TDCroPower Posted February 18, 2020 Posted February 18, 2020 Armbianmonitor: http://ix.io/2c5R Hello everyone, I need some help from the community. I would like to install the Unifi Controller on my OrangePi Plus 2e, but it requires mongodb see here... [root@OrangePi:mongodb]$ apt-get install unifi Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: unifi : Depends: mongodb-server (>= 2.4.10) but it is not installable or mongodb-10gen (>= 2.4.14) but it is not installable or mongodb-org-server (>= 2.6.0) but it is not installable Depends: mongodb-server (< 1:3.6.0) but it is not installable or mongodb-10gen (< 3.6.0) but it is not installable or mongodb-org-server (< 3.6.0) but it is not installable E: Unable to correct problems, you have held broken packages. [root@OrangePi:mongodb]$ ...but mongodb is not present in the armbian repos... [root@OrangePi:~]$ apt-get install mongodb Reading package lists... Done Building dependency tree Reading state information... Done Package mongodb is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'mongodb' has no installation candidate [root@OrangePi:~]$ I was able to install mongodb with the help of THIS manual and THESE binaries and it also starts successfully... [root@OrangePi:mongodb]$ service mongodb start [root@OrangePi:mongodb]$ service mongodb status ● mongodb.service - High-performance, schema-free document-oriented database Loaded: loaded (/lib/systemd/system/mongodb.service; disabled; vendor preset: enabled) Active: active (running) since Tue 2020-02-18 18:03:06 CET; 6s ago Main PID: 7635 (mongod) Tasks: 9 (limit: 4915) Memory: 41.2M CPU: 551ms CGroup: /system.slice/mongodb.service └─7635 /usr/bin/mongod --quiet --config /etc/mongodb.conf Feb 18 18:03:06 OrangePi systemd[1]: Started High-performance, schema-free document-oriented database. Feb 18 18:03:06 OrangePi mongod[7635]: 2020-02-18T18:03:06.187+0100 I CONTROL Feb 18 18:03:06 OrangePi mongod[7635]: 2020-02-18T18:03:06.187+0100 W CONTROL 32-bit servers don't have journaling enabled by default. Please use --journa Feb 18 18:03:06 OrangePi mongod[7635]: 2020-02-18T18:03:06.187+0100 I CONTROL Does anyone know a solution how I can install unifi or explain to the installation that I have installed mongodb? Or is there another better solution to solve the problem?
lanefu Posted February 19, 2020 Posted February 19, 2020 57 minutes ago, TDCroPower said: Does anyone know a solution how I can install unifi or explain to the installation that I have installed mongodb? Or is there another better solution to solve the problem? the OS mongo packages are usually super outdated, not surprised they don't work. Consider this container. the linuxserver.io project builds multiarch containers for arm32, arm64, and x86.https://hub.docker.com/r/linuxserver/unifi-controller 1
TDCroPower Posted February 19, 2020 Author Posted February 19, 2020 thank you lanefu for your fast answer! I have never used docker before. Is there anything I need to be aware of? How do I get the docker container, because it is mounted on my OrangePi? Here are the dependecies from unifi... Package: unifi Version: 5.12.35-12979-1 Section: java Priority: optional Architecture: all Depends: binutils, coreutils, adduser, libcap2, curl, mongodb-server (>= 2.4.10) | mongodb-10gen (>= 2.4.14) | mongodb-org-server (>= 2.6.0), mongodb-server (<< 1:3.6.0) | mongodb-10gen (<< 3.6.0) | mongodb-org-server (<< 3.6.0), java8-runtime-headless, jsvc (>=1.0.8) Pre-Depends: debconf (>= 0.5) | debconf-2.0 Conflicts: unifi-controller Provides: unifi-controller Replaces: unifi-controller Installed-Size: 164519 Maintainer: UniFi developers <unifi-dev@ubnt.com> Description: Ubiquiti UniFi server Ubiquiti UniFi server is a centralized management system for UniFi suite of devices. After the UniFi server is installed, the UniFi controller can be accessed on any web browser. The UniFi controller allows the operator to instantly provision thousands of UniFi devices, map out network topology, quickly manage system traffic, and further provision individual UniFi devices. Homepage: http://www.ubnt.com/unifi i have just tried to install unifi without the mongodb dependecies (which is deactivated by most of the instructions anyway) but even this leads to problems... [root@OrangePi:mongodb]$ apt-get download unifi Get:1 https://dl.ubnt.com/unifi/debian stable/ubiquiti armhf unifi all 5.12.35-12979-1 [99.2 MB] Fetched 99.2 MB in 23s (4,309 kB/s) [root@OrangePi:mongodb]$ dpkg --ignore-depends=mongodb-server -i unifi_5.12.35-12979-1_all.deb Selecting previously unselected package unifi. (Reading database ... 