On 3/15/2021 at 6:41 PM, rreignier said:
Hi @rdeyes
On an Orange Pi One (which might be close to your Orange Pi PC), I have managed to get the OV5640 thanks to the amazing work of the contributors of this thread.
Last time I have tried was on Armbian 20.08.17 with Linux 5.8.16.
The device tree overlay I use is this one (you may have to change some pins) :
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun8i-h3";
&ccu {
        assigned-clocks = <&ccu 107>;
        assigned-clock-parents = <&osc24M>;
        assigned-clock-rates = <24000000>;
&pio {
        csi_mclk_pin: csi-mclk-pin {
                pins = "PE1";
                function = "csi";
&i2c2_pins {
        bias-pull-up;
&i2c2 {
        status = "okay";
        ov5640: camera@3c {
                compatible = "ovti,ov5640";
                reg = <0x3c>;
                pinctrl-names = "default";
                pinctrl-0 = <&csi_mclk_pin>;
                clock-names = "xclk";
                AVDD-supply = <&reg_vcc_af_csi>;
                DOVDD-supply = <&reg_vdd_1v5_csi>;
                DVDD-supply = <&reg_vcc_csi>;
                reset-gpios = <&pio 4 14 1>; /* CSI-RST-R: PE14 */
                powerdown-gpios = <&pio 4 15 0>; /* CSI-STBY-R: PE15 */
                port {
                        ov5640_ep: endpoint {
                                remote-endpoint = <&csi_ep>;
                                bus-width = <8>;
                                data-shift = <2>; /* lines 9:2 are used */
                                hsync-active = <1>; /* Active high */
                                vsync-active = <0>; /* Active low */
                                data-active = <1>;  /* Active high */
                                pclk-sample = <1>;  /* Rising */
&csi {
        status = "okay";
        port {
                #address-cells = <1>;
                #size-cells = <0>;
                csi_ep: endpoint {
                        remote-endpoint = <&ov5640_ep>;
                        bus-width = <8>;
To enable it, I use this command:
sudo armbian-add-overlay csi-ov5640.dts
And then, to take a picture:
media-ctl --device /dev/media1 --set-v4l2 '"ov5640 1-003c":0[fmt:JPEG_1X8/1920x1080]'
fswebcam -d /dev/video0 -r 1920x1080 -D 0 --jpeg 100 /tmp/test.jpg
I hope this can help you and others.
Today, i have tried your dts on Orange Pi PC Plus with the camera ov5640.
But after reboot there are only the video0 and it is not ov5640, the output of command
v4l2-ctl -d /dev/video0 --all
show
Quote
Driver Info:
        Driver name      : cedrus
        Card type        : cedrus
        Bus info         : platform:cedrus
        Driver version   : 5.4.45
        Capabilities     : 0x84208000
                Video Memory-to-Memory
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x04208000
                Streaming
                Extended Pix Format
any wrong?
First off, thanks to everyone who has figured this all out. Much of this is over my head :)
I think I've nearly got my camera working with Armbian 22.08.6 Jammy on Linux 5.15.69-sunxi which is running on an Orange Pi PC.
I've gotten  /dev/media1 and /dev/video1 nodes after using the following device tree overlay. It is just a combination of @rreignier's overlay with @gsumner's regulator nodes but I haven't seen anyone post a combined overlay yet so I hope this makes it clear for anyone trying to get this to work on the same platform.
