I have a problem with my Banana Pi Pro... I installed Armbian bionic from this site…
https://www.armbian.com/banana-pi-pro/
In addition to other programs that I have installed and which all work, I would like to install piVCCU.
I try this according to the instructions from this page ...
https://github.com/alexreinert/piVCCU/blob/master/docs/setup/armbian.md
Everything works until I get to Step 5.
At the end of the installation comes the message...
DKMS: add completed.
Error! Your kernel headers for kernel 5.4.14-sunxi cannot be found.
Please install the linux-headers-5.4.14-sunxi package,
or use the --kernelsourcedir option to tell DKMS where it's located
My question is, where can I get the missing kernel headers or what can I do to ensure that the installation runs without errors?
Since I am a newbie, I would be happy about detailed instructions.
Thank you.
Headers will be updated to (compatible and installable from armbian-config) version once we are finish with this (around 2 weeks):
This is amateur service and we already made this experience very simple. Headers can install from armbian-config or the way piVCCU suggessts ... if everything is ok.
There are also some issues with kernel headers
https://github.com/armbian/build/pull/1754
https://github.com/armbian/build/issues/1751
which means also experienced people have issues. What you can try is to build from sources and enable header compilation ... https://docs.armbian.com/Developer-Guide_Build-Options/ its a little bit more work, but doable.
