 0061cba8 >] [< 0061d604 >] [< 00611a7c >] [< 00611c1c >] [< 0061137c >] [< 00611930 >] [< 0061170c >] [< 00611c1c >] [< 00611340 >] [< 0061cba8 >] [< 0061d604 >] [< 00611a7c >] [< 00611c1c >] [< 00611340 >] [< 0061cb0c >] [< 0060fd48 >] [< 00612810 >] [< 00650680 >] [< 00612a20 >] [< 0060193c >] Copy above stack info to a file(eg. dump.txt), and execute command in your U-Boot project: ./scripts/stacktrace.sh dump.txt Edited January 22, 2020 by TRS-80 add spoiler and code tags
TRS-80 Posted January 22, 2020 Posted January 22, 2020 (edited) NOTE: I originally found this thread in RK3399 subforum, but according to https://wiki.radxa.com/RockpiS this device is RK3308 based, so I moved it and added that tag to the title. @RudiO, Welcome to the forums! Because this board is currently unsupported, I moved it to P2P section, because I don't think you have access to Development area (and I'm not sure it is really yet under any kind of development anyway). Good luck! Edited January 22, 2020 by TRS-80 add welcome and move things around
piter75 Posted January 24, 2020 Posted January 24, 2020 On 1/22/2020 at 3:37 PM, RudiO said: Rock Pi S @%^ Mb Ram no WiFi not starting with Armbian I never tested it with 256M as I only have 512M units. It should be fixed in this branch: https://github.com/armbian/build/tree/rockpis-fix-256m-boot. If you can build the image yourself then try it - otherwise it should make it into Armbian 20.02 release. 1
RudiO Posted January 28, 2020 Author Posted January 28, 2020 Thanks Piter it works with the changes. I made a minimal image. 1
