Arjan van Vught Posted February 21, 2020 Share Posted February 21, 2020 Dear forum, When looking at the Orange Pi Zero schematic V1.1, the OSC-RTC box is empty. Does this mean that there is no crystal for the internal RTC? The internal RTC cannot be used at all? When just checking the time register, the RTC is running too fast. Thanks, Arjan 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted February 21, 2020 Share Posted February 21, 2020 38 minutes ago, Arjan van Vught said: The internal RTC cannot be used at all? RTC is by default set to run with internal OSC, so no need for external one. 39 minutes ago, Arjan van Vught said: When just checking the time register, the RTC is running too fast. How did you check that ? "hwclock" seem to provide the right time ... 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted February 21, 2020 Author Share Posted February 21, 2020 4 minutes ago, martinayotte said: RTC is by default set to run with internal OSC, so no need for external one. The internal clock (which is about 16MHz) does not give an accurate reference. So I did not try to use that option. I will check your source code for the configuration. 6 minutes ago, martinayotte said: How did you check that ? Just reading the register directly and printing the value when the seconds have changed. 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted February 21, 2020 Author Share Posted February 21, 2020 12 minutes ago, martinayotte said: RTC is by default set to run with internal OSC, so no need for external one. This https://github.com/armbian/linux/blob/sun8i/drivers/rtc/rtc-sunxi.c#L499 is referencing to an external OSC. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted February 21, 2020 Share Posted February 21, 2020 14 minutes ago, Arjan van Vught said: This https://github.com/armbian/linux/blob/sun8i/drivers/rtc/rtc-sunxi.c#L499 is referencing to an external OSC. Right ! But since the RTC has no external source, it stays with internal one. Check the registers description of Allwinner H3 user manual and check values with "devmem2" "devmem2 0x01f00000" report 0x0001, which is effectively mean LOSC_SRC_SEL bit is set to External, but "devmem2 0x01f00004" (the LOSC_AUTO_SWT_STA_REG) report 0x4, where LOSC_SRC_SEL_STA status bit is 0 meaning InternalOSC. To my understanding, the LOSC_AUTO_SWT_STA_REG autoswitch probably detect that there is no clock present and doesn't switch the clock ... Did you verify with "hwclock" on your board if it is accurate ? 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted February 21, 2020 Author Share Posted February 21, 2020 8 minutes ago, martinayotte said: but "devmem2 0x01f00004" (the LOSC_AUTO_SWT_STA_REG) report 0x4, where LOSC_SRC_SEL_STA status bit is 0 meaning InternalOSC. So the check here https://github.com/armbian/linux/blob/sun8i/drivers/rtc/rtc-sunxi.c#L512 is basically wrong. The CTRL tells what has been set, and then AUTO_STA really tells the status. And the RTC goes into default internal with prescaler 0xF -> 16 MHz / 32 / 15 that is about 33KHz. Which is slightly faster than the desired 32768 Hz. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted February 21, 2020 Share Posted February 21, 2020 18 minutes ago, Arjan van Vught said: So the check here https://github.com/armbian/linux/blob/sun8i/drivers/rtc/rtc-sunxi.c#L512 is basically wrong. The CTRL tells what has been set, and then AUTO_STA really tells the status. You're right ! I don't see those warning in my dmesg ... something fishy there ... But, at least, it still seems to work in my case. EDIT: Oh ! But rtc-sunxi.c doesn't even look at LOSC_AUTO_SWT_STA_REG, it is only validate that write to SUNXI_LOSC_CTRL_REG was successful ... hmmm ! 