Dears,
We have 4 boards Nanopi Neo2, but when we connect to energy, they don't boot, leds of net port (green and yellow ones) and internal led (red) are on all time.
We tried to access via serial port (using an usb-serial adapter), but they not show any boot process. We tried some different boot images on sd card. Nothing works.
All four devices are in this situation (and they are new!). There is any thing we can do?
Thank you for your responses! I tried too with Armbian_19.11.6_Nanopineo2_buster_current_5.4.7.7z image, but that boards don't boot. I connect a serial/usb card for read boot process, but I don't se anything.
As I said, don't mix NEO and NEO2 images, they don't have the same CPU !
The picture you've provided shows that your board is a NEO not a NEO2, so, use the proper image ...
Thank you very much, that was the problem. Using neo image they work correctly.
  • abgenis changed the title to [RESOLVED] Nanopi Neo2 don't boot, all leds on
