Dennboy Posted February 17, 2020 Posted February 17, 2020 Armbianmonitor: http://ix.io/2bX2 Dear all, Starting from NAND memory used to work fine on the nanopi neo plus2, however with the new boards (both v1.2 and v2.0 revision) we just obtained it frequently doesn't want to reboot, while a cold boot works fine (I tried also earlier u-boot versions (2019.04, 2018.11) without much success for the reboot from NAND). The re-boot process stops at this point (from the serial console): [ OK ] Reached target Shutdown. [ 152.452083] reboot: Restarting system U-Boot SPL 2019.10-armbian (Jan 25 2020 - 19:56:27 +0100) DRAM: 1024 MiB Trying to boot from MMC2 I suspected the problem to be in the u-boot, since the friendlyarm on NAND reboots without a hitch. I found a work-around for the latest stretch image (Armbian_20.02.0-rc1_Nanopineoplus2_stretch_current_5.4.14.7z), by doing the following: boot friendlyarm image from NAND and copy the sunxi-spl.bin: sudo dd if=/dev/mmcblk2 of=sunxi-spl-friendlyarm.bin count=4 bs=8k skip=1 boot armbian from NAND and update u-boot: switched to linux-image-next-sunxi64=5.90 kernel via armbian-config / System / Other / switch dd if=sunxi-spl-friendlyarm.bin of=/dev/mmcblk2 count=4 bs=8k seek=1 conv=fsync The atached armbianmonitor -u upload is from after a fresh reboot with the working configuration. Kind regards, Dennis
Dennboy Posted February 18, 2020 Author Posted February 18, 2020 For your information, with this work-around, U-boot warns about a SPL version mismatch (DRAM: sunxi SPL version mismatch: expected 3, got 2), but works nontheless. I wonder what is different in the SPL version that makes the boot possible (maybe the CPU frequency or DRAM frequency?), and if we can transfer this functionality to the newer SPL without breaking the reboot. See the serial trace of a successful reboot below for the NanoPi neo plus hardware revision 2.0 (revision 1.2 with 512MB DRAM works as well): [ 311.266768] reboot: Restarting system U-Boot SPL 2017.11 (Nov 15 2019 - 05:14:40) DRAM: 1024 MiB(504MHz) CPU Freq: 408MHz memory test: 1 Pattern 55aa Writing...Reading...OK Trying to boot from MMC2 Boot device: emmc NOTICE: BL31: v2.1(debug):bb2d778-dirty NOTICE: BL31: Built : 18:34:11, Jul 5 2019 NOTICE: BL31: Detected Allwinner H5 SoC (1718) NOTICE: BL31: Found U-Boot DTB at 0x40899d8, model: FriendlyARM NanoPi NEO Plus 2 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller NOTICE: BL31: PMIC: Defaulting to PortL GPIO according to H5 reference design. INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.04-armbian (Jul 06 2019 - 18:02:12 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO Plus 2 DRAM: sunxi SPL version mismatch: expected 3, got 2 1 GiB MMC: mmc@1c0f000: 0, mmc@1c11000: 1 An occasional successful boot from NAND without the workaround looks like below. The main difference seems to be the cpu/memory frequency and the memory test. [ 401.171972] reboot: Restarting system U-Boot SPL 2019.04-armbian (Jul 06 2019 - 18:02:12 +0200) DRAM: 1024 MiB Trying to boot from MMC2 U-Boot SPL 2019.04-armbian (Jul 06 2019 - 18:02:12 +0200) DRAM: 1024 MiB Trying to boot from MMC2 NOTICE: BL31: v2.1(debug):bb2d778-dirty NOTICE: BL31: Built : 18:34:11, Jul 5 2019 NOTICE: BL31: Detected Allwinner H5 SoC (1718) NOTICE: BL31: Found U-Boot DTB at 0x40899d8, model: FriendlyARM NanoPi NEO Plus 2 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller NOTICE: BL31: PMIC: Defaulting to PortL GPIO according to H5 reference design. INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.04-armbian (Jul 06 2019 - 18:02:12 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO Plus 2 DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c11000: 1
Quanta Posted February 27, 2020 Posted February 27, 2020 Thanks for this post Denny. Armbianmonitor: http://ix.io/2cPw Can you or anyone actually, point me to a solution? I have a NEO 2 that will not reliably boot (now). Your solution looks like you boot SD card and then, using the booted system, fix the MMC boot process. I can't get board to boot with valid SD image. This board and image were working fine and I know of nothing I did that would break it. The same card/image works on a NEO 2+ just fine. Both are earlier HW revs I think but have been working reliably through many power cycles and shutdowns. I see that no DTB is found now on my non booting board when it won't boot according to the console but unclear how to fix in this case. I don't want to break the SD card - I spent a lot of time getting it set up and was trying to backup card and ran afoul of this problem. In my case I don't want to use mmc because I can't replace if I run into a wearout problem. I want to be able to drop in a new card with a reference