jwhouwers Posted February 13, 2020 Share Posted February 13, 2020 Armbianmonitor: http://ix.io/2bFx Hello All, I'm trying to set-up MCP2515 on 8mhz on orange Pi one on SPI0 running recent installed Armbian 5.9 / Linux 3.4.113-sun8i can bus support orange pi zero i was reading trough above for pi Zero and trying get the unit up and running, but no luck till now, CAN unit is modifed, so 3v3 for mcp and 5v for can tranciever, connections: pin1 3v3 power on vcc for mcp2515 pin2 5v power for cantranciever pin6 gnd pin19/PC0(GPIO Orange PI) MOSI - (MCP2515<->CAN) SI pin21/PC1(GPIO Orange PI) MISO - (MCP2515<->CAN) SO pin23/PC2(GPIO Orange PI) CLK - (MCP2515<->CAN) SCK pin24/PC3(GPIO Orange PI) CS - (MCP2515<->CAN) CS pin29 PA7(GPIO Orange PI) INT - (MCP2515<->CAN) INT connected per i/o schematic from: Pi one GPIO overlay for mcp2515 in folder boot/user-overlay --> sun8i-h3-spi0-mcp2515.dtbo ArmbianEnv.txt verbosity=1 console=serial overlay_prefix=sun8i-h3 disp_mem_reserves=on extraargs=cma=96M rootdev=UUID=698619e7-7638-4282-b3c1-743acf73e189 rootfstype=ext4 overlays=spi-spidev0 user_overlays=spi0-mcp2515 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u debug via serial cable,during start-up no spi seems enabled.. U-Boot 2018.05-armbian (Jul 05 2019 - 23:30:10 +0200) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** Failed (-5) In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 230454 bytes read in 25 ms (8.8 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... Device NOT ready Request Sense returned 02 3A 00 6 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop i'm a bit puzzled how find out what i do wrong with the overlays, upon check: root@orangepione:# dmesg | grep spi||mcp [ 0.628802] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. [ 0.628817] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. [ 0.629394] spi spi0: master is unqueued, this is deprecated Seems i would have something wrong in armbianenv.txt / what do i have wrong in overlay.. some good direction pointer were really appreciated.. Link to comment Share on other sites More sharing options...
martinayotte Posted February 14, 2020 Share Posted February 14, 2020 14 hours ago, jwhouwers said: overlays=spi-spidev0 Such "spi-spidev0" overlay doesn't exist by default. Did you wrote your own ? The one that exist is : overlays=spi-spidev param_spidev_spi_bus=0 Also, your u-boot log is truncated, we don't see the part where overlays are loaded ... Link to comment Share on other sites More sharing options...
jwhouwers Posted February 14, 2020 Author Share Posted February 14, 2020 Martin, thanks for the reply, changed per your comments, as no i did not write one, but same result on dsmeg as above.. looks like spi0 were not enabled, used the mcp2515 board earlier with arduino without issue's added the u-boot file, and dtbo overlay file..i was checking the overlay info from Armbian user-guide it made me doubt on the folder locations, after installing base image copied attached dtbo file to folder /boot/overlay-user or do i need to do something after copying??? ArmbianEnv.txt verbosity=1 console=serial overlay_prefix=sun8i-h3 disp_mem_reserves=on extraargs=cma=96M rootdev=UUID=698619e7-7638-4282-b3c1-743acf73e189 rootfstype=ext4 overlays=spi-spidev param_spidev_spi_bus=0 user_overlays=spi0-mcp2515 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u i checked the u-boot log but can't see it seems to load the mcp2515 overlay.. but i'm not experienced enough on this.. root@orangepione:~# dmesg | grep spi||mcp [ 0.629326] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. [ 0.629340] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. [ 0.629914] spi spi0: master is unqueued, this is deprecated JW sun8i-h3-spi0-mcp2515.dtbo orange_PI_one_U_boot.txt Link to comment Share on other sites More sharing options...
martinayotte Posted February 15, 2020 Share Posted February 15, 2020 14 hours ago, jwhouwers said: looks like spi0 were not enabled I'm seeing in your boot log "Armbian Linux 3.4.113-sun8i", this is a Legacy image, and Legacy images doesn't support DT overlays at all ! You should try with Mainline "current" or "dev" images ... Link to comment Share on other sites More sharing options...
jwhouwers Posted February 19, 2020 Author Share Posted February 19, 2020 Martin, Thanks for good advise will look into it, unfortenately to travel for next 2 weeks, to be continued. JW Link to comment Share on other sites More sharing options...