/dts-v1/;
/plugin/;
&ccu {
&pio {
                pins = "PE1";
                function = "csi";
&i2c2_pins {
        bias-pull-up;
&i2c2 {
        status = "okay";
        ov5640: camera@3c {
                reg = <0x3c>;
                port {
                                bus-width = <8>;
&csi {
        status = "okay";
        port {
                #size-cells = <0>;
                csi_ep: endpoint {
                        bus-width = <8>;
        reg_vdd_1v5_csi: vdd-1v5-csi {
                compatible = "regulator-fixed";
                regulator-name = "vdd1v5-csi";
                regulator-min-microvolt = <1500000>;
                regulator-max-microvolt = <1500000>;
                gpio = <&pio 6 13 0>; /* PG13 */
                enable-active-high;
                regulator-boot-on;
                regulator-always-on;
        reg_vcc_csi: vcc-csi {
                regulator-name = "vcc-csi";
                regulator-min-microvolt = <2800000>;
                regulator-max-microvolt = <2800000>;
                gpio = <&pio 6 11 0>; /* PG11 */
                enable-active-high;
                regulator-boot-on;
        reg_vcc_af_csi: vcc-af-csi {
                regulator-name = "vcc-af-csi";
                gpio = <&pio 0 17 0>; /* PA17 */
                enable-active-high;
                regulator-boot-on;
After applying the overlay and rebooting, I can use lsmod to see the camera driver:
lsmod | grep "ov5640"
ov5640                 28672  1
v4l2_fwnode            24576  2 ov5640,sun6i_csi
v4l2_async             20480  3 ov5640,v4l2_fwnode,sun6i_csi
And I can use the media-ctl command to check the topology:
media-ctl --device /dev/media1 --print-topology
Media controller API version 5.15.69
Media device information
driver          sun6i-csi
model           Allwinner Video Capture Device
serial
bus info        platform:1cb0000.camera
hw revision     0x0
driver version  5.15.69
Device topology
- entity 1: sun6i-csi (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video1
        pad0: Sink
                <- "ov5640 0-003c":0 [ENABLED]
- entity 5: ov5640 0-003c (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev0
        pad0: Source
                [fmt:UYVY8_2X8/640x480@1/30 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:full-range]
                -> "sun6i-csi":0 [ENABLED]
However, when I try to use the command to set 1920x1080, it fails:
media-ctl --device /dev/media1 --set-v4l2 '"ov5640 1-003c":0[fmt:UYVY8/1920x1080]'
Unable to setup formats: Invalid argument (22)
I've been staring at the help output for media-ctl but I'm in over my head with this one.
I also tried poking around with v4l2-ctl but nothing there seems to be working. Here is the result of a v4l2-ctl --info command:
Driver Info:
        Card type        : cedrus
        Driver version   : 5.15.74
                Streaming
                Extended Pix Format
                Device Capabilities
                Streaming
                Extended Pix Format
Media Driver Info:
        Model            : cedrus
        Serial           :
        Media version    : 5.15.74
        Hardware revision: 0x00000000 (0)
Interface Info:
        Type             : V4L Video
Entity Info:
        Function         : V4L2 I/O
        Pad 0x01000002   : 0: Source
          Link 0x02000008: to remote pad 0x1000004 of entity 'cedrus-proc' (Video Decoder): Data, Enabled, Immutable
What am I still missing?
Did you ever solve this?
Maybe try this:
media-ctl --device /dev/media1 --set-v4l2 '"ov5640 1-003c":0[fmt:UYVY8_2X8/1920x1080]'
note the _2X8
(I found this while searching for latest DT overlay)
T.
Posted (edited)
trying to get the ov5640 camera working on an OrangePiOne.