85492 files and directories currently installed.) Preparing to unpack unifi_5.12.35-12979-1_all.deb ... Unpacking unifi (5.12.35-12979-1) ... Setting up unifi (5.12.35-12979-1) ... Created symlink /etc/systemd/system/multi-user.target.wants/unifi.service → /lib/systemd/system/unifi.service. Job for unifi.service failed because a timeout was exceeded. See "systemctl status unifi.service" and "journalctl -xe" for details. invoke-rc.d: initscript unifi, action "start" failed. ● unifi.service - unifi Memory: 123.4M CPU: 50.849s CGroup: /system.slice/unifi.service ├─27510 unifi -cwd /usr/lib/unifi -home /usr/lib/jvm/java-8-openjdk-armhf -cp /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pid…rt ├─27511 unifi -cwd /usr/lib/unifi -home /usr/lib/jvm/java-8-openjdk-armhf -cp /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pid…rt ├─27512 unifi -cwd /usr/lib/unifi -home /usr/lib/jvm/java-8-openjdk-armhf -cp /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pid…rt ├─27546 /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/java -Dfile.encoding=UTF-8 -Djava.awt.headless=true -Dapple.awt.UIElement=true -Xmx1024M -XX:+…rt └─27586 curl -s --connect-timeout 1 -o /dev/null -w %{http_code} http://localhost:8080/status Feb 19 01:40:12 OrangePi systemd[1]: unifi.service: Unit entered failed state. Feb 19 01:40:12 OrangePi systemd[1]: unifi.service: Failed with result 'timeout'. Processing triggers for systemd (232-25+deb9u12) ... [root@OrangePi:mongodb]$
lanefu Posted February 19, 2020 Posted February 19, 2020 apt install docker.io then read some of the documentation here https://docs.linuxserver.io/general/containers-101 1
TDCroPower Posted February 19, 2020 Author Posted February 19, 2020 thank you for the tip you gave me about the docker container. I have successfully run the controller through Docker and it works perfectly. The best thing about the Docker solution, I can quickly delete or renew the "installation". docks@OrangePi:/opt/docker$ docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES dc14b6ce9fa3 linuxserver/unifi-controller "/init" 20 minutes ago Up 3 minutes 0.0.0.0:6789->6789/tcp, 0.0.0.0:8080->8080/tcp, 0.0.0.0:8443->8443/tcp, 0.0.0.0:8843->8843/tcp, 0.0.0.0:3478->3478/udp, 0.0.0.0:10001->10001/udp, 0.0.0.0:8880->8880/tcp, 8081/tcp unifi docks@OrangePi:/opt/docker$ 1
Utkarsh Posted April 27, 2020 Posted April 27, 2020 I am getting this error with running the docker image, not sure why root@orangepipc:~# docker create \ > --name=unifi-controller \ > -e PUID=1000 \ > -e PGID=1000 \ > -e MEM_LIMIT=1024M `#optional` \ > -p 3478:3478/udp \ > -p 10001:10001/udp \ > -p 8080:8080 \ > -p 8081:8081 \ > -p 8443:8443 \ > -p 8843:8843 \ > -p 8880:8880 \ > -p 6789:6789 \ > -v path to data:/config \ > --restart unless-stopped \ > linuxserver/unifi-controller Unable to find image 'to:latest' locally Error response from daemon: pull access denied for to, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
Utkarsh Posted April 27, 2020 Posted April 27, 2020 On 2/19/2020 at 9:58 AM, TDCroPower said: thank you for the tip you gave me about the docker container. I have successfully run the controller through Docker and it works perfectly. The best thing about the Docker solution, I can quickly delete or renew the "installation". docks@OrangePi:/opt/docker$ docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES dc14b6ce9fa3 linuxserver/unifi-controller "/init" 20 minutes ago Up 3 minutes 0.0.0.0:6789->6789/tcp, 0.0.0.0:8080->8080/tcp, 0.0.0.0:8443->8443/tcp, 0.0.0.0:8843->8843/tcp, 0.0.0.0:3478->3478/udp, 0.0.0.0:10001->10001/udp, 0.0.0.0:8880->8880/tcp, 8081/tcp unifi docks@OrangePi:/opt/docker$ That's great news! Can you please assist me as well by letting me know the exact steps you took?
u2mike99 Posted March 30, 2021 Posted March 30, 2021 would be great if you write down your steps getting your container running i got the same issue creating the container
Manwell Posted November 19, 2021 Posted November 19, 2021 On 2/19/2020 at 9:58 AM, TDCroPower said: thank you for the tip you gave me about the docker container. I have successfully run the controller through Docker and it works perfectly. The best thing about the Docker solution, I can quickly delete or renew the "installation". docks@OrangePi:/opt/docker$ docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES dc14b6ce9fa3 linuxserver/unifi-controller "/init" 20 minutes ago Up 3 minutes 0.0.0.0:6789->6789/tcp, 0.0.0.0:8080->8080/tcp, 0.0.0.0:8443->8443/tcp, 0.0.0.0:8843->8843/tcp, 0.0.0.0:3478->3478/udp, 0.0.0.0:10001->10001/udp, 0.0.0.0:8880->8880/tcp, 8081/tcp unifi docks@OrangePi:/opt/docker$ Please some help how did you run the controller through Docker? I'm a begginer with linux