backup image and have the board back operational. This may not be optimal but at my current level of proficiency and because of the application this seems the most sensible right now. So, to re-state more clearly the question, what should I do to get a (more) reliable boot from sd card at this point? I am concerned that while the board is running at the moment, It will choke on some future reboot - perhaps in the process of fixing uboot and I won't know what to do... This isn't something I feel I can 'experiment' with to fix. There are too many unknowns for me. Dumping a file onto the board or editing via winscp or webmin I can do now but once the board will not boot to SD I am in up a little over my nose... This board doesn't do much and doesn't need to do it particularly fast. Reliability is far more important in this case. U-Boot SPL 2019.04-armbian (Jul 16 2019 - 09:15:50 +0200) DRAM: 4096 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):3ce3ce0-dirty NOTICE: BL31: Built : 17:00:24, Jul 15 2019 NOTICE: BL31: Detected Allwinner H5 SoC (1718) NOTICE: BL31: No DTB found. INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller NOTICE: BL31: PMIC: Defaulting to PortL GPIO according to H5 reference design. INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 !!! This time the board booted as expected!!! Problem is I can't have it behaving like this at the remote site! U-Boot SPL 2019.04-armbian (Jul 16 2019 - 09:15:50 +0200) DRAM: 512 MiB Trying to boot from MMC1 NOTICE: BL31: v2.1(debug):3ce3ce0-dirty NOTICE: BL31: Built : 17:00:24, Jul 15 2019 NOTICE: BL31: Detected Allwinner H5 SoC (1718) NOTICE: BL31: Found U-Boot DTB at 0x408c3b0, model: FriendlyARM NanoPi NEO 2 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller NOTICE: BL31: PMIC: Defaulting to PortL GPIO according to H5 reference design. INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.04-armbian (Jul 16 2019 - 09:15:50 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: FriendlyARM NanoPi NEO 2 DRAM: 512 MiB MMC: mmc@1c0f000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial NanoPi NEO2 v1.0 detected Net: phy interface7 eth0: ethernet@1c30000 ** Reading file would overwrite reserved memory ** There is no valid bmp file at the given address starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 3 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 2 ms (1.5 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc Thanks to all. Q
Dennboy Posted February 27, 2020 Author Posted February 27, 2020 (edited) 50 minutes ago, Quanta said: So, to re-state more clearly the question, what should I do to get a (more) reliable boot from sd card at this point? I am concerned that while the board is running at the moment, It will choke on some future reboot - perhaps in the process of fixing uboot and I won't know what to do... This isn't something I feel I can 'experiment' with to fix. There are too many unknowns for me. Dumping a file onto the board or editing via winscp or webmin I can do now but once the board will not boot to SD I am in up a little over my nose... Hi Quanta, Thanks for you reaction. In my case the (re)boot from sdcard do not fail, I only had failing EMMC re-boots. I think the older first stage u-boot from FriendlyArm is running at slower speed so there is less chance of failures. Your u-boot on the sdcard may be fixable with a similar procedure, i.e. by capturing the first stage u-boot bytes from FriendlyArm NEO image and writing it to the sdcard instead of the MMC I guess it would be possible to do this on a linux PC without first booting from the sdcard. Before changing the sdcard, you can of course make a backup on your hard-drive: dd if=/dev/mmcblk0 of=recoveryimage.img bs=8k Quote In my case I don't want to use mmc because I can't replace if I run into a wearout problem. I want to be able to drop in a new card with a reference backup image and have the board back operational. This may not be optimal but at my current level of proficiency and because of the application this seems the most sensible right now. I think the flash wearing on regular sdcards would be similar to EMMC, most mobile phones run from EMMC nowadays and have sdcard as optional storage. Industrial-grade sdcards may be more reliable, but can still have degraded contacts and problems after vibrations. You can also start using sdcards once the EMMC starts failing, that's my plan with our remote Neo2+'s. Kind regards, Dennis Edited February 27, 2020 by Dennboy added notice about backing up the sdcard before starting
Onira Posted February 28, 2020 Posted February 28, 2020 Hello, That's my problem as well I was writing about it In my case the easiest way is just having empty SD card in slot and it reboots again but I will try Your solution, Dennboy I guess the friendyarm image you mention about is the image from FriendlyARM wiki? Regards
