Максим Круземан Posted January 25, 2020 Posted January 25, 2020 I bought a HK1 Max (~20$) especially for make a small linux home server for my projects. Why Rockchip? I found rockchip repo on github with ffmpeg and gstreamer libs for hardware encoding. It's very important (but not critical necessary) for me. So... HK1 Max 2/16 (2.4Ghz + 5Ghz + BT4.0 wireless) Tech specs: CPU: RK3318 RAM: 2Gb DDR3L Samsung K4B2G0446D eMMC: 16Gb KLMAG2GE4A-A001 LAN: Rockchip (???) Wi-Fi + Bluetooth: HK6334Q (Not found information about it) 2.4Ghz + 5Ghz + BT On first run I dump some partitions from Android (This TV Box has root out of the box): dtb dtbo boot trust security uboot Trying to run Armbian: Extract dtb from my image and recompile it Use u-boot from this thread - https://forum.armbian.com/topic/8082-armbian-for-tv-box-rk3328 (thanks @hexdump) My trust.img Armbian_19.11.5_Arm-64_eoan_dev_5.5.0-rc7_20200124.img And... It hangs on Kernel boot Then I try dtb from @hexdump(thanks again :)) And it's boot normaly (hdmi work, usb2.0, usb3.0 work, ethernet detected) But Wireless and Bluetooth doesnt work. Tryed to add wireless-wlan block to hexdump dtb and recompile - wireless not work. Tryed to replace all similar blocks in hexdump dtb to blocks from my dtb - It hangs on Kernel boot. Can anyone help my with dtb. Reveal hidden contents boot.imgFetching info... trust.imgFetching info... dtb.imgFetching info... uboot.imgFetching info... HK1MAX.dtbFetching info... HK1MAX.dtsFetching info... HK1MAX_recompiled.dtbFetching info...
Максим Круземан Posted January 25, 2020 Author Posted January 25, 2020 Now trying to compile gstreamer from official repo rockchip.
soljah Posted February 13, 2020 Posted February 13, 2020 I have the same TVbox, but i have some problem with booting armbian. I burn SD card with armbian image then dd of trust.img and uboot.img but uboot stopped at DRAM point U-Boot 2019.10-armbian (Nov 29 2019 - 09:50:19 +0300) Model: Rockchip RK3328 EVB DRAM: Tell me please how you boot armbian more details 1
hexdump Posted February 13, 2020 Posted February 13, 2020 @soljah - you might give this u-boot a try: and in case that works you'll then most probably need this one too: best is to read a bit around those posts in that thread too to get some other good hints best wishes and good luck - hexdump
soljah Posted February 14, 2020 Posted February 14, 2020 @hexdump I have been try all of this dd your uboot-rk3318.img and add rk3318-h96max.dtb file. I will try one more time. What is the effect of which linux image is recorded on SD? For chose correct dtb file need only to change name in "/extlinux/extlinux.conf"?
hexdump Posted February 14, 2020 Posted February 14, 2020 please keep in mind that my dtb file was for a mainline kernel and not for the 4.4 rockchip kernel used in some images ...
lucky_noob Posted April 24, 2020 Posted April 24, 2020 On 1/25/2020 at 7:31 AM, Максим Круземан said: I bought a HK1 Max (~20$) especially for make a small linux home server for my projects. Why Rockchip? I found rockchip repo on github with ffmpeg and gstreamer libs for hardware encoding. It's very important (but not critical necessary) for me. So... HK1 Max 2/16 (2.4Ghz + 5Ghz + BT4.0 wireless) Tech specs: CPU: RK3318 RAM: 2Gb DDR3L Samsung K4B2G0446D eMMC: 16Gb KLMAG2GE4A-A001 LAN: Rockchip (???) Wi-Fi + Bluetooth: HK6334Q (Not found information about it) 2.4Ghz + 5Ghz + BT On first run I dump some partitions from Android (This TV Box has root out of the box): dtb dtbo boot trust security uboot Trying to run Armbian: Extract dtb from my image and recompile it Use u-boot from this thread - https://forum.armbian.com/topic/8082-armbian-for-tv-box-rk3328 (thanks @hexdump) My trust.img Armbian_19.11.5_Arm-64_eoan_dev_5.5.0-rc7_20200124.img And... It hangs on Kernel boot Then I try dtb from @hexdump(thanks again :)) And it's boot normaly (hdmi work, usb2.0, usb3.0 work, ethernet detected) But Wireless and Bluetooth doesnt work. Tryed to add wireless-wlan block to hexdump dtb and recompile - wireless not work. Tryed to replace all similar blocks in hexdump dtb to blocks from my dtb - It hangs on Kernel boot. Can anyone help my with dtb. Reveal hidden contents boot.img 32 MB · 103 downloads trust.img 4 MB · 92 downloads dtb.img 4 MB · 81 downloads uboot.img 4 MB · 95 downloads HK1MAX.dtb 13.3 MB · 84 downloads HK1MAX.dts 81.65 kB · 82 downloads HK1MAX_recompiled.dtbFetching info... 72.28 kB · 88 downloadg Expand Halo, How to dump How do I backup and dump partitions on Android?
Werner Posted April 25, 2020 Posted April 25, 2020 On 4/24/2020 at 11:11 PM, lucky_noob said: Halo, How to dump How do I backup and dump partitions on Android? Expand https://lmgtfy.com/?q=How+to+dump+How+do+I+backup+and+dump+partitions+on+Android%3F+
wasanka Posted June 17, 2020 Posted June 17, 2020 Hi, I bought HH96 Max with 4Gb Ram and 32GB eMMC and followed the steps but failed. Below is the serial out and it stops at "INFO: boot cpu mask: 1" I have attached the photos of the board. Can someone please help with steps I should follow and the files I should use? Quote ID:0xFFF In DDR3 333MHz Bus Width=32 Col=11 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=4096MB ddrconfig:3 OUT Boot1 Release Time: Sep 7 2018 15:49:55, version: 2.49 ChipType = 0x11, 194 mmc2:cmd19,100 SdmmcInit=2 0 BootCapSize=1000 UserCapSize=29820MB FwPartOffset=2000 , 1000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=15340MB FwPartOffset=2000 , 0 StorageInit ok = 205459 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 GPT 0x337a9e0 signature is wrong LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa0268 RunBL31 0x10000 NOTICE: BL31: v1.3(debug):0eba775 NOTICE: BL31: Built : 12:11:32, Nov 23 2018 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 Expand Attaching files are disabled. Plaese use this link to view the photos https://photos.google.com/share/AF1QipNX2PxRpfdeoyi13zyg7pFVwOSInKGUAeSB3iQap_5acywSYcfC3n0Zs3EC_DLvmA?key=d1lkS0V2RlRlMzhTTm00MUJnd3VMclNNT1JNaDlB
