So my sshd service won't start after a system upgrade. I have no uart access, so currently no console access. I do have access to the root drive on a usb device.
I suspect systemd is having a problem starting sshd from the ssh.service unit file. But I'm not sure how to fix it. Any suggestions would be much appreciated.
Here are the contents of my ssh.service file. I checked that /etc/ssh/sshd_not_to_be_run doesn't exist. I'm a little confused about the runtime directory, so I made a folder in the root directory called sshd with 0755 permissions, but that doesn't seem right.
Strangely I couldn't find anything in the syslog file that mentioned ssh.
[Unit]
Description=OpenBSD Secure Shell server
After=network.target auditd.service
ConditionPathExists=!/etc/ssh/sshd_not_to_be_run
[Service]
EnvironmentFile=-/etc/default/ssh
ExecStartPre=/usr/sbin/sshd -t
ExecStart=/usr/sbin/sshd -D $SSHD_OPTS
ExecReload=/usr/sbin/sshd -t
ExecReload=/bin/kill -HUP $MAINPID
KillMode=process
Restart=on-failure
RestartPreventExitStatus=255
Type=notify
RuntimeDirectory=sshd
RuntimeDirectoryMode=0755
[Install]
WantedBy=multi-user.target
Alias=sshd.service
Also, here are the contents of /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=odroidxu4
BOARD_NAME="Odroid XU4"
BOARDFAMILY=odroidxu4
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=8250438c
VERSION=5.97
LINUXFAMILY=odroidxu4
BRANCH=next
ARCH=arm
IMAGE_TYPE=user-built
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=zImage
10 hours ago, Igor said:
Next kernel v5.97 is not very stable.
I didn't realise I was on an unstable kernel. That makes sense now though. I'll keep poking around and see what I find.
Thanks for the comment.
I'm pretty sure I found the problem. It's a bad file-system.
I think the cause of the bad filesystem was usb 2.0 hub with a long cable. I had the root drive (thumb drive) plugged in at the end of this long cable.
I noticed in the documentation it mentions most problems are caused by either a bad file system or a bad power supply.