Dennboy Posted February 28, 2020 Author Posted February 28, 2020 7 minutes ago, Onira said: In my case the easiest way is just having empty SD card in slot and it reboots again but I will try Your solution, Dennboy I guess the friendyarm image you mention about is the image from FriendlyARM wiki? Yes, I use the image from FriendlyArm mentioned on their website (in my case, I booted the image that was on the MMC when it got shipped, which is most likely the same one). To capture their first stage bootloader with dd, I analysed the nand-sata-install script to see what needed to be copied. It may be possible to directly fetch the bootloader part from the sdcard image, with a similar dd with if=sdcard.img when you have a linux PC. Since u-boot is opensource, we can probably ask FriendlyArm for their software/configuration changes to the first-stage u-boot in order to get this integrated into the Armbian tree as a patch.
Onira Posted February 28, 2020 Posted February 28, 2020 Is there a way to do your workaround without re-flashing eMMC? Like writing FriendlyElec on any other SD and connect it after system boots from eMMC already having system?
Quanta Posted February 29, 2020 Posted February 29, 2020 Dennis I apologize for calling you Denny. It wasn't intentional. It was done in haste. I *always* check with the person for a preference before doing such a thing. I am not clear just how to do this. What file has bytes? What form (binary? Ascii? ) How to ID bytes I want etc. .....Deleted I worked for a while trying to express more questions and observations, verify what I think I have seen etc. I wonder if it is possible I have stumbled on the source of the problem - usb to serial console adapter. Is it possible that it is messing with power? I am using the FA adapter sold with the boards. I use the FA power dock to power the board from a compact form factor PC supply 12V buss. In order to see boot, I leave serial adapter connected to console, powered and connected to Putty. I usually issue shutdown, toggle power switch on dock for some seconds and then re-power. [I have observed in the past that after issuing shutdown the board does go through the routine but will get / stay warm -even hot long after if I don't shut of dock. Seems I read shutdown doesn't work like it ought to for early boards - possibly related? ] When board acts up I cannot do what I normally do in remote context (reboot now). I have a warning that comes up instead of shutdown when I issue that command without explicit path because normally I won't be there to power cycle. Also, in the remote context, I never have the console port connected. So the greatest potential for this possible problem to appear would be when the board is on the bench and I have removed sd card to image, and then re-install while using console port to monitor. ... A little more testing. I have some trouble with the usb cable to the serial adapter dropping out if I move it so this complicates the testing some but it looks like this is part of the problem at least. There are times when with serial adapter connected, and the power dock switched off, cpu power remains up. I see it on a protobard connected to the B side of the power dock (has a power LED). Removing usb extinguishes of course. Also when reconnecting USB, the led on adapter indicating either TD or RD (or both) activity {don't recall} will light dimly. Another observation today is that with no SD card I get nothing from console now. I think this is different from earlier. I made no changes to on board mmc. I am fairly sure the serial adapter is ok when this happens but I need to look at this a little deeper. Hopefully all this means that I have reliable boot so long as there is only one possible source for power. I have yet to test a backup image. Perhaps later today. Thanks to all and I hope I have added something useful. I will report back with more if I have something helpful. Should I start a new thread? Q
Dennboy Posted March 1, 2020 Author Posted March 1, 2020 Hi Quanta, Depending on the type of serial connector, it may (partly) power the nanopi, I usually only connect the GND, RX and TX with my FT232RL USB to TTL Serial Adapter. I've seen cases where parts of the board didn't fully reset when the serial was still connected. You can of course start a separate thread about serial adaptor power issues, which may be a more general issue. My reboot problems however also seem to occur without the serial connected, i.e. can can notice it doesn't become reachable again after reboot is invoked remotely. Kind regards, Dennis
