ot8 Posted January 27, 2020 Posted January 27, 2020 After bootup I get # systemd-analyze Bootup is not yet finished. Please try again later. # systemctl list-jobs JOB UNIT TYPE STATE 142 systemd-update-utmp-runlevel.service start waiting 114 rk3399-bluetooth.service start running 1 multi-user.target start waiting If I stop rk3399-bluetooth.service everything completes and list-jobs is clean, but then bluetooth stops working. I've tried a few things in the rk3399-bluetooth unit file but so far I've not been able to find a way to make systemd happy and finish cleanly. By the way, in the service file it uses "--use_baudrate_for_downloade", typo and should be "--use_baudrate_for_download"
sergvpurik Posted January 30, 2020 Posted January 30, 2020 (edited) Hello. I've Radxa Rock Pi 4 SBC. I've tried several latest Armbian Buster images with 5.x kernel and never got bluetooth working. I've tested your propose on Armbian_20.02.0-rc1_Rockpi-4b_buster_current_5.4.14_desktop... On 1/27/2020 at 8:27 PM, ot8 said: By the way, in the service file it uses "--use_baudrate_for_downloade", typo and should be "--use_baudrate_for_download" Expand ... bluetooth doesn't work and I've got a flood in Rock Pi 4 syslog ... Jan 30 20:10:30 rockpi brcm_patchram_plus_rk3399[1089]: 01 03 0c 00 Jan 30 20:10:34 rockpi brcm_patchram_plus_rk3399[1089]: writing Jan 30 20:10:34 rockpi brcm_patchram_plus_rk3399[1089]: 01 03 0c 00 Jan 30 20:10:38 rockpi brcm_patchram_plus_rk3399[1089]: writing Jan 30 20:10:38 rockpi brcm_patchram_plus_rk3399[1089]: 01 03 0c 00 Jan 30 20:10:42 rockpi brcm_patchram_plus_rk3399[1089]: writing Jan 30 20:10:42 rockpi brcm_patchram_plus_rk3399[1089]: 01 03 0c 00 .... There're also interesting bluetooth related messages in Rock Pi 4 syslog: ... Jan 30 19:41:41 localhost systemd[1]: Starting Bluetooth Rockpi... ... Jan 30 19:41:50 localhost systemd[1]: Condition check resulted in Bluetooth service being skipped. Jan 30 19:41:50 localhost brcm_patchram_plus_rk3399[1089]: writing Jan 30 19:41:50 localhost brcm_patchram_plus_rk3399[1089]: 01 03 0c 00 Jan 30 19:41:54 localhost brcm_patchram_plus_rk3399[1089]: writing Jan 30 19:41:54 localhost brcm_patchram_plus_rk3399[1089]: 01 03 0c 00 ... Jan 30 19:45:10 localhost dbus-daemon[803]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.44' (uid=1000 pid=1830 comm="/usr/lib/chromium/chromium --disable-smooth-scroll") Jan 30 19:45:10 localhost systemd[1]: Condition check resulted in Bluetooth service being skipped. ... Edited January 30, 2020 by TRS-80 put in some code fences for clarity
piter75 Posted January 30, 2020 Posted January 30, 2020 On 1/30/2020 at 8:30 PM, sergvpurik said: ... bluetooth doesn't work and I've got a flood in Rock Pi 4 syslog Expand I didn't have time and enough interest in Bluetooth to pursue a solution but one thing I have noticed with 5.x kernels on all rk3399 boards I own is that Bluetooth's firmware is correctly patched after cold boot / power on but not after a reboot. 1