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted February 21, 2020 Author Share Posted February 21, 2020 Simple test pi@orangepizero:~$ cat ./rtc_test.sh while true do ./dev2mem 0x01f00014 | tail -n 1 echo `date +"%S"` sleep 1 done pi@orangepizero:~$ sudo ./rtc_test.sh Value at address 0x1F00014 (0xb6ff7014): 0xF162D 22 Value at address 0x1F00014 (0xb6f63014): 0xF162E 23 Value at address 0x1F00014 (0xb6f09014): 0xF162F 24 Value at address 0x1F00014 (0xb6f4a014): 0xF1630 25 Value at address 0x1F00014 (0xb6f9f014): 0xF1632 26 Value at address 0x1F00014 (0xb6f0a014): 0xF1633 27 Value at address 0x1F00014 (0xb6ffb014): 0xF1634 28 Value at address 0x1F00014 (0xb6f8b014): 0xF1635 29 ^C Skipping a second here. Quote pi@orangepizero:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepizero BOARD_NAME="Orange Pi Zero" BOARDFAMILY=sun8i BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin BUILD_REPOSITORY_COMMIT=3e533c9 DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.02.1 LINUXFAMILY=sunxi BRANCH=current ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted February 21, 2020 Share Posted February 21, 2020 10 minutes ago, Arjan van Vught said: Skipping a second here. That is not really a good way to test, since your loop is a bit more than 1 second due to execution of previous lines. Do a sleep of 120 seconds or even bigger, such 1 hour, and calculate the number of seconds elapse between the two devmem2. 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted February 21, 2020 Author Share Posted February 21, 2020 4 minutes ago, martinayotte said: hat is not really a good way to test, since your loop is a bit more than 1 second due to execution of previous lines. Therefore I am also showing the seconds from the date command. I will do another test. However, the apt update/upgrade I just did, it broke the startup. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted February 21, 2020 Share Posted February 21, 2020 2 hours ago, Arjan van Vught said: So the check here https://github.com/armbian/linux/blob/sun8i/drivers/rtc/rtc-sunxi.c#L512 is basically wrong. In fact, this URL is completely obsolete, it is a snapshot of code from 4 years ago ... The current Mainline is here : https://github.com/torvalds/linux/blob/master/drivers/rtc/rtc-sun6i.c But they still don't check the LOSC_AUTO_SWT_STA_REG register ... EDIT: I've done few tests with measurement at 8 minutes intervals, it is loosing/gaining around 8 seconds / 8 minutes, but since it is both loosing/gaining, overall the average should be good. 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted February 21, 2020 Author Share Posted February 21, 2020 See the remarkable output below. Many observations and some questions: The internal RTC seems to be useless with the internal OSC. The internal RTC gets updated; once every ? seconds. From which source? What is the source for the date command? Specific which ARM Counter or with SoC Timer? This test is with an Internet connection; hence the system clock gets updated with the NTP Client. Interesting to know what happens with no Internet connection. Quote pi@orangepizero:~$ sudo ./rtc_test.sh 17:00:39 17:00:21 ============== 17:02:47 17:02:21 ============== 17:04:55 17:04:21 ============== 17:07:04 17:06:21 ============== 17:08:25 17:08:21 ============== 17:10:34 17:10:21 ============== 17:12:42 17:12:21 ============== 17:14:51 17:14:21 ============== pi@orangepizero:~$ cat ./rtc_test.sh while true do ./devmem2 0x01f00014 | tail -n 1 |rev|cut -f1 -d' '|rev | ./convert echo `date +"%H:%M:%S"` echo ============== sleep 120 done /* * convert.c */ #include <stdio.h> #include <stdlib.h> #define TIME_GET_SEC_VALUE(x) ((x) & 0x0000003f) #define TIME_GET_MIN_VALUE(x) (((x) & 0x00003f00) >> 8 ) #define TIME_GET_HOUR_VALUE(x) (((x) & 0x001f0000) >> 16) int main(void) { unsigned num; fscanf(stdin, "%x", &num); printf("%.2d:%.2d:%.2d\n", TIME_GET_HOUR_VALUE(num), TIME_GET_MIN_VALUE(num), TIME_GET_SEC_VALUE(num)); return EXIT_SUCCESS; } 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted February 21, 2020 Share Posted February 21, 2020 43 minutes ago, Arjan van Vught said: See the remarkable output below