armbianmonitor logs https://paste.armbian.com/gucenokapa
Using this overlay :
I get some things working and mostly not at all. What works: the kernel modules load
bruno@orangepione2:~$ lsmod | grep ov
ov5640                 36864  1
videodev              167936  7 ov5640,sunxi_cedrus,videobuf2_common,sun6i_csi,v4l2_mem2mem,videobuf2_v4l2,v4l2_async
mc                     40960  8 ov5640,sunxi_cedrus,videobuf2_common,videodev,sun6i_csi,v4l2_mem2mem,videobuf2_v4l2,v4l2_async
and the device appears on /dev/video1
I assume this means the camera is accessed through the i2c and detected. I see it on the i2c bus:
bruno@orangepione2:~/ustreamer$ cat /sys/class/i2c-dev/i2c-1/device/1-003c/of_node/name
camera
bruno@orangepione2:~/ustreamer$ ls -l /sys/class/i2c-adapter/
total 0
lrwxrwxrwx 1 root root 0 Jan  1  1970 i2c-0 -> ../../devices/platform/soc/1ee0000.hdmi/i2c-0
lrwxrwxrwx 1 root root 0 Jan  1  1970 i2c-1 -> ../../devices/platform/soc/1c2b400.i2c/i2c-1
bruno@orangepione2:~/ustreamer$ sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- UU -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
media-ctl sees it
bruno@orangepione2:~$ media-ctl -d 1 --print-topology
Media controller API version 6.1.63
driver          sun6i-csi
model           Allwinner A31 CSI Device
serial
hw revision     0x0
driver version  6.1.63
Device topology
        pad0: Sink
                <- "ov5640 1-003c":0 [ENABLED]
- entity 5: ov5640 1-003c (1 pad, 1 link)
        pad0: Source
                [fmt:JPEG_1X8/640x480@1/30 colorspace:jpeg xfer:srgb ycbcr:601 quantization:full-range
                 crop.bounds:(0,0)/2624x1964
                 crop:(0,4)/2624x1944]
I read https://linux-sunxi.org/CSI so I know the format and size must be selected before grabbing frames
this for example works correctly
media-ctl --device /dev/media1 --set-v4l2 '"ov5640 1-003c":0[fmt:UYVY8_2X8/640x480@1/30]'
 (no error after executing that command. and I can then verify it has been selected by running media-ctl and see the pad0 Source has the format changed. Tried many other formats and sizes, they are taken correctly.
What does not work: everything else. I can not grab frames with anything. For both ustreamer and ffmpeg I tried many sizes and format, always fails the same way.
ffmpeg:
bruno@orangepione2:~/ustreamer$ ffmpeg  -input_format mjpeg -s 640x480 -i /dev/video1 output.mjpg
fmpeg version 5.1.4-0+deb12u1 Copyright (c) 2000-2023 the FFmpeg developers
  built with gcc 12 (Debian 12.2.0-14)
  configuration: --prefix=/usr --extra-version=0+deb12u1 --toolchain=hardened --libdir=/usr/lib/arm-linux-gnueabihf --incdir=/usr/include/arm-linux-gnueabihf --arch=arm --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared
  libavutil      57. 28.100 / 57. 28.100
  libavcodec     59. 37.100 / 59. 37.100
  libavformat    59. 27.100 / 59. 27.100
  libavdevice    59.  7.100 / 59.  7.100
  libavfilter     8. 44.100 /  8. 44.100
  libswscale      6.  7.100 /  6.  7.100
  libswresample   4.  7.100 /  4.  7.100
  libpostproc    56.  6.100 / 56.  6.100
[video4linux2,v4l2 @ 0xa36470] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0xa36470] Time per frame unknown
[video4linux2,v4l2 @ 0xa36470] ioctl(VIDIOC_STREAMON): Broken pipe
/dev/video1: Broken pipe
ustreamer
bruno@orangepione2:~/ustreamer$ ustreamer -d /dev/video1 -r 640x480 -m JPEG
-- INFO  [14503.025      main] -- Using internal blank placeholder
-- INFO  [14503.027      main] -- Listening HTTP on [127.0.0.1]:8080
-- INFO  [14503.027    stream] -- Using V4L2 device: /dev/video1
-- INFO  [14503.028    stream] -- Using desired FPS: 0
-- INFO  [14503.028      http] -- Starting HTTP eventloop ...
-- INFO  [14503.030    stream] -- Device fd=8 opened
-- INFO  [14503.030    stream] -- Using input channel: 0
-- INFO  [14503.030    stream] -- Using resolution: 640x480
-- INFO  [14503.030    stream] -- Using pixelformat: JPEG
-- INFO  [14503.030    stream] -- Querying HW FPS changing is not supported
-- ERROR [14503.030    stream] -- Device does not support setting of HW encoding quality parameters
-- INFO  [14503.030    stream] -- Using IO method: MMAP
-- INFO  [14503.035    stream] -- Requested 5 device buffers, got 5
-- ERROR [14503.036    stream] -- Unable to start capturing: Broken pipe
-- INFO  [14503.038    stream] -- Device fd=8 closed
-- INFO  [14503.038    stream] -- Sleeping 1 seconds before new stream init ...