sergvpurik Posted January 31, 2020 Posted January 31, 2020 Looks like the typo "--use_baudrate_for_downloade" is used to skip this brcm_patchram_plus_rk3399 option. I've tried to use brcm_patchram_plus_rk3399 without "--use_baudrate_for_downloade". I did power OFF/ON. Jan 31 19:28:46 localhost systemd[1]: Starting Bluetooth Rockpi... ... Jan 31 19:28:46 localhost brcm_patchram_plus_rk3399[1126]: proc_resetwriting Jan 31 19:28:46 localhost brcm_patchram_plus_rk3399[1126]: 01 03 0c 00 Jan 31 19:28:46 localhost kernel: [ 86.277578] ttyS0 - failed to request DMA ... Jan 31 19:28:46 localhost brcm_patchram_plus_rk3399[1126]: received 7 Jan 31 19:28:46 localhost brcm_patchram_plus_rk3399[1126]: 04 0e 04 01 03 0c 00 Jan 31 19:28:46 localhost brcm_patchram_plus_rk3399[1126]: writing ... Here're many "writing" and "received X" messages mixed with HEX dumps. ... Jan 31 19:28:50 localhost brcm_patchram_plus_rk3399[1126]: Done setting baudrate Jan 31 19:28:50 localhost kernel: [ 90.111432] Bluetooth: Core ver 2.22 Jan 31 19:28:50 localhost kernel: [ 90.111479] NET: Registered protocol family 31 Jan 31 19:28:50 localhost kernel: [ 90.111481] Bluetooth: HCI device and connection manager initialized Jan 31 19:28:50 localhost kernel: [ 90.111491] Bluetooth: HCI socket layer initialized Jan 31 19:28:50 localhost kernel: [ 90.111495] Bluetooth: L2CAP socket layer initialized Jan 31 19:28:50 localhost kernel: [ 90.111503] Bluetooth: SCO socket layer initialized Jan 31 19:28:50 localhost brcm_patchram_plus_rk3399[1126]: Can't set hci protocol Jan 31 19:28:50 localhost kernel: [ 90.119645] Bluetooth: HCI UART driver ver 2.3 ... Jan 31 19:28:55 localhost systemd[1]: Starting Bluetooth service... Jan 31 19:28:55 localhost bluetoothd[1729]: Bluetooth daemon 5.50 Jan 31 19:28:55 localhost dbus-daemon[779]: [system] Successfully activated service 'org.bluez' Jan 31 19:28:55 localhost systemd[1]: Started Bluetooth service. Jan 31 19:28:55 localhost bluetoothd[1729]: Starting SDP server Jan 31 19:28:56 localhost bluetoothd[1729]: kernel lacks bnep-protocol support Jan 31 19:28:56 localhost bluetoothd[1729]: System does not support network plugin Jan 31 19:28:56 localhost bluetoothd[1729]: Bluetooth management interface 1.14 initialized Jan 31 19:28:56 localhost NetworkManager[806]: <info> [1580498936.0221] bluez: use BlueZ version 5 ... and no bluetooth. hciconfig doesn't show any device. I found there isn't any selected HCI protocol in /proc/config.gz. # # Bluetooth device drivers # # CONFIG_BT_HCIBTUSB is not set # CONFIG_BT_HCIBTSDIO is not set CONFIG_BT_HCIUART=m # CONFIG_BT_HCIUART_H4 is not set # CONFIG_BT_HCIUART_BCSP is not set # CONFIG_BT_HCIUART_ATH3K is not set # CONFIG_BT_HCIUART_INTEL is not set # CONFIG_BT_HCIUART_AG6XX is not set # CONFIG_BT_HCIBCM203X is not set # CONFIG_BT_HCIBPA10X is not set # CONFIG_BT_HCIBFUSB is not set # CONFIG_BT_HCIVHCI is not set # CONFIG_BT_MRVL is not set CONFIG_BT_MTKSDIO=m # end of Bluetooth device drivers It looks similar to Raspberry Pi bluetooth problem ( https://github.com/raspberrypi/linux/issues/2479 ). And the solution was enabling CONFIG_SERIAL_DEV_BUS=m, CONFIG_BT_HCIUART_SERDEV=y, CONFIG_BT_HCIUART_BCM=y options.
