S805 Tech's specs and latest Armbian version
Hi there,
I'm new to these boards and armbian.
I've checked the forums but i have some questions that can be also helpfull for other peoples.
1) hardware specs
My board (You can see there https://ibb.co/ZSbw62q) is a AM_MXQ_A 20150825 i can see on the board these chips:
- MAIN CPU => AMLOGIC S8005
- GPU => ????
- WIFI => REALTEK IC RTL8189ETV 802.11b/g/n 1T1R
- (S)DRAM => 2X HYNIX DDR3 H5TQ4G63AFR-PBC 4Gb x16 x1 1600 29nm FBGA96 √ (792MHz) √ (636MHz)
- STORAGE (NAND) => SANDISK MLC SDTNRGAMA-008GK 8GB 1 40bit /1024B 1ynm TSOP48 Note 1
Why ram is 1gb if there are 2x4gb on board?? Are also used for system as a storage?
Can't find GPU on this board is missing?
2) Armbian what's the best version/release for this board? The only one i've got working is Armbian_5.32_S805_Ubuntu_xenial_3.10.33_mate_20170821 (suggested by karkow in this thread at page 6). Maybe there's a latest version that run better/faster?
3) It's possible to install in NAND? I've read trought sites but cannot find a final word on this
Thanks a lot for any response and for the wonderfull works!
Rob
S805 == ARM Mali-450MP GPU
Forum search -> S805 ...
@NicoD ok so GPU is integrated in S805 :)
@NicoD
Yep what i have found is there but cannot really find where the latest image is...
btw thanks
  • Werner locked this topic
