Hi there.
I want to use a push button on a GPIO to shutdown O Pi Zero safely.  Though the acpid way runs fine on an O Pi One, I wonder if there is a way to make it work on a O Pi Zero. Please direct me if its documented somewhere already. Thanks
Beware that even if you trigger event from GPIO to execute "halt" command using a "gpio-key" node in DT, the OPiZero will still be connected to PSU since there is no PMIC to really turn off the power...
Yeah thats fine for me. Just want to implement that for safe shutdown as I would want to disconnect power after that. So is there simple way to implement that??
Sure !
Take this overlay source and save it as "gpio-keys.dts" :
/dts-v1/;
/plugin/;
   compatible = "allwinner,sun8i-h3";
   fragment@0 {
      target = <&pio>;
      __overlay__ {
         keypad_pins: keypad_pins {
            allwinner,pins = "PA10";
            allwinner,function = "gpio_in";
            allwinner,pull = <1>;
   fragment@1 {
      target-path = "/"; // "/soc";
      __overlay__ {
         mykeypad: mykeypad {
            compatible = "gpio-keys";
            #address-cells = <1>;
            #size-cells = <0>;
            pinctrl-names = "default";
            pinctrl-0 = <&keypad_pins>;
            status = "okay";
            button@10 {
               label = "GPIO KEY_POWEROFF";
               linux,code = <0x74>;
               gpios = <&pio 0 10 1>; // PA10, active_low
   __overrides__ {
      mykeypad =     <&mykeypad>,"status";
Compile it as an overlay DTBO using this command :
git-work/dtc/dtc -@ -I dts -O dtb -o /boot/dtb/overlay/sun8i-h3-gpio-keys.dtbo gpio-keys.dts
Then, add this overlay either in /boot/armbianEnv.txt with "overlays=gpio-keys" or by loading it dynamically using :
mkdir /sys/kernel/config/device-tree/overlays/gpiokeys
cat /boot/dtb/overlay/sun8i-h3-gpio-keys.dtbo > /sys/kernel/config/device-tree/overlays/gpiokeys/dtbo
As soon as you connect the PA10 pin to GND, it will trigger a "shutdown" ...
Great ! I would try that right away.
A small query though. Can another button be hooked similar to this for a simple reboot also?
By the way thanks a lot for this. You guys just rock.
I am sorry but I am really a noob. Do I need to install something for this purpose?? Because it says this
-bash: git-work/dtc/dtc: No such file or directory
The <0x74> is KEY_POWER, I've tried <0x198> which seem to be for KEY_RESTART, but it doesn't seem to work ... I will try to dig kernel sources to figure out ...
9 minutes ago, martinayotte said:
Right ! You need to install DT compiler from here : http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_armhf.deb
And do not provide this path "git-work/dtc/dtc" but simply "dtc -@ -I dts -O dtb -o /boot/dtb/overlay/sun8i-h3-gpio-keys.dtbo gpio-keys.dts" ...
After installing that and compiling, it gave a couple of warnings
/boot/dtb/overlay/sun8i-h3-gpio-keys.dtbo: Warning (unit_address_vs_reg): /fragment@1/__overlay__/mykeypad/button@10: node has a unit name, but no reg property
/boot/dtb/overlay/sun8i-h3-gpio-keys.dtbo: Warning (avoid_unnecessary_addr_size): /fragment@1/__overlay__/mykeypad: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
Is that okay
I short the PA10 pin to ground and its not shutting down.
I have installed wiring pi and by giving command
gpio readall
I can see that PA10 is an input and voltage is high(pullup).
But not shutting down. What could be the reason?
Strange ... Which kernel are you using ?
Did you loaded the overlay ?
If you try "evtest /dev/input/event0", what are you seeing while putting PA10 to GND ?
I did but it had asked for permission which I missed somehow. I mean I used sudo but it again said permission denied for half of the command.
Later used su command first and then gave loaded it easily.
Right ! I didn't mentioned it, loading overlay dynamically requires root privileges ...
1 hour ago, Aditya said:
Can you please take a look into the reboot button also.
I've look during more than an hour, it deosn't seems to be implemented ...
The only other way I would see is to run this python script and add a " os.system("reboot") " after the "button pressed" print :
#!/usr/bin/env python
"""Read button.
Make gpio input and enable pull-up resistor.
import os
import sys
import time
import logging
if not os.getegid() == 0:
    sys.exit('Script must be run as root')
from pyA20.gpio import gpio
from pyA20.gpio import connector
from pyA20.gpio import port
button = port.PA10
"""Init gpio module"""
gpio.init()
"""Set directions"""
gpio.setcfg(button, gpio.INPUT)
"""Enable pullup resistor"""
gpio.pullup(button, gpio.PULLUP)
#gpio.pullup(button, gpio.PULLDOWN)     # Optionally you can use pull-down resistor
try:
    while True:
        state = gpio.input(button)      # Read button state
#        print (state)
        if state == 0:
            print("button pressed")
            logging.info("button pressed")
        time.sleep(0.2)
except KeyboardInterrupt:
    print ("Goodbye.")