ot8 Posted February 3, 2020 Author Posted February 3, 2020 What I ended up doing for NanoPC T4 is disable the systemd service and in rc.local: /usr/bin/brcm_patchram_plus_rk3399 --enable_hci --no2bytes \ --use_baudrate_for_download --tosleep 200000 --baudrate 1500000 \ --enable_lpm --patchram /lib/firmware/brcm/BCM4345C5.hcd /dev/ttyS0 & > ... bluetooth doesn't work and I've got a flood in Rock Pi 4 syslog The --enable_lpm stops the flood and allows it to more-or-less complete. FWIW I haven't yet seen an Armbian 5.x kernel where both wifi and bluetooth actually worked on the T4, but I haven't tried 5.x since I started messing around with brcm_patchram so maybe ... 1
sergvpurik Posted February 5, 2020 Posted February 5, 2020 I've built Armbain (5.4.17-rockchip64) from sources with additing the next options CONFIG_BT_HCIUART_SERDEV=y, CONFIG_BT_HCIUART_H4=y, CONFIG_BT_HCIUART_BCM=y to linux-rockchip64-current.config. And bluetooth is working. brcm_patchram_plus_rk3399[1446]: Done setting baudrate Feb 3 20:28:32 localhost kernel: [ 99.787745] Bluetooth: Core ver 2.22 Feb 3 20:28:32 localhost kernel: [ 99.787784] NET: Registered protocol family 31 Feb 3 20:28:32 localhost kernel: [ 99.787787] Bluetooth: HCI device and connection manager initialized Feb 3 20:28:32 localhost kernel: [ 99.787797] Bluetooth: HCI socket layer initialized Feb 3 20:28:32 localhost kernel: [ 99.787802] Bluetooth: L2CAP socket layer initialized Feb 3 20:28:32 localhost kernel: [ 99.787809] Bluetooth: SCO socket layer initialized Feb 3 20:28:32 localhost kernel: [ 99.800667] Bluetooth: HCI UART driver ver 2.3 Feb 3 20:28:32 localhost kernel: [ 99.800672] Bluetooth: HCI UART protocol H4 registered Feb 3 20:28:32 localhost kernel: [ 99.800829] Bluetooth: HCI UART protocol Broadcom registered Feb 3 20:28:32 localhost brcm_patchram_plus_rk3399[1446]: Done setting line discpline Feb 3 20:28:32 localhost systemd[1]: Starting Load/Save RF Kill Switch Status... Feb 3 20:28:32 localhost systemd[1]: Starting Bluetooth service... Feb 3 20:28:32 localhost systemd[1]: Started Load/Save RF Kill Switch Status. rock@rockpi:~$ hciconfig hci0: Type: Primary Bus: UART BD Address: 43:45:C5:00:1F:AC ACL MTU: 1021:8 SCO MTU: 64:1 UP RUNNING RX bytes:1186 acl:0 sco:0 events:77 errors:0 TX bytes:3609 acl:0 sco:0 commands:71 errors:0 rock@rockpi:~$ sudo hcitool lescan LE Scan ... D8:2D:27:A6:53:45 (unknown) D8:2D:27:A6:53:45 Mi Smart Band 4 F8:D8:37:3D:17:75 (unknown) F8:D8:37:3D:17:75 Mi Smart Band 4 ... but only after a cold boot, as @piter75 said. Who knows what is a right way to make changes in Armbian sources to fix Linux kernel options for Rock Pi 4? I want to make pull request. 1
piter75 Posted February 5, 2020 Posted February 5, 2020 On 2/5/2020 at 7:33 PM, sergvpurik said: Who knows what is a right way to make changes in Armbian sources to fix Linux kernel options for Rock Pi 4? I want to make pull request. Expand I would add the mentioned options to kernel config, built the kernel, copied resulting ".config" file over "linux-rockchip64-current.config" and then commit it. It would be great to do the same with "dev" kernel (which is now 5.5.y in Armbian's master) in the same PR for feature parity 1
chwe Posted February 5, 2020 Posted February 5, 2020 On 2/5/2020 at 7:33 PM, sergvpurik said: Who knows what is a right way to make changes in Armbian sources to fix Linux kernel options for Rock Pi 4? Expand IMO the easiest way is ./compile.sh KERNEL_CONFIGURE=yes make your changes when menuconfig pops up and you get your new config in output/config after compilation. It's even named the way it should be.. 1
sergvpurik Posted February 10, 2020 Posted February 10, 2020 Thank for your advices. My PR has already been merged. https://github.com/armbian/build/commit/48bb7ca9aec095138805c06ebde6d9d0b71ad9a3 1
