FrikoAnPulento Posted January 23, 2020 Posted January 23, 2020 Hello, I'm new to Armbian. I've recently tried Olimex's image for a13 (https://github.com/OLIMEX/build). I saw (and read) on armbian's guide that there's the possibility to customize images build. I need to add two specific drivers (smsc95xx for my eth interface and uvcvideo for my webcam) to kernel. I can find their sources in build\cache\sources\linux-mainline\linux-5.0.y\drivers, but they are not listed in various "modules.order" files (ok, so that's why my devices doesn't get loaded). If I want to add these modules to kernel the only way is to create a patch for "modules.order" in userpatches\kernel (if it's the right directory), or there's a cleaner way (like a .config file) to add them?
Werner Posted January 23, 2020 Posted January 23, 2020 Simply run the build script and if asked to adjust the kernel config before building hit yes and then simply select or deselect the modules you want to include in your kernel package. Please note that this is a fork of the Armbian build script so if something does not work as it is intended to you should blame them, not Armbian
FrikoAnPulento Posted January 23, 2020 Author Posted January 23, 2020 hello @Werner, first of all thank you for your reply. 3 hours ago, Werner said: if something does not work as it is intended to you should blame them Yes, I'm aware of it. I was writing here to get help, not to blame anyone (as I said, I'm new to armbian). 3 hours ago, Werner said: Simply run the build script and if asked to adjust the kernel config before building I check out compile.sh script in build directory and understand how it works. As you said, I see that I need to enable some options in linux-sunxi-default.config, and that the best way to do it is by creating a new file in userpatches called linux-sunxi-default.config. (probably would be also better creating a patch in userpatches/kernel/sunxi-next-olinuxino, but I've never had time to test it now...). So, I've copied old config/kernel/linux-sunxi-default.config to userpatches/linux-sunxi-default.config and changed: #CONFIG_USB_NET_SMSC95XX is not set to CONFIG_USB_NET_SMSC95XX=m for adding usb/eth driver and #CONFIG_USB_VIDEO_CLASS is not set to CONFIG_USB_VIDEO_CLASS=m for adding webcam drivers. Hope this will help other newbies
Werner Posted January 23, 2020 Posted January 23, 2020 Well I actually pointed you in this direction so you do not have to edit config files manually since the build script hands you over to the menuconfig containing the designated config which should be linux-sunxi-xxx . Anyway nice that you could figure it out your way.