That strange, you drifts is really bigger than mines, mines are 1 or 2 or 3 seconds per 2 minutes ... I've added "hwclock -w" before the loop and get the following results (not that I forgot to add UTC to "date") : 17:30:39 12:30:39 --------------- 17:32:41 12:32:39 --------------- 17:34:40 12:34:39 --------------- 17:36:43 12:36:39 --------------- 17:38:46 12:38:39 --------------- 17:40:48 12:40:39 --------------- 17:42:51 12:42:39 --------------- 17:44:54 12:44:39 --------------- 17:46:42 <---- drift correction 12:46:39 --------------- 17:48:44 12:48:39 --------------- 17:50:47 12:50:39 --------------- 17:52:50 12:52:39 --------------- 17:54:53 12:54:39 --------------- 17:56:55 12:56:39 --------------- 17:58:43 <---- drift correction 12:58:39 --------------- Yes, it seems that a background process is doing "hwclock -w" in background, maybe every 12 minutes, as you said, most probably the ntp or chrony service ... BTW, I've the same test on my OPi3 which actually has an external crystal, no drifts at all ... 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted February 21, 2020 Share Posted February 21, 2020 1 hour ago, Arjan van Vught said: Many observations Some new ones : I've done tests on my OPiPC2, OPiZeroPlus2, OPi+2E, OPiOne and OPiLite which also don't have a external 32768 crystal, drifts are seen only on H3 but not on H5 ... Also, the H3 RTC drift is late/slow compared to H2+ of the OPiZero previously tested which were ahead/fast. 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted February 21, 2020 Author Share Posted February 21, 2020 15 minutes ago, martinayotte said: .. drifts are seen only on H3 but not on H5 ... Also, the H3 RTC drift is late/slow compared to H2+ of the OPiZero previously tested which were ahead/fast. That's a shame as I am using the Orange Pi Zero LTS 256MB and the Orange Pi One boards only. I will try to contact Steven and ask if it is doable getting the external 32768 crystal on the(se) H2+/H3 boards. 0 Quote Link to comment Share on other sites More sharing options...
gounthar Posted December 18, 2020 Share Posted December 18, 2020 What would we need besides a crystal to get a RTC hat to work with the Orange Pi Zero? Thanks. 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted December 18, 2020 Author Share Posted December 18, 2020 24 minutes ago, gounthar said: What would we need besides a crystal to get a RTC hat to work with the Orange Pi Zero? Thanks. When there is a crystal placed on the OPi board itself, then there is no need for a hat. Of course, we also need a proper battery connector -> removing the WiFi chip for making some space. 0 Quote Link to comment Share on other sites More sharing options...
gounthar Posted December 18, 2020 Share Posted December 18, 2020 But if I was to design a very simple hat, what would be needed ? Thanks. 0 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted December 18, 2020 Author Share Posted December 18, 2020 1 hour ago, gounthar said: But if I was to design a very simple hat, what would be needed ? Thanks. This topic is about the missing RTC crystal on the OPi board. And therefore we cannot use the RTC in the SoC. When you would like to build an expansion board then for examples; check the dataset for: DS3231 or Google for: rtc i2c board 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted December 18, 2020 Share Posted December 18, 2020 The PCF8523 chip is a good one since it can trigger an alarm interrupt ... 1 Quote Link to comment Share on other sites More sharing options...
Arjan van Vught Posted December 18, 2020 Author Share Posted December 18, 2020 55 minutes ago, martinayotte said: The PCF8523 chip is a good one since it can trigger an alarm interrupt ... https://www.adafruit.com/product/3295 -> The PCF8523 is simple and inexpensive but not a high precision device. It may lose or gain up to 2 seconds a day. 1 Quote Link to comment Share on other sites More sharing options...