I built ustreamer from source with debug symbols and stepped with gdb, it fails on
device.c:328  if (_D_XIOCTL((enable ? VIDIOC_STREAMON : VIDIOC_STREAMOFF), &type) < 0) {
which is, afaik, when the video device is opened for grabbing frames.
Something else that is very strange, trying to list camera controls returns empty
bruno@orangepione2:~$ v4l2-ctl -d 1 --list-ctrls
however using yavta on the video subdevice retrieves controls
bruno@orangepione2:~$ yavta --no-query -l /dev/v4l-subdev0
Device /dev/v4l-subdev0 opened.
--- User Controls (class 0x00980001) ---
control 0x00980901 `Contrast' min 0 max 255 step 1 default 0 current 0
control 0x00980902 `Saturation' min 0 max 255 step 1 default 64 current 64
control 0x00980903 `Hue' min 0 max 359 step 1 default 0 current 0
control 0x0098090c `White Balance, Automatic' min 0 max 1 step 1 default 1 current 1
control 0x0098090e `Red Balance' min 0 max 4095 step 1 default 0 current 0
control 0x0098090f `Blue Balance' min 0 max 4095 step 1 default 0 current 0
control 0x00980911 `Exposure' min 0 max 65535 step 1 default 0 current 0
control 0x00980912 `Gain, Automatic' min 0 max 1 step 1 default 1 current 1
control 0x00980914 `Horizontal Flip' min 0 max 1 step 1 default 0 current 0
control 0x00980915 `Vertical Flip' min 0 max 1 step 1 default 0 current 0
control 0x00980918 `Power Line Frequency' min 0 max 3 step 1 default 1 current 1
  0: Disabled
  1: 50 Hz (*)
  2: 60 Hz
  3: Auto
--- Camera Controls (class 0x009a0001) ---
control 0x009a0901 `Auto Exposure' min 0 max 1 step 1 default 0 current 0
  0: Auto Mode (*)
  1: Manual Mode
control 0x009a090c `Focus, Automatic Continuous' min 0 max 1 step 1 default 0 current 0
control 0x009a091c `Auto Focus, Start' min 0 max 0 step 0 default 0
control 0x009a091d `Auto Focus, Stop' min 0 max 0 step 0 default 0
control 0x009a091e `Auto Focus, Status' min 0 max 7 step 0 default 0 current 0x00000000
--- Image Source Controls (class 0x009e0001) ---
control 0x009e0901 `Vertical Blanking' min 24 max 2895 step 1 default 600 current 600
control 0x009e0902 `Horizontal Blanking' min 1256 max 1256 step 1 default 1256 current 1256
control 0x009e0903 `Analogue Gain' min 0 max 1023 step 1 default 0 current 0
--- Image Processing Controls (class 0x009f0001) ---
control 0x009f0901 `Link Frequency' min 0 max 22 step 1 default 13 current 13
  0: 992000000
  1: 888000000
  2: 768000000
  3: 744000000
  4: 672000000
  5: 672000000
  6: 592000000
  7: 592000000
  8: 576000000
  9: 576000000
  10: 496000000
  11: 496000000
  12: 384000000
  13: 384000000 (*)
  14: 384000000
  15: 336000000
  16: 296000000
  17: 288000000
  18: 248000000
  19: 192000000
  20: 192000000
  21: 192000000
  22: 96000000
control 0x009f0902 `Pixel Rate' min 48000000 max 168000000 step 1 default 48000000 current 48000000
control 0x009f0903 `Test Pattern' min 0 max 4 step 1 default 0 current 0
  0: Disabled (*)
  1: Color bars
  2: Color bars w/ rolling bar
  3: Color squares
  4: Color squares w/ rolling bar
22 controls found.
something else that is bothersome: the adapter board for the ov5640 has one component that reaches 90 degrees (c) constantly... not sure it should be that hot all the time !
this is starting to irritate me as it seems everything is configured correctly... grr.
Any suggestions ?
Edited by bschwand
add more information